path: root/drivers/gpu/drm/drm_context.c
2015-07-02drm: Convert drm_legacy_ctxbitmap_init to void return typeDaniel Vetter
It can't fail really. Also remove the redundant kms check Peter added. Cc: Peter Antoine <peter.antoine@intel.com> Reviewed-by: Peter Antoine <peter.antoine@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2015-07-02drm: Turn off Legacy Context FunctionsPeter Antoine
The context functions are not used by the i915 driver and should not be used by modeset drivers. These driver functions contain several bugs and security holes. This change makes these functions optional can be turned on by a setting, they are turned off by default for modeset driver with the exception of the nouvea driver that may require them with an old version of libdrm. The previous attempt was commit 7c510133d93dd6f15ca040733ba7b2891ed61fd1 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Thu Aug 8 15:41:21 2013 +0200 drm: mark context support as a legacy subsystem but this had to be reverted commit c21eb21cb50d58e7cbdcb8b9e7ff68b85cfa5095 Author: Dave Airlie <airlied@redhat.com> Date: Fri Sep 20 08:32:59 2013 +1000 Revert "drm: mark context support as a legacy subsystem" v2: remove returns from void function, and formatting (Daniel Vetter) v3: - s/Nova/nouveau/ in the commit message, and add references to the previous attempts - drop the part touching the drm hw lock, that should be a separate patch. Signed-off-by: Peter Antoine <peter.antoine@intel.com> (v2) Cc: Peter Antoine <peter.antoine@intel.com> (v2) Reviewed-by: Peter Antoine <peter.antoine@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-08-05drm: mark drm_context support as legacyDavid Herrmann
This renames all drm-context helpers to drm_legacy_*() and moves the internal definitions into the new drm_legacy.h header. This header is local to DRM-core and drivers shouldn't access it. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
2014-08-05drm: extract legacy ctxbitmap flushingDavid Herrmann
The ctxbitmap code is only used by legacy drivers so lets try to keep it as separated as possible. Furthermore, the locking is non-obvious and kinda weird with ctxlist_mutex *and* struct_mutex. Keeping all ctxbitmap access in one file is much easier to review and makes drm_release() more readable. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
2013-10-09drm: Kill ctx_count from struct drm_deviceVille Syrjälä
The only user of ctx_count is the via driver, and we can replace that use with list_is_singular(). Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-09-20Revert "drm: mark context support as a legacy subsystem"Dave Airlie
This reverts commit 7c510133d93dd6f15ca040733ba7b2891ed61fd1. Well looks like not enough digging was done, libdrm_nouveau before 2.4.33 used contexts, 292da616fe1f936ca78a3fa8e1b1b19883e343b6 nouveau: pull in major libdrm rewrite got rid of them, Reported-by: Paul Zimmerman <Paul.Zimmerman@synopsys.com> Reported-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm: mark context support as a legacy subsystemDaniel Vetter
So after a lot of digging around in git histories it looks like this has only ever be used by dri1 render clients. Hence we can fully disable the entire thing for modesetting drivers and so greatly reduce the attack surface for potential exploits (or at least tools like trinity ...). Also add the drm_legacy prefix for functions which are called from common code. To further reduce the impact on common code also extract all the ctx release handling into a function (instead of only releasing individual handles) and make ctxbitmap_cleanup return void - it can never fail. Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-07-23drm: remove dev->last_switchDaniel Vetter
Only ever assigned in the context code for real, with no readers anywhere. Remove it. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@gmail.com>
2013-07-23drm: kill dev->context_waitDaniel Vetter
No one ever waits on this waitqueue, so the wake_up call is wasted. Remove it all. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@gmail.com>
2013-07-23drm: remove drm_modctx ioctl and use drm_noop insteadDaniel Vetter
It doesn't do anything, so kill the code. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@gmail.com>
2013-02-27drm: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. * drm_ctxbitmap_next() error handling in drm_addctx() seems broken. drm_ctxbitmap_next() return -errno on failure not -1. [artem.savkov@gmail.com: missing idr_preload_end in drm_gem_flink_ioctl] [jslaby@suse.cz: fix drm_gem_flink_ioctl() return value] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Airlie <airlied@linux.ie> Signed-off-by: Artem Savkov <artem.savkov@gmail.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27drm: don't use idr_remove_all()Tejun Heo
idr_destroy() can destroy idr by itself and idr_remove_all() is being deprecated. Drop its usage. * drm_ctxbitmap_cleanup() was calling idr_remove_all() but forgetting idr_destroy() thus leaking all buffered free idr_layers. Replace it with idr_destroy(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Airlie <airlied@linux.ie> Cc: Inki Dae <inki.dae@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Seung-Woo Kim <sw0312.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/David Howells
Convert #include "..." to #include <path/...> in drivers/gpu/. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-04-24drm: Unify and fix idr error handlingVille Syrjälä
The error handling code w.r.t. idr usage looks inconsistent. In the case of drm_mode_object_get() and drm_ctxbitmap_next() the error handling is also incomplete. Unify the code to follow the same pattern always. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-05drm: make DRM_UNLOCKED ioctls with their own mutexIlija Hadzic
drm_getclient, drm_getstats and drm_getmap (with a few minor adjustments) do not need global mutex, so fix that and make the said ioctls DRM_UNLOCKED. Details: drm_getclient: the only thing that should be protected here is dev->filelist and that is already protected everywhere with dev->struct_mutex. drm_getstats: there is no need for any mutex here because the loop runs through quasi-static (set at load time only) data, and the actual count access is done with atomic_read() drm_getmap already uses dev->struct_mutex to protect dev->maplist, which also used to protect the same structure everywhere else except at three places: * drm_getsarea, which doesn't grab *any* mutex before touching dev->maplist (so no drm_global_mutex doesn't help here either; different issue for a different patch). However, drivers seem to call it only at initialization time so it probably doesn't matter * drm_master_destroy, which is called from drm_master_put, which in turn is protected with dev->struct_mutex everywhere else in drm module, so we are good here too. * drm_getsareactx, which releases the dev->struct_mutex too early, but this patch includes the fix for that. v2: * incorporate comments received from Daniel Vetter * include the (long) explanation above to make it clear what we are doing (and why), also at Daniel Vetter's request * tighten up mutex grab/release locations to only encompass real critical sections, rather than some random code around them Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill context_ctor callbackDaniel Vetter
It's not used by any driver. The destructor callback is unfortunately used by the via driver in a rather convoluted piece of code used to reimplement something resembling broken futexes. I didn't dare to touch this code. But at least kill the needless NULL assignemt in the sis driver. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-18drm: Remove memory debugging infrastructure.Eric Anholt
It hasn't been used in ages, and having the user tell your how much memory is being freed at free time is a recipe for disaster even if it was ever used. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-03-13drm: Split drm_map and drm_local_mapBenjamin Herrenschmidt
Once upon a time, the DRM made the distinction between the drm_map data structure exchanged with user space and the drm_local_map used in the kernel. For some reasons, while the BSD port still has that "feature", the linux part abused drm_map for kernel internal usage as the local map only existed as a typedef of the struct drm_map. This patch fixes it by declaring struct drm_local_map separately (though its content is currently identical to the userspace variant), and changing the kernel code to only use that, except when it's a user<->kernel interface (ie. ioctl). This allows subsequent changes to the in-kernel format I've also replaced the use of drm_local_map_t with struct drm_local_map in a couple of places. Mostly by accident but they are the same (the former is a typedef of the later) and I have some remote plans and half finished patch to completely kill the drm_local_map_t typedef so I left those bits in. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-12-29drm: move to kref per-master structures.Dave Airlie
This is step one towards having multiple masters sharing a drm device in order to get fast-user-switching to work. It splits out the information associated with the drm master into a separate kref counted structure, and allocates this when a master opens the device node. It also allows the current master to abdicate (say while VT switched), and a new master to take over the hardware. It moves the Intel and radeon drivers to using the sarea from within the new master structures. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
