path: root/drivers/gpio/gpio-wm8994.c
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-16gpio: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26Merge tag 'gpio-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: - New driver for AMD-8111 southbridge GPIOs - New driver for Wolfson Micro Arizona devices - Propagate device tree parse errors - Probe deferral finalizations - all expected calls to GPIO will now hopefully request deferral where apropriate - Misc updates to TCA6424, WM8994, LPC32xx, PCF857x, Samsung MXC, OMAP and PCA953X drivers. Fix up gpio_idx conflicts in drivers/gpio/gpio-mxc.c * tag 'gpio-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: of_get_named_gpio_flags() return -EPROBE_DEFER if GPIO not yet available gpiolib: Defer failed gpio requests by default MAINTAINERS: add entry OMAP GPIO driver gpio/pca953x: increase variables size to support 24 bit of data GPIO: PCA953X: Increase size of invert variable to support 24 bit gpio/omap: move bank->dbck initialization to omap_gpio_mod_init() gpio/mxc: use the edge_sel feature if available gpio: propagate of_parse_phandle_with_args errors gpio: samsung: add flags specifier to device-tree binding gpiolib: Add support for Wolfson Microelectronics Arizona class devices gpio: gpio-lpc32xx: Add gpio_to_irq mapping gpio: pcf857x: share 8/16 bit access functions gpio: LPC32xx: Driver cleanup MAINTAINERS: Add Wolfson gpiolib drivers to the Wolfson entry gpiolib: wm8994: Convert to devm_kzalloc() gpiolib: wm8994: Use irq_domain mappings for gpios gpio: add a driver for GPIO pins found on AMD-8111 south bridge chips gpio/tca6424: merge I2C transactions, remove cast gpio/of: fix a typo of comment message
2012-07-12gpiolib: wm8994: Convert to devm_kzalloc()Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-12gpiolib: wm8994: Use irq_domain mappings for gpiosMark Brown
This has no practical impact at present since we don't support device tree so any user must have set an irq_base but this will in future allow a transition to device tree with minimal invasiveness. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-05gpiolib: wm8994: Pay attention to the value set when enabling as outputMark Brown
Not paying attention to the value being set is a bad thing because it means that we'll not set the hardware up to reflect what was requested. Not setting the hardware up to reflect what was requested means that the caller won't get the results they wanted. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-02gpio: Add decode of WM8994 GPIO configurationMark Brown
For the human reader. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
