The drm_gem_dumb_destroy() isn't used in drivers, don't export it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
GEM's vmap and vunmap interfaces now wrap memory pointers in struct
dma_buf_map.
Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de>
Tested-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20201103093015.1063-8-tzimmermann@suse.de
It's the only ioctl handler purely for legacy drivers that didn't have
this yet.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20201008142927.2819321-1-daniel.vetter@ffwll.ch
We can now also delete drm_dev_init, now that vkms, vgem and i915
selftests are resolved.
Reviewed-by: Thomas Zimmermann <tzimmermann@suse.de>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20200918132505.2316382-5-daniel.vetter@ffwll.ch
Add some kind of vblank workers. The interface is similar to regular
delayed works, and is mostly based off kthread_work. It allows for
scheduling delayed works that execute once a particular vblank sequence
has passed. It also allows for accurate flushing of scheduled vblank
works - in that flushing waits for both the vblank sequence and job
execution to complete, or for the work to get cancelled - whichever
comes first.
Whatever hardware programming we do in the work must be fast (must at
least complete during the vblank or scanout period, sometimes during the
first few scanlines of the vblank). As such we use a high-priority
per-CRTC thread to accomplish this.
Changes since v7:
* Stuff drm_vblank_internal.h and drm_vblank_work_internal.h contents
into drm_internal.h
* Get rid of unnecessary spinlock in drm_crtc_vblank_on()
* Remove !vblank->worker check
* Grab vbl_lock in drm_vblank_work_schedule()
* Mention self-rearming work items in drm_vblank_work_schedule() kdocs
* Return 1 from drm_vblank_work_schedule() if the work was scheduled
successfully, 0 or error code otherwise
* Use drm_dbg_core() instead of DRM_DEV_ERROR() in
* Remove vblank->worker checks in drm_vblank_destroy_worker() and
drm_vblank_flush_worker()
Changes since v6:
* Get rid of ->pending and seqcounts, and implement flushing through
simpler means - danvet
* Get rid of work_lock, just use drm_device->event_lock
* Move drm_vblank_work item cleanup into drm_crtc_vblank_off() so that
we ensure that all vblank work has finished before disabling vblanks
* Add checks into drm_crtc_vblank_reset() so we yell if it gets called
while there's vblank workers active
* Grab event_lock in both drm_crtc_vblank_on()/drm_crtc_vblank_off(),
the main reason for this is so that other threads calling
drm_vblank_work_schedule() are blocked from attempting to schedule
while we're in the middle of enabling/disabling vblanks.
* Move drm_handle_vblank_works() call below drm_handle_vblank_events()
* Simplify drm_vblank_work_cancel_sync()
* Fix drm_vblank_work_cancel_sync() documentation
* Move wake_up_all() calls out of spinlock where we can. The only one I
left was the call to wake_up_all() in drm_vblank_handle_works() as
this seemed like it made more sense just living in that function
(which is all technically under lock)
* Move drm_vblank_work related functions into their own source files
* Add drm_vblank_internal.h so we can export some functions we don't
want drivers using, but that we do need to use in drm_vblank_work.c
* Add a bunch of documentation
Changes since v4:
* Get rid of kthread interfaces we tried adding and move all of the
locking into drm_vblank.c. For implementing drm_vblank_work_flush(),
we now use a wait_queue and sequence counters in order to
differentiate between multiple work item executions.
* Get rid of drm_vblank_work_cancel() - this would have been pretty
difficult to actually reimplement and it occurred to me that neither
nouveau or i915 are even planning to use this function. Since there's
also no async cancel function for most of the work interfaces in the
kernel, it seems a bit unnecessary anyway.
* Get rid of to_drm_vblank_work() since we now are also able to just
pass the struct drm_vblank_work to work item callbacks anyway
Changes since v3:
* Use our own spinlocks, don't integrate so tightly with kthread_works
Changes since v2:
* Use kthread_workers instead of reinventing the wheel.
Cc: Tejun Heo <tj@kernel.org>
Cc: dri-devel@lists.freedesktop.org
Cc: nouveau@lists.freedesktop.org
Co-developed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Lyude Paul <lyude@redhat.com>
Acked-by: Dave Airlie <airlied@gmail.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200627194657.156514-4-lyude@redhat.com
Nothing special here, except that this is the first time that we
automatically clean up something that's initialized with an explicit
driver call. But the cleanup was done at the very end of the release
sequence for all drivers, and that's still the case. At least without
more uses of drmm_ through explicit driver calls.
Also for this one we need drmm_kcalloc, so lets add those.
The motivation here is to allow us to remove the explicit calls to
drm_dev_fini() from all drivers.
v2: Sort includes (Laurent)
v3: Motivate the change in the commit message better (Sam)
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20200323144950.3018436-25-daniel.vetter@ffwll.ch
We might want to look into pushing this down into drm_mm_init, but
that would mean rolling out return codes to a pile of functions
unfortunately. So let's leave that for now.
Link: https://patchwork.freedesktop.org/patch/msgid/20200323144950.3018436-24-daniel.vetter@ffwll.ch
We have lots of these. And the cleanup code tends to be of dubious
quality. The biggest wrong pattern is that developers use devm_, which
ties the release action to the underlying struct device, whereas
all the userspace visible stuff attached to a drm_device can long
outlive that one (e.g. after a hotunplug while userspace has open
files and mmap'ed buffers). Give people what they want, but with more
correctness.
Mostly copied from devres.c, with types adjusted to fit drm_device and
a few simplifications - I didn't (yet) copy over everything. Since
the types don't match code sharing looked like a hopeless endeavour.
For now it's only super simplified, no groups, you can't remove
actions (but kfree exists, we'll need that soon). Plus all specific to
drm_device ofc, including the logging. Which I didn't bother to make
compile-time optional, since none of the other drm logging is compile
time optional either.
One tricky bit here is the chicken&egg between allocating your
drm_device structure and initiliazing it with drm_dev_init. For
perfect onion unwinding we'd need to have the action to kfree the
allocation registered before drm_dev_init registers any of its own
release handlers. But drm_dev_init doesn't know where exactly the
drm_device is emebedded into the overall structure, and by the time it
returns it'll all be too late. And forcing drivers to be able clean up
everything except the one kzalloc is silly.
Work around this by having a very special final_kfree pointer. This
also avoids troubles with the list head possibly disappearing from
underneath us when we release all resources attached to the
drm_device.
v2: Do all the kerneldoc at the end, to avoid lots of fairly pointless
shuffling while getting everything into shape.
v3: Add static to add/del_dr (Neil)
Move typo fix to the right patch (Neil)
v4: Enforce contract for drmm_add_final_kfree:
Use ksize() to check that the drm_device is indeed contained somewhere
in the final kfree(). Because we need that or the entire managed
release logic blows up in a pile of use-after-frees. Motivated by a
discussion with Laurent.
v5: Review from Laurent:
- %zu instead of casting size_t
- header guards
- sorting of includes
- guarding of data assignment if we didn't allocate it for a NULL
pointer
- delete spurious newline
- cast void* data parameter correctly in ->release call, no idea how
this even worked before
v6: Review from Sam
- Add the kerneldoc for the managed sub-struct back in, even if it
doesn't show up in the generated html somehow.
- Explain why __always_inline.
- Fix bisectability around the final kfree() in drm_dev_relase(). This
is just interim code which will disappear again.
- Some whitespace polish.
- Add debug output when drmm_add_action or drmm_kmalloc fail.
v7: My bisectability fix wasn't up to par as noticed by smatch.
v8: Remove unecessary {} around if else
v9: Use kstrdup_const, which requires kfree_const and introducing a free_dr()
helper (Thomas).
v10: kfree_const goes boom on the plain "kmalloc" assignment, somehow
we need to wrap that in kstrdup_const() too!! Also renumber revision
log, I somehow reset it midway thruh.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Thomas Zimmermann <tzimmermann@suse.de>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Neil Armstrong <narmstrong@baylibre.com
Cc: "Rafael J. Wysocki" <rafael@kernel.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20200324124540.3227396-1-daniel.vetter@ffwll.ch
As a result of commit 987d65d01356 (drm: debugfs: make
drm_debugfs_create_files() never fail) and changes to various debugfs
functions in drm/core and across various drivers, there is no need for
the drm_driver.debugfs_init() hook to have a return value. Therefore,
declare it as void.
This also includes refactoring all users of the .debugfs_init() hook to
return void across the subsystem.
v2: include changes to the hook and drivers that use it in one patch to
prevent driver breakage and enable individual successful compilation of
this change.
References: https://lists.freedesktop.org/archives/dri-devel/2020-February/257183.html
Signed-off-by: Wambui Karuga <wambui.karugax@gmail.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20200310133121.27913-18-wambui.karugax@gmail.com
As we are not using the sysfs infrastructure anymore, link to it is
removed. And global srm data and mutex to protect it are removed,
with required handling at revocation check function.
v2:
srm_data is dropped and few more comments are addressed.
v3:
ptr passing around is fixed with functional testing.
v4:
fix htmldoc [lkp]
Signed-off-by: Ramalingam C <ramalingam.c@intel.com>
Suggested-by: Sean Paul <seanpaul@chromium.org>
Reviewed-by: Sean Paul <sean@poorly.run>
Link: https://patchwork.freedesktop.org/patch/msgid/20200212102942.26568-2-ramalingam.c@intel.com
This catches the majority of drivers (unfortunately not if we take
users into account, because all the big drivers have at least a
lastclose hook).
With the prep patches out of the way all drm state is fully protected
and either prevents or can deal with the races from dropping the BKL
around open/close. The only thing left to audit are the various driver
hooks - by keeping the BKL around if any of them are set we have a
very simple cop-out!
Note that one of the biggest prep pieces to get here was making
dev->open_count atomic, which was done in
commit 7e13ad896484a0165a68197a2e64091ea28c9602
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Fri Jan 24 13:01:07 2020 +0000
drm: Avoid drm_global_mutex for simple inc/dec of dev->open_count
v2:
- Rebase and fix locking in drm_open() (Chris)
- Indentation fix in drm_release
- Typo fix in the commit message (Sam)
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Tested-by: Thomas Zimmermann <tzimmermann@suse.de>
Acked-by: Thomas Zimmermann <tzimmermann@suse.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20200204150146.2006481-6-daniel.vetter@ffwll.ch
Non-PCI systems should not build PCI helpers. Set up source code, header
file and Makefile accordingly.
Reviewed-by: Emil Velikov <emil.velikov@collabora.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20191203100406.9674-2-tzimmermann@suse.de
They're purely for internal use, not for drivers.
Cc: Noralf Trønnes <noralf@tronnes.org>
Cc: Christian König <christian.koenig@amd.com>
Reviewed-by: Eric Anholt <eric@anholt.net>
Link: https://patchwork.freedesktop.org/patch/msgid/20190614203615.12639-3-daniel.vetter@ffwll.ch
When calling debugfs functions, there is no need to ever check the
return value. The function can work or not, but the code logic should
never do something different based on this.
Because there is no need to check these functions, a number of local
functions can be made to return void to simplify things as nothing can
fail.
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Sean Paul <sean@poorly.run>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190613133439.GA6715@kroah.com
This picks up rc2 for us as well.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
git://anongit.freedesktop.org/drm/drm-intel into drm-next
Features:
- Engine discovery query (Tvrtko)
- Support for DP YCbCr4:2:0 outputs (Gwan-gyeong)
- HDCP revocation support, refactoring (Ramalingam)
- Remove DRM_AUTH from IOCTLs which also have DRM_RENDER_ALLOW (Christian König)
- Asynchronous display power disabling (Imre)
- Perma-pin uC firmware and re-enable global reset (Fernando)
- GTT remapping for display, for bigger fb size and stride (Ville)
- Enable pipe HDR mode on ICL if only HDR planes are used (Ville)
- Kconfig to tweak the busyspin durations for i915_wait_request (Chris)
- Allow multiple user handles to the same VM (Chris)
- GT/GEM runtime pm improvements using wakerefs (Chris)
- Gen 4&5 render context support (Chris)
- Allow userspace to clone contexts on creation (Chris)
- SINGLE_TIMELINE flags for context creation (Chris)
- Allow specification of parallel execbuf (Chris)
Refactoring:
- Header refactoring (Jani)
- Move GraphicsTechnology files under gt/ (Chris)
- Sideband code refactoring (Chris)
Fixes:
- ICL DSI state readout and checker fixes (Vandita)
- GLK DSI picture corruption fix (Stanislav)
- HDMI deep color fixes (Clinton, Aditya)
- Fix driver unbinding from a device in use (Janusz)
- Fix clock gating with pipe scaling (Radhakrishna)
- Disable broken FBC on GLK (Daniel Drake)
- Miscellaneous GuC fixes (Michal)
- Fix MG PHY DP register programming (Imre)
- Add missing combo PHY lane power setup (Imre)
- Workarounds for early ICL VBT issues (Imre)
- Fix fastset vs. pfit on/off on HSW EDP transcoder (Ville)
- Add readout and state check for pch_pfit.force_thru (Ville)
- Miscellaneous display fixes and refactoring (Ville)
- Display workaround fixes (Ville)
- Enable audio even if ELD is bogus (Ville)
- Fix use-after-free in reporting create.size (Chris)
- Sideband fixes to avoid BYT hard lockups (Chris)
- Workaround fixes and improvements (Chris)
Maintainer shortcomings:
- Failure to adequately describe and give credit for all changes (Jani)
Link: https://patchwork.freedesktop.org/patch/msgid/87sgt3n45z.fsf@intel.com
Do not require users of drm_internal.h to include other
files just to let it build
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190526173535.32701-5-sam@ravnborg.org
drm_fb_helper_is_bound() is used to check if DRM userspace is in control.
This is done by looking at the fb on the primary plane. By the time
fb-helper gets around to committing, it's possible that the facts have
changed.
Avoid this race by holding the drm_device->master_mutex lock while
committing. When DRM userspace does its first open, it will now wait
until fb-helper is done. The helper will stay away if there's a master.
Two igt tests fail with the new 'bail out if master' rule. Work around
this by relaxing this rule for drm_fb_helper_restore_fbdev_mode_unlocked()
until the tests have been fixed. Add todo entry for this.
Locking rule: Always take the fb-helper lock first.
v5: drm_fb_helper_restore_fbdev_mode_unlocked(): Use
restore_fbdev_mode_force()
v2:
- Remove drm_fb_helper_is_bound() (Daniel Vetter)
- No need to check fb_helper->dev->master in
drm_fb_helper_single_fb_probe(), restore_fbdev_mode() has the check.
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190506180139.6913-3-noralf@tronnes.org
Below Sparsh warnings are fixed.
Commit: drm: revocation check at drm subsystem
+drivers/gpu/drm/drm_hdcp.c:235:6: warning: symbol
'drm_hdcp_request_srm' was not declared. Should it be static?
+drivers/gpu/drm/drm_hdcp.c:27:3: warning: symbol 'srm_data' was not
+drivers/gpu/drm/drm_hdcp.c:317:5: warning: symbol 'drm_setup_hdcp_srm'
+drivers/gpu/drm/drm_hdcp.c:327:6: warning: symbol
'drm_teardown_hdcp_srm' was not declared. Should it be static?
cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reported-by: kbuild test robot <lkp@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190513133504.18612-1-ramalingam.c@intel.com
On every hdcp revocation check request SRM is read from fw file
/lib/firmware/display_hdcp_srm.bin
SRM table is parsed and stored at drm_hdcp.c, with functions exported
for the services for revocation check from drivers (which
implements the HDCP authentication)
This patch handles the HDCP1.4 and 2.2 versions of SRM table.
v2:
moved the uAPI to request_firmware_direct() [Daniel]
v3:
kdoc added. [Daniel]
srm_header unified and bit field definitions are removed. [Daniel]
locking improved. [Daniel]
vrl length violation is fixed. [Daniel]
v4:
s/__swab16/be16_to_cpu [Daniel]
be24_to_cpu is done through a global func [Daniel]
Unused variables are removed. [Daniel]
unchecked return values are dropped from static funcs [Daniel]
Acked-by: Satyeshwar Singh <satyeshwar.singh@intel.com>
Reviewed-by: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190507162745.25600-5-ramalingam.c@intel.com
If you don't want the legacy drivers, then lets get rid of all the
legacy codepaths from the core module.
This drop the size of drm.ko for me by about 10%.
380515 7422 4192 392129 5fbc1 ../../drm-next-build/drivers/gpu/drm/drm.ko
351736 7298 4192 363226 58ada ../../drm-next-build/drivers/gpu/drm/drm.ko
v2: drop drm_lock as well, fix some DMA->DRM typos
v3: avoid ifdefs in mainline code
v4: rework ioctl defs
v4.1: fix nouveau Kconfig
v2: individually allocate chain array, since chain node is free independently.
v3: all existing points must be already signaled before cpu perform signal operation,
so add check condition for that.
v4: remove v3 change and add checking to prevent out-of-order
v5: unify binary and timeline
Signed-off-by: Chunming Zhou <david1.zhou@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
Cc: Tobias Hector <Tobias.Hector@amd.com>
Cc: Jason Ekstrand <jason@jlekstrand.net>
Cc: Dave Airlie <airlied@redhat.com>
Reviewed-by: Lionel Landwerlin <lionel.g.landwerlin@intel.com>
Link: https://patchwork.freedesktop.org/patch/295792/?series=58813&rev=1
we need to import/export timeline point.
v2: unify to one transfer ioctl
Link: https://patchwork.freedesktop.org/patch/295790/?series=58813&rev=1
user mode can query timeline payload.
v2: check return value of copy_to_user
v3: handle querying entry by entry
v4: rebase on new chain container, simplify interface
v5: query last signaled timeline point, not last point.
v6: add unorder point check
Link: https://patchwork.freedesktop.org/patch/295784/?series=58813&rev=1
points array is one-to-one match with syncobjs array.
v2:
add seperate ioctl for timeline point wait, otherwise break uapi.
v3:
userspace can specify two kinds waits::
a. Wait for time point to be completed.
b. and wait for time point to become available
v4:
rebase
v5:
add comment for xxx_WAIT_AVAILABLE
v6: rebase and rework on new container
v7: drop _WAIT_COMPLETED, it is the default anyway
v8: correctly handle garbage collected fences
Link: https://patchwork.freedesktop.org/patch/295782/?series=58813&rev=1
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for 5.1:
UAPI Changes:
Cross-subsystem Changes:
- Turn dma-buf fence sequence numbers into 64 bit numbers
Core Changes:
- Move to a common helper for the DP MST hotplug for radeon, i915 and
amdgpu
- i2c improvements for drm_dp_mst
- Removal of drm_syncobj_cb
- Introduction of an helper to create and attach the TV margin properties
Driver Changes:
- Improve cache flushes for v3d
- Reflection support for vc4
- HDMI overscan support for vc4
- Add implicit fencing support for rockchip and sun4i
- Switch to generic fbdev emulation for virtio
[airlied: applied amdgpu merge fixup]
Link: https://patchwork.freedesktop.org/patch/msgid/20190107180333.amklwycudbsub3s5@flea
Move DRM_IF_VERSION out of drmP.h to allow users
to get rid of the drmP include.
Link: https://patchwork.freedesktop.org/patch/msgid/20181226210353.13993-1-sam@ravnborg.org
Pull drm updates from Dave Airlie:
"Core:
- shared fencing staging removal
- drop transactional atomic helpers and move helpers to new location
- DP/MST atomic cleanup
- Leasing cleanups and drop EXPORT_SYMBOL
- Convert drivers to atomic helpers and generic fbdev.
- removed deprecated obj_ref/unref in favour of get/put
- Improve dumb callback documentation
- MODESET_LOCK_BEGIN/END helpers
panels:
- CDTech panels, Banana Pi Panel, DLC1010GIG,
- Olimex LCD-O-LinuXino, Samsung S6D16D0, Truly NT35597 WQXGA,
- Himax HX8357D, simulated RTSM AEMv8.
- GPD Win2 panel
- AUO G101EVN010
vgem:
- render node support
ttm:
- move global init out of drivers
- fix LRU handling for ghost objects
- Support for simultaneous submissions to multiple engines
scheduler:
- timeout/fault handling changes to help GPU recovery
- helpers for hw with preemption support
i915:
- Scaler/Watermark fixes
- DP MST + powerwell fixes
- PSR fixes
- Break long get/put shmemfs pages
- Icelake fixes
- Icelake DSI video mode enablement
- Engine workaround improvements
amdgpu:
- freesync support
- GPU reset enabled on CI, VI, SOC15 dGPUs
- ABM support in DC
- KFD support for vega12/polaris12
- SDMA paging queue on vega
- More amdkfd code sharing
- DCC scanout on GFX9
- DC kerneldoc
- Updated SMU firmware for GFX8 chips
- XGMI PSP + hive reset support
- GPU reset
- DC trace support
- Powerplay updates for newer Polaris
- Cursor plane update fast path
- kfd dma-buf support
virtio-gpu:
- add EDID support
vmwgfx:
- pageflip with damage support
nouveau:
- Initial Turing TU104/TU106 modesetting support
msm:
- a2xx gpu support for apq8060 and imx5
- a2xx gpummu support
- mdp4 display support for apq8060
- DPU fixes and cleanups
- enhanced profiling support
- debug object naming interface
- get_iova/page pinning decoupling
tegra:
- Tegra194 host1x, VIC and display support enabled
- Audio over HDMI for Tegra186 and Tegra194
exynos:
- DMA/IOMMU refactoring
- plane alpha + blend mode support
- Color format fixes for mixer driver
rcar-du:
- R8A7744 and R8A77470 support
- R8A77965 LVDS support
imx:
- fbdev emulation fix
- multi-tiled scalling fixes
- SPDX identifiers
rockchip
- dw_hdmi support
- dw-mipi-dsi + dual dsi support
- mailbox read size fix
qxl:
- fix cursor pinning
vc4:
- YUV support (scaling + cursor)
v3d:
- enable TFU (Texture Formatting Unit)
mali-dp:
- add support for linear tiled formats
sun4i:
- Display Engine 3 support
- H6 DE3 mixer 0 support
- H6 display engine support
- dw-hdmi support
- H6 HDMI phy support
- implicit fence waiting
- BGRX8888 support
meson:
- Overlay plane support
- HDMI 1.4 4k modes
bridge:
- i2c fixes for sii902x"
* tag 'drm-next-2018-12-14' of git://anongit.freedesktop.org/drm/drm: (1403 commits)
drm/amd/display: Add fast path for cursor plane updates
drm/amdgpu: Enable GPU recovery by default for CI
drm/amd/display: Fix duplicating scaling/underscan connector state
drm/amd/display: Fix unintialized max_bpc state values
Revert "drm/amd/display: Set RMX_ASPECT as default"
drm/amdgpu: Fix stub function name
drm/msm/dpu: Fix clock issue after bind failure
drm/msm/dpu: Clean up dpu_media_info.h static inline functions
drm/msm/dpu: Further cleanups for static inline functions
drm/msm/dpu: Cleanup the debugfs functions
drm/msm/dpu: Remove dpu_irq and unused functions
drm/msm: Make irq_postinstall optional
drm/msm/dpu: Cleanup callers of dpu_hw_blk_init
drm/msm/dpu: Remove unused functions
drm/msm/dpu: Remove dpu_crtc_is_enabled()
drm/msm/dpu: Remove dpu_crtc_get_mixer_height
drm/msm/dpu: Remove dpu_dbg
drm/msm: dpu: Remove crtc_lock
drm/msm: dpu: Remove vblank_requested flag from dpu_crtc
drm/msm: dpu: Separate crtc assignment from vblank enable
Sending the exact same hotplug event is not great uapi. Luckily the
only already merged implementation of leases (in the -modesetting
driver) doesn't care about what kind of uevent it gets, and
unconditionally processes both hotplug and lease changes. So we can
still adjust the uapi here.
But e.g. weston tries to filter stuff, and I guess others might want
to do that too. Try to make that possible. Cc: stable since it's uapi
adjustement that we want to roll out everywhere.
Michel Dänzer mentioned on irc that -amdgpu also has lease support. It
has the same code flow as -modesetting though, so we can still go
ahead.
v2: Mention -amdgpu (Michel)
Cc: Keith Packard <keithp@keithp.com>
Cc: stable@vger.kernel.org
Reviewed-by: Keith Packard <keithp@keithp.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181129094226.30591-1-daniel.vetter@ffwll.ch
Ever since
commit cb6458f97b53d7f73043206c18014b3ca63ac345
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Thu Aug 8 15:41:34 2013 +0200
drm: remove procfs code, take 2
Having the code shared between procfs and debugfs in the separate
drm_info.c file stopped making sense. Merge them.
Noticed because Lyude asked some questions on irc about why we even
have drm_info_node and I remember this old story.
Cc: Lyude Paul <lyude@redhat.com>
Reviewed-by: Lyude Paul <lyude@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181121213510.31260-1-daniel.vetter@ffwll.ch
Only needed minimal changes in drm_internal.h (for the drm_ioctl_t
type and a few forward declarations), plus a few missing includes in
drm_connector.c.
Yay, the last stage of the drm header cleanup can finally commence!
v2: Compiles now, with drm/drm_util.h extracted.
v3: Fix up commit message (Sam Ravnborg)
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20180905135711.28370-2-daniel.vetter@ffwll.ch
Rather than doing drm_file allocation/destruction right in the fops, lets
provide separate helpers. This decouples drm_file management from the
still-mandatory drm-fops. It prepares for use of drm_file without the
fops, both by possible separate fops implementations and APIs (not that I
am aware of any such plans), and more importantly from in-kernel use where
no real file is available.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180618141739.48151-2-noralf@tronnes.org
Bake in the conflict between the drm_print.h extraction and the
addition of DRM_DEBUG_LEASES since we lost it a few too many times.
Also fix a new use of drm_plane_helper_check_state in msm to follow
Ville's conversion in
commit a01cb8ba3f6282934cff65e89ab36b18b14cbe27
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Date: Wed Nov 1 22:16:19 2017 +0200
drm: Move drm_plane_helper_check_state() into drm_atomic_helper.c
Acked-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Add debugfs file that dumps info about the framebuffers and its planes.
Also dump info about any connected gem object(s).
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171107191348.17555-5-noralf@tronnes.org
These provide crtc-id based functions instead of pipe-number, while
also offering higher resolution time (ns) and wider frame count (64)
as required by the Vulkan API.
v2:
* Check for DRIVER_MODESET in new crtc-based vblank ioctls
Failing to check this will oops the driver.
* Ensure vblank interupt is running in crtc_get_sequence ioctl
The sequence and timing values are not correct while the
interrupt is off, so make sure it's running before asking for
them.
* Short-circuit get_sequence if the counter is enabled and accurate
Steal the idea from the code in wait_vblank to avoid the
expense of drm_vblank_get/put
* Return active state of crtc in crtc_get_sequence ioctl
Might be useful for applications that aren't in charge of
modesetting?
* Use drm_crtc_vblank_get/put in new crtc-based vblank sequence ioctls
Daniel Vetter prefers these over the old drm_vblank_put/get
APIs.
* Return s64 ns instead of u64 in new sequence event
Suggested-by: Daniel Vetter <daniel@ffwll.ch>
Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
v3:
* Removed FIRST_PIXEL_OUT_FLAG
* Document that the timestamp in the query and event are
that of the first pixel leaving the display engine for
the display (using the same wording as the Vulkan spec).
Suggested-by: Michel Dänzer <michel@daenzer.net>
Acked-by: Dave Airlie <airlied@redhat.com>
[airlied: left->leaves (Michel)]
Signed-off-by: Keith Packard <keithp@keithp.com>
There is a risk of overflowing vblank timestamps in 2038 or 2106 if
someone sets the drm_timestamp_monotonic module parameter to zero.
I found no indication of anyone ever setting the parameter, or
complaining about the default being wrong, after it was introduced
as a way to handle backwards-compatibility with linux prior to
c61eef726a78 ("drm: add support for monotonic vblank timestamps"),
so it's probably safer to just remove the parameter completely
and only allowing the default behavior.
Acked-by: Daniel Stone <daniels@collabora.com>
This IOCTL provides a mechanism for userspace to trigger a sync object
directly. There are other ways that userspace can trigger a syncobj
such as submitting a dummy batch somewhere or hanging on to a triggered
sync_file and doing an import. This just provides an easy way to
manually trigger the sync object without weird hacks.
The motivation for this IOCTL is Vulkan fences. Vulkan lets you create
a fence already in the signaled state so that you can wait on it
immediatly without stalling. We could also handle this with a new
create flag to ask the driver to create a syncobj that is already
signaled but the IOCTL seemed a bit cleaner and more generic.
v2:
- Take an array of sync objects (Dave Airlie)
v3:
- Throw -EINVAL if pad != 0
Signed-off-by: Jason Ekstrand <jason@jlekstrand.net>
This just resets the dma_fence to NULL so it looks like it's never been
signaled. This will be useful once we add the new wait API for allowing
wait on "submit and signal" behavior.
v2:
v3:
Reviewed-by: Christian König <christian.koenig@amd.com> (v1)
This interface will allow sync object to be used to back
Vulkan fences. This API is pretty much the vulkan fence waiting
API, and I've ported the code from amdgpu.
v2: accept relative timeout, pass remaining time back
to userspace.
v3: return to absolute timeouts.
v4: absolute zero = poll,
rewrite any/all code to have same operation for arrays
return -EINVAL for 0 fences.
v4.1: fixup fences allocation check, use u64_to_user_ptr
v5: move to sec/nsec, and use timespec64 for calcs.
v6: use -ETIME and drop the out status flag. (-ETIME
is suggested by ickle, I can feel a shed painting)
v7: talked to Daniel/Arnd, use ktime and ns everywhere.
v8: be more careful in the timeout calculations
use uint32_t for counter variables so we don't overflow
graciously handle -ENOINT being returned from dma_fence_wait_timeout
Reviewed-by: Jason Ekstrand <jason@jlekstrand.net>
Acked-by: Christian König <christian.koenig@amd.com>
I need this to be able to apply the deferred fbdev setup patches, I
need the relevant prep work that landed through the drm-intel tree.
Also squash in conflict fixup from Laurent Pinchart.
"This is the main pull request for the drm, I think I've got one later
driver pull for mediatek SoC driver, I'm undecided on if it needs to
go to you yet.
Otherwise summary below:
Core drm:
- Atomic add driver private objects
- Deprecate preclose hook in modern drivers
- MST bandwidth tracking
- Use kvmalloc in more places
- Add mode_valid hook for crtc/encoder/bridge
- Reduce sync_file construction time
- Documentation updates
- New DRM synchronisation object support
New drivers:
- pl111 - pl111 CLCD display controller
Panel:
- Innolux P079ZCA panel driver
- Add NL12880B20-05, NL192108AC18-02D, P320HVN03 panels
- panel-samsung-s6e3ha2: Add s6e3hf2 panel support
i915:
- SKL+ watermark fixes
- G4x/G33 reset improvements
- DP AUX backlight improvements
- Buffer based GuC/host communication
- New getparam for (sub)slice infomation
- Cannonlake and Coffeelake initial patches
- Execbuf optimisations
radeon/amdgpu:
- Lots of Vega10 bug fixes
- Preliminary raven support
- KIQ support for compute rings
- MEC queue management rework
- DCE6 Audio support
- SR-IOV improvements
- Better radeon/amdgpu selection support
nouveau:
- HDMI stereoscopic support
- Display code rework for >= GM20x GPUs
msm:
- GEM rework for fine-grained locking
- Per-process pagetable work
- HDMI fixes for Snapdragon 820.
vc4:
- Remove 256MB CMA limit from vc4
- Add out-fence support
- Add support for cygnus
- Get/set tiling ioctls support
- Add T-format tiling support for scanout
zte:
- add VGA support.
etnaviv:
- Thermal throttle support for newer GPUs
- Restore userspace buffer cache performance
- dma-buf sync fix
stm:
- add stm32f429 display support
exynos:
- Rework vblank handling
- Fixup sw-trigger code
sun4i:
- V3s display engine support
- HDMI support for older SoCs
- Preliminary work on dual-pipeline SoCs.
rcar-du:
- VSP work
imx-drm:
- Remove counter load enable from PRE
- Double read/write reduction flag support
tegra:
- Documentation for the host1x and drm driver.
- Lots of staging ioctl fixes due to grate project work.
omapdrm:
- dma-buf fence support
- TILER rotation fixes"
* tag 'drm-for-v4.13' of git://people.freedesktop.org/~airlied/linux: (1270 commits)
drm: Remove unused drm_file parameter to drm_syncobj_replace_fence()
drm/amd/powerplay: fix bug fail to remove sysfs when rmmod amdgpu.
amdgpu: Set cik/si_support to 1 by default if radeon isn't built
drm/amdgpu/gfx9: fix driver reload with KIQ
drm/amdgpu/gfx8: fix driver reload with KIQ
drm/amdgpu: Don't call amd_powerplay_destroy() if we don't have powerplay
drm/ttm: Fix use-after-free in ttm_bo_clean_mm
drm/amd/amdgpu: move get memory type function from early init to sw init
drm/amdgpu/cgs: always set reference clock in mode_info
drm/amdgpu: fix vblank_time when displays are off
drm/amd/powerplay: power value format change for Vega10
drm/amdgpu/gfx9: support the amdgpu.disable_cu option
drm/amd/powerplay: change PPSMC_MSG_GetCurrPkgPwr for Vega10
drm/amdgpu: Make amdgpu_cs_parser_init static (v2)
drm/amdgpu/cs: fix a typo in a comment
drm/amdgpu: Fix the exported always on CU bitmap
drm/amdgpu/gfx9: gfx_v9_0_enable_gfx_static_mg_power_gating() can be static
drm/amdgpu/psp: upper_32_bits/lower_32_bits for address setup
drm/amd/powerplay/cz: print message if smc message fails
drm/amdgpu: fix typo in amdgpu_debugfs_test_ib_init
There's no reason for drivers to call this, and all the ones I've
removed looked very fishy:
- Proper quiescenting of the vblank machinery should be done by
calling drm_crtc_vblank_off(), which is best done by shutting down
the entire display engine with drm_atomic_helper_shutdown.
- Releasing of allocated memory is done by the core already, it calls
drm_vblank_cleanup as a fallback.
- drm_vblank_cleanup also has checks for drivers which forget to clean
up vblank interrupts.
This essentially reverts
commit e77cef9c2d87db835ad9d70cde4a9b00b0ca2262
Author: Jerome Glisse <jglisse@redhat.com>
Date: Thu Jan 7 15:39:13 2010 +0100
drm: Avoid calling vblank function is vblank wasn't initialized
which was done to fix a bug in radeon code with msi interrupts:
commit 003e69f9862bcda89a75c27750efdbc17ac02945
Date: Thu Jan 7 15:39:14 2010 +0100
drm/radeon/kms: Don't try to enable IRQ if we have no handler installed
Afaict from digging around in old code, this was needed to avoid
blowing up in the ums fallback, and has stopped serving it's purpose
long ago - if irq init fails, the driver fails to load, and there's
really no way to blow up anymore.
Long story short, this was most likely a small ums compat/fallback
hack that became a thing of it's own and got cargo-cult duplicated all
over the drm codebase for essentially no gain at all.
v2: Mention that for drivers with a ->release callback cleanup is
handled by drm_dev_fini() (Thierry).
Cc: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170626161949.25629-2-daniel.vetter@ffwll.ch
Required for Daniel's drm_vblank_cleanup cleanup
The only special-case is pci devices, and we can easily handle this in
the core. Do so and drop a pile of boilerplate from drivers.
Link: http://patchwork.freedesktop.org/patch/msgid/20170524145212.27837-5-daniel.vetter@ffwll.ch
I alwasy get confused about drm_wait_vblank for a split second until I
realize it's the ioctl handler. Unconfuse me, and do it for the legacy
modeset vblank control ioctl too.
While at it also noticed that I misplaced the irq ioctl handler in the
internal header file.
Link: http://patchwork.freedesktop.org/patch/msgid/20170524145212.27837-12-daniel.vetter@ffwll.ch
Sync objects are new toplevel drm object, that contain a
pointer to a fence. This fence can be updated via command
submission ioctls via drivers.
There is also a generic wait obj API modelled on the vulkan
wait API (with code modelled on some amdgpu code).
These objects can be converted to an opaque fd that can be
passes between processes.
v2: rename reference/unreference to put/get (Chris)
fix leaked reference (David Zhou)
drop mutex in favour of cmpxchg (Chris)
v3: cleanups from danvet, rebase on drm_fops rename
check fd_flags is 0 in ioctls.
v4: export find/free, change replace fence to take a
syncobj. In order to support lookup first, replace
later semantics which seem in the end to be cleaner.
drm_irq.c contains both the irq helper library (optional) and the
vblank support (optional, but part of the modeset uapi, and doesn't
require the use of the irq helpers at all.
Split this up for more clarity of the scope of the individual bits.
v2: Move misplaced hunks to this patch (Stefan).
Cc: Stefan Agner <stefan@agner.ch>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20170531092146.12528-1-daniel.vetter@ffwll.ch
