Get the amdgpu_device from the DRM device by use
of an inline function, drm_to_adev(). The inline
function resolves a pointer to struct drm_device
to a pointer to struct amdgpu_device.
v2: Use a typed visible static inline function
instead of an invisible macro.
Signed-off-by: Luben Tuikov <luben.tuikov@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Currently, every single piece of code in amdgpu that loops through
connectors does it incorrectly and doesn't use the proper list iteration
helpers, drm_connector_list_iter_begin() and
drm_connector_list_iter_end(). Yeesh.
So, do that.
Cc: Juston Li <juston.li@intel.com>
Cc: Imre Deak <imre.deak@intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Harry Wentland <hwentlan@amd.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Lyude Paul <lyude@redhat.com>
Drop use of drmP.h in all files named amdgpu*
in drm/amd/amdgpu/
Fix fallout.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: "Christian König" <christian.koenig@amd.com>
Cc: "David (ChunMing) Zhou" <David1.Zhou@amd.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190609220757.10862-10-sam@ravnborg.org
Demangle amdgpu.h.
Signed-off-by: Huang Rui <ray.huang@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
Again to align with the usual prefix of just drm_connector_. Again
done with sed + manual fixup for indent issues.
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180709084016.23750-7-daniel.vetter@ffwll.ch
This adds the non-asic specific core driver code.
v2: remove extra kconfig option
v3: implement minor fixes from Fengguang Wu
v4: fix cast in amdgpu_ucode.c
Acked-by: Jammy Zhou <Jammy.Zhou@amd.com>
