path: root/drivers/gpio
2012-12-19gpio/mvebu-gpio: Make mvebu-gpio depend on OF_CONFIGGregory CLEMENT
When building without device tree support (for the mv78x00 SoCs for example), the build failed because of_irq_count is undeclared. However mvebu-gpio is not designed to build without device tree support. So make it depends on OF_CONFIG, remove the #ifdef OF_CONFIG line and the platform_device_id. Tested on RD-78x00-mASA, DB-78460-BP, DB-88F6710-BP-DDR3, DB-MV784MP-GP, Mirabox and OpenBlocks AX3. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-19gpio/ich: Add missing spinlock initJean Delvare
As reported by CONFIG_DEBUG_SPINLOCK=y. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC driver specific changes from Olof Johansson: "A collection of mostly SoC-specific driver updates: - a handful of pincontrol and setup changes - new drivers for hwmon and reset controller for vexpress - timing support updates for OMAP (gpmc and other interfaces) - plus a collection of smaller cleanups" * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits) ARM: ux500: fix pin warning ARM: OMAP2+: tusb6010: generic timing calculation ARM: OMAP2+: smc91x: generic timing calculation ARM: OMAP2+: onenand: generic timing calculation ARM: OMAP2+: gpmc: generic timing calculation ARM: OMAP2+: gpmc: handle additional timings ARM: OMAP2+: nand: remove redundant rounding gpio: samsung: use pr_* instead of printk ARM: ux500: fixup magnetometer pins ARM: ux500: add STM pin configuration ARM: ux500: 8500: add pinctrl support for uart1 and uart2 ARM: ux500: cosmetic fixups for uart0 gpio: samsung: Fix input mode setting function for GPIO int ARM: SAMSUNG: Insert bitmap_gpio_int member in samsung_gpio_chip ARM: ux500: 8500: define SDI sleep states ARM: vexpress: Reset driver ARM: ux500: 8500: update SKE keypad pinctrl table hwmon: Versatile Express hwmon driver ARM: ux500: delete duplicate macro ARM: ux500: 8500: add IDLE pin configuration for SPI ...
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-11Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO updates from Grant Likely: "GPIO follow up patch and type change for v3.5 merge window Primarily device driver additions, features and bug fixes. Not much touching gpio common subsystem support. Should not be scary." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio: Provide the STMPE GPIO driver with its own IRQ Domain gpio: add TS-5500 DIO blocks support gpio: pcf857x: use client->irq for gpio_to_irq() gpio: stmpe: Add DT support for stmpe gpio gpio: pl061 depends on ARM gpio/pl061: remove old comment gpio: SPEAr: add spi chipselect control driver gpio: gpio-max710x: Support device tree probing gpio: twl4030: Use only TWL4030_MODULE_LED for LED configuration gpio: tegra: read output value when gpio is set in direction_out gpio: pca953x: Add compatible strings to gpio-pca953x driver gpio: pca953x: Register an IRQ domain gpio: mvebu: Set free callback for gpio_chip gpio: tegra: Drop exporting static functions gpio: tegra: Staticize non-exported symbols gpio: tegra: fix suspend/resume apis gpio-pch: Set parent dev for gpio chip gpio: em: Fix build errors GPIO: clps711x: use platform_device_unregister in gpio_clps711x_init() gpio/tc3589x: convert to use the simple irqdomain ...
2012-12-11Merge tag 'pm+acpi-for-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: - Introduction of device PM QoS flags. - ACPI device power management update allowing subsystems other than PCI to use it more easily. - ACPI device enumeration rework allowing additional kinds of devices to be enumerated via ACPI. From Mika Westerberg, Adrian Hunter, Mathias Nyman, Andy Shevchenko, and Rafael J. Wysocki. - ACPICA update to version 20121018 from Bob Moore and Lv Zheng. - ACPI memory hotplug update from Wen Congyang and Yasuaki Ishimatsu. - Introduction of acpi_handle_<level>() messaging macros and ACPI-based CPU hot-remove support from Toshi Kani. - ACPI EC updates from Feng Tang. - cpufreq updates from Viresh Kumar, Fabio Baltieri and others. - cpuidle changes to quickly notice governor prediction failure from Youquan Song. - Support for using multiple cpuidle drivers at the same time and cpuidle cleanups from Daniel Lezcano. - devfreq updates from Nishanth Menon and others. - cpupower update from Thomas Renninger. - Fixes and small cleanups all over the place. * tag 'pm+acpi-for-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (196 commits) mmc: sdhci-acpi: enable runtime-pm for device HID INT33C6 ACPI: add Haswell LPSS devices to acpi_platform_device_ids list ACPI: add documentation about ACPI 5 enumeration pnpacpi: fix incorrect TEST_ALPHA() test ACPI / PM: Fix header of acpi_dev_pm_detach() in acpi.h ACPI / video: ignore BIOS initial backlight value for HP Folio 13-2000 ACPI : do not use Lid and Sleep button for S5 wakeup ACPI / PNP: Do not crash due to stale pointer use during system resume ACPI / video: Add "Asus UL30VT" to ACPI video detect blacklist ACPI: do acpisleep dmi check when CONFIG_ACPI_SLEEP is set spi / ACPI: add ACPI enumeration support gpio / ACPI: add ACPI support PM / devfreq: remove compiler error with module governors (2) cpupower: IvyBridge (0x3a and 0x3e models) support cpupower: Provide -c param for cpupower monitor to schedule process on all cores cpupower tools: Fix warning and a bug with the cpu package count cpupower tools: Fix malloc of cpu_info structure cpupower tools: Fix issues with sysfs_topology_read_file cpupower tools: Fix minor warnings cpupower tools: Update .gitignore for files created in the debug directories ...
2012-12-11Merge tag 'pinctrl-for-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl changes from Linus Walleij: "These are the first and major pinctrl changes for the v3.8 merge cycle. Some of this is used as merge base for other trees so I better be early on the trigger. As can be seen from the diffstat the major changes are: - A big conversion of the AT91 pinctrl driver and the associated ACKed platform changes under arch/arm/max-at91 and its device trees. This has been coordinated with the AT91 maintainers to go in through the pinctrl tree. - A larger chunk of changes to the SPEAr drivers and the addition of the "plgpio" driver for the SPEAr as well. - The removal of the remnants of the Nomadik driver from the arch/arm tree and fusion of that into the Nomadik driver and platform data header files. - Some local movement in the Marvell MVEBU drivers, these now have their own subdirectory. - The addition of a chunk of code to gpiolib under drivers/gpio to register gpio-to-pin range mappings from the GPIO side of things. This has been requested by Grant Likely and is now implemented, it is particularly useful for device tree work. Then we have incremental updates all over the place, many of these are cleanups and fixes from Axel Lin who has done a great job of removing minor mistakes and compilation annoyances." * tag 'pinctrl-for-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (114 commits) ARM: mmp: select PINCTRL for ARCH_MMP pinctrl: Drop selecting PINCONF for MMP2, PXA168 and PXA910 pinctrl: pinctrl-single: Fix error check condition pinctrl: SPEAr: Update error check for unsigned variables gpiolib: Fix use after free in gpiochip_add_pin_range gpiolib: rename pin range arguments pinctrl: single: support gpio request and free pinctrl: generic: add input schmitt disable parameter pinctrl/u300/coh901: stop spawning pinctrl from GPIO pinctrl/u300/coh901: let the gpio_chip register the range pinctrl: add function to retrieve range from pin gpiolib: return any error code from range creation pinctrl: make range registration defer properly gpiolib: rename find_pinctrl_* gpiolib: let gpiochip_add_pin_range() specify offset ARM: at91: pm9g45: add mmc support ARM: at91: Animeo IP: add mmc support ARM: at91: dt: add mmc pinctrl for Atmel reference boards ARM: at91: dt: at91sam9: add mmc pinctrl support ARM: at91/dts: add nodes for atmel hsmci controllers for atmel boards ...
2012-12-10gpio: Provide the STMPE GPIO driver with its own IRQ DomainLee Jones
The STMPE GPIO driver can be used as an IRQ controller by some related devices. Here we provide it with its very own IRQ Domain so that IRQs can be issued dynamically. This will stand the driver in good stead when it is enabled for Device Tree, as this it a prerequisite. Cc: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-10gpio: add TS-5500 DIO blocks supportVivien Didelot
Technologic Systems TS-5500 provides digital I/O lines exposed through pin blocks. On this platform, there are three of them, named DIO1, DIO2 and LCD port, that may be used as a DIO block. The TS-5500 pin blocks are described in the product's wiki: http://wiki.embeddedarm.com/wiki/TS-5500#Digital_I.2FO This driver is not limited to the TS-5500 blocks. It can be extended to support similar boards pin blocks, such as on the TS-5600. This patch is the V2 of the previous https://lkml.org/lkml/2012/9/25/671 with corrections suggested by Linus Walleij. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Jerome Oufella <jerome.oufella@savoirfairelinux.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-07gpio: pcf857x: use client->irq for gpio_to_irq()Kuninori Morimoto
6e20a0a429bd4dc07d6de16d9c247270e04e4aa0 (gpio: pcf857x: enable gpio_to_irq() support) added gpio_to_irq() support on pcf857x driver, but it used pdata->irq. This patch modifies driver to use client->irq instead of it. It modifies kzm9g board platform settings, and device probe information too. This patch is tested on kzm9g board Reported-by: Christian Engelmayer <christian.engelmayer@frequentis.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-03treewide: Fix typos in various KconfigMasanari Iida
Correct spelling typo within various Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-01gpio: stmpe: Add DT support for stmpe gpioVipul Kumar Samar
This patch allows the STMPE GPIO driver to be successfully probed and initialised when Device Tree support is enabled. Bindings are mentioned in Documentation too. Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-01gpio: pl061 depends on ARMAlessandro Rubini
Commit dece904d (gpio: pl061: use chained_irq_* functions in irq handler) introduced chained_irq_enter/exit, which is only available for arch/arm and the driver won't compile elsewhere. The dependency is thus made explicit, because AMBA is used in the x86 world by a PCI-to-AMBA bridge, to be submitted. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-30Merge branch 'acpi-enumeration'Rafael J. Wysocki
* acpi-enumeration: spi / ACPI: add ACPI enumeration support gpio / ACPI: add ACPI support
2012-11-30gpio / ACPI: add ACPI supportMathias Nyman
Add support for translating ACPI GPIO pin numbers to Linux GPIO API pins. Needs a gpio controller driver with the acpi handler hook set. Drivers can use acpi_get_gpio() to translate ACPI5 GpioIO and GpioInt resources to Linux GPIO's. Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-30gpio/pl061: remove old commentBaruch Siach
Since 3ab524754 (gpio: pl061: convert to use generic irq chip) we only have one spinlock in struct pl061_gpio. Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitconstBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitconst is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26Merge tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux ↵Olof Johansson
into next/dt From Jason Cooper: orion dt for v3.8 - ehci-orion dt binding - gpio-poweroff - use dt regulators - move mpp to DT/pinctrl Depends on: - orion/boards - merge conflicts - keep all 'select's in Kconfig - remove all #includes in board-*.c - pinctrl/devel up to: - 06763c7 pinctrl: mvebu: move to its own directory * tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux: (211 commits) ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ARM: Kirkwood: Convert dnskw to pinctrl ARM: Kirkwood: Convert iConnect to pinctrl. ARM: Kirkwood: Convert TS219 to pinctrl. ARM: Kirkwood: Add DTSI files for pinctrl ARM: Kirkwood: Make use of mvebu pincltl and gpio drivers ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-25Merge tag 'v3.7-rc7' into next/cleanupOlof Johansson
Merging in mainline back to next/cleanup since it has collected a few conflicts between fixes going upstream and some of the cleanup patches. Git doesn't auto-resolve some of them, and they're mostly noise so let's take care of it locally. Conflicts are in: arch/arm/mach-omap2/omap_hwmod_44xx_data.c arch/arm/plat-omap/i2c.c drivers/video/omap2/dss/dss.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-24GPIO: mvebu: Allow all plat-orion platforms.Andrew Lunn
Kirkwood & Dove can also use this driver, so expand the scope to include all platform orion devices. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21Merge branch 'next/dt-samsung' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt From Kukjin Kim: Here is Samsung DT for v3.8 and this is including DT for EXYNOS4X12 SoC, SMDK4412 board, pinctrl for exynos4x12, TMU, MFC, SATA and SATA PHY. As I commented on [4/7], this branch merged pinctrl/samsung to support pinctrl for exynos4x12 without useless merge conflicts. * 'next/dt-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (32 commits) ARM: EXYNOS: DT Support for SATA and SATA PHY ARM: dts: Remove broken-voltage property from sdhci node for exynos4210-trats ARM: dts: Add node for touchscreen for exynos4210-trats ARM: dts: Add node for touchscreen voltage regulator for exynos4210-trats ARM: dts: Add node for i2c3 bus for exynos4210-trats ARM: dts: Add nodes for GPIO keys available on Trats ARM: dts: Update for pinctrl-samsung driver for exynos4210-trats ARM: dts: Add nodes for pin controllers for exynos4x12 pinctrl: samsung: Add support for EXYNOS4X12 gpio: samsung: Skip registration if pinctrl driver is present on EXYNOS4X12 ARM: EXYNOS: Skip wakeup-int setup if pinctrl driver is used on EXYNOS4X12 ARM: dts: add board dts file for EXYNOS4412 based SMDK board ARM: dts: Add support for EXYNOS4X12 SoCs ARM: EXYNOS: Add devicetree node for TMU driver for exynos5 ARM: EXYNOS: Add devicetree node for TMU driver for exynos4 ARM: EXYNOS: Add MFC device tree support ARM: dts: Enable serial controllers on Origen and SMDKV310 Documentation: Update samsung-pinctrl device tree bindings documentation pinctrl: samsung: Add GPIO to IRQ translation pinctrl: exynos: Set pin function to EINT in irq_set_type of wake-up EINT ... Add/add conflicts in: arch/arm/boot/dts/exynos5250-smdk5250.dts arch/arm/boot/dts/exynos5250.dtsi arch/arm/mach-exynos/mach-exynos5-dt.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21Merge branch 'next/gpio-samsung' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/drivers From Kukjin Kim: This is for Samsung gpio stuff and got the ack from Linus Walleij. * 'next/gpio-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: gpio: samsung: use pr_* instead of printk gpio: samsung: Fix input mode setting function for GPIO int ARM: SAMSUNG: Insert bitmap_gpio_int member in samsung_gpio_chip
2012-11-21mfd/rtc/gpio: twl: No need to allocate bigger buffer for writePeter Ujfalusi
Since the twl-core has been converted to use regmap it is no longer needed to allocate bigger buffer for data when writing to twl. CC: Grant Likely <grant.likely@secretlab.ca> CC: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21gpiolib: Fix use after free in gpiochip_add_pin_rangeAxel Lin
This is introduced by commit 9ab6e988 "gpiolib: return any error code from range creation". Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21gpiolib: rename pin range argumentsLinus Walleij
To be crystal clear on what the arguments mean in this funtion dealing with both GPIO and PIN ranges with confusing naming, we now have gpio_offset and pin_offset and we are on the clear that these are offsets into the specific GPIO and pin controller respectively. The GPIO chip itself will of course keep track of the base offset into the global GPIO number space. Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21gpiolib: return any error code from range creationLinus Walleij
If we try to create a range for a certain GPIO chip and the target pin controller is not yet available it may return a probe deferral error code, so handle this all the way our by checking the error code. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21gpiolib: rename find_pinctrl_*Linus Walleij
Rename the function find_pinctrl_and_add_gpio_range() to pinctrl_find_and_add_gpio_range() so as to be consistent with the rest of the functions. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-21gpiolib: let gpiochip_add_pin_range() specify offsetLinus Walleij
Like with commit 3c739ad0df5eb41cd7adad879eda6aa09879eb76 it is not always enough to specify all the pins of a gpio_chip from offset zero to be added to a pin map range, since the mapping from GPIO to pin controller may not be linear at all, but need to be broken into a few consecutive sub-ranges or 1-pin entries for complicated cases. The ranges may also be sparse. This alters the signature of the function to accept offsets into both the GPIO-chip local pinspace and the pin controller local pinspace. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-20gpio: Add viperboard gpio driverLars Poeschel
This adds the mfd cell to use the gpio a and gpio b part of the Nano River Technologies viperboard. Signed-off-by: Lars Poeschel <poeschel@lemonage.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-20gpio: gpio-da9052: Convert to the new da9052 interrupt functionsFabio Estevam
Convert to the new da9052 interrupt functions, so that we can get rid of irq_base references. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-18gpio: SPEAr: add spi chipselect control driverShiraz Hashim
SPEAr platform provides a provision to control chipselects of ARM PL022 Prime Cell spi controller through its system registers, which otherwise remains under PL022 control which some protocols do not want. This commit intends to provide the spi chipselect control in software over gpiolib interface. spi chip drivers can use the exported gpiolib interface to define their chipselect through DT or platform data. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Reviewed-by: Vipin Kumar <vipin.kumar@st.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio-mcp23s08: Build I2C support even when CONFIG_I2C=mDaniel M. Weeks
The driver has both SPI and I2C pieces. The appropriate pieces are built based on whether SPI and/or I2C is/are enabled. However, it was only checking if I2C was built-in, never if it was built as a module. This patch checks for either since building both this driver and I2C as modules is possible. Signed-off-by: Daniel M. Weeks <dan@danweeks.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: adnp: Depend on OF_GPIO instead of OFThierry Reding
The driver accesses the of_node field of struct gpio_chip, which is only available if OF_GPIO is selected. This solves a build issue on SPARC which conflicts with OF_GPIO and therefore does not provide this field. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17mvebu-gpio: Disable blinking when enabling a GPIO for outputJamie Lentin
The plat-orion GPIO driver would disable any pin blinking whenever using a pin for output. Do the same here, as a blinking LED will continue to blink regardless of what the GPIO pin level is. Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: gpio-max710x: Support device tree probingRoland Stigge
For probing via device tree, we need to support the case without platform_data. In this case, chip.base is set to -1 for automatic numbering. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: twl4030: Use only TWL4030_MODULE_LED for LED configurationPeter Ujfalusi
Avoid using the TWL4030_MODULE_PWMA/B as module ID. The LEDEN, PWMA ON/OFF and PWMB ON/OFF registers are in a continuous range starting from LED base. This is going to be helpful for further cleanup in the twl stack. No functional changes. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: tegra: read output value when gpio is set in direction_outLaxman Dewangan
Read the output value when gpio is set for the output mode for gpio_get_value(). Reading input value in direction out does not give correct value. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: pca953x: Add compatible strings to gpio-pca953x driverMaxime Ripard
Even though the device tree binding code was already written, the compatible strings were not yet in the driver. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-17gpio: pca953x: Register an IRQ domainMaxime Ripard
The PCA953x used to register no IRQ domain, which made it impossible to use it as an interrupt-parent from the device tree. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-15ARM: pxa: remove pxa95x supportHaojian Zhuang
PXA95x isn't widely used. And it adds the effort on supporting multiple platform. So remove it. The assumption is that nobody will miss this support. If you are reading this text because you actually require pxa95x support on a new kernel, we can work out a way to revert this patch or add support to the mmp platform. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-13mfd: Implement tps6586x gpio_to_irqLaxman Dewangan
The TPS6586x adds the interrupt of this device using linear mapping on irq domain. Hence, implement gpio_to_irq to get the irq number corresponding to TPS6586x GPIOs which is created dynamically. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-11gpiolib: separation of pin concernsLinus Walleij
The fact that of_gpiochip_add_pin_range() and gpiochip_add_pin_range() share too much code is fragile and will invariably mean that bugs need to be fixed in two places instead of one. So separate the concerns of gpiolib.c and gpiolib-of.c and have the latter call the former as back-end. This is necessary also when going forward with other device descriptions such as ACPI. This is done by: - Adding a return code to gpiochip_add_pin_range() so we can reliably check whether this succeeds. - Get rid of the custom of_pinctrl_add_gpio_range() from pinctrl. Instead create of_pinctrl_get() to just retrive the pin controller per se from an OF node. This composite function was just begging to be deleted, it was way to purpose-specific. - Use pinctrl_dev_get_name() to get the name of the retrieved pin controller and use that to call back into the generic gpiochip_add_pin_range(). Now the pin range is only allocated and tied to a pin controller from the core implementation in gpiolib.c. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
