The parameters were renamed.
Signed-off-by: Yifan Zhang <yifan1.zhang@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Change mgr->available into mgr->used (invert the value).
Makes more sense to do it this way since we don't need the spinlock any
more to double check the handling.
v3 (chk): separated from the TEMPOARAY FLAG change.
Signed-off-by: Lang Yu <Lang.Yu@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
Acked-by: Nirmoy Das <nirmoy.das@amd.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210622162339.761651-4-andrey.grodzovsky@amd.com
Currently, we have a limitted GTT memory size and need a bounce buffer
when doing buffer migration between VRAM and SYSTEM domain.
The problem is under GTT memory pressure we can't do buffer migration
between VRAM and SYSTEM domain. But in some cases we really need that.
Eespecially when validating a VRAM backing store BO which resides in
SYSTEM domain.
v2: still account temporary GTT allocations
v3 (chk): revert to the simpler change for now
Link: https://patchwork.freedesktop.org/patch/msgid/20210622162339.761651-2-andrey.grodzovsky@amd.com
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for 5.14:
UAPI Changes:
* drm/panfrost: Export AFBC_FEATURES register to userspace
Cross-subsystem Changes:
* dma-buf: Fix debug printing; Rename dma_resv_*() functions + changes
in callers; Cleanups
Core Changes:
* Add prefetching memcpy for WC
* Avoid circular dependency on CONFIG_FB
* Cleanups
* Documentation fixes throughout DRM
* ttm: Make struct ttm_resource the base of all managers + changes
in all users of TTM; Add a generic memcpy for page-based iomem; Remove
use of VM_MIXEDMAP; Cleanups
Driver Changes:
* drm/bridge: Add TI SN65DSI83 and SN65DSI84 + DT bindings
* drm/hyperv: Add DRM driver for HyperV graphics output
* drm/msm: Fix module dependencies
* drm/panel: KD53T133: Support rotation
* drm/pl111: Fix module dependencies
* drm/qxl: Fixes
* drm/stm: Cleanups
* drm/sun4i: Be explicit about format modifiers
* drm/vc4: Use struct gpio_desc; Cleanups
* drm/vgem: Cleanups
* drm/vmwgfx: Use ttm_bo_move_null() if there's nothing to copy
* fbdev/mach64: Cleanups
* fbdev/mb862xx: Use DEVICE_ATTR_RO
Link: https://patchwork.freedesktop.org/patch/msgid/YMBw3DF2b9udByfT@linux-uq9g
Instead of both driver and TTM allocating memory finalize embedding the
ttm_resource object as base into the driver backends.
v2: fix typo in vmwgfx grid mgr and double init in amdgpu_vram_mgr.c
Reviewed-by: Matthew Auld <matthew.auld@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210602100914.46246-10-christian.koenig@amd.com
Similar to the TTM range manager.
Link: https://patchwork.freedesktop.org/patch/msgid/20210602100914.46246-6-christian.koenig@amd.com
TTM is going to need this again since we are moving the resource
allocation into the backend.
Acked-by: Matthew Auld <matthew.auld@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210602100914.46246-4-christian.koenig@amd.com
https://gitlab.freedesktop.org/agd5f/linux into drm-next
amd-drm-next-5.14-2021-06-02:
amdgpu:
- GC/MM register access macro clean up for SR-IOV
- Beige Goby updates
- W=1 Fixes
- Aldebaran fixes
- Misc display fixes
- ACPI ATCS/ATIF handling rework
- SR-IOV fixes
- RAS fixes
- 16bpc fixed point format support
- Initial smartshift support
- RV/PCO power tuning fixes for suspend/resume
- More buffer object subclassing work
- Add new INFO query for additional vbios information
- Add new placement for preemptable SG buffers
amdkfd:
- Misc fixes
radeon:
- W=1 Fixes
- Misc cleanups
UAPI:
Useful for debugging vbios related issues. Proposed umr patch:
https://patchwork.freedesktop.org/patch/433297/
IGT test:
https://lists.freedesktop.org/archives/igt-dev/2021-May/031507.html
Proposed Vulkan patch:
https://github.com/kleinerm/pal/commit/a25d4802074b13a8d5f7edc96ae45469ecbac3c4
- Add a new GEM flag which is only used internally in the kernel driver. Userspace
is not allowed to set it.
drm:
- 16bpc fixed point format fourcc
Link: https://patchwork.freedesktop.org/patch/msgid/20210602214009.4553-1-alexander.deucher@amd.com
When we want to decouble resource management from buffer management we need to
be able to handle resources separately.
Add a resource pointer and rename bo->mem so that all code needs to
change to access the pointer instead.
No functional change.
Link: https://patchwork.freedesktop.org/patch/msgid/20210430092508.60710-4-christian.koenig@amd.com
Don't flush gart changes after recovering each BO instead
do it after recovering all the BOs. Flishing gart also needed
for amdgpu_ttm_alloc_gart().
v4: use containerof to retrieve adev struct.
v3: rename amdgpu_gart_tlb_flush() -> amdgpu_gart_invalidate_tlb().
v2: abstract out gart tlb flushing logic to amdgpu_gart.c
Signed-off-by: Nirmoy Das <nirmoy.das@amd.com>
Backmerging from drm/drm-next to the patches for AMD devices
for v5.14.
Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de>
amd-drm-next-5.14-2021-05-19:
amdgpu:
- Aldebaran updates
- More LTTPR display work
- Vangogh updates
- SDMA 5.x GCR fixes
- RAS fixes
- PCIe ASPM support
- Modifier fixes
- Enable TMZ on Renoir
- Buffer object code cleanup
- Display overlay fixes
- Initial support for multiple eDP panels
- Initial SR-IOV support for Aldebaran
- DP link training refactor
- Misc code cleanups and bug fixes
- SMU regression fixes for variable sized arrays
- MAINTAINERS fixes for amdgpu
amdkfd:
- Topology fixes
- Initial HMM SVM support
radeon:
- Flickering fix for Oland with multiple 4K displays
UAPI:
- amdgpu: Drop AMDGPU_GEM_CREATE_SHADOW flag.
This was always a kernel internal flag and userspace use of it has always been blocked.
It's no longer needed so remove it.
- amdkgd: HMM SVM support
Overview: https://patchwork.freedesktop.org/series/85562/
Porposed userspace: https://github.com/RadeonOpenCompute/ROCT-Thunk-Interface/tree/fxkamd/hmm-wip
Link: https://patchwork.freedesktop.org/patch/msgid/20210520031258.231896-1-alexander.deucher@amd.com
This allows to remove explicit creation and destruction
of those attrs and by this avoids warnings on device
finalizing post physical device extraction.
v5: Use newly added pci_driver.dev_groups directly
Acked-by: Christian König <christian.koenig@amd.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210512142648.666476-9-andrey.grodzovsky@amd.com
Christian needs some patches from drm/next
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
Avoid the forward define, fix coding style, add documentation.
Reviewed-by: Nirmoy Das <nirmoy.aiemd@gmail.com>
The alignment is a constant property and shouldn't change.
v2: move documentation as well as suggested by Matthew.
Link: https://patchwork.freedesktop.org/patch/msgid/20210413135248.1266-4-christian.koenig@amd.com
Fix the following coccicheck warning:
drivers/gpu//drm/amd/amdgpu/amdgpu_ras.c:434:9-17: WARNING:
use scnprintf or sprintf
drivers/gpu//drm/amd/amdgpu/amdgpu_xgmi.c:220:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_xgmi.c:249:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/df_v3_6.c:208:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_psp.c:2973:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_vram_mgr.c:75:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_vram_mgr.c:112:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_vram_mgr.c:58:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_vram_mgr.c:93:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_vram_mgr.c:125:9-17: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_gtt_mgr.c:52:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_gtt_mgr.c:71:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_device.c:140:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_device.c:164:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_device.c:186:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_device.c:208:8-16: WARNING:
drivers/gpu//drm/amd/amdgpu/amdgpu_atombios.c:1916:8-16: WARNING:
Signed-off-by: Tian Tao <tiantao6@hisilicon.com>
git://people.freedesktop.org/~agd5f/linux into drm-next
amd-drm-next-5.11-2020-11-05:
amdgpu:
- Add initial support for Vangogh
- Add support for Green Sardine
- Add initial support for Dimgrey Cavefish
- Scatter/Gather display support for Renoir
- Updates for Sienna Cichlid
- Updates for Navy Flounder
- SMU7 power improvements
- Modifier support for gfx9+
- CI BACO fixes
- Arcturus SMU fixes
- Lots of code cleanups
- DC fixes
- Kernel doc fixes
- Add more GPU HW client information to page fault error logging
- MPO clock tuning for RV
- FP fixes for DCN3 on ARM and PPC
radeon:
- Expose voltage via hwmon on Sumo APUs
amdkfd:
- Fix unique id handling
- Misc fixes
Link: https://patchwork.freedesktop.org/patch/msgid/20201105222749.201798-1-alexander.deucher@amd.com
Running "make htmldocs: produce lots of warnings on those files:
./drivers/gpu/drm/amd/amdgpu/amdgpu_vram_mgr.c:177: warning: Excess function parameter 'man' description in 'amdgpu_vram_mgr_init'
./drivers/gpu/drm/amd/amdgpu/amdgpu_vram_mgr.c:177: warning: Excess function parameter 'p_size' description in 'amdgpu_vram_mgr_init'
./drivers/gpu/drm/amd/amdgpu/amdgpu_vram_mgr.c:211: warning: Excess function parameter 'man' description in 'amdgpu_vram_mgr_fini'
./drivers/gpu/drm/amd/amdgpu/amdgpu_gtt_mgr.c:90: warning: Excess function parameter 'man' description in 'amdgpu_gtt_mgr_init'
./drivers/gpu/drm/amd/amdgpu/amdgpu_gtt_mgr.c:90: warning: Excess function parameter 'p_size' description in 'amdgpu_gtt_mgr_init'
./drivers/gpu/drm/amd/amdgpu/amdgpu_gtt_mgr.c:134: warning: Excess function parameter 'man' description in 'amdgpu_gtt_mgr_fini'
./drivers/gpu/drm/amd/amdgpu/amdgpu_device.c:675: warning: Excess function parameter 'dev' description in 'amdgpu_device_asic_init'
They're related to the repacement of some parameters by adev,
and due to a few renamed parameters.
While here, uniform the name of the parameter for it to be
the same on all functions using a pointer to struct amdgpu_device.
Update the kernel-doc documentation accordingly.
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
Make it more clear what the resource manager function
does and nuke the wrapper function.
v2: nuke the wrapper
v3: fix typo in radeon, rebased
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> (v2)
Link: https://patchwork.freedesktop.org/patch/393914/
Instead of letting TTM make an educated guess based on
some mask all drivers should just specify what caching
they want for their CPU mappings.
Reviewed-by: Dave Airlie <airlied@redhat.com>
Link: https://patchwork.freedesktop.org/patch/390207/
As far as I can tell this was never used either and we just
always fallback to the order cached > wc > uncached anyway.
Link: https://patchwork.freedesktop.org/patch/390142/
amd-drm-next-5.10-2020-09-03:
amdgpu:
- RAS fixes
- Sienna Cichlid updates
- Navy Flounder updates
- DCE6 (SI) support in DC
- Enable plane rotation
- Rework pre-OS vram reservation handling during driver init
- Add standard interface to dump GPU metrics table from SMU
- Rework tiling and tmz state handling in atomic commits
- Pstate fixes
- Add voltage and power hwmon interfaces for renoir
- SW CTF fixes
- S/G display fix for Raven
- Print client strings for vmfaults for vega and newer
- Manual fan control fixes
- Display updates
- Reorg power management directory structure
- Misc bug fixes
amdkfd:
- Topology fixes
- Add SMI events for thermal throttling and GPU resets
radeon:
- switch from pci_* to dma_* for dma allocations
- PLL fix
Scheduler:
- Clean up priority levels
UAPI:
- amdgpu INFO IOCTL query update for TMZ state
https://gitlab.freedesktop.org/mesa/mesa/-/merge_requests/6049
- amdkfd SMI event interface updates
https://github.com/RadeonOpenCompute/rocm_smi_lib/tree/therm_thrott
Link: https://patchwork.freedesktop.org/patch/msgid/20200903222921.4152-1-alexander.deucher@amd.com
Get the amdgpu_device from the DRM device by use
of an inline function, drm_to_adev(). The inline
function resolves a pointer to struct drm_device
to a pointer to struct amdgpu_device.
v2: Use a typed visible static inline function
instead of an invisible macro.
Signed-off-by: Luben Tuikov <luben.tuikov@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Backmerging drm-next into drm-misc-next for nouveau and panel updates.
Resolves a conflict between ttm and nouveau, where struct ttm_mem_res got
renamed to struct ttm_resource.
The names get/put are associated with reference counting
in the Linux kernel, use alloc/free instead.
Link: https://patchwork.freedesktop.org/patch/384340/?series=80346&rev=1
Christian suggested this and it makes sense.
Link: https://patchwork.freedesktop.org/patch/msgid/20200806233459.4057784-2-airlied@gmail.com
This name better reflects what the object does. I didn't rename
all the pointers it seemed too messy.
Reviewed-by: Ben Skeggs <bskeggs@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-60-airlied@gmail.com
This name makes a lot more sense, since these are about managing
driver resources rather than just memory ranges.
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-59-airlied@gmail.com
under driver control, this flag isn't needed anymore,
remove the API that used to access it, and consoldiate
with the used api.
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-56-airlied@gmail.com
This link isn't needed anymore, drop it from the init interface.
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-54-airlied@gmail.com
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-46-airlied@gmail.com
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-38-airlied@gmail.com
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-28-airlied@gmail.com
Use new init calls to unwrap manager init
Link: https://patchwork.freedesktop.org/patch/msgid/20200804025632.3868079-16-airlied@gmail.com
drm-misc-next for v5.9:
UAPI Changes:
- Add ckoenig as dma-buf maintainer.
- Revert invalid fix for dma-fence-chain, and fix selftest.
- Add fixmes to amifb about APUS support.
- Use array3_size in fbcon_prepare_logo, and struct_size() in alloc_apertures.
- Fix leaks in neofb, fb/savage and omapfb.
- Other small fixes to fb code.
- Convert some dt bindings to schema for some panels, and fix simple-framebuffer dt example.
Core Changes:
- Add DRM_FORMAT_MOD_GENERIC_16_16_TILE as alias to DRM_FORMAT_MOD_SAMSUNG_16_16_TILE,
as it can be used more generic.
- Add support for multiple DispID extension blocks in edid.
- Use https instead of http for some of the urls.
- Use drm_* macros for logging in mipi-dsi and fb-helper.
- Further cleanup ttm_mem_reg handling.
- Remove duplicated words in comments.
Driver Changes:
- Use __drm_atomic_helper_crtc_reset in all atomic drivers.
- Add Amlogic Video FBC support to meson and fourcc to core.
- Refactor hisilicon's hibmc_drv_vdac.
- Create a TXP CRTC for vc4.
- Rework cursor support in ast.
- Fix runtime PM in STM.
- Allow bigger cursors in vkms.
- Cleanup sg handling in radeon and amdgpu, and stop creating dummy
gtt nodes with ttm fixed.
- Rework crtc handling in mgag200.
- Miscellaneous small fixes to meson, vgem, bridge/dw-hdmi,
panel/auo,b116xw03, panel/LG LB070WV8, lima, bridge/sil_sii8620,
virtio, tilcdc.
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/8b360d65-f228-9286-d247-3004156a5254@linux.intel.com
Now that TTM is fixed up we can finally stop that nonsense.
Reviewed-by: Madhav Chauhan <madhav.chauhan@amd.com>
Link: https://patchwork.freedesktop.org/patch/375620
Silence documentation warnings by correcting kernel-doc comments.
./drivers/gpu/drm/amd/amdgpu/amdgpu_device.c:3388: warning: Excess function parameter 'suspend' description in 'amdgpu_device_suspend'
./drivers/gpu/drm/amd/amdgpu/amdgpu_device.c:3485: warning: Excess function parameter 'resume' description in 'amdgpu_device_resume'
./drivers/gpu/drm/amd/amdgpu/amdgpu_vram_mgr.c:418: warning: Excess function parameter 'tbo' description in 'amdgpu_vram_mgr_del'
./drivers/gpu/drm/amd/amdgpu/amdgpu_vram_mgr.c:418: warning: Excess function parameter 'place' description in 'amdgpu_vram_mgr_del'
./drivers/gpu/drm/amd/amdgpu/amdgpu_gtt_mgr.c:279: warning: Excess function parameter 'tbo' description in 'amdgpu_gtt_mgr_del'
./drivers/gpu/drm/amd/amdgpu/amdgpu_gtt_mgr.c:279: warning: Excess function parameter 'place' description in 'amdgpu_gtt_mgr_del'
./drivers/gpu/drm/amd/display/amdgpu_dm/amdgpu_dm.h:332: warning: Function parameter or member 'hdcp_workqueue' not described in 'amdgpu_display_manager'
./drivers/gpu/drm/amd/display/amdgpu_dm/amdgpu_dm.h:332: warning: Function parameter or member 'cached_dc_state' not described in 'amdgpu_display_manager'
Signed-off-by: Colton Lewis <colton.w.lewis@protonmail.com>
Instead of signaling failure by setting the node pointer to
NULL do so by returning -ENOSPC.
v2: add memset() to make sure that mem is always initialized.
v3: drop memset() only set mm_node = NULL, move mm_node init in amdgpu
Reviewed-by: Michael J. Ruhl <michael.j.ruhl@intel.com>
Link: https://patchwork.freedesktop.org/patch/373181/
Drop use of drmP.h in all files named amdgpu*
in drm/amd/amdgpu/
Fix fallout.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: "Christian König" <christian.koenig@amd.com>
Cc: "David (ChunMing) Zhou" <David1.Zhou@amd.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190609220757.10862-10-sam@ravnborg.org
Add 6 files that return (in bytes):
The total amount of VRAM/visible VRAM/GTT
and the current total used VRAM/visible VRAM/GTT
v2: Split used and total into separate files
Signed-off-by: Kent Russell <kent.russell@amd.com>
Inside amdgpu_gtt_mgr_fini add a missing lock to maintain
locking balance
Signed-off-by: Mikita Lipski <mikita.lipski@amd.com>
Reviewed-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
And rename it to amdgpu_gmc as well.
Reviewed-by: Samuel Li <Samuel.Li@amd.com>
The GTT manager handles the GART address space anyway, so it is
completely pointless to keep the same information around twice.
v2: rebased
Reviewed-by: Chunming Zhou <david1.zhou@amd.com>
Rename amdgpu_gtt_mgr_is_allocated() to amdgpu_gtt_mgr_has_gart_addr() and use
that instead.
v2: rename the function as well.
this can fix the memory leak under the case that not all
BO are freed during "takedown" stage, because originally
it blocks following kfree on mgr.
Signed-off-by: Monk Liu <Monk.Liu@amd.com>
While binding BOs to GART we need to allow a bit overcommit in the GTT
domain. Otherwise we can never use the full GART space when GART size=GTT size.
Use ttm_bo_mem_space instead of manually allocating GART space.
This allows us to evict BOs when there isn't enought GART space any more.
It doesn't make much sense to count those numbers twice.
v2: use and atomic64_t instead
Instead of the separate switch/case in the calling function.
