[ Upstream commit d74c67dd7800fc7aae381f272875c337f268806c ]
The crtc_h/vdisplay fields may not match the CRTC viewport dimensions
with special modes such as interlaced ones.
Fixes the HW cursor disappearing in the bottom half of the screen with
interlaced modes.
Fixes: 6b16cf7785a4 ("drm/radeon: Hide the HW cursor while it's out of bounds")
Cc: stable@vger.kernel.org
Reported-by: Ashutosh Kumar <ashutosh.kumar@amd.com>
Tested-by: Sonny Jiang <sonny.jiang@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit bb08c04dc867b5f392caec635c097d5d5fcd8c9f ]
100% reproducible issue found on SKL SkullCanyon NUC with two external
DP daisy-chained monitors in DP/MST mode. When turning off or changing
the input of the second monitor the machine stops with a kernel
oops. This issue happened with 4.8.8 as well as drm/drm-intel-nightly.
This issue is traced to an inconsistent control flow in
drm_dp_update_payload_part1(): the 'port' pointer is set to NULL at the
same time as 'req_payload.num_slots' is set to zero, but the pointer is
dereferenced even when req_payload.num_slot is zero.
The problematic dereference was introduced in commit dfda0df34
("drm/mst: rework payload table allocation to conform better") and may
impact all versions since v3.18
The fix suggested by Chris Wilson removes the kernel oops and was found to
work well after 10mn of monkey-testing with the second monitor power and
input buttons
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=98990
Fixes: dfda0df34264 ("drm/mst: rework payload table allocation to conform better.")
Cc: Dave Airlie <airlied@redhat.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Nathan D Ciobanu <nathan.d.ciobanu@linux.intel.com>
Cc: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Cc: Sean Paul <seanpaul@chromium.org>
Cc: <stable@vger.kernel.org> # v3.18+
Tested-by: Nathan D Ciobanu <nathan.d.ciobanu@linux.intel.com>
Reviewed-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1487076561-2169-1-git-send-email-jani.nikula@intel.com
[ Upstream commit 5351fbb1bf1413f6024892093528280769ca852f ]
page_flip_completed() dereferences 'work' variable after executing
queue_work(). This is not safe as the 'work' item might be already freed
by queued work:
BUG: KASAN: use-after-free in page_flip_completed+0x3ff/0x490 at addr ffff8803dc010f90
Call Trace:
__asan_report_load8_noabort+0x59/0x80
intel_finish_page_flip_mmio+0xe3/0x130
intel_pipe_handle_vblank+0x2d/0x40
gen8_irq_handler+0x4a7/0xed0
__handle_irq_event_percpu+0xf6/0x860
handle_irq_event_percpu+0x6b/0x160
handle_irq_event+0xc7/0x1b0
handle_edge_irq+0x1f4/0xa50
handle_irq+0x41/0x70
do_IRQ+0x9a/0x200
common_interrupt+0x89/0x89
Freed:
kfree+0x113/0x4d0
intel_unpin_work_fn+0x29a/0x3b0
process_one_work+0x79e/0x1b70
worker_thread+0x611/0x1460
kthread+0x241/0x3a0
ret_from_fork+0x27/0x40
Move queue_work() after trace_i915_flip_complete() to fix this.
Fixes: e5510fac98a7 ("drm/i915: add tracepoints for flip requests & completions")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: <stable@vger.kernel.org> # v2.6.36+
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20170126143211.24013-1-aryabinin@virtuozzo.com
(cherry picked from commit 05c41f926fcc7ef838c80a6a99d84f67b4e0b824)
[ Upstream commit 24bf7ae359b8cca165bb30742d2b1c03a1eb23af ]
Based on the xf86-video-nv code, NFORCE (NV1A) and NFORCE2 (NV1F) have a
different way of retrieving clocks. See the
nv_hw.c:nForceUpdateArbitrationSettings function in the original code
for how these clocks were accessed.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=54587
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
[ Upstream commit c34f078675f505c4437919bb1897b1351f16a050 ]
In the path where intel_crt_detect_ddc() detects a CRT, if would return
true without freeing the edid.
Fixes: a2bd1f541f19 ("drm/i915: check whether we actually received an edid in detect_ddc")
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: intel-gfx@lists.freedesktop.org
Cc: <stable@vger.kernel.org> # v3.6+
Signed-off-by: Ander Conselvan de Oliveira <ander.conselvan.de.oliveira@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1484922525-6131-1-git-send-email-ander.conselvan.de.oliveira@intel.com
(cherry picked from commit c96b63a6a7ac4bd670ec2e663793a9a31418b790)
[ Upstream commit fdf35a6b22247746a7053fc764d04218a9306f82 ]
I noticed that the VT switch doesn't work any longer with a Dell
laptop with 1366x768 eDP when the machine is connected with a DP
monitor. It behaves as if VT were switched, but the graphics remain
frozen. Actually the keyboard works, so I could switch back to VT7
again.
I tried to track down the problem, and encountered a long story until
we reach to this error:
- The machine is booted with video=1366x768 option (the distro
installer seems to add it as default).
- Recently, drm_helper_probe_single_connector_modes() deals with
cmdline modes, and it tries to create a new mode when no
matching mode is found.
- The drm_mode_create_from_cmdline_mode() creates a mode based on
either CVT of GFT according to the given cmdline mode; in our case,
it's 1366x768.
- Since both CVT and GFT can't express the width 1366 due to
alignment, the resultant mode becomes 1368x768, slightly larger than
the given size.
- Later on, the atomic commit is performed, and in
drm_atomic_check_only(), the size of each plane is checked.
- The size check of 1366x768 fails due to the above, and eventually
the whole VT switch fails.
Back in the history, we've had a manual fix-up of 1368x768 in various
places via c09dedb7a50e ("drm/edid: Add a workaround for 1366x768 HD
panel"), but they have been all in drm_edid.c at probing the modes
from EDID. For addressing the problem above, we need a similar hack
to the mode newly created from cmdline, manually adjusting the width
when the expected size is 1366 while we get 1368 instead.
Fixes: eaf99c749d43 ("drm: Perform cmdline mode parsing during...")
Link: http://patchwork.freedesktop.org/patch/msgid/20170109145614.29454-1-tiwai@suse.de
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
[ Upstream commit 8a08403bcb39f5d0e733bcf59a8a74f16b538f6e ]
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=98897
https://bugs.launchpad.net/bugs/1651981
Acked-by: Edward O'Callaghan <funfunctor@folklore1984.net>
Cc: Adrian Fiergolski <A.Fiergolski@gmail.com>
[ Upstream commit 298360af3dab45659810fdc51aba0c9f4097e4f6 ]
ast_get_dram_info() configures a window in order to access BMC memory.
A BMC register can be configured to disallow this, and if so, causes
an infinite loop in the ast driver which renders the system unusable.
Fix this by erroring out if an error is detected. On powerpc systems with
EEH, this leads to the device being fenced and the system continuing to
operate.
Cc: <stable@vger.kernel.org> # 3.10+
Signed-off-by: Russell Currey <ruscur@russell.cc>
Reviewed-by: Joel Stanley <joel@jms.id.au>
Link: http://patchwork.freedesktop.org/patch/msgid/20161215051241.20815-1-ruscur@russell.cc
[ Upstream commit 8729675c00a8d13cb2094d617d70a4a4da7d83c5 ]
New variant.
[ Upstream commit 6b16cf7785a4200b1bddf4f70c9dda2efc49e278 ]
Fixes hangs in that case under some circumstances.
v2:
* Only use non-0 x/yorigin if the cursor is (partially) outside of the
top/left edge of the total surface with AVIVO/DCE
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000433
Reviewed-by: Alex Deucher <alexander.deucher@amd.com> (v1)
[ Upstream commit 4349bd775cc8fd75cb648e3a2036a690f497de5c ]
We were storing viewport relative coordinates for AVIVO/DCE display
engines. However, radeon_crtc_cursor_set2 and radeon_cursor_reset pass
radeon_crtc->cursor_x/y as the x/y parameters of
radeon_cursor_move_locked, which would break if the CRTC isn't located
at (0, 0).
[ Upstream commit dcab0fa64e300afa18f39cd98d05e0950f652adf ]
The cursor size also affects the register programming.
[ Upstream commit 0a97c81a9717431e6c57ea845b59c3c345edce67 ]
Hook up drm_compat_ioctl to support 32-bit userspace on 64-bit kernels.
It turns out that N2600 and N2800 comes with 64-bit enabled. We
previously assumed there where no such systems out there.
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20161101144315.2955-1-patrik.r.jakobsson@gmail.com
[ Upstream commit 5f12b80a0b42da253691ca03828033014bb786eb ]
We use obj->phys_handle to choose the pread/pwrite path, but as
obj->phys_handle is a union with obj->userptr, we then mistakenly use
the phys_handle path for userptr objects within pread/pwrite.
Testcase: igt/gem_userptr_blits/forbidden-operations
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97519
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161003124516.12388-2-chris@chris-wilson.co.uk
[ Upstream commit 0727e40a48a1d08cf54ce2c01e120864b92e59bf ]
Bspec says:
"The mailbox response data may not account for memory read latency.
If the mailbox response data for level 0 is 0us, add 2 microseconds
to the result for each valid level."
This means we should only do the +2 in case wm[0] == 0, not always.
So split the sanitizing implementation from the WA implementation and
fix the WA implementation.
v2: Add Fixes tag (Maarten).
Fixes: 367294be7c25 ("drm/i915/gen9: Add 2us read latency to WM level")
Cc: Vandana Kannan <vandana.kannan@intel.com>
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1474578035-424-5-git-send-email-paulo.r.zanoni@intel.com
[ Upstream commit 89f82cbb0d5c0ab768c8d02914188aa2211cd2e3 ]
Use instead __copy_from_user_inatomic() and fallback to slow-path where
we drop and re-aquire the lock in case of fault.
Reported-by: Vaishali Thakkar <vaishali.thakkar@oracle.com>
Signed-off-by: Rob Clark <robdclark@gmail.com>
[ Upstream commit 7dc86ef5ac91642dfc3eb93ee0f0458e702a343e ]
Consolidate existing quirks. Fixes stability issues
on some kickers.
[ Upstream commit 4da5caa6a6f82cda3193bca855235b87debf78bd ]
Only certain types of pdts have the DDC bus registered, so check for
that before we attempt the EDID read. Othwewise we risk playing around
with an i2c adapter that doesn't actually exist.
Cc: Carlos Santa <carlos.santa@intel.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Carlos Santa <carlos.santa@intel.com>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97666
Link: http://patchwork.freedesktop.org/patch/msgid/1477472755-15288-5-git-send-email-ville.syrjala@linux.intel.com
[ Upstream commit ccf03d6995fa4b784f5b987726ba98f4859bf326 ]
This just removes the magic number.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
[ Upstream commit 36e3fa6a38e135e9478a2f75dec9bf6ff1e6480e ]
The i2c adapter is only relevant for some peer device types, so
let's clear the pdt if it's still the same as the old_pdt when we
tear down the i2c adapter.
I don't really like this design pattern of updating port->whatever
before doing the accompanying changes and passing around old_whatever
to figure stuff out. Would make much more sense to me to the pass the
new value around and only update the port->whatever when things are
consistent. But let's try to work with what we have right now.
Quoting a follow-up from Ville:
"And naturally I forgot to amend the commit message w.r.t. this guy
[the change in drm_dp_destroy_port]. We don't really need to do this
here, but I figured I'd try to be a bit more consistent by having it,
just to avoid accidental mistakes if/when someone changes this stuff
again later."
v2: Clear port->pdt in the caller, if needed (Daniel)
Cc: Daniel Vetter <daniel@ffwll.ch>
Tested-by: Carlos Santa <carlos.santa@intel.com> (v1)
Tested-by: Kirill A. Shutemov <kirill@shutemov.name> (v1)
Link: http://patchwork.freedesktop.org/patch/msgid/1477488633-16544-1-git-send-email-ville.syrjala@linux.intel.com
[ Upstream commit 537b4b462caa8bfb9726d9695b8e56e2d5e6b41e ]
The read is taking a considerable amount of time (about 50us on this
machine). The register does not ever hold anything other than the ring
ID that is updated in this exact function, so there is no need for
the read modify write cycle.
This chops off a big chunk of the time spent in hardirq disabled
context, as this function is called multiple times in the interrupt
handler. With this change applied radeon won't show up in the list
of the worst IRQ latency offenders anymore, where it was a regular
before.
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Lucas Stach <dev@lynxeye.de>
[ Upstream commit 9dc79965b21967caebde575f5f5d8bf1aa2c23ab ]
This reverts commit 1a738347df2ee4977459a8776fe2c62196bdcb1b.
It caused at least some Kaveri laptops to incorrectly report DisplayPort
connectors as connected.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97857
[ Upstream commit fb9a5b0c1c9893db2e0d18544fd49e19d784a87d ]
Limit clocks on a specific HD86xx part to avoid
crashes (while awaiting an appropriate PP fix).
Signed-off-by: Tom St Denis <tom.stdenis@amd.com>
[ Upstream commit 670bb4fd21c966d0d2a59ad4a99bb4889f9a2987 ]
Add clock quirks for Jet parts.
Reviewed-by: Sonny Jiang <sonny.jiang@amd.com>
error.
[ Upstream commit 02cfb5fccb0f9f968f0e208d89d9769aa16267bc ]
Ported from Rex's amdgpu change.
[ Upstream commit 47a66e45d7a7613322549c2475ea9d809baaf514 ]
Similar to struct drm_update_draw, struct drm_mode_fb_cmd2 has an
unaligned 64 bit field (modifier). This get packed differently between
32 bit and 64 bit modes on architectures that can handle unaligned 64
bit access (X86 and IA64). Other architectures pack the structs the
same and don't need the compat wrapper. Use the same condition for
drm_mode_fb_cmd2 as we use for drm_update_draw.
Note that only the modifier will be packed differently between compat
and non-compat versions.
Reviewed-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Kristian H. Kristensen <hoegsberg@chromium.org>
[seanpaul added not at bottom of commit msg re: modifier]
Link: http://patchwork.freedesktop.org/patch/msgid/1473801645-116011-1-git-send-email-hoegsberg@chromium.org
[ Upstream commit d31ed3f05763644840c654a384eaefa94c097ba2 ]
The code is applying the same scaling for the X and Y components,
thus making the scaling feature only functional when both components
have the same scaling factor.
Do the s/_w/_h/ replacement where appropriate to fix vertical scaling.
Signed-off-by: Jan Leupold <leupold@rsi-elektrotechnik.de>
Fixes: 1a396789f65a2 ("drm: add Atmel HLCDC Display Controller support")
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[ Upstream commit 6f00975c619064a18c23fd3aced325ae165a73b9 ]
Somehow this one slipped through, which means drivers without modeset
support can be oopsed (since those also don't call
drm_mode_config_init, which means the crtc lookup will chase an
uninitalized idr).
Reported-by: Alexander Potapenko <glider@google.com>
Cc: Alexander Potapenko <glider@google.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
[ Upstream commit 13f479b9df4e2bbf2d16e7e1b02f3f55f70e2455 ]
This bug seems to be present for a very long time.
Signed-off-by: Christian König <christian.koenig@amd.com>
[ Upstream commit ae5b80d2b68eac945b124227dea34462118a6f01 ]
Looks like some RV6xx have problems with that.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=97099
[ Upstream commit 9ef8537e68941d858924a3eacee5a1945767cbab ]
Seems to cause problems for some older hardware. Kudos to Thom Kouwenhoven
for working a lot with the PLLs and figuring this out.
[ Upstream commit 3871f42a57efcdc6a9da751a8cb6fa196c212289 ]
In i915_ggtt_cleanup_hw we need to remember to free aliasing_ppgtt. This
fixes the following kmemleak message:
unreferenced object 0xffff880213cca000 (size 8192):
comm "modprobe", pid 1298, jiffies 4294745402 (age 703.930s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff817c808e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff8121f9c2>] kmem_cache_alloc_trace+0x142/0x1d0
[<ffffffffa06d11ef>] i915_gem_init_ggtt+0x10f/0x210 [i915]
[<ffffffffa06d71bb>] i915_gem_init+0x5b/0xd0 [i915]
[<ffffffffa069749a>] i915_driver_load+0x97a/0x1460 [i915]
[<ffffffffa06a26ef>] i915_pci_probe+0x4f/0x70 [i915]
[<ffffffff81423015>] local_pci_probe+0x45/0xa0
[<ffffffff81424463>] pci_device_probe+0x103/0x150
[<ffffffff81515e6c>] driver_probe_device+0x22c/0x440
[<ffffffff81516151>] __driver_attach+0xd1/0xf0
[<ffffffff8151379c>] bus_for_each_dev+0x6c/0xc0
[<ffffffff8151555e>] driver_attach+0x1e/0x20
[<ffffffff81514fa3>] bus_add_driver+0x1c3/0x280
[<ffffffff81516aa0>] driver_register+0x60/0xe0
[<ffffffff8142297c>] __pci_register_driver+0x4c/0x50
[<ffffffffa013605b>] 0xffffffffa013605b
Signed-off-by: Matthew Auld <matthew.auld@intel.com>
Fixes: b18b6bde300e ("drm/i915/bdw: Free PPGTT struct")
Link: http://patchwork.freedesktop.org/patch/msgid/1470420280-21417-1-git-send-email-matthew.auld@intel.com
(cherry picked from commit cb7f27601c81a1e0454e9461e96f65b31fafbea0)
[ Upstream commit d0e62ef6ed257715a88d0e5d7cd850a1695429e2 ]
This should fix some unaligned access warnings. This is also likely to
fix non-descript issues on nv30/nv34 as a result of incorrect channel
setup.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96836
[ Upstream commit 28668f43b8e421634e1623f72a879812288dd06b ]
The patch f045f459d925 ("drm/nouveau/fbcon: fix out-of-bounds memory accesses")
tries to fix some out of memory accesses. Unfortunatelly, the patch breaks the
display when using fonts with width that is not divisiable by 8.
The monochrome bitmap for each character is stored in memory by lines from top
to bottom. Each line is padded to a full byte.
For example, for 22x11 font, each line is padded to 16 bits, so each
character is consuming 44 bytes total, that is 11 32-bit words. The patch
f045f459d925 changed the logic to "dsize = ALIGN(image->width *
image->height, 32) >> 5", that is just 8 words - this is incorrect and it
causes display corruption.
This patch adds the necesary padding of lines to 8 bytes.
This patch should be backported to stable kernels where f045f459d925 was
backported.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Fixes: f045f459d925 ("drm/nouveau/fbcon: fix out-of-bounds memory accesses")
[ Upstream commit 3edc38a0facef45ee22af8afdce3737f421f36ab ]
Some of the checks didn't handle frev 2 tables properly.
[ Upstream commit d3200be6c423afa1c34f7e39e9f6d04dd5b0af9d ]
Same interface as other UNIPHY blocks
[ Upstream commit 14ff8d48f2235295dfb3117693008e367b49cdb5 ]
DRM_CONNECTOR_POLL_CONNECT only enables polling for connections, not
disconnections. Because of this, we end up losing hotplug polling for
analog connectors once they get connected.
Easy way to reproduce:
- Grab a machine with a radeon GPU and a VGA port
- Plug a monitor into the VGA port, wait for it to update the connector
from disconnected to connected
- Disconnect the monitor on VGA, a hotplug event is never sent for the
removal of the connector.
Originally, only using DRM_CONNECTOR_POLL_CONNECT might have been a good
idea since doing VGA polling can sometimes result in having to mess with
the DAC voltages to figure out whether or not there's actually something
there since VGA doesn't have HPD. Doing this would have the potential of
showing visible artifacts on the screen every time we ran a poll while a
VGA display was connected. Luckily, radeon_vga_detect() only resorts to
this sort of polling if the poll is forced, and DRM's polling helper
doesn't force it's polls.
Additionally, this removes some assignments to connector->polled that
weren't actually doing anything.
Signed-off-by: Lyude <cpaul@redhat.com>
[ Upstream commit d814b24fb74cb9797d70cb8053961447c5879a5c ]
ATPX dGPU power control requires a 200ms delay between
power off and on. This should fix dGPU failures on
resume from power off.
Reviewed-by: Hawking Zhang <Hawking.Zhang@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
[ Upstream commit 8c07eb68330f3ed9a735023a0f0e7f4e873e0c63 ]
This reverts commit f165d2834ceb3d5c29bebadadc27629bebf402ac.
It breaks one of our CI systems. Quoting from Ville:
[ 13.100979] [drm:ironlake_init_pch_refclk] has_panel 1 has_lvds 1 has_ck505 0 using_ssc_source 1
[ 13.101413] ------------[ cut here ]------------
[ 13.101429] kernel BUG at drivers/gpu/drm/i915/intel_display.c:8528!
"which is the 'BUG_ON(val != final)' at the end of ironlake_init_pch_refclk()."
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Lyude <cpaul@redhat.com>
Cc: marius.c.vlad@intel.com
References: https://www.spinics.net/lists/dri-devel/msg109557.html
Acked-by: Lyude <cpaul@redhat.com>
[ Upstream commit b19240062722c39fa92c99f04cbfd93034625123 ]
In commit 7608a43d8f2e ("locking/mutexes: Use MUTEX_SPIN_ON_OWNER when
appropriate") the owner field in the mutex was updated from being
dependent upon CONFIG_SMP to using optimistic spin. Update our peek
function to suite.
Fixes:7608a43d8f2e ("locking/mutexes: Use MUTEX_SPIN_ON_OWNER...")
Reported-by: Hong Liu <hong.liu@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1468244777-4888-1-git-send-email-chris@chris-wilson.co.uk
Reviewed-by: Matthew Auld <matthew.auld@intel.com>
(cherry picked from commit 4f074a5393431a7d2cc0de7fcfe2f61d24854628)
[ Upstream commit 94477bff390aa4612d2332c8abafaae0a13d6923 ]
There are cases where it is desired to see if a proposed placement
is compatible with a buffer object before calling ttm_bo_validate().
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
This is the first of a 3-patch series to fix a black screen
issue observed on Ubuntu 16.04 server.
[ Upstream commit e3c00d87845ab375f90fa6e10a5e72a3a5778cd3 ]
On DCE6.1 PPLL2 is exclusively available to UNIPHYA, so it should not
be taken into consideration when looking for an already enabled PLL
to be shared with other outputs.
This fixes the broken VGA port (TRAVIS DP->VGA bridge) on my Richland
based laptop, where the internal display is connected to UNIPHYA through
a TRAVIS DP->LVDS bridge.
Bug:
https://bugs.freedesktop.org/show_bug.cgi?id=78987
v2: agd: add check in radeon_get_shared_nondp_ppll as well, drop
extra parameter.
[ Upstream commit 7d3fdfff23852fe458a0d0979a3555fe60f1e563 ]
Restore the lost phys status page cleanup.
Fixes the following splat with DMA_API_DEBUG=y:
WARNING: CPU: 0 PID: 21615 at ../lib/dma-debug.c:974 dma_debug_device_change+0x190/0x1f0()
pci 0000:00:02.0: DMA-API: device driver has pending DMA allocations while released from device [count=1]
One of leaked entries details: [device address=0x0000000023163000] [size=4096 bytes] [mapped with DMA_BIDIRECTIONAL] [mapped as coherent]
Modules linked in: i915(-) i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm sha256_generic hmac drbg ctr ccm sch_fq_codel binfmt_misc joydev mousedev arc4 ath5k iTCO_wdt mac80211 smsc_ircc2 ath snd_intel8x0m snd_intel8x0 snd_ac97_codec ac97_bus psmouse snd_pcm input_leds i2c_i801 pcspkr snd_timer cfg80211 snd soundcore i2c_core ehci_pci firewire_ohci ehci_hcd firewire_core lpc_ich 8139too rfkill crc_itu_t mfd_core mii usbcore rng_core intel_agp intel_gtt usb_common agpgart irda crc_ccitt fujitsu_laptop led_class parport_pc video parport evdev backlight
CPU: 0 PID: 21615 Comm: rmmod Tainted: G U 4.4.0-rc4-mgm-ovl+ #4
Hardware name: FUJITSU SIEMENS LIFEBOOK S6120/FJNB16C, BIOS Version 1.26 05/10/2004
e31a3de0 e31a3de0 e31a3d9c c128d4bd e31a3dd0 c1045a0c c15e00c4 e31a3dfc
0000546f c15dfad2 000003ce c12b3740 000003ce c12b3740 00000000 00000001
f61fb8a0 e31a3de8 c1045a83 00000009 e31a3de0 c15e00c4 e31a3dfc e31a3e4c
Call Trace:
[<c128d4bd>] dump_stack+0x16/0x19
[<c1045a0c>] warn_slowpath_common+0x8c/0xd0
[<c12b3740>] ? dma_debug_device_change+0x190/0x1f0
[<c1045a83>] warn_slowpath_fmt+0x33/0x40
[<c12b3740>] dma_debug_device_change+0x190/0x1f0
[<c1065499>] notifier_call_chain+0x59/0x70
[<c10655af>] __blocking_notifier_call_chain+0x3f/0x80
[<c106560f>] blocking_notifier_call_chain+0x1f/0x30
[<c134cfb3>] __device_release_driver+0xc3/0xf0
[<c134d0d7>] driver_detach+0x97/0xa0
[<c134c440>] bus_remove_driver+0x40/0x90
[<c134db18>] driver_unregister+0x28/0x60
[<c1079e8c>] ? trace_hardirqs_on_caller+0x12c/0x1d0
[<c12c0618>] pci_unregister_driver+0x18/0x80
[<f83e96e7>] drm_pci_exit+0x87/0xb0 [drm]
[<f8b3be2d>] i915_exit+0x1b/0x1ee [i915]
[<c10b999c>] SyS_delete_module+0x14c/0x210
[<c115a9bd>] ? ____fput+0xd/0x10
[<c1002014>] do_fast_syscall_32+0xa4/0x450
[<c149f6fa>] sysenter_past_esp+0x3b/0x5d
---[ end trace c2ecbc77760f10a0 ]---
Mapped at:
[<c12b3183>] debug_dma_alloc_coherent+0x33/0x90
[<f83e989c>] drm_pci_alloc+0x18c/0x1e0 [drm]
[<f8acd59f>] intel_init_ring_buffer+0x2af/0x490 [i915]
[<f8acd8b0>] intel_init_render_ring_buffer+0x130/0x750 [i915]
[<f8aaea4e>] i915_gem_init_rings+0x1e/0x110 [i915]
v2: s/BUG_ON/WARN_ON/ since dim doens't like the former anymore
Fixes: 5c6c600 ("drm/i915: Remove DRI1 ring accessors and API")
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> (v1)
Link: http://patchwork.freedesktop.org/patch/msgid/1452538112-5331-1-git-send-email-ville.syrjala@linux.intel.com
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
[ Upstream commit 0e5585dc870af947fab2af96a88c2d8b4270247c ]
Higher mclk values are not stable due to a bug somewhere.
Limit them for now.
[ Upstream commit f971f2263deaa4a441e377b385c11aee0f3b3f9a ]
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=94692
[ Upstream commit 72b9ff0612ad8fc969b910cd00ac16b57a1a9ba4 ]
For drm_gem_object_unreference callers are required to hold
dev->struct_mutex, which these paths don't. Enforcing this requirement
has become a bit more strict with
commit ef4c6270bf2867e2f8032e9614d1a8cfc6c71663
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Thu Oct 15 09:36:25 2015 +0200
drm/gem: Check locking in drm_gem_object_unreference
[ Upstream commit 396aa4451e865d1e36d6d4e0686a9303c038b606 ]
For test 4.2.2.5 to pass per the Link CTS Core 1.2 rev1.1 spec, the source
device must attempt at least 7 times to read the EDID when it receives an
I2C defer. The normal DRM code makes only 7 retries, regardless of whether
or not the response is a native defer or an I2C defer. Test 4.2.2.5 fails
since there are native defers interspersed with the I2C defers which
results in less than 7 EDID read attempts.
The solution is to add the numer of defers to the retry counter when an I2C
DEFER is returned such that another read attempt will be made. This situation
should normally only occur in compliance testing, however, as a worse case
real-world scenario, it would result in 13 attempts ( 6 native defers, 7 I2C
defers) for a single transaction to complete. The net result is a slightly
slower response to an EDID read that shouldn't significantly impact overall
performance.
V2:
- Added a check on the number of I2C Defers to limit the number
of times that the retries variable will be decremented. This
is to address review feedback regarding possible infinite loops
from misbehaving sink devices.
V3:
- Fixed the limit value to 7 instead of 8 to get the correct retry
count.
- Combined the increment of the defer count into the if-statement
V4:
- Removed i915 tag from subject as the patch is not i915-specific
V5:
- Updated the for-loop to add the number of i2c defers to the retry
counter such that the correct number of retry attempts will be
made
Signed-off-by: Todd Previte <tprevite@gmail.com>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
[ Upstream commit 52dfcc5ccfbb6697ac3cac7f7ff1e712760e1216 ]
after this commit:
commit f045f459d925138fe7d6193a8c86406bda7e49da
Author: Ben Skeggs <bskeggs@redhat.com>
Date: Thu Jun 2 12:23:31 2016 +1000
kernel started to oops when loading nouveau module when using GTX 780 Ti
video adapter. This patch fixes the problem.
Bug report: https://bugzilla.kernel.org/show_bug.cgi?id=120591
Signed-off-by: Dmitrii Tcvetkov <demfloro@demfloro.ru>
Suggested-by: Ilia Mirkin <imirkin@alum.mit.edu>
Fixes: f045f459d925 ("nouveau_fbcon_init()")
[ Upstream commit 1b7e38b92b0bbd363369f5160f13f4d26140972d ]
The driver is only enabling scaling, but never disabling it, thus, if you
enable the scaling feature once it stays enabled forever.
Reported-by: Alex Vazquez <avazquez.dev@gmail.com>
Reviewed-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fixes: 1a396789f65a ("drm: add Atmel HLCDC Display Controller support")
[ Upstream commit fd2d2bac6e79b0be91ab86a6075a0c46ffda658a ]
Not clearing mst manager's proposed vcpis table for destroyed connectors when the manager is stopped leaves it pointing to unrefernced memory, this causes pagefault when the manager is restarted when plugging back a branch.
Fixes: 91a25e463130 ("drm/dp/mst: deallocate payload on port destruction")
Signed-off-by: Andrey Grodzovsky <Andrey.Grodzovsky@amd.com>
Reviewed-by: Lyude <cpaul@redhat.com>
Cc: Mykola Lysenko <Mykola.Lysenko@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
