path: root/drivers/gpu/drm/ttm/ttm_page_alloc.c
2014-11-20drm/ttm: Avoid memory allocation from shrinker functions.Tetsuo Handa
Andrew Morton wrote: > On Wed, 12 Nov 2014 13:08:55 +0900 Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> wrote: > > > Andrew Morton wrote: > > > Poor ttm guys - this is a bit of a trap we set for them. > > > > Commit a91576d7916f6cce ("drm/ttm: Pass GFP flags in order to avoid deadlock.") > > changed to use sc->gfp_mask rather than GFP_KERNEL. > > > > - pages_to_free = kmalloc(npages_to_free * sizeof(struct page *), > > - GFP_KERNEL); > > + pages_to_free = kmalloc(npages_to_free * sizeof(struct page *), gfp); > > > > But this bug is caused by sc->gfp_mask containing some flags which are not > > in GFP_KERNEL, right? Then, I think > > > > - pages_to_free = kmalloc(npages_to_free * sizeof(struct page *), gfp); > > + pages_to_free = kmalloc(npages_to_free * sizeof(struct page *), gfp & GFP_KERNEL); > > > > would hide this bug. > > > > But I think we should use GFP_ATOMIC (or drop __GFP_WAIT flag) > > Well no - ttm_page_pool_free() should stop calling kmalloc altogether. > Just do > > struct page *pages_to_free[16]; > > and rework the code to free 16 pages at a time. Easy. Well, ttm code wants to process 512 pages at a time for performance. Memory footprint increased by 512 * sizeof(struct page *) buffer is only 4096 bytes. What about using static buffer like below? ---------- >From d3cb5393c9c8099d6b37e769f78c31af1541fe8c Mon Sep 17 00:00:00 2001 From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Date: Thu, 13 Nov 2014 22:21:54 +0900 Subject: [PATCH] drm/ttm: Avoid memory allocation from shrinker functions. Commit a91576d7916f6cce ("drm/ttm: Pass GFP flags in order to avoid deadlock.") caused BUG_ON() due to sc->gfp_mask containing flags which are not in GFP_KERNEL. https://bugzilla.kernel.org/show_bug.cgi?id=87891 Changing from sc->gfp_mask to (sc->gfp_mask & GFP_KERNEL) would avoid the BUG_ON(), but avoiding memory allocation from shrinker function is better and reliable fix. Shrinker function is already serialized by global lock, and clean up function is called after shrinker function is unregistered. Thus, we can use static buffer when called from shrinker function and clean up function. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: stable <stable@kernel.org> [2.6.35+] Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-08-05drm/ttm: Pass GFP flags in order to avoid deadlock.Tetsuo Handa
Commit 7dc19d5a "drivers: convert shrinkers to new count/scan API" added deadlock warnings that ttm_page_pool_free() and ttm_dma_page_pool_free() are currently doing GFP_KERNEL allocation. But these functions did not get updated to receive gfp_t argument. This patch explicitly passes sc->gfp_mask or GFP_KERNEL to these functions, and removes the deadlock warning. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: stable <stable@kernel.org> [2.6.35+] Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-08-05drm/ttm: Fix possible stack overflow by recursive shrinker calls.Tetsuo Handa
While ttm_dma_pool_shrink_scan() tries to take mutex before doing GFP_KERNEL allocation, ttm_pool_shrink_scan() does not do it. This can result in stack overflow if kmalloc() in ttm_page_pool_free() triggered recursion due to memory pressure. shrink_slab() => ttm_pool_shrink_scan() => ttm_page_pool_free() => kmalloc(GFP_KERNEL) => shrink_slab() => ttm_pool_shrink_scan() => ttm_page_pool_free() => kmalloc(GFP_KERNEL) Change ttm_pool_shrink_scan() to do like ttm_dma_pool_shrink_scan() does. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: stable <stable@kernel.org> [2.6.35+] Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-07-22drm/ttm: use gfp_t instead of int for flags.Dave Airlie
fixes sparse warning. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-09-10drivers: convert shrinkers to new count/scan APIDave Chinner
Convert the driver shrinkers to the new API. Most changes are compile tested only because I either don't have the hardware or it's staging stuff. FWIW, the md and android code is pretty good, but the rest of it makes me want to claw my eyes out. The amount of broken code I just encountered is mind boggling. I've added comments explaining what is broken, but I fear that some of the code would be best dealt with by being dragged behind the bike shed, burying in mud up to it's neck and then run over repeatedly with a blunt lawn mower. Special mention goes to the zcache/zcache2 drivers. They can't co-exist in the build at the same time, they are under different menu options in menuconfig, they only show up when you've got the right set of mm subsystem options configured and so even compile testing is an exercise in pulling teeth. And that doesn't even take into account the horrible, broken code... [glommer@openvz.org: fixes for i915, android lowmem, zcache, bcache] Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Glauber Costa <glommer@openvz.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Kent Overstreet <koverstreet@google.com> Cc: John Stultz <john.stultz@linaro.org> Cc: David Rientjes <rientjes@google.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Carlos Maiolino <cmaiolino@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Rientjes <rientjes@google.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: J. Bruce Fields <bfields@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Jerome Glisse <jglisse@redhat.com> Cc: John Stultz <john.stultz@linaro.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-16ttm: Clear the ttm page allocated from high memory zone correctlyZhao Yakui
The TTM page can be allocated from high memory. In such case it is wrong to use the page_address(page) as the virtual address for the high memory page. bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50241 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Cc: stable@vger.kernel.org Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/David Howells
Convert #include "..." to #include <path/...> in drivers/gpu/. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-03-20drm/ttm: Use pr_fmt and pr_<level>Joe Perches
Use the more current logging style. Add pr_fmt and remove the TTM_PFX uses. Coalesce formats and align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-06drm/ttm: isolate dma data from ttm_tt V4Jerome Glisse
Move dma data to a superset ttm_dma_tt structure which herit from ttm_tt. This allow driver that don't use dma functionalities to not have to waste memory for it. V2 Rebase on top of no memory account changes (where/when is my delorean when i need it ?) V3 Make sure page list is initialized empty V4 typo/syntax fixes Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: introduce callback for ttm_tt populate & unpopulate V4Jerome Glisse
Move the page allocation and freeing to driver callback and provide ttm code helper function for those. Most intrusive change, is the fact that we now only fully populate an object this simplify some of code designed around the page fault design. V2 Rebase on top of memory accounting overhaul V3 New rebase on top of more memory accouting changes V4 Rebase on top of no memory account changes (where/when is my delorean when i need it ?) Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: page allocation use page array instead of listJerome Glisse
Use the ttm_tt pages array for pages allocations, move the list unwinding into the page allocation functions. Signed-off-by: Jerome Glisse <jglisse@redhat.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-21ttm: Fix spelling mistakes and remove unused #ifdefKonrad Rzeszutek Wilk
. and some comments to make it easier to understand. Ackedby: Randy Dunlap <randy.dunlap@oracle.com> [v2: Added some more updates from Randy Dunlap] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-13Revert "ttm: Utilize the DMA API for pages that have TTM_PAGE_FLAG_DMA32 set."Dave Airlie
This reverts commit 69a07f0b117a40fcc1a479358d8e1f41793617f2. We've tracked a number of problems back to this, and Thomas thinks we should redesign this for .40/41 anyways so I'm happy to revert it. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23Revert "ttm: Include the 'struct dev' when using the DMA API."Dave Airlie
This reverts commit 5a893fc28f0393adb7c885a871b8c59e623fd528. This causes a use after free in the ttm free alloc pages path, when it tries to get the be after the be has been destroyed. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-22ttm: Include the 'struct dev' when using the DMA API.Konrad Rzeszutek Wilk
This makes the accounting when using 'debug_dma_dump_mappings()' and CONFIG_DMA_API_DEBUG=y be assigned to the correct device instead of 'fallback'. No functional change - just cosmetic. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-27ttm: Utilize the DMA API for pages that have TTM_PAGE_FLAG_DMA32 set.Konrad Rzeszutek Wilk
For pages that have the TTM_PAGE_FLAG_DMA32 flag set we use the DMA API. We save the bus address in our array which we use to program the GART (see "radeon/ttm/PCIe: Use dma_addr if TTM has set it." and "nouveau/ttm/PCIe: Use dma_addr if TTM has set it."). The reason behind using the DMA API is that under Xen we would end up programming the GART with the bounce buffer (SWIOTLB) DMA address instead of the physical DMA address of the TTM page. The reason being that alloc_page with GFP_DMA32 does not allocate pages under the the 4GB mark when running under Xen hypervisor. Under baremetal this means we do the DMA API call earlier instead of when we program the GART. For details please refer to: https://lkml.org/lkml/2011/1/7/251 [v2: Fixed indentation, revised desc, added Reviewed-by] Reviewed-by: Thomas Hellstrom <thomas@shipmail.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Ian Campbell <ian.campbell@citrix.com>
2011-01-27ttm: Introduce a placeholder for DMA (bus) addresses.Konrad Rzeszutek Wilk
This is right now limited to only non-pool constructs. [v2: Fixed indentation issues, add review-by tag] Reviewed-by: Thomas Hellstrom <thomas@shipmail.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Ian Campbell <ian.campbell@citrix.com>
2010-09-24drm: ttm sparse fixes.Daniel J Blueman
Correct allocation flags type and function prototype for ANSI C compliance. [airlied: whitespace fixed] Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-22Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: add quirk to make HP DV5000 laptop resume drm/radeon/kms: fix RADEON_INFO_CRTC_FROM_ID info ioctl Fix ttm_page_alloc.c build breakage drm/radeon/kms: fix legacy LVDS dpms sequence drm/radeon/kms: drop taking lock around crtc lookup.
2010-07-22Fix ttm_page_alloc.c build breakageLuck, Tony
The commit 1e8655f87333def92bb8215b423adc65403b08a5 drm/ttm: Fix build on architectures without AGP looks at TTM_HAS_AGP before it has been set in ttm_bo_driver.h Move the conditional inclusion of <asm/agp.h> *after* we have included ttm_bo_driver.h Signed-of-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-21mm: add context argument to shrinker callback to remaining shrinkersDave Chinner
Add the shrinkers missed in the first conversion of the API in commit 7f8275d0d660c146de6ee3017e1e2e594c49e820 ("mm: add context argument to shrinker callback"). Signed-off-by: Dave Chinner <dchinner@redhat.com>
2010-07-20drm/ttm: Fix build on architectures without AGPBen Hutchings
Make inclusion of <asm/agp.h> conditional on TTM_HAS_AGP. The use of the functions declared in it is already conditional. Reported-by: Geert Stappers <stappers@stappers.nl> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Tested-by: Geert Stappers <stappers@stappers.nl> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-07drm/ttm: Allocate the page pool manager in the heap.Francisco Jerez
Repeated ttm_page_alloc_init/fini fails noisily because the pool manager kobj isn't zeroed out between uses (we could do just that but statically allocated kobjects are generally considered a bad thing). Move it to kzalloc'ed memory. Note that this patch drops the refcounting behavior of the pool allocator init/fini functions: it would have led to a race condition in its current form, and anyway it was never exploited. This fixes a regression with reloading kms modules at runtime, since page allocator was introduced. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-01drm/ttm: non pooled page allocation should have GFP_USER setJerome Glisse
Non pooled page allocation should have GFP_USER set so allocation can wait and reclaim page from other process (ie non atomic). Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-01drm/ttm: Fix ttm_page_alloc.cThomas Hellstrom
Fix a number of typos misspellings and checkpatch.pl warnings. Replace "[ttm] " with TTM_PFX Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-01drm/ttm: Fix cached TTM page allocation.Thomas Hellstrom
This patch fixes a regression introduced with the pool page allocator in the event that there are no highmem pages (for example x86_64), in which case cached page allocation would fail. Tested with the vmwgfx driver on a 64-bit vm. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-08drm/ttm: using kmalloc/kfree requires including slab.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-08drm/ttm: include linux/seq_file.h for seq_printfMatt Turner
Fixes drivers/gpu/drm/ttm/ttm_page_alloc.c: In function 'ttm_page_alloc_debugfs': drivers/gpu/drm/ttm/ttm_page_alloc.c:829: error: implicit declaration of function 'seq_printf' Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-06drm/ttm: Add sysfs interface to control pool allocator.Pauli Nieminen
Sysfs interface allows user to configure pool allocator functionality and change limits for the size of pool. Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-06drm/ttm: Use set_pages_array_wc instead of set_memory_wc.Pauli Nieminen
Using single call to set multiple pages to wc reduces number of expensive cache flushes. Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-06drm/ttm: Add debugfs output entry to pool allocator.Pauli Nieminen
ttm_page_alloc_debugfs can be registered to output the state of pools. Debugfs file will output number of pages freed from the pool, number of pages in pool now and the lowes number of pages in pool since previous shrink. Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-06drm/ttm: add pool wc/uc page allocator V3Pauli Nieminen
On AGP system we might allocate/free routinely uncached or wc memory, changing page from cached (wb) to uc or wc is very expensive and involves a lot of flushing. To improve performance this allocator use a pool of uc,wc pages. Pools are protected with spinlocks to allow multiple threads to allocate pages simultanously. Expensive operations are done outside of spinlock to maximize concurrency. Pools are linked lists of pages that were recently freed. mm shrink callback allows kernel to claim back pages when they are required for something else. Fixes: * set_pages_array_wb handles highmem pages so we don't have to remove them from pool. * Add count parameter to ttm_put_pages to avoid looping in free code. * Change looping from _safe to normal in pool fill error path. * Initialize sum variable and make the loop prettier in get_num_unused_pages. * Moved pages_freed reseting inside the loop in ttm_page_pool_free. * Add warning comment about spinlock context in ttm_page_pool_free. Based on Jerome Glisse's and Dave Airlie's pool allocator. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
