There shouldn't be any other driver support necessary, since none of
the driver-specific ioctls ever required auth, and none of them deal
with modesetting.
Signed-off-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
We could possibly save a bit of power by not requesting gamma
conversion when the ramp happens to be 1:1, but at least if all the
CRTCs are off the SRAM will be disabled.
This should fix brightness sliders in a lot of fullscreen games.
If you make it here other than through err_destroy_encoder, vc4->hdmi
is still NULL.
The DPI interface involves taking a ton of our GPIOs to be used as
outputs, and routing display signals over them in parallel.
v2: Use display_info.bus_formats[] to replace our custom DT
properties.
v3: Rebase on V3D documentation changes.
v4: Fix rebase detritus from V3D documentation changes.
Acked-by: Rob Herring <robh@kernel.org>
Pull drm updates from Dave Airlie:
"This is the main drm pull request for 4.6 kernel.
Overall the coolest thing here for me is the nouveau maxwell signed
firmware support from NVidia, it's taken a long while to extract this
from them.
I also wish the ARM vendors just designed one set of display IP, ARM
display block proliferation is definitely increasing.
Core:
- drm_event cleanups
- Internal API cleanup making mode_fixup optional.
- Apple GMUX vga switcheroo support.
- DP AUX testing interface
Panel:
- Refactoring of DSI core for use over more transports.
New driver:
- ARM hdlcd driver
i915:
- FBC/PSR (framebuffer compression, panel self refresh) enabled by default.
- Ongoing atomic display support work
- Ongoing runtime PM work
- Pixel clock limit checks
- VBT DSI description support
- GEM fixes
- GuC firmware scheduler enhancements
amdkfd:
- Deferred probing fixes to avoid make file or link ordering.
amdgpu/radeon:
- ACP support for i2s audio support.
- Command Submission/GPU scheduler/GPUVM optimisations
- Initial GPU reset support for amdgpu
vmwgfx:
- Support for DX10 gen mipmaps
- Pageflipping and other fixes.
exynos:
- Exynos5420 SoC support for FIMD
- Exynos5422 SoC support for MIPI-DSI
nouveau:
- GM20x secure boot support - adds acceleration for Maxwell GPUs.
- GM200 support
- GM20B clock driver support
- Power sensors work
etnaviv:
- Correctness fixes for GPU cache flushing
- Better support for i.MX6 systems.
imx-drm:
- VBlank IRQ support
- Fence support
- OF endpoint support
msm:
- HDMI support for 8996 (snapdragon 820)
- Adreno 430 support
- Timestamp queries support
virtio-gpu:
- Fixes for Android support.
rockchip:
- Add support for Innosilicion HDMI
rcar-du:
- Support for 4 crtcs
- R8A7795 support
- RCar Gen 3 support
omapdrm:
- HDMI interlace output support
- dma-buf import support
- Refactoring to remove a lot of legacy code.
tilcdc:
- Rewrite of pageflipping code
- dma-buf support
- pinctrl support
vc4:
- HDMI modesetting bug fixes
- Significant 3D performance improvement.
fsl-dcu (FreeScale):
- Lots of fixes
tegra:
- Two small fixes
sti:
- Atomic support for planes
- Improved HDMI support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1063 commits)
drm/amdgpu: release_pages requires linux/pagemap.h
drm/sti: restore mode_fixup callback
drm/amdgpu/gfx7: add MTYPE definition
drm/amdgpu: removing BO_VAs shouldn't be interruptible
drm/amd/powerplay: show uvd/vce power gate enablement for tonga.
drm/amd/powerplay: show uvd/vce power gate info for fiji
drm/amdgpu: use sched fence if possible
drm/amdgpu: move ib.fence to job.fence
drm/amdgpu: give a fence param to ib_free
drm/amdgpu: include the right version of gmc header files for iceland
drm/radeon: fix indentation.
drm/amd/powerplay: add uvd/vce dpm enabling flag to fix the performance issue for CZ
drm/amdgpu: switch back to 32bit hw fences v2
drm/amdgpu: remove amdgpu_fence_is_signaled
drm/amdgpu: drop the extra fence range check v2
drm/amdgpu: signal fences directly in amdgpu_fence_process
drm/amdgpu: cleanup amdgpu_fence_wait_empty v2
drm/amdgpu: keep all fences in an RCU protected array v2
drm/amdgpu: add number of hardware submissions to amdgpu_fence_driver_init_ring
drm/amdgpu: RCU protected amd_sched_fence_release
The Raspberry Pi Foundation's firmware updates are shipping device
trees using the old string, so we'll keep recognizing that as this rev
of V3D. Still, we should use a more specific name in the upstream DT
to clarify which board is being supported, in case we do other revs of
V3D in the future.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The copy_from_user() function returns the number of bytes not copied but
we want to return a negative error code.
Fixes: 463873d57014 ('drm/vc4: Add an API for creating GPU shaders in GEM BOs.')
Cc: stable@vger.kernel.org
Reviewed-by: Eric Anholt <eric@anholt.net>
The original Raspberry Pi had the GPIO active high, but the later
models are active low. The DT GPIO bindings allow specifying the
active flag, except that it doesn't get propagated to the gpiodesc, so
you have to handle it yourself.
Tested-by: Daniel Stone <daniels@collabora.com>
Fixes an error thrown every few seconds when we poll HPD when it's on
a I2C to GPIO expander.
The hardware provides us with separate threads for binning and
rendering, and the existing model waits for them both to complete
before submitting the next job.
Splitting the binning and rendering submissions reduces idle time and
gives us approx 20-30% speedup with some x11perf tests such as -line10
and -tilerect1. Improves openarena performance by 1.01897% +/-
0.247857% (n=16).
Thanks to anholt for suggesting this.
v2: Rebase on the spurious resets fix (change by anholt).
Signed-off-by: Varad Gautam <varadgautam@gmail.com>
This pull request fixes the major VC4 HDMI modesetting bugs found when
the first wave of users showed up in Raspbian.
* tag 'drm-vc4-fixes-2016-03-03' of github.com:anholt/linux:
drm/vc4: Initialize scaler DISPBKGND on modeset.
drm/vc4: Fix setting of vertical timings in the CRTC.
drm/vc4: Fix the name of the VSYNCD_EVEN register.
drm/vc4: Add another reg to HDMI debug dumping.
drm/vc4: Bring HDMI up from power off if necessary.
drm/vc4: Fix a framebuffer reference leak on async flip interrupt.
Nouveau wanted this to avoid some worse conflicts when I merge that.
Rename dma_*_writecombine() to dma_*_wc(), so that the naming
is coherent across the various write-combining APIs. Keep the
old names for compatibility for a while, these can be removed
at a later time. A guard is left to enable backporting of the
rename, and later remove of the old mapping defines seemlessly.
Build tested successfully with allmodconfig.
The following Coccinelle SmPL patch was used for this simple
transformation:
@ rename_dma_alloc_writecombine @
expression dev, size, dma_addr, gfp;
-dma_alloc_writecombine(dev, size, dma_addr, gfp)
+dma_alloc_wc(dev, size, dma_addr, gfp)
@ rename_dma_free_writecombine @
expression dev, size, cpu_addr, dma_addr;
-dma_free_writecombine(dev, size, cpu_addr, dma_addr)
+dma_free_wc(dev, size, cpu_addr, dma_addr)
@ rename_dma_mmap_writecombine @
expression dev, vma, cpu_addr, dma_addr, size;
-dma_mmap_writecombine(dev, vma, cpu_addr, dma_addr, size)
+dma_mmap_wc(dev, vma, cpu_addr, dma_addr, size)
We also keep the old names as compatibility helpers, and
guard against their definition to make backporting easier.
Generated-by: Coccinelle SmPL
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: bp@suse.de
Cc: dan.j.williams@intel.com
Cc: daniel.vetter@ffwll.ch
Cc: dhowells@redhat.com
Cc: julia.lawall@lip6.fr
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: luto@amacapital.net
Cc: mst@redhat.com
Cc: tomi.valkeinen@ti.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1453516462-4844-1-git-send-email-mcgrof@do-not-panic.com
We weren't updating the interlaced bit, so we'd scan out incorrectly
if the firmware had brought up the TV encoder and we were switching to
HDMI.
It looks like when I went to add the interlaced bits, I just took the
existing PV_VERT* block and indented it, instead of copy and pasting
it first. Without this, changing resolution never worked.
It's used for delaying vsync in interlaced mode.
This is also involved in the HDMI setup sequence so it's nice to see
it.
If the firmware hadn't brought up HDMI for us, we need to do its
power-on reset sequence (reset HD and and clear its STANDBY bits,
reset HDMI, and leave the PHY disabled).
We'd need X to queue up an async pageflip while another is
outstanding, and then take a SIGIO. I think X actually avoids sending
out the next pageflip while one's already queued, but I'm not sure.
This gets us functional GPU reset again, like we had until a refactor
at merge time. Tested with a little patch to stuff in a broken binner
job every 100 frames.
This may actually get us a feature that the closed driver didn't have:
turning off the GPU in between rendering jobs, while the V3D device is
still opened by the client.
There may be some tuning to be applied here to use autosuspend so that
we don't bounce the device's power so much, but in steady-state
GPU-bound rendering we keep the power on (since we keep multiple jobs
outstanding) and even if we power cycle on every job we can still
manage at least 680 fps.
More importantly, though, runtime PM will allow us to power off the
device to do a GPU reset.
v2: Switch #ifdef to CONFIG_PM not CONFIG_PM_SLEEP (caught by kbuild
test robot)
We were tracking the "where are the head pointers pointing" globally,
so if another job reused the same BOs and execution was at the same
point as last time we checked, we'd stop and trigger a reset even
though the GPU had made progress.
These ioctls end up getting exposed to fairly directly to GL users,
and having normal user operations print DRM errors is obviously wrong.
The message was originally to give us some idea of what happened when
a hang occurred, but we have a DRM_INFO from reset for that.
This caused the wait ioctls to claim that waiting had completed when
we actually got interrupted by a signal before it was done. Fixes
broken rendering throttling that produced serious lag in X window
dragging.
Fixes igt vc4_create_bo/create-bo-0 by returning -EINVAL from the
ioctl instead of -ENOMEM.
Apparently in hardware (as opposed to simulation), the clear colors
need to be uploaded before the render config, otherwise they won't
take effect. Fixes igt's vc4_wait_bo/used-bo-* subtests.
This is ABI future-proofing if we ever want to extend the pad to mean
something.
This supports 420 and 422 subsampling with 2 or 3 planes, tested with
modetest. It doesn't set up chroma subsampling position (which it
appears KMS doesn't deal with yet).
The LBM memory is overallocated in many cases, but apparently the docs
aren't quite correct and I'll probably need to look at the hardware
source to really figure it out.
These were all touch-tested with modetest.
This implements a simple policy for choosing scaling modes
(trapezoidal for decimation, PPF for magnification), and a single PPF
filter (Mitchell/Netravali's recommendation).
This doesn't matter yet since we only allow 1:1 scaling, but the
comment clearly says we should be using the source size.
Previously we only did the primary and cursor plane, but overlay
planes are useful and just require this setup to add, since all planes
go into the HVS display list in the same way.
So far, we've only ever lit up one CRTC, so this has been fine. To
extend to more displays or more planes, we need to make sure we don't
run our display lists into each other.
Previously, on every modeset we would allocate new display list
memory, recompute changed planes, write all of them to the new memory,
and pointed scanout at the new list (which will latch approximately at
the next line of scanout). We let
drm_atomic_helper_wait_for_vblanks() decide whether we needed to wait
for a vblank after a modeset before cleaning up the old state and
letting the next modeset proceed, and on legacy cursor updates we
wouldn't wait. If you moved the cursor fast enough, we could
potentially wrap around the display list memory area and overwrite the
existing display list while it was still being scanned out, resulting
in the HVS scanning out garbage or just halting.
Instead of making cursor updates wait for scanout to move to the new
display list area (which introduces significant cursor lag in X), we
just rewrite our current display list.
As we add actual scaling, this is going to get way more complicated.
This is the pointer to the HVS device's memory where we stored the
contents of *dlist.
git://anongit.freedesktop.org/drm-intel into drm-next
First drm-misc pull req for 4.6. Big one is the drm_event cleanup, which
is also prep work for adding android fence support to kms (Gustavo is
planning to do that). Otherwise random small bits all over.
* tag 'topic/drm-misc-2016-02-08' of git://anongit.freedesktop.org/drm-intel: (33 commits)
gma500: clean up an excessive and confusing helper
drm/gma500: remove helper function
drm/vmwgfx: Nuke preclose hook
drm/vc4: Nuke preclose hook
drm/tilcdc: Nuke preclose hook
drm/tegra: Stop cancelling page flip events
drm/shmob: Nuke preclose hook
drm/rcar: Nuke preclose hook
drm/omap: Nuke close hooks
drm/msm: Nuke preclose hooks
drm/imx: Unconfuse preclose logic
drm/exynos: Remove event cancelling from postclose
drm/atmel: Nuke preclose
drm/i915: Nuke intel_modeset_preclose
drm: Nuke vblank event file cleanup code
drm: Clean up pending events in the core
drm/vblank: Use drm_event_reserve_init
drm/vmwgfx: fix a NULL dereference
drm/crtc-helper: Add caveat to disable_unused_functions doc
drm/gma500: Remove empty preclose hook
Again since the drm core takes care of event unlinking/disarming this
is now just needless code.
v2: Fixup misplaced hunk.
Cc: Eric Anholt <eric@anholt.net>
Acked-by: Daniel Stone <daniels@collabora.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com> (v1)
Acked-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1453756616-28942-14-git-send-email-daniel.vetter@ffwll.ch
drm-fixes
This pull request just includes the !CONFIG_PM_SLEEP build fix for
vc4.
* tag 'drm-vc4-fixes-2015-01-19' of http://github.com/anholt/linux:
drm/vc4: Remove broken attempt at GPU reset using genpd.
Move the generic implementation to <linux/dma-mapping.h> now that all
architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now
that everyone supports them.
[valentinrothberg@gmail.com: remove leftovers in Kconfig]
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Helge Deller <deller@gmx.de>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
I've tested and confirmed that it doesn't actually work. We'll need
to sort out how to do this properly later, but for now just remove it
since it also caused build breakage due to using CONFIG_PM_SLEEP
functions without our Kconfig depending on PM_SLEEP.
Acked-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
This just fixes a warning on 64-bit builds:
drivers/gpu/drm/vc4/vc4_validate.c: In function ‘validate_gl_shader_rec’:
drivers/gpu/drm/vc4/vc4_validate.c:864:12: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Since your main drm-next pull isn't out of the door yet I figured I might
as well flush out drm-misc instead of delaying for 4.6. It's really just
random stuff all over, biggest thing probably connector_mask tracking from
Maarten.
* tag 'topic/drm-misc-2016-01-17' of git://anongit.freedesktop.org/drm-intel: (24 commits)
drm/fb_cma_helper: Remove implicit call to disable_unused_functions
drm/sysfs: use kobj_to_dev()
drm/i915: Init power domains early in driver load
drm: Do not set connector->encoder in drivers
apple-gmux: Add initial documentation
drm: move MODULE_PARM_DESC to other file
drm/edid: index CEA/HDMI mode tables using the VIC
drm/atomic: Remove drm_atomic_connectors_for_crtc.
drm/i915: Update connector_mask during readout, v2.
drm: Remove opencoded drm_gem_object_release_handle()
drm: Do not set outparam on error during GEM handle allocation
drm/docs: more leftovers from the big vtable documentation pile
drm/atomic-helper: Reject legacy flips on a disabled pipe
drm/atomic: add connector mask to drm_crtc_state.
drm/tegra: Use __drm_atomic_helper_reset_connector for subclassing connector state, v2.
drm/atomic: Add __drm_atomic_helper_connector_reset, v2.
drm/i915: Set connector_state->connector using the helper.
drm: Use a normal idr allocation for the obj->name
drm: Only bump object-reference count when adding first handle
drm: Balance error path for GEM handle allocation
Now that connector_mask is reliable there's no need for this
function any more.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1451908400-25147-6-git-send-email-maarten.lankhorst@linux.intel.com
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
drm-next
I've decided to just send this fixes-for-next pull request now, even if
we don't have a patch for the CONFIG_PM_SLEEP build failure reviewed.
If you like my patch for that, I'd be happy to see it applied directly.
This pull request brings in little fixes from Dan Carpenter for the 3D
support added in this -next cycle.
* tag 'drm-vc4-next-2015-12-21' of http://github.com/anholt/linux:
drm/vc4: fix an error code
drm/vc4: allocate enough memory in vc4_save_hang_state()
drm/vc4: copy_to_user() returns the number of bytes remaining
"exec->exec_bo" is NULL at this point so this code returns success. We
want to return -ENOMEM.
Fixes: d5b1a78a772f ('drm/vc4: Add support for drawing 3D frames.')
"state" is smaller than "kernel_state" so we end up corrupting memory.
Fixes: 214613656b51 ('drm/vc4: Add an interface for capturing the GPU state after a hang.')
The copy_to/from_user() functions return the number of bytes remaining
to be copied. We want to return error codes here.
Also it's a bad idea to print an error message if a copy from user fails
because users can use that to spam /var/log/messages which is annoying
so I removed those.
The following code pattern exists in some DRM drivers:
ddev = drm_dev_alloc(&driver, parent_dev);
drm_dev_set_unique(ddev, dev_name(parent_dev));
(Sometimes dev_name(ddev->dev) is used, which is the same.)
As suggested in
http://lists.freedesktop.org/archives/dri-devel/2015-December/096441.html,
the unique name of a new DRM device can be set as dev_name(parent_dev)
when parent_dev is not NULL (vgem is a special case).
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
