[ Upstream commit d82e2c249c8ffaec20fa618611ea2ab4dcfd4d01 ]
Crash:
BUG: unable to handle page fault for address: 00000000000010e1
RIP: 0010:vega10_power_gate_vce+0x26/0x50 [amdgpu]
Call Trace:
pp_set_powergating_by_smu+0x16a/0x2b0 [amdgpu]
amdgpu_dpm_set_powergating_by_smu+0x92/0xf0 [amdgpu]
amdgpu_dpm_enable_vce+0x2e/0xc0 [amdgpu]
vce_v4_0_hw_fini+0x95/0xa0 [amdgpu]
amdgpu_device_fini_hw+0x232/0x30d [amdgpu]
amdgpu_driver_unload_kms+0x5c/0x80 [amdgpu]
amdgpu_pci_remove+0x27/0x40 [amdgpu]
pci_device_remove+0x3e/0xb0
device_release_driver_internal+0x103/0x1d0
device_release_driver+0x12/0x20
pci_stop_bus_device+0x79/0xa0
pci_stop_and_remove_bus_device_locked+0x1b/0x30
remove_store+0x7b/0x90
dev_attr_store+0x17/0x30
sysfs_kf_write+0x4b/0x60
kernfs_fop_write_iter+0x151/0x1e0
Why:
VCE/UVD had dependency on SMC block for their suspend but
SMC block is the first to do HW fini due to some constraints
How:
Since the original patch was dealing with suspend issues
move the SMC block dependency back into suspend hooks as
was done in V1 of the original patches.
Keep flushing idle work both in suspend and HW fini seuqnces
since it's essential in both cases.
Fixes: 859e4659273f1d ("drm/amdgpu: add missing cleanups for more ASICs on UVD/VCE suspend")
Fixes: bf756fb833cbe8 ("drm/amdgpu: add missing cleanups for Polaris12 UVD/VCE on suspend")
Signed-off-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Perform proper cleanups on UVD/VCE suspend: powergate enablement,
clockgating enablement and dpm disablement. This can fix some hangs
observed on suspending when UVD/VCE still using(e.g. issue
"pm-suspend" when video is still playing).
Signed-off-by: Evan Quan <evan.quan@amd.com>
Signed-off-by: xinhui pan <xinhui.pan@amd.com>
Reviewed-by: Guchun Chen <guchun.chen@amd.com>
Allow separate ring to share the same scheduler score.
No functional change.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-and-Tested-by: Leo Liu <leo.liu@amd.com>
Generate HW IP's sched_list in amdgpu_ring_init() instead of
amdgpu_ctx.c. This makes amdgpu_ctx_init_compute_sched(),
ring.has_high_prio and amdgpu_ctx_init_sched() unnecessary.
This patch also stores sched_list for all HW IPs in one big
array in struct amdgpu_device which makes amdgpu_ctx_init_entity()
much more leaner.
v2:
fix a coding style issue
do not use drm hw_ip const to populate amdgpu_ring_type enum
v3:
remove ctx reference and move sched array and num_sched to a struct
use num_scheds to detect uninitialized scheduler list
v4:
use array_index_nospec for user space controlled variables
fix possible checkpatch.pl warnings
Signed-off-by: Nirmoy Das <nirmoy.das@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Better clean that up before some automation starts to complain about it
Acked-by: Christian König <christian.koenig@amd.com>
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for v5.3:
UAPI Changes:
Cross-subsystem Changes:
- Add code to signal all dma-fences when freed with pending signals.
- Annotate reservation object access in CONFIG_DEBUG_MUTEXES
Core Changes:
- Assorted documentation fixes.
- Use irqsave/restore spinlock to add crc entry.
- Move code around to drm_client, for internal modeset clients.
- Make drm_crtc.h and drm_debugfs.h self-contained.
- Remove drm_fb_helper_connector.
- Add bootsplash to todo.
- Fix lock ordering in pan_display_legacy.
- Support pinning buffers to current location in gem-vram.
- Remove the now unused locking functions from gem-vram.
- Remove the now unused kmap-object argument from vram helpers.
- Stop checking return value of debugfs_create.
- Add atomic encoder enable/disable helpers.
- pass drm_atomic_state to atomic connector check.
- Add atomic support for bridge enable/disable.
- Add self refresh helpers to core.
Driver Changes:
- Add extra delay to make MTP SDM845 work.
- Small fixes to virtio, vkms, sii902x, sii9234, ast, mcde, analogix, rockchip.
- Add zpos and ?BGR8888 support to meson.
- More removals of drm_os_linux and drmP headers for amd, radeon, sti, r128, r128, savage, sis.
- Allow synopsis to unwedge the i2c hdmi bus.
- Add orientation quirks for GPD panels.
- Edid cleanups and fixing handling for edid < 1.2.
- Add runtime pm to stm.
- Handle s/r in dw-hdmi.
- Add hooks for power on/off to dsi for stm.
- Remove virtio dirty tracking code, done in drm core.
- Rework BO handling in ast and mgag200.
Tiny conflict in drivers/gpu/drm/amd/display/dc/clk_mgr/clk_mgr.c,
needed #include <linux/slab.h> to make it compile.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/0e01de30-9797-853c-732f-4a5bd6e61445@linux.intel.com
With this commit drm/amd/ has no longer any uses of
the deprecated drmP.h header file.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Cc: "Christian König" <christian.koenig@amd.com>
Cc: "David (ChunMing) Zhou" <David1.Zhou@amd.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190609220757.10862-11-sam@ravnborg.org
There is no user fence support for VCE
Signed-off-by: Leo Liu <leo.liu@amd.com>
Replace the last bool type parameter with a general flags parameter,
to make the last parameter be able to contain more information.
v2: drop setting need_ctx_switch = false
Reviewed-by: Hawking Zhang <Hawking.Zhang@amd.com>
Signed-off-by: Jack Xiao <Jack.Xiao@amd.com>
Remove gca/gfx_8_0_d.h which is included more than once
Reviewed-by: Junwei Zhang <Jerry.Zhang@amd.com>
Signed-off-by: Brajeswar Ghosh <brajeswar.linux@gmail.com>
use the point of struct amdgpu_job as the function
argument instand of vmid, so the other members of
struct amdgpu_job can be visit in emit_ib function.
v2: add a wrapper for getting the VMID
add the job before the ib on the parameter list.
v3: refine the wrapper name
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
Start using drm_gpu_scheduler.ready isntead.
v3:
Add helper function to run ring test and set
sched.ready flag status accordingly, clean explicit
sched.ready sets from the IP specific files.
v4: Add kerneldoc and rebase.
Everything that isn't related to the IH ring.
Reviewed-by: Huang Rui <ray.huang@amd.com>
Entity init should after ring init, as the entity's sched_rq's initialization
is in ring init.
SWDEV-161495
Signed-off-by: Emily Deng <Emily.Deng@amd.com>
v2: Rebase
v3: Use defines for CP_SQ and CP_ECC_ERROR interrupts.
Set the me instance in early init and use that rather than
calculating the instance based on the ring pointer.
Reviewed-by: James Zhu <James.Zhu@amd.com>
Reviewed-by: Leo Liu <leo.liu@amd.com>
The phys and vm versions had the values swapped.
1. fix set vce clocks failed on Cz/St
which lead 1s delay when boot up.
2. remove the workaround in vce_v3_0.c
Acked-by: Shirish S <shirish.s@amd.com>
Cc: stable@vger.kernel.org
Stuffing the PASID mapping into the VM flush isn't flexible enough since
the PASID mapping changes not as often as we need a VM flush.
v2: add missing use of gmc_v7_0_emit_pasid_mapping
Reviewed-by: Felix Kuehling <Felix.Kuehling@amd.com>
rd the pasid from the VM code to the emit_vm_flush function and update
all implementations with the new parameter.
Reviewed-by: Chunming Zhou <david1.zhou@amd.com>
sed -i "s/vm_id/vmid/g" drivers/gpu/drm/amd/amdgpu/*.c
sed -i "s/vm_id/vmid/g" drivers/gpu/drm/amd/amdgpu/*.h
Fixes init failures on Polaris cards with harvested
VCE blocks.
We need program ring buffer on instance 1 register space domain,
when only if instance 1 available, with two instances or instance 0,
and we need only program instance 0 regsiter space domain for ring.
the ixcurrent_pg_status addr is different between APU and DGPU.
fix logic error in hw_fini and
set_clockgating_state functions.
The contextID field (formerly known as src_data) of the IH
vector stores client specific information about an interrupt.
It was expanded from 32 bits to 128 on newer asics. Expand the
src_id field to handle this.
Reviewed-by: Harry Wentland <harry.wentland@amd.com>
Newer asics have a two levels of irq ids now:
client id - the IP
src id - the interrupt src within the IP
v2: integrated Christian's comments.
v3: fix rebase fail in SI and CIK
Signed-off-by: Ken Wang <Qingqing.Wang@amd.com>
Reviewed-by: Ken Wang <Qingqing.Wang@amd.com>
Newer asics need 64 bit wptrs. If the wptr is now
smaller than the rptr that doesn't indicate a wrap-around
anymore.
v2: integrate Christian's comments.
Add a bit needed during initialization into the driver, where it is supposed
to be. Currently, this is happening in the VCE firmware, and although
functional, this is the correct place to perform this initialization.
Signed-off-by: Alan Harrison <Alan.Harrison@amd.com>
1. not start vce3.0 when hw_init
2. stop vce3.0 when vce idle.
3. pg mask used to ctrl power down/up vce.
4. change cg pg sequence in powerplay.
1. disable vce cg when vce hw initialize.
2. initizlize vce clock to 10KHz fo dgpu,
so no need to set bypass clock to vce.
Change-Id: I934c2c4820cc95c1bfa2fa41ff0f40a0d3cd1c40
Signed-off-by: Huang Rui <ray.huang@amd.com>
need to clear bit31-29 in GRBM_GFX_INDEX,
then the program can be valid.
Set the proper bits for clockgating setup.
v2: agd: squash in various fixes
v3: agd: squash in:
drm/amdgpu: remove unnecessary smc sk firmware for polaris12
Signed-off-by: Junwei Zhang <Jerry.Zhang@amd.com>
VCE clocks are set to be disabled, when not in use.
Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com>
Linux 4.9-rc4
This is needed for nouveau development.
Fix the problems with killing VCE sessions in VM mode.
Reviewed-and-Tested by: Leo Liu <leo.liu@amd.com>
This makes it easier to replace specific IP blocks on
asics for handling virtual_dce, DAL, etc. and for building
IP lists for hw or tables. This also stored the status
information in the same structure.
v2: split out spelling fix into a separate patch
add a function to add IPs to the list
They are constant as well.
v2: update uvd and vce phys ring structures as well
It's constant, so it doesn't make to much sense to keep it
with the variable data.
v2: update vce and uvd phys mode ring structures as well
I should have suggested that on the initial patchset. This saves us a
few CPU cycles during CS and a bunch of loc.
sed -i "/\.parse_cs = NULL,/d" drivers/gpu/drm/amd/amdgpu/*.c
That's just a leftover from radeon.
Older firmware versions don't support 3 rings.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=98016
v2: use define for fw version
IP types are not an index. Each asic may have number and
type of IPs. Properly check the the type rather than
using the type id as an index.
v2: fix all the IPs to not use IP type as an idx as well.
