Most bridge drivers create a DRM connector to model the connector at the
output of the bridge. This model is historical and has worked pretty
well so far, but causes several issues:
- It prevents supporting more complex display pipelines where DRM
connector operations are split over multiple components. For instance a
pipeline with a bridge connected to the DDC signals to read EDID data,
and another one connected to the HPD signal to detect connection and
disconnection, will not be possible to support through this model.
- It requires every bridge driver to implement similar connector
handling code, resulting in code duplication.
- It assumes that a bridge will either be wired to a connector or to
another bridge, but doesn't support bridges that can be used in both
positions very well (although there is some ad-hoc support for this in
the analogix_dp bridge driver).
In order to solve these issues, ownership of the connector should be
moved to the display controller driver (where it can be implemented
using helpers provided by the core).
Extend the bridge API to allow disabling connector creation in bridge
drivers as a first step towards the new model. The new flags argument to
the bridge .attach() operation allows instructing the bridge driver to
skip creating a connector. Unconditionally set the new flags argument to
0 for now to keep the existing behaviour, and modify all existing bridge
drivers to return an error when connector creation is not requested as
they don't support this feature yet.
The change is based on the following semantic patch, with manual review
and edits.
@ rule1 @
identifier funcs;
identifier fn;
struct drm_bridge_funcs funcs = {
.attach = fn
@ depends on rule1 @
identifier rule1.fn;
identifier bridge;
statement S, S1;
int fn(
struct drm_bridge *bridge
+ , enum drm_bridge_attach_flags flags
... when != S
+ if (flags & DRM_BRIDGE_ATTACH_NO_CONNECTOR) {
+ DRM_ERROR("Fix bridge driver to make connector optional!");
+ return -EINVAL;
S1
identifier bridge, flags;
expression E1, E2, E3;
int fn(
struct drm_bridge *bridge,
drm_bridge_attach(E1, E2, E3
+ , flags
+ , 0
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Boris Brezillon <boris.brezillon@collabora.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Tested-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200226112514.12455-10-laurent.pinchart@ideasonboard.com
This way the drm_bridge_funcs interface is consistent with the rest of
the subsystem.
The drivers implementing those hooks are patched too.
v10:
* Add changelog to the commit message
v8 -> v9:
* No changes
v7:
* Adjust things to the bridge_state changes
v6:
* Also fixed rcar-du/rcar_lvds.c same as analogix/analogix_dp_core.c
v5:
* No changes
v4:
* Rename func params into old_bridge_state
* Add Laurent's Rb
v3:
* Old state clarification moved to a separate patch
v2:
* Pass the old bridge state
Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
[narmstrong: renamed state as old_bridge_state in rcar_lvds_atomic_disable]
Reviewed by: Jernej Skrabec <jernej.skrabec@siol.net>
Tested-by: Jonas Karlman <jonas@kwiboo.se>
Link: https://patchwork.freedesktop.org/patch/msgid/20200128135514.108171-5-boris.brezillon@collabora.com
This is needed to pass a bridge state to all atomic hooks, if we don't
do that, the core can't duplicate/create bridge states.
v10:
v9:
* Add Neil's R-b
* Move earlier in the series
v8:
* No changes
v7:
* New patch
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200128135514.108171-3-boris.brezillon@collabora.com
This reverts commit f7619a58ef92 ("drm/bridge: Patch atomic hooks to
take a drm_bridge_state"). Commit 6ed7e9625fa6 ("drm/bridge: Add a
drm_bridge_state object") introduced a circular dependency between
drm.ko and drm_kms_helper.ko which uncovered a misdesign in how the
whole thing was implemented. Let's revert all patches depending on the
bridge_state infrastructure for now.
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200107185807.606999-5-boris.brezillon@collabora.com
the subsystem.
The only driver implementing those hooks (analogix DP) is patched too.
Link: https://patchwork.freedesktop.org/patch/msgid/20200106143409.32321-3-narmstrong@baylibre.com
R-Car Display Unit changes:
- Color Management Module support
- LVDS encoder dual-link support enhancements
- R8A77980 support
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
From: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20191218151710.GA13830@pendragon.ideasonboard.com
Add direct support for the r8a77980 (V3H).
The V3H shares a common, compatible configuration with the r8a77970
(V3M) so that device info structure is reused.
Signed-off-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
DT properties dual-lvds-even-pixels and dual-lvds-odd-pixels
can be used to work out if the driver needs to swap even
and odd pixels around.
This patch makes use of the return value from function
drm_of_lvds_get_dual_link_pixel_order to determine if we
need to swap odd and even pixels around for things to work
properly.
The dual_link boolean field from struct rcar_lvds is not
sufficient to describe the type of LVDS link anymore, since
we now have information related to pixel order, therefore
rename it to link_type and repurpose its usage to fit the
new requirements.
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
For dual-LVDS configurations, it is now possible to mark the
DT port nodes for the sink with boolean properties (like
dual-lvds-even-pixels and dual-lvds-odd-pixels) to let drivers
know the encoders need to be configured in dual-LVDS mode.
Rework the implementation of rcar_lvds_parse_dt_companion
to make use of the DT markers while keeping backward
compatibility.
Dual-LVDS panels are mistakenly identified as bridges, this
commit replaces the current logic with a call to
drm_of_find_panel_or_bridge to sort that out.
The R-Car LVDS encoder driver implements the bridge .mode_set()
operation for the sole purpose of storing the mode in the LVDS private
data, to be used later when enabling the encoder.
Switch to the bridge .atomic_enable() and .atomic_disable() operations
in order to access the global atomic state, and get the mode from the
state instead. Remove both the unneeded .mode_set() operation and the
display_mode and mode fields storing state data from the rcar_lvds
private structure.
As a side effect we get the CRTC from the state, replace the CRTC
pointer retrieved through the bridge's encoder that shouldn't be used by
atomic drivers.
While at it, clarify a few error messages in rcar_lvds_get_lvds_mode()
and turn them into warnings as they are not fatal.
Reviewed-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Tested-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
The Renesas-specific "vsps" property lacks a vendor prefix.
Add a "renesas," prefix to comply with DT best practises.
Retain backward compatibility with old DTBs by falling back to "vsps"
when needed.
Fixes: 6d62ef3ac30be756 ("drm: rcar-du: Expose the VSP1 compositor through KMS planes")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Enable the GAMMA_LUT KMS property using the framework helpers to
register the property and set the associated gamma table maximum size.
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Reviewed-by: Ulrich Hecht <uli+renesas@fpond.eu>
Signed-off-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
Implement CMM handling in the crtc begin and enable atomic callbacks,
and enable CMM unit through the Display Extensional Functions
register at group setup time.
[Fix printk format modifier for size_t variable]
Implement device tree parsing to collect the available CMM instances
described by the 'renesas,cmms' property. Associate CMMs with CRTCs and
store a mask of active CMMs in the DU group for later enablement.
Enforce the probe and suspend/resume ordering of DU and CMM by creating
a stateless device link between the two.
Add a driver for the R-Car Display Unit Color Correction Module.
In most of Gen3 SoCs, each DU output channel is provided with a CMM unit
to perform image enhancement and color correction.
Add support for CMM through a driver that supports configuration of
the 1-dimensional LUT table. More advanced CMM features will be
implemented on top of this initial one.
To facilitate moving connector creation to display drivers,
decouple the drm_connector from drm_panel.
This patch adds a connector argument to drm_panel_get_modes().
All users of drm_panel_get_modes() already had the connector
available, so updating users was trivial.
With this patch drm_panel no longer keeps a reference to the drm_connector.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Jeffrey Hugo <jeffrey.l.hugo@gmail.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Laurent Pinchart <Laurent.pinchart@ideasonboard.com>
Cc: Andrzej Hajda <a.hajda@samsung.com>
Cc: Neil Armstrong <narmstrong@baylibre.com>
Cc: Jonas Karlman <jonas@kwiboo.se>
Cc: Jernej Skrabec <jernej.skrabec@siol.net>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Maxime Ripard <mripard@kernel.org>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: Seung-Woo Kim <sw0312.kim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Stefan Agner <stefan@agner.ch>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Pengutronix Kernel Team <kernel@pengutronix.de>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP Linux Team <linux-imx@nxp.com>
Cc: CK Hu <ck.hu@mediatek.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Cc: Sandy Huang <hjc@rock-chips.com>
Cc: "Heiko Stübner" <heiko@sntech.de>
Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Cc: Vincent Abriou <vincent.abriou@st.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Jonathan Hunter <jonathanh@nvidia.com>
Cc: Torsten Duwe <duwe@lst.de>
Cc: Vasily Khoruzhick <anarsoul@gmail.com>
Cc: Icenowy Zheng <icenowy@aosc.io>
Cc: Sean Paul <seanpaul@chromium.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Boris Brezillon <boris.brezillon@collabora.com>
Cc: Hariprasad Kelam <hariprasad.kelam@gmail.com>
Cc: Alexios Zavras <alexios.zavras@intel.com>
Cc: Brian Masney <masneyb@onstation.org>
Cc: Rob Clark <robdclark@chromium.org>
Cc: Allison Randal <allison@lohutok.net>
Cc: Shayenne Moura <shayenneluzmoura@gmail.com>
Cc: Abhinav Kumar <abhinavk@codeaurora.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-mediatek@lists.infradead.org
Cc: linux-renesas-soc@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
Cc: linux-tegra@vger.kernel.org
Link: https://patchwork.freedesktop.org/patch/msgid/20191207140353.23967-7-sam@ravnborg.org
We are about to replace the single-linked bridge list by a double-linked
one based on list.h, leading to the suppression of the encoder->bridge
field. But before we can do that we must provide a
drm_bridge_chain_get_first_bridge() bridge helper and patch all drivers
and core helpers to use it instead of directly accessing encoder->bridge.
Note that we still have 2 drivers (VC4 and Exynos) manipulating the
encoder->bridge field directly because they need to cut the bridge chain
in order to control the enable/disable sequence. This is definitely
not something we want to encourage, so let's keep those 2 oddities
around until we find a better solution.
Link: https://patchwork.freedesktop.org/patch/msgid/20191203141515.3597631-4-boris.brezillon@collabora.com
The LVDS encoders on RZ/G2N SoC is similar to R-Car M3-N. Add support for
RZ/G2N (R8A774B1) SoC to the LVDS encoder driver.
Signed-off-by: Biju Das <biju.das@bp.renesas.com>
Add support for the R8A774B1 DU (which is very similar to the R8A77965 DU
except that it lacks TCON and CMM); it has one RGB output, one LVDS output
and one HDMI output.
Commit 5cca30ebe089be23 ("drm/rcar-du: Add LVDS_LANES quirk") states
that LVDS lanes 1 and 3 are inverted on R-Car H2 ES1 only, and that the
problem has been fixed in newer revisions.
However, the code didn't take into account the actual hardware revision,
thus applying the quirk also on newer hardware revisions, causing green
color reversals.
Fix this by applying the quirk when running on R-Car H2 ES1.x only.
Reported-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Fixes: 5cca30ebe089be23 ("drm/rcar-du: Add LVDS_LANES quirk")
Tested-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Expand comment in the 'vsps' parsing routine to specify the LIF
channel index defaults to 0 in case the second cell of the property
is not specified to remain compatible with older DT bindings.
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for 5.5:
UAPI Changes:
-Colorspace: Expose different prop values for DP vs. HDMI (Gwan-gyeong Mun)
-fourcc: Add DRM_FORMAT_MOD_ARM_16X16_BLOCK_U_INTERLEAVED (Raymond)
-not_actually: s/ENOTSUPP/EOPNOTSUPP/ in drm_edid and drm_mipi_dbi. This should
not reach userspace, but adding here to specifically call that out (Daniel)
-i810: Prevent underflow in dispatch ioctls (Dan)
-komeda: Add ACLK sysfs attribute (Mihail)
-v3d: Allow userspace to clean up after render jobs (Iago)
Cross-subsystem Changes:
-MAINTAINERS:
-Add Alyssa & Steven as panfrost reviewers (Rob)
-Add Jernej as DE2 reviewer (Maxime)
-Add Chen-Yu as Allwinner maintainer (Maxime)
-staging: Make some stack arrays static const (Colin)
Core Changes:
-ttm: Allow drivers to specify their vma manager (to use gem mgr) (Gerd)
-docs: Various fixes in connector/encoder/bridge docs (Daniel, Lyude, Laurent)
-connector: Allow more than 3 possible encoders for a connector (José)
-dp_cec: Allow a connector to be associated with a cec device (Dariusz)
-various: Fix some compile/sparse warnings (Ville)
-mm: Ensure mm node removals are properly serialised (Chris)
-panel: Specify the type of panel for drm_panels for later use (Laurent)
-panel: Use drm_panel_init to init device and funcs (Laurent)
-mst: Refactors and cleanups in anticipation of suspend/resume support (Lyude)
-vram:
-Add lazy unmapping for gem bo's (Thomas)
-Unify and rationalize vram mm and gem vram (Thomas)
-Expose vmap and vunmap for gem vram objects (Thomas)
-Allow objects to be pinned at the top of vram to avoid fragmentation (Thomas)
Driver Changes:
-various: Include drm_bridge.h instead of relying on drm_crtc.h (Boris)
-ast/mgag200: Refactor show_cursor(), move cursor to top of video mem (Thomas)
-komeda:
-Add error event printing (behind CONFIG) and reg dump support (Lowry)
-Add suspend/resume support (Lowry)
-Workaround D71 shadow registers not flushing on disable (Lowry)
-meson: Add suspend/resume support (Neil)
-omap: Miscellaneous refactors and improvements (Tomi/Jyri)
-panfrost/shmem: Silence lockdep by using mutex_trylock (Rob)
-panfrost: Miscellaneous small fixes (Rob/Steven)
-sti: Fix warnings (Benjamin/Linus)
-sun4i:
-Add vcc-dsi regulator to sun6i_mipi_dsi (Jagan)
-A few patches to figure out the DRQ/start delay calc on dsi (Jagan/Icenowy)
-virtio:
-Add module param to switch resource reuse workaround on/off (Gerd)
-Avoid calling vmexit while holding spinlock (Gerd)
-Use gem shmem helpers instead of ttm (Gerd)
-Accommodate command buffer allocations too big for cma (David)
Cc: Rob Herring <robh@kernel.org>
Cc: Gwan-gyeong Mun <gwan-gyeong.mun@intel.com>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Lyude Paul <lyude@redhat.com>
Cc: José Roberto de Souza <jose.souza@intel.com>
Cc: Dariusz Marcinkiewicz <darekm@google.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Raymond Smith <raymond.smith@arm.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Thomas Zimmermann <tzimmermann@suse.de>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Mihail Atanassov <Mihail.Atanassov@arm.com>
Cc: Lowry Li <Lowry.Li@arm.com>
Cc: Jyri Sarha <jsarha@ti.com>
Cc: Alyssa Rosenzweig <alyssa.rosenzweig@collabora.com>
Cc: Steven Price <steven.price@arm.com>
Cc: Benjamin Gaignard <benjamin.gaignard@st.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Iago Toral Quiroga <itoral@igalia.com>
Cc: David Riley <davidriley@chromium.org>
# gpg: Signature made Thu 10 Oct 2019 01:00:47 AM AEST
# gpg: using RSA key 732C002572DCAF79
# gpg: Can't check signature: public key not found
# Conflicts:
# drivers/gpu/drm/i915/gem/i915_gem_execbuffer.c
# drivers/gpu/drm/i915/i915_drv.c
# drivers/gpu/drm/i915/i915_gem.c
# drivers/gpu/drm/i915/i915_gem_gtt.c
# drivers/gpu/drm/i915/i915_vma.c
Link: https://patchwork.freedesktop.org/patch/msgid/20191009150825.GA227673@art_vandelay
We haven't done any backmerge for a while due to the merge window, and it
starts to become an issue for komeda. Let's bring 5.4-rc1 in.
Signed-off-by: Maxime Ripard <mripard@kernel.org>
We haven't backmerged for a while, let's start the -rc period by pulling
rc1.
Adds the check if the writeback_job with an empty fb, then it should
be freed in atomic_check phase.
With this change, the driver users will not check empty fb case any more.
So refined accordingly.
Signed-off-by: Lowry Li (Arm Technology China) <lowry.li@arm.com>
Reviewed-by: Liviu Dudau <liviu.dudau@arm.com>
Reviewed-by: James Qian Wang (Arm Technology China) <james.qian.wang@arm.com>
Signed-off-by: james qian wang (Arm Technology China) <james.qian.wang@arm.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1564571048-15029-2-git-send-email-lowry.li@arm.com
Pull drm updates from Dave Airlie:
"This is the main pull request for 5.4-rc1 merge window. I don't think
there is anything outstanding so next week should just be fixes, but
we'll see if I missed anything. I landed some fixes earlier in the
week but got delayed writing summary and sending it out, due to a mix
of sick kid and jetlag!
There are some fixes pending, but I'd rather get the main merge out of
the way instead of delaying it longer.
It's also pretty large in commit count and new amd header file size.
The largest thing is four new amdgpu products (navi12/14, arcturus and
renoir APU support).
Otherwise it's pretty much lots of work across the board, i915 has
started landing tigerlake support, lots of icelake fixes and lots of
locking reworking for future gpu support, lots of header file rework
(drmP.h is nearly gone), some old legacy hacks (DRM_WAIT_ON) have been
put into the places they are needed.
uapi:
- content protection type property for HDCP
core:
- rework include dependencies
- lots of drmP.h removals
- link rate calculation robustness fix
- make fb helper map only when required
- add connector->DDC adapter link
- DRM_WAIT_ON removed
- drop DRM_AUTH usage from drivers
dma-buf:
- reservation object fence helper
dma-fence:
- shrink dma_fence struct
- merge signal functions
- store timestamps in dma_fence
- selftests
ttm:
- embed drm_get_object struct into ttm_buffer_object
- release_notify callback
bridges:
- sii902x - audio graph card support
- tc358767 - aux data handling rework
- ti-snd64dsi86 - debugfs support, DSI mode flags support
panels:
- Support for GiantPlus GPM940B0, Sharp LQ070Y3DG3B, Ortustech
COM37H3M, Novatek NT39016, Sharp LS020B1DD01D, Raydium RM67191, Boe
Himax8279d, Sharp LD-D5116Z01B
- TI nspire, NEC NL8048HL11, LG Philips LB035Q02, Sharp LS037V7DW01,
Sony ACX565AKM, Toppoly TD028TTEC1 Toppoly TD043MTEA1
i915:
- Initial tigerlake platform support
- Locking simplification work, general all over refactoring.
- Selftests
- HDCP debug info improvements
- DSI properties
- Icelake display PLL fixes, colorspace fixes, bandwidth fixes, DSI
suspend/resume
- GuC fixes
- Perf fixes
- ElkhartLake enablement
- DP MST fixes
- GVT - command parser enhancements
amdgpu:
- add wipe memory on release flag for buffer creation
- Navi12/14 support (may be marked experimental)
- Arcturus support
- Renoir APU support
- mclk DPM for Navi
- DC display fixes
- Raven scatter/gather support
- RAS support for GFX
- Navi12 + Arcturus power features
- GPU reset for Picasso
- smu11 i2c controller support
amdkfd:
- navi12/14 support
- Arcturus support
radeon:
- kexec fix
nouveau:
- improved display color management
- detect lack of GPU power cables
vmwgfx:
- evicition priority support
- remove unused security feature
msm:
- msm8998 display support
- better async commit support for cursor updates
etnaviv:
- per-process address space support
- performance counter fixes
- softpin support
mcde:
- DCS transfers fix
exynos:
- drmP.h cleanup
lima:
- reduce logging
kirin:
- misc clenaups
komeda:
- dual-link support
- DT memory regions
hisilicon:
- misc fixes
imx:
- IPUv3 image converter fixes
- 32-bit RGB V4L2 pixel format support
ingenic:
- more support for panel related cases
mgag200:
- cursor support fix
panfrost:
- export GPU features register to userspace
- gpu heap allocations
- per-fd address space support
pl111:
- CLD pads wiring support removed from DT
rockchip:
- rework to use DRM PSR helpers
- fix bug in VOP_WIN_GET macro
- DSI DT binding rework
sun4i:
- improve support for color encoding and range
- DDC enabled GPIO
tinydrm:
- rework SPI support
- improve MIPI-DBI support
- moved to drm/tiny
vkms:
- rework CRC tracking
dw-hdmi:
- get_eld and i2s improvements
gm12u320:
- misc fixes
meson:
- global code cleanup
- vpu feature detect
omap:
- alpha/pixel blend mode properties
rcar-du:
- misc fixes"
* tag 'drm-next-2019-09-18' of git://anongit.freedesktop.org/drm/drm: (2112 commits)
drm/nouveau/bar/gm20b: Avoid BAR1 teardown during init
drm/nouveau: Fix ordering between TTM and GEM release
drm/nouveau/prime: Extend DMA reservation object lock
drm/nouveau: Fix fallout from reservation object rework
drm/nouveau/kms/nv50-: Don't create MSTMs for eDP connectors
drm/i915: Use NOEVICT for first pass on attemping to pin a GGTT mmap
drm/i915: to make vgpu ppgtt notificaiton as atomic operation
drm/i915: Flush the existing fence before GGTT read/write
drm/i915: Hold irq-off for the entire fake lock period
drm/i915/gvt: update RING_START reg of vGPU when the context is submitted to i915
drm/i915/gvt: update vgpu workload head pointer correctly
drm/mcde: Fix DSI transfers
drm/msm: Use the correct dma_sync calls harder
drm/msm: remove unlikely() from WARN_ON() conditions
drm/msm/dsi: Fix return value check for clk_get_parent
drm/msm: add atomic traces
drm/msm/dpu: async commit support
drm/msm: async commit support
drm/msm: split power control from prepare/complete_commit
drm/msm: add kms->flush_commit()
The drm panel bridge creates a connector using a connector type
explicitly passed by the display controller or bridge driver that
instantiates the panel bridge. Now that drm_panel reports its connector
type, we can use it to avoid passing an explicit (and often incorrect)
connector type to drm_panel_bridge_add() and
devm_drm_panel_bridge_add().
Several drivers report incorrect or unknown connector types to
userspace. Reporting a different type may result in a breakage. For that
reason, rename (devm_)drm_panel_bridge_add() to
(devm_)drm_panel_bridge_add_typed(), and add new
(devm_)drm_panel_bridge_add() functions that use the panel connector
type. Update all callers of (devm_)drm_panel_bridge_add() to the _typed
function, they will be converted one by one after testing.
The panel drivers have been updated with the following Coccinelle
semantic patch, with manual inspection and fixes to indentation.
expression bridge;
expression dev;
expression panel;
identifier type;
-bridge = drm_panel_bridge_add(panel, type);
+bridge = drm_panel_bridge_add_typed(panel, type);
-bridge = devm_drm_panel_bridge_add(dev, panel, type);
+bridge = devm_drm_panel_bridge_add_typed(dev, panel, type);
Link: https://patchwork.freedesktop.org/patch/msgid/20190904132804.29680-3-laurent.pinchart@ideasonboard.com
We are about to add a drm_bridge_state that inherits from
drm_private_state which is defined in drm_atomic.h. Problem is,
drm_atomic.h includes drm_crtc.h which in turn includes drm_bridge.h,
leading to "drm_private_state has incomplete type" error.
Let's force all users of the drm_bridge API to explicitly include
drm_bridge.h.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190826152649.13820-2-boris.brezillon@collabora.com
The R-Car LVDS encoder units support dual-link operations by splitting
the pixel output between the primary encoder and the companion encoder.
Currently the companion encoder fails at probe time, causing the
registration of the primary to fail as well, preventing the whole DU unit
from being registered at all.
Fix this by not bailing out from probe with error if the
"renesas,companion" property is not specified.
Fixes: fa440d870358 ("drm: rcar-du: lvds: Add support for dual-link mode")
Reported-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Using name "bridge" for macro bridge_to_rcar_lvds argument doesn't
work when the pointer name used by the caller is not "bridge".
Rename the argument to "b" to allow for any pointer name.
While at it, fix the connector_to_rcar_lvds macro similarly.
Fixes: c6a27fa41fab ("drm: rcar-du: Convert LVDS encoder code to bridge driver")
[Fix connector_to_rcar_lvds]
They're the default.
Aside: Would be really nice to switch the others over to
drm_gem_object_funcs.
Reviewed-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Emil Velikov <emil.velikov@collabora.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190614203615.12639-27-daniel.vetter@ffwll.ch
Split out to make the functional changes stick out more.
All places where DRIVER_PRIME was used have been removed in previous
patches already.
v2: amdgpu gained DRIVER_SYNCOBJ_TIMELINE.
v3: amdgpu lost DRIVER_SYNCOBJ_TIMELINE.
v4: Don't add a space in i915_drv.c (Sam)
v5: Add note that previous patches removed all the DRIVER_PRIME users
already (Emil).
v6: Fixupe ingenic (new driver) while applying.
Cc: amd-gfx@lists.freedesktop.org
Cc: etnaviv@lists.freedesktop.org
Cc: freedreno@lists.freedesktop.org
Cc: intel-gfx@lists.freedesktop.org
Cc: lima@lists.freedesktop.org
Cc: linux-amlogic@lists.infradead.org
Cc: linux-arm-msm@vger.kernel.org
Cc: linux-aspeed@lists.ozlabs.org
Cc: linux-stm32@st-md-mailman.stormreply.com
Cc: nouveau@lists.freedesktop.org
Cc: spice-devel@lists.freedesktop.org
Cc: virtualization@lists.linux-foundation.org
Cc: VMware Graphics <linux-graphics-maintainer@vmware.com>
Cc: xen-devel@lists.xenproject.org
Link: https://patchwork.freedesktop.org/patch/msgid/20190617153924.414-1-daniel.vetter@ffwll.ch
drm_atomic_get_crtc_state() returns an error pointer when it fails, so
the null check is doing nothing here.
Credit to 0-day/Dan Carpenter for reporting this.
Fixes: 6f3b62781bbd ("drm: Convert connector_helper_funcs->atomic_check to accept drm_atomic_state")
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Eric Anholt <eric@anholt.net>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> [for rcar lvds]
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Sean Paul <sean@poorly.run>
Cc: Karol Herbst <karolherbst@gmail.com>
Cc: Ilia Mirkin <imirkin@alum.mit.edu>
Cc: dri-devel@lists.freedesktop.org
Reported-by: kbuild test robot <lkp@intel.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190617181548.124134-1-sean@poorly.run
drm-misc-next for v5.3:
UAPI Changes:
- Add code to signal all dma-fences when freed with pending signals.
- Annotate reservation object access in CONFIG_DEBUG_MUTEXES
Core Changes:
- Assorted documentation fixes.
- Use irqsave/restore spinlock to add crc entry.
- Move code around to drm_client, for internal modeset clients.
- Make drm_crtc.h and drm_debugfs.h self-contained.
- Remove drm_fb_helper_connector.
- Add bootsplash to todo.
- Fix lock ordering in pan_display_legacy.
- Support pinning buffers to current location in gem-vram.
- Remove the now unused locking functions from gem-vram.
- Remove the now unused kmap-object argument from vram helpers.
- Stop checking return value of debugfs_create.
- Add atomic encoder enable/disable helpers.
- pass drm_atomic_state to atomic connector check.
- Add atomic support for bridge enable/disable.
- Add self refresh helpers to core.
Driver Changes:
- Add extra delay to make MTP SDM845 work.
- Small fixes to virtio, vkms, sii902x, sii9234, ast, mcde, analogix, rockchip.
- Add zpos and ?BGR8888 support to meson.
- More removals of drm_os_linux and drmP headers for amd, radeon, sti, r128, r128, savage, sis.
- Allow synopsis to unwedge the i2c hdmi bus.
- Add orientation quirks for GPD panels.
- Edid cleanups and fixing handling for edid < 1.2.
- Add runtime pm to stm.
- Handle s/r in dw-hdmi.
- Add hooks for power on/off to dsi for stm.
- Remove virtio dirty tracking code, done in drm core.
- Rework BO handling in ast and mgag200.
Tiny conflict in drivers/gpu/drm/amd/display/dc/clk_mgr/clk_mgr.c,
needed #include <linux/slab.h> to make it compile.
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/0e01de30-9797-853c-732f-4a5bd6e61445@linux.intel.com
Everyone who implements connector_helper_funcs->atomic_check reaches
into the connector state to get the atomic state. Instead of continuing
this pattern, change the callback signature to just give atomic state
and let the driver determine what it does and does not need from it.
Eventually all atomic functions should do this, but that's just too much
busy work for me.
Changes in v3:
- Added to the set
Changes in v4:
- None
Changes in v5:
- intel_digital_connector_atomic_check declaration moved to i915_atomic.h
Link to v3: https://patchwork.freedesktop.org/patch/msgid/20190502194956.218441-5-sean@poorly.run
Link to v4: https://patchwork.freedesktop.org/patch/msgid/20190508160920.144739-5-sean@poorly.run
Tested-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> [for rcar lvds]
Acked-by: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190611160844.257498-5-sean@poorly.run
Add support for the DRM_FORMAT_RGBA5551, DRM_FORMAT_RGBX5551,
DRM_FORMAT_ABGR1555, DRM_FORMAT_XBGR1555, DRM_FORMAT_BGRA5551 and
DRM_FORMAT_BGRX5551 formats to the DU driver. Those formats are only
available on Gen3.
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Reviewed-by: Jacopo Mondi <jacopo@jmondi.org>
Add support for the DRM_FORMAT_RGBA4444, DRM_FORMAT_RGBX4444,
DRM_FORMAT_ABGR4444, DRM_FORMAT_XBGR4444, DRM_FORMAT_BGRA4444 and
DRM_FORMAT_BGRX4444 formats to the DU driver. Those formats are only
available on Gen3.
Add support for the DRM_FORMAT_RGBA8888, DRM_FORMAT_RGBX8888,
DRM_FORMAT_ABGR8888 and DRM_FORMAT_XBGR8888 formats to the DU driver.
Those formats are only available on Gen3.
In dual-link LVDS mode, the LVDS1 encoder is used as a companion for
LVDS0, and both encoders transmit data from DU0. The LVDS1 output of DU1
can't be used in that case, don't create an encoder and connector for
it.
Reviewed-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
Tested-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
In dual-link mode the LVDS0 encoder transmits even-numbered pixels, and
sends odd-numbered pixels to the LVDS1 encoder for transmission on a
separate link.
To implement support for this mode of operation, determine if the LVDS
connection operates in dual-link mode by querying the next device in the
pipeline, locate the companion encoder, and control it directly through
its bridge operations.
The DRM core and DU driver guarantee that the LVDS bridge will not be
double-enabled or double-disabled. Remove the corresponding unnecessary
checks.
The new writeback feature exports functions so that they can integrate
into the rcar_du_kms module.
The interface functions are defined in the rcar_du_writeback header, but
it is not included in the object file itself leading to compiler
warnings for missing prototypes.
Include the header as appropriate.
The LVDS encoders on RZ/G2M SoC is similar to R-Car M3-W. Add support for
RZ/G2M (R8A774A1) SoC to the LVDS encoder driver.
Add support for the R8A774A1 DU (which is very similar to the R8A7796 DU
On the D3 SoC the LVDS PHY must be enabled in the same register write
that enables the LVDS output. Skip writing the LVEN bit independently
on that platform, it will be set by the write that sets LVRES.
The D3 and E3 SoCs have different pixel clock frequency limits for the
LVDS encoder than the other SoCs in the Gen3 family. Adjust the mode
fixup implementation accordingly.
The rcar_du_crtc functions have a heavy reliance on the rcar_du_group
structure, in many cases just to access the DU device context.
To better separate the groups out of the CRTC handling code, give the
rcar_du_crtc its own pointer to the device and remove the indirection
through the group pointers.
The PLL parameters are computed by looping over the range of acceptable
M, N and E values, and selecting the combination that produces the
output frequency closest to the target. The internal frequency
constraints are taken into account by restricting the tested values for
the PLL parameters, reducing the search space. The target frequency,
however, is only taken into account when computing the post-PLL divider,
which can result in a 0 value for the divider when the PLL output
frequency being tested is lower than half of the target frequency.
Subsequent loops will produce a better set of PLL parameters, but for
some of the iterations this can result in a division by 0.
Fix it by clamping the divider value. We could instead restrict the E
values being tested in the inner loop, but that would require additional
calculation that would likely be less efficient as the E parameter can
only take three different values.
Fixes: c25c01361199 ("drm: rcar-du: lvds: D3/E3 support")
The CRTC suspend and resume functions have been replaced, but the
prototypes were not removed.
Remove the redundant definitions.
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
