path: root/drivers/gpu/drm/i915/i915_oa_sklgt2.h
2018-10-23drm/i915/perf: update generated files headersLionel Landwerlin
Lucas submitted a patch to generator script, so just reflecting the change here. Signed-off-by: Lionel Landwerlin <lionel.g.landwerlin@intel.com> Reviewed-by: Lucas De Marchi <lucas.demarchi@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20181023100707.31738-2-lionel.g.landwerlin@intel.com
2017-08-03drm/i915/perf: prune OA configsLionel Landwerlin
In the following commit we'll introduce loadable userspace configs. This change reworks how configurations are handled in the perf driver and retains only the test configurations in kernel space. We now store the test config in dev_priv and resolve the id only once when opening the perf stream. The OA config is then handled through a pointer to the structure holding the configuration details. v2: Rework how test configs are handled (Lionel) v3: Use u32 to hold number of register (Matthew) v4: Removed unused dev_priv->perf.oa.current_config variable (Matthew) v5: Lock device when accessing exclusive_stream (Lionel) v6: Ensure OACTXCONTROL is always reprogrammed (Lionel) v7: Switch a couple of index variable from int to u32 (Matthew) Signed-off-by: Lionel Landwerlin <lionel.g.landwerlin@intel.com> Reviewed-by: Matthew Auld <matthew.auld@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170803165812.2373-3-lionel.g.landwerlin@intel.com
2017-06-14drm/i915/perf: Add 'render basic' Gen8+ OA unit configsRobert Bragg
Adds a static OA unit, MUX, B Counter + Flex EU configurations for basic render metrics on Broadwell, Cherryview, Skylake and Broxton. These are auto generated from an XML description of metric sets, currently maintained in gputop, ref: https://github.com/rib/gputop > gputop-data/oa-*.xml > scripts/i915-perf-kernelgen.py $ make -C gputop-data -f Makefile.xml WHITELIST=RenderBasic v2: add newlines to debug messages + fix comment (Matthew Auld) Signed-off-by: Robert Bragg <robert@sixbynine.org> Signed-off-by: Lionel Landwerlin <lionel.g.landwerlin@intel.com> Reviewed-by: Matthew Auld <matthew.auld@intel.com> Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
