path: root/drivers/gpio/gpio-tc3589x.c
2019-11-07gpio: Use new GPIO_LINE_DIRECTIONMatti Vaittinen
It's hard for occasional GPIO code reader/writer to know if values 0/1 equal to IN or OUT. Use defined GPIO_LINE_DIRECTION_IN and GPIO_LINE_DIRECTION_OUT to help them out. NOTE - for gpio-amd-fch and gpio-bd9571mwv: This commit also changes the return value for direction get to equal 1 for direction INPUT. Prior this commit these drivers might have returned some other positive value but 1 for INPUT. Signed-off-by: Matti Vaittinen <matti.vaittinen@fi.rohmeurope.com> Acked-by: Scott Branden <scott.branden@broadcom.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: William Breathitt Gray <vilhelm.gray@gmail.com> Acked-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 464Thomas Gleixner
Based on 1 normalized pattern(s): license terms gnu general public license version 2 extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 11 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Enrico Weigelt <info@metux.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081202.373849232@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08gpio: Move irqdomain into struct gpio_irq_chipThierry Reding
In order to consolidate the multiple ways to associate an IRQ chip with a GPIO chip, move more fields into the new struct gpio_irq_chip. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-01-26pinctrl / gpio: Introduce .set_config() callback for GPIO chipsMika Westerberg
Currently we already have two pin configuration related callbacks available for GPIO chips .set_single_ended() and .set_debounce(). In future we expect to have even more, which does not scale well if we need to add yet another callback to the GPIO chip structure for each possible configuration parameter. Better solution is to reuse what we already have available in the generic pinconf. To support this, we introduce a new .set_config() callback for GPIO chips. The callback takes a single packed pin configuration value as parameter. This can then be extended easily beyond what is currently supported by just adding new types to the generic pinconf enum. If the GPIO driver is backed up by a pinctrl driver the GPIO driver can just assign gpiochip_generic_config() (introduced in this patch) to .set_config and that will take care configuration requests are directed to the pinctrl driver. We then convert the existing drivers over .set_config() and finally remove the .set_single_ended() and .set_debounce() callbacks. Suggested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-13Merge tag 'gpio-v4.10-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Luinus Walleij: "Bulk GPIO changes for the v4.10 kernel cycle: Core changes: - Simplify threaded interrupt handling: instead of passing numbed parameters to gpiochip_irqchip_add_chained() we create a new call: gpiochip_irqchip_add_nested() so the two types are clearly semantically different. Also make sure that all nested chips call gpiochip_set_nested_irqchip() which is necessary for IRQ resend to work properly if it happens. - Return error on seek operations for the chardev. - Clamp values set as part of gpio[d]_direction_output() so that anything != 0 will be send down to the driver as "1" not the value passed in. - ACPI can now support naming of GPIO lines, hogs and holes in the GPIO lists. New drivers: - The SX150x driver was deemed unfit for the GPIO subsystem and was moved over to a combined GPIO+pinctrl driver in the pinctrl subsystem. New features: - Various cleanups to various drivers" * tag 'gpio-v4.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (49 commits) gpio: merrifield: Implement gpio_get_direction callback gpio: merrifield: Add support for hardware debouncer gpio: chardev: Return error for seek operations gpio: arizona: Tidy up probe error path gpio: arizona: Remove pointless set of platform drvdata gpio: pl061: delete platform data handling gpio: pl061: move platform data into driver gpio: pl061: rename variable from chip to pl061 gpio: pl061: rename state container struct gpio: pl061: use local state for parent IRQ storage gpio: set explicit nesting on drivers gpio: simplify adding threaded interrupts gpio: vf610: use builtin_platform_driver gpio: axp209: use correct register for GPIO input status gpio: stmpe: fix interrupt handling bug gpio: em: depnd on ARCH_SHMOBILE gpio: zx: depend on ARCH_ZX gpio: x86: update config dependencies for x86 specific hardware gpio: mb86s7x: use builtin_platform_driver gpio: etraxfs: use builtin_platform_driver ...
2016-11-25gpio: simplify adding threaded interruptsLinus Walleij
This tries to simplify the use of CONFIG_GPIOLIB_IRQCHIP when using threaded interrupts: add a new call gpiochip_irqchip_add_nested() to indicate that we're dealing with a nested rather than a chained irqchip, then create a separate gpiochip_set_nested_irqchip() to mirror the gpiochip_set_chained_irqchip() call to connect the parent and child interrupts. In the nested case gpiochip_set_nested_irqchip() does nothing more than call irq_set_parent() on each valid child interrupt, which has little semantic effect in the kernel, but this is probably still formally correct. Update all drivers using nested interrupts to use gpiochip_irqchip_add_nested() so we can now see clearly which these users are. The DLN2 driver can drop its specific hack with .irq_not_threaded as we now recognize whether a chip is threaded or not from its use of gpiochip_irqchip_add_nested() signature rather than from inspecting .can_sleep. We rename the .irq_parent to .irq_chained_parent since this parent IRQ is only really kept around for the chained interrupt handlers. Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Octavian Purdila <octavian.purdila@intel.com> Cc: Daniel Baluta <daniel.baluta@intel.com> Cc: Bin Gao <bin.gao@linux.intel.com> Cc: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: Ajay Thomas <ajay.thomas.david.rajamanickam@intel.com> Cc: Semen Protsenko <semen.protsenko@globallogic.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Cc: Phil Reid <preid@electromag.com.au> Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com> Cc: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-11-15gpio: tc3589x: fix up .get_direction()Linus Walleij
The bit in the TC3589x direction register is 0 for input and 1 for output, but the gpiolib expects the reverse. Fix up the logic. Cc: stable@vger.kernel.org Fixes: 14063d71e5e6 ("gpio: tc3589x: add .get_direction() and small cleanup") Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-19gpio: tc3589x: fix up complaints on unsignedLinus Walleij
A bunch of variables were just declared "unsigned" and should be "unsigned int". Fix it up for this driver. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-19gpio: tc3589x: add .get_direction() and small cleanupLinus Walleij
This adds a .get_direction() callback to the TC3589x and renames the function for setting single-ended mode to be more to the point. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-13gpio: constify gpio_chip structuresJulia Lawall
These structures are only used to copy into other structures, so declare them as const. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct gpio_chip i@p = { ... }; @ok@ identifier r.i; expression e; position p; @@ e = i@p; @bad@ position p != {r.p,ok.p}; identifier r.i; struct gpio_chip e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct gpio_chip i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-06-07gpio: remove redundant owner assignments of driversMasahiro Yamada
A platform_driver need not set an owner since it will be populated by platform_driver_register(). Likewise for mcb_driver (gpio-menz127.c). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-05gpio: tc3589x: make explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: drivers/gpio/Kconfig:config GPIO_TC3589X drivers/gpio/Kconfig: bool "TC3589X GPIOs" ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init was not in use by this code, the init ordering remains unchanged with this commit. We also delete the MODULE_LICENSE tag etc. since all that information is already contained at the top of the file in the comments. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Hanumath Prasad <hanumath.prasad@stericsson.com> Cc: linux-gpio@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-05gpio: tc3589x: implement open drain/source callbackLinus Walleij
This makes use of the new .set_single_ended() callback to set the GPIO line as open drain/open source using hardware. The TC3589x can do this by either disabling the N-MOS transistor (open drain) or the P-MOS transistor (open source) of the output driver stage, in the first case making the signal drive actively low and high impedance as "high" and in the second case actively high and high impedance, which is as close to native open drain support as we come. Cc: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-05gpio: tc3589x: use BIT() macroLinus Walleij
This switch to use BIT(n) instead of (1 << n) which is less to the point. Most GPIO drivers do this to avoid mistakes. Also switch from using <linux/gpio.h> to the apropriate <linux/gpio/driver.h> include. Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-23gpio: tc3589x: Use devm_gpiochip_add_data() for gpio registrationLaxman Dewangan
Use devm_gpiochip_add_data() for GPIO registration and remove the need of driver callback .remove. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com>
2016-01-05gpio: tc3589x: use gpiochip data pointerLinus Walleij
This makes the driver use the data pointer added to the gpio_chip to store a pointer to the state container instead of relying on container_of(). Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-26gpio: tc3589x: Be sure to clamp return valueLinus Walleij
As we want gpio_chip .get() calls to be able to return negative error codes and propagate to drivers, we need to go over all drivers and make sure their return values are clamped to [0,1]. We do this by using the ret = !!(val) design pattern. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-19gpio: change member .dev to .parentLinus Walleij
The name .dev in a struct is normally reserved for a struct device that is let us say a superclass to the thing described by the struct. struct gpio_chip stands out by confusingly using a struct device *dev to point to the parent device (such as a platform_device) that represents the hardware. As we want to give gpio_chip:s real devices, this is not working. We need to rename this member to parent. This was done by two coccinelle scripts, I guess it is possible to combine them into one, but I don't know such stuff. They look like this: @@ struct gpio_chip *var; @@ -var->dev +var->parent and: @@ struct gpio_chip var; @@ -var.dev +var.parent and: @@ struct bgpio_chip *var; @@ -var->gc.dev +var->gc.parent Plus a few instances of bgpio that I couldn't figure out how to teach Coccinelle to rewrite. This patch hits all over the place, but I *strongly* prefer this solution to any piecemal approaches that just exercise patch mechanics all over the place. It mainly hits drivers/gpio and drivers/pinctrl which is my own backyard anyway. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Alek Du <alek.du@intel.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-27gpio: tc3589x: use static container helperLinus Walleij
There is a helper function to do the container_of() magic for the tc3589x GPIO, so use it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-26mfd: tc3589x: Enforce device-tree only modeLinus Walleij
All systems using the TC3589x multifunction expander uses devicetree, so don't clutter the place with a lot of and assume it is there. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-01-15gpio: tc3589x: get rid of platform dataLinus Walleij
This device is only used from the device tree, and the startup() and remove() callbacks are not used anywhere in the kernel, so retire them and the pdata altogether. Cc: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-11-25mfd: tc3589x: get rid of static baseLinus Walleij
The TC3589x driver is now a device tree-only driver, so we want only dynamic IRQs and GPIO numbers from the tc3589x, no static assignments. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-26gpio: handle also nested irqchips in the chained handler set-upLinus Walleij
To unify how we connect cascaded IRQ chips to parent IRQs, if NULL us passed as handler to the gpiochip_set_chained_irqchip() function, assume the chips is nested rather than chained, and we still get the parent set up correctly by way of this function call. Alter the drivers for tc3589x and stmpe to use this to set up their chained handlers as a demonstration of the usage. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: use gpiolib irqchip helpersLinus Walleij
Now that the gpiolib irqchip helpers can support nested, threaded IRQ handlers, switch the TC3589x driver over to using this new infrastructure. Tested on the Ux500. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: get rid of static IRQ baseLinus Walleij
The static IRQ base is not used on any platforms with this chip (only Ux500). Get rid of it forever, and rely on dynamic IRQ descriptor allocation. Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: use managed resourcesLinus Walleij
Grab state container and irq using the devm_* functions and save some lines of hairy clean-up code. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-11gpio: tc3589x: drop references to "virtual" IRQLinus Walleij
Rename the argument "virq" to just "irq", this IRQ isn't any more "virtual" than any other Linux IRQ number, we use "hwirq" for the actual hw-numbers, "virq" is just bogus. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-30gpio: tc3589x: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-27gpio: gpio-tc3589x.c: fix checkpatch errorsLaurent Navet
Fix : gpio/gpio-tc3589x.c:285: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:286: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:287: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:347: ERROR: code indent should use tabs where possible Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-26gpio/tc3589x: convert to use the simple irqdomainLinus Walleij
The special checks for whether we have a base IRQ offset or not is surplus if we use the simple IRQ domain. The IRQ offset zero will be interpreted as a linear domain case. Plus this makes sure we allocate descriptors where need be, or warn if they are preallocated with SPARSE_IRQ. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-12gpio: Enable the tc3298x GPIO expander driver for Device TreeLee Jones
Here we provide a means to probe and extract vital information from Device Tree when booting with it enabled. Without this patch sub-devices wouldn't be able to reference the tc3589x-gpio expander from Device Tree. CC: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-12gpio: Provide the tc3589x GPIO expander driver with an IRQ domainLee Jones
In preparation for Device Tree enablement all IRQ controllers should control their own IRQ domain. This patch provides just that for the tc3589x GPIO expander. CC: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
