path: root/drivers/gpu/drm/i810
2010-10-06Merge remote branch 'korg/drm-fixes' into drm-vmware-nextDave Airlie
necessary for some of the vmware fixes to be pushed in. Conflicts: drivers/gpu/drm/drm_gem.c drivers/gpu/drm/i915/intel_fb.c include/drm/drmP.h
2010-09-30drm: i810/i830: fix locked ioctl variantArnd Bergmann
The i810 and i830 device drivers may replace their file operations on an open file descriptor. My previous patch to move the BKL out of the common DRM code into these drivers only caught the default file operations, not the ones that actually end up being used. Found while trying to come up with a way to kill the BKL for good in these drivers. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill get_reg_ofs callbackDaniel Vetter
Every driver used the default implementation. Fold that one into the only callsite and drop the callback. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill drm_map_ofs callbacksDaniel Vetter
All drivers happily copy&pasted the default implementation without checking whether this callback is used at all. It's not. Sigh. Kill it. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-17drm: block userspace under allocating buffer and having drivers overwrite it ↵Dave Airlie
(v2) With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory. This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation. Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau. v2: fix nouveau pushbuf arg (thanks to Ben for pointing it out) Reported-by: Linus Torvalds <torvalds@linuxfoundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-05drm: kill BKL from common codeArnd Bergmann
This restricts the use of the big kernel lock to the i830 and i810 device drivers. The three remaining users in common code (open, ioctl and release) get converted to a new mutex, the drm_global_mutex, making the locking stricter than the big kernel lock. This may have a performance impact, but only in those cases that currently don't use DRM_UNLOCKED flag in the ioctl list and would benefit from that anyway. The reason why i810 and i830 cannot use drm_global_mutex in their mmap functions is a lock-order inversion problem between the current use of the BKL and mmap_sem in these drivers. Since the BKL has release-on-sleep semantics, it's harmless but it would cause trouble if we replace the BKL with a mutex. Instead, these drivers get their own ioctl wrappers that take the BKL around every ioctl call and then set their own handlers as DRM_UNLOCKED. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02drm/i810: fixed coding style issuesNicolas Kaiser
Fixed brace, macro and spacing coding style issues, and a C99 comment. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-18drm: convert drm_ioctl to unlocked_ioctlArnd Bergmann
drm_ioctl is called with the Big Kernel Lock held, which shows up very high in statistics on vfs_ioctl. Moving the lock into the drm_ioctl function itself makes sure we blame the right subsystem and it gets us one step closer to eliminating the locked version of fops->ioctl. Since drm_ioctl does not require the lock itself, we only need to hold it while calling the specific handler. The 32 bit conversion handlers do not interact with any other code, so they don't need the BKL here either and can just call drm_ioctl. As a bonus, this cleans up all the other users of drm_ioctl which now no longer have to find the inode or call lock_kernel. [airlied: squashed the non-driver bits of the second patch in here, this provides the flag for drivers to use to select unlocked ioctls - but doesn't modify any drivers]. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.sourceforge.net Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-18drm: Remove memory debugging infrastructure.Eric Anholt
It hasn't been used in ages, and having the user tell your how much memory is being freed at free time is a recipe for disaster even if it was ever used. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-03-13drm: Split drm_map and drm_local_mapBenjamin Herrenschmidt
Once upon a time, the DRM made the distinction between the drm_map data structure exchanged with user space and the drm_local_map used in the kernel. For some reasons, while the BSD port still has that "feature", the linux part abused drm_map for kernel internal usage as the local map only existed as a typedef of the struct drm_map. This patch fixes it by declaring struct drm_local_map separately (though its content is currently identical to the userspace variant), and changing the kernel code to only use that, except when it's a user<->kernel interface (ie. ioctl). This allows subsequent changes to the in-kernel format I've also replaced the use of drm_local_map_t with struct drm_local_map in a couple of places. Mostly by accident but they are the same (the former is a typedef of the later) and I have some remote plans and half finished patch to completely kill the drm_local_map_t typedef so I left those bits in. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
