[ Upstream commit 9e4dde28e9cd34ee13a6b7247f0857fb49fd3f19 ]
Someone on IRC once asked an innocent enough sounding question: Why
with xf86-video-modesetting is es2gears limited at 120fps.
So I broke out the perfetto tracing mesa MR and took a look. It turns
out the problem was drm_atomic_helper_dirtyfb(), which would end up
waiting for vblank.. es2gears would rapidly push two frames to Xorg,
which would blit them to screen and in idle hook (I assume) call the
DIRTYFB ioctl. Which in turn would do an atomic update to flush the
dirty rects, which would stall until the next vblank. And then the
whole process would repeat.
But this is a bit silly, we only need dirtyfb for command mode DSI
panels. So track in plane state whether dirtyfb is required, and
track in the fb how many attached planes require dirtyfb so that we
can skip it when not required. (Note, mdp4 does not actually have
cmd mode support.)
Signed-off-by: Rob Clark <robdclark@chromium.org>
Reviewed-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
Link: https://lore.kernel.org/r/20220223191118.881321-1-robdclark@gmail.com
This reverts commit c1d12c19efd91b9cda5472bc4ec48854e67c24a8.
Breaks armv7 build
ERROR: modpost: "__aeabi_ldivmod" [drivers/gpu/drm/msm/msm.ko] undefined!
Instead of using static bandwidth setup, manage bandwidth dynamically,
depending on the amount of allocated planes, their format and
resolution.
Co-developed-with: James Willcox <jwillcox@squareup.com>
Signed-off-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
Reported-by: kernel test robot <lkp@intel.com>
Link: https://lore.kernel.org/r/20210525131316.3117809-8-dmitry.baryshkov@linaro.org
Instead of implemeting zpos property on our own, use standard zpos
property support.
Link: https://lore.kernel.org/r/20210525131316.3117809-6-dmitry.baryshkov@linaro.org
Use drm_plane_state's 'pixel_blend_mode' field rather than using
'premultiplied' field to mdp5_plane_state.
Link: https://lore.kernel.org/r/20210525131316.3117809-4-dmitry.baryshkov@linaro.org
Use drm_plane_state's 'alpha' field rather than adding extra 'alpha'
Link: https://lore.kernel.org/r/20210525131316.3117809-3-dmitry.baryshkov@linaro.org
Some SoCs, like MSM8956/8976 (and APQ variants), do feature these
clocks and we need to enable them in order to get both of the
hw (mdp5/rot) Translation Buffer Units (TBUs) to properly work.
Signed-off-by: AngeloGioacchino Del Regno <kholk11@gmail.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation this program is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 503 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Enrico Weigelt <info@metux.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190602204653.811534538@linutronix.de
With the addition of "private_objs" in drm_atomic_state, we no longer
need to subclass drm_atomic_state to store state of share resources
that don't perfectly fit within planes/crtc/connector state information.
We can now save this state within drm_atomic_state itself using
the private objects.
Remove the infrastructure that allowed subclassing of drm_atomic_state
in the driver.
Changes in v3:
- Added to the msm atomic helper patch set
Changes in v4:
- None
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Global shared resources (hwpipes, hwmixers and SMP) for MDP5 are
implemented as a part of atomic state by subclassing drm_atomic_state.
The preferred approach is to use the drm_private_obj infrastructure
available in the atomic core.
mdp5_global_state is introduced as a drm atomic private object. The two
funcs mdp5_get_global_state() and mdp5_get_existing_global_state() are
the two variants that will be used to access mdp5_global_state.
This will replace the existing mdp5_state struct (which subclasses
drm_atomic_state) and the funcs around it. These will be removed later
once we mdp5_global_state is put to use everywhere.
Changes in v3:
- Added glob_state_lock instead of pushing it into the core
Changes in v4:
- None
For DSI cmd-mode and writeback, we need to write the CTL's START
register to kick things off, but we only want to do that once both
the encoder and the crtc have a chance to write their corresponding
flush bits. The difficulty is that when there is a full modeset
(ie. encoder state has changed) we want to defer the start until
encoder->enable(). But if only plane's have changed, we want to do
this from crtc->commit().
The start_mask was a previous attempt to handle this, but it didn't
really do the right thing since atomic conversion.
Instead track in the crtc state that the start should be deferred,
set to try from encoder's (or in future writeback's) atomic_check().
This way the state is part of the atomic state, and rollback can
work properly if an atomic test fails.
Since new display controller is called "dpu" instead of "mdp". Lets
make the name of the toplevel directory for the display controllers a
bit more generic.
Reviewed-by: Sean Paul <seanpaul@chromium.org>
