git://anongit.freedesktop.org/tegra/linux into drm-next
drm/panel: Changes for v3.15-rc1
Add support for a couple more simple panels. A few cleanups to the
simple panel driver are also included (gpiod interface conversion,
removal of redundant call to regulator_disable()).
* tag 'drm/panel/for-3.15-rc1' of git://anongit.freedesktop.org/tegra/linux:
drm/panel: add support for LG LD070WX3-SL01 panel
drm/panel: add support for LG LH500WX1-SD03 panel
drm/panel: simple: Allow DSI panels to provide mode flags
drm/panel: simple: Allow GPIO accesses to sleep
drm/panel: remove redundant regulator_disable()
drm/panel: use gpiod interface for enable GPIO
drm/panel: Add LG 12.9" LCD panel
MAINTAINERS: Add entry for DRM panel drivers
MAINTAINERS
The patch adds MIPI-DSI based S6E8AA0 AMOLED LCD panel driver.
Driver uses mipi_dsi bus to communicate with panel and exposes drm_panel
interface.
v2
- added bus error handling,
- set maxmimum DSI packet size on init,
- removed unsupported brightness drm_panel callbacks,
- minor improvements
v3
- switched to gpiod framework,
- minor fixes in error handling
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
The patch adds LD9040 parallel RGB panel driver with SPI control interface.
The driver uses drm_panel framework.
This panel is used by Tegra Note 7 and supported by the simple-panel
driver.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
This panel is used by the NVIDIA SHIELD and supported by the
simple-panel driver.
In order to differentiate between the different video modes (burst vs.
non-burst, sync pulses vs. sync events) supported by peripherals, pass
the flags that specify this mode in the panel description to the DSI
peripheral device when probed.
The enable GPIO for panels may be provided by GPIO expanders on slow
busses (such as I2C), and therefore toggling the GPIO may sleep. Since
these accesses don't happen in interrupt context, use the *_cansleep()
variants of the GPIO API.
regulator_disable() is already performed by panel_simple_disable(),
which is called by panel_simple_remove().
Use the new GPIO descriptor interface to handle the panel's enable GPIO.
This considerably simplifies the code.
[treding@nvidia.com: rework to improve readability]
The LP129QE LCD has an LED backlight and a display resolution of
2560x1700 pixels.
This stashes away the EDID data so that the sysfs per-connector file
"edid" can display it. Without this change, the "edid" file is always
empty.
The Chunghwa CLAA101WA01A is a 10.1" 1366x768 panel, which can be
supported by the simple panel driver.
The Samsung LNT101NT05 10.1" WXVGA panel can be supported by the simple panel
driver.
Cc: linux-fbdev@vger.kernel.org
Cc: dri-devel@lists.freedesktop.org
Cc: David Airlie <airlied@linux.ie>
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
The Panasonic VVX10F004B0 is a 10.1" WUXGA TFT LCD panel connected using
four DSI lanes.
Add a driver for simple panels. Such panels can have a regulator that
provides the supply voltage and a separate GPIO to enable the panel.
Optionally the panels can have a backlight associated with them so it
can be enabled or disabled according to the panel's power management
mode.
Support is added for two panels: An AU Optronics 10.1" WSVGA and a
Chunghwa Picture Tubes 10.1" WXGA panel.
Add a very simple framework to register and lookup panels. Panel drivers
can initialize a DRM panel and register it with the framework, allowing
them to be retrieved and used by display drivers. Currently only support
for DPMS and obtaining panel modes is provided. However it should be
sufficient to enable a large number of panels. The framework should also
be easily extensible to support more sophisticated kinds of panels such
as DSI.
The framework hasn't been tied into the DRM core, even though it should
be easily possible to do so if that's what we want. In the current
implementation, display drivers can simple make use of it to retrieve a
panel, obtain its modes and control its DPMS mode.
Note that this is currently only tested on systems that boot from a
device tree. No glue code has been written yet for systems that use
platform data, but it should be easy to add.
