path: root/drivers/gpio/gpio-mxc.c
2016-10-05Merge tag 'gpio-v4.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.9 series: Subsystem improvements: - do away with the last users of the obsolete Kconfig options ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter always sounded like an item on a wishlist to Santa Claus to me). We can now select GPIOLIB and be done with it, for all archs. After some struggle it even work on UM. Not that it has GPIO, but if it wants to, it can select the library. - continued efforts to make drivers properly either tristate or bool. - introduce a warning for drivers assigning default triggers to their irqchip lines when probed from device tree, so we find and fix these ambigous drivers. It is agreed that in the OF config path, the device tree defines trigger characteristics. - the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips. - we introduce the ability to mark certain IRQ lines as "unusable" as they can be taken by BIOS/firmware, unrouted in silicon and generally nasty if you use them, and such things. This is put to good use in the STMPE driver and also in the Cherryview pin control driver. - a new "mockup" virtual GPIO device that can be used for testing. The plan is to add unit tests under tools/* for exercising this device and verify that the kernel code paths are working as they should. - make memory-mapped I/O-drivers depend on HAS_IOMEM. This was implicit all the time, but when people started building UM with allyesconfig or allmodconfig it exploded in their face. - move some stray bits of device tree and ACPI HW description callbacks down into their respective implementation silo. These were causing issues when compiling on !HAS_IOMEM as well, so now eventually UM compiles the GPIOLIB library if it wants to. New drivers: - new driver for the Aspeed GPIO front-end companion to the pin controller merged through the pin control tree. - new driver for the LP873x PMIC GPIO portions. - new driver for Technologic Systems' I2C FPGA GPIO such as TS4900, TS-7970, TS-7990 and TS-4100. - new driver for the Broadcom BCM63xx series including BCM6338 and BCM6345. - new driver for the Intel WhiskeyCove PMIC GPIO. - new driver for the Allwinner AXP209 PMIC GPIO portions. - new driver for Diamond Systems 48 line GPIO-MM, another of these port-mapped I/O expansion cards. - support the STMicroelectronics STMPE1600 variant in the STMPE driver. Driver improvements: - the STMPE driver now supports rising/falling edge detection properly for IRQs. - the PCA954x will now fetch and enable its VCC regulator properly. - major rework of the PCA953x driver with the goal of eventually switching it over to use regmap and thus modernize it even more. - switch the IOP driver to use the generic MMIO GPIO library. - move the ages old HTC EGPIO (extended GPIO) GPIO expander driver over to this subsystem from MFD, achieveing some separation of concerns" * tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits) gpio: add missing static inline gpio: OF: localize some gpiochip init functions gpio: acpi: separation of concerns gpio: OF: separation of concerns gpio: make memory-mapped drivers depend on HAS_IOMEM gpio: stmpe: use BIT() macro gpio: stmpe: forbid unused lines to be mapped as IRQs mfd/gpio: Move HTC GPIO driver to GPIO subsystem gpio: MAINTAINERS: Add an entry for GPIO mockup driver gpio/mockup: add virtual gpio device gpio: Added zynq specific check for special pins on bank zero gpio: axp209: Implement get_direction gpio: aspeed: remove redundant return value check gpio: loongson1: remove redundant return value check ARM: omap2: fix missing include gpio: tc3589x: fix up complaints on unsigned gpio: tc3589x: add .get_direction() and small cleanup gpio: f7188x: use gpiochip_get_data instead of container_of gpio: tps65218: use devm_gpiochip_add_data() for gpio registration gpio: aspeed: fix return value check in aspeed_gpio_probe() ...
2016-09-12gpio: mxc: add generic gpio request/free callbacks to pinctrlVladimir Zapolskiy
If a GPIO controller description in board DTB contains information about mappings between GPIOs and pads under IOMUX control use it to request and free GPIOs with respect to pinctrl/pinmux subsystems. One of immediate positive functional changes is inability to request non-existing GPIOs, i.e. if there is no pad such. Also pinctrl/pinmux may now properly account pads occupied by requested GPIOs. The change has no effect, if "gpio-ranges" property is not found including the case if a board has no DTB firmware. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-12gpio: mxc: shift gpio_mxc_init() to subsys_initcall levelVladimir Zapolskiy
In general situation on-SoC GPIO controller drivers should be probed after pinctrl/pinmux controller driver, because on-SoC GPIOs utilize a pin/pad as a resource provided and controlled by pinctrl subsystem. This is stated in multiple places, e.g. from drivers/Makefile: GPIO must come after pinctrl as gpios may need to mux pins etc Looking at Freescale iMX SoC series specifics, imx*_pinctrl_init() functions are called at arch_initcall and postcore_initcall init levels, so the change of initcall level for gpio-mxc driver from postcore_initcall to subsys_initcall level is sufficient. Also note that the most of GPIO controller drivers settled at subsys_initcall level. If pinctrl subsystem manages pads with GPIO functions, the change is needed to avoid unwanted driver probe deferrals during kernel boot. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-08-23gpio: mxc: drop unused MODULE_ tags from non-modular codePaul Gortmaker
The Kconfig currently controlling compilation of this code is: drivers/gpio/Kconfig:config GPIO_MXC drivers/gpio/Kconfig: def_bool y ...meaning that it currently is not being built as a module by anyone. Lets remove the couple traces of modular infrastructure use, so that when reading the driver there is no doubt it is builtin-only. We delete the MODULE_LICENSE tag etc. since all that information was (or is now) contained at the top of the file in the comments. Note the original e-mail had a missing/typo'd @ symbol anyway. We don't replace module.h with init.h since the file already has that. Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Daniel Mack <daniel@caiaq.de> Cc: Juergen Beisert <kernel@pengutronix.de> Cc: linux-gpio@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-23gpio: mxc: Use devm_gpiochip_add_data() for gpio registrationLaxman Dewangan
Use devm_gpiochip_add_data() for GPIO registration and clean the error path. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com>
2016-01-05gpio: generic: factor into gpio_chip structLinus Walleij
The separate struct bgpio_chip has been a pain to handle, both by being confusingly similar in name to struct gpio_chip and for being contained inside a struct so that struct gpio_chip is contained in a struct contained in a struct, making several steps of dereferencing necessary. Make things simpler: include the fields directly into <linux/gpio/driver.h>, #ifdef:ed for CONFIG_GENERIC_GPIO, and get rid of the <linux/basic_mmio_gpio.h> altogether. Prefix some of the member variables with bgpio_* and add proper kerneldoc while we're at it. Modify all users to handle the change and use a struct gpio_chip directly. And while we're at it: replace all container_of() dereferencing by gpiochip_get_data() and registering the gpio_chip with gpiochip_add_data(). Cc: arm@kernel.org Cc: Alexander Shiyan <shc_work@mail.ru> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Kukjin Kim <kgene@kernel.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Brian Norris <computersforpeace@gmail.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Olof Johansson <olof@lixom.net> Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Rabin Vincent <rabin@rab.in> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: bcm-kernel-feedback-list@broadcom.com Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-10-15gpio-mxc: stop including <asm-generic/bug>Christoph Hellwig
<asm-generic/bug> contains the default implementation of BUG() and friends, which architectures may decide to use. The proper way to get them is <linux/bug.h>, so use that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-09-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This is a rather large update post rc1 due to the final steps of cleanups and API changes which had to wait for the preparatory patches to hit your tree. - Regression fixes for ARM GIC irqchips - Regression fixes and lockdep anotations for renesas irq chips - The leftovers of the cleanup and preparatory patches which have been ignored by maintainers - Final conversions of the newly merged users of obsolete APIs - Final removal of obsolete APIs - Final removal of ARM artifacts which had been introduced during the conversion of ARM to the generic interrupt code. - Final split of the irq_data into chip specific and common data to reflect the needs of hierarchical irq domains. - Treewide removal of the first argument of interrupt flow handlers, i.e. the irq number, which is not used by the majority of handlers and simple to retrieve from the other argument the irq descriptor. - A few comment updates and build warning fixes" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) arm64: Remove ununsed set_irq_flags ARM: Remove ununsed set_irq_flags sh: Kill off set_irq_flags usage irqchip: Kill off set_irq_flags usage gpu/drm: Kill off set_irq_flags usage genirq: Remove irq argument from irq flow handlers genirq: Move field 'msi_desc' from irq_data into irq_common_data genirq: Move field 'affinity' from irq_data into irq_common_data genirq: Move field 'handler_data' from irq_data into irq_common_data genirq: Move field 'node' from irq_data into irq_common_data irqchip/gic-v3: Use IRQD_FORWARDED_TO_VCPU flag irqchip/gic: Use IRQD_FORWARDED_TO_VCPU flag genirq: Provide IRQD_FORWARDED_TO_VCPU status flag genirq: Simplify irq_data_to_desc() genirq: Remove __irq_set_handler_locked() pinctrl/pistachio: Use irq_set_handler_locked gpio: vf610: Use irq_set_handler_locked powerpc/mpc8xx: Use irq_set_handler_locked() powerpc/ipic: Use irq_set_handler_locked() powerpc/cpm2: Use irq_set_handler_locked() ...
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-14gpio: mxc: need to check return value of irq_alloc_generic_chipPeng Fan
Need to check return value of irq_alloc_generic_chip, because it may return NULL. 1. Change mxc_gpio_init_gc return type from void to int. 2. Add a new lable out_irqdomain_remove to remove the irq domain when mxc_gpio_init_gc fail. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Alexandre Courbot <gnurou@gmail.com> [Manually rebased] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-13gpio: mxc: fix section mismatch warningDirk Behme
Fix the section mismatch warning WARNING: vmlinux.o(.text+0x2b2788): Section mismatch in reference from the function mxc_gpio_probe() to the function .init.text:mxc_gpio_init_gc() The function mxc_gpio_probe() references the function __init mxc_gpio_init_gc(). This is often because mxc_gpio_probe lacks a __init annotation or the annotation of mxc_gpio_init_gc is wrong. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-13gpio/mxc: mask gpio interrupts in suspendUlises Brindis
Currently in the FSL platform all GPIO interrupts in a bank are muxed into two GPIO lines to the GPC interrupt controller. In each GPIO bank GPIOs 0-15 are OR'ed into one GPC interrupt controller interrupt and 16-31 are OR'ed into another. With the current code, if any of the 0-15 or 16-31 interrupts are marked as wakeup capable, all interrupts belonging to that sub-bank (either 0-15 or 16-31) will wake up the device. This is because interrupts are only being masked at the interrupt controller and not at the GPIO controller. This patch allows masking of GPIO interrupts at the GPIO controller during suspend if they have not been labeled wakeup capable. This patch uses preexisting IRQCHIP_MASK_ON_SUSPEND flag while initializing the GPIO interrupts to get the desired behavior. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: linux-gpio@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Ulises Brindis <ubrindis56@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-14gpio: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Preparatory patch for the removal of the 'irq' argument from irq flow handlers. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-23Merge tag 'gpio-v4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio updates from Linus Walleij: "This is the big bulk of GPIO changes queued for the v4.2 kernel series: - a big set of cleanups to the aged sysfs interface from Johan Hovold. To get these in, v4.1-rc3 was merged into the tree as the first patch in that series had to go into stable. This makes the locking much more fine-grained (get rid of the "big GPIO lock(s)" and store states in the GPIO descriptors. - rename gpiod_[g|s]et_array() to gpiod_[g|s]et_array_value() to avoid confusions. - New drivers for: * NXP LPC18xx (currently LPC1850) * NetLogic XLP * Broadcom STB SoC's * Axis ETRAXFS * Zynq Ultrascale+ (subdriver) - ACPI: * make it possible to retrieve GpioInt resources from a GPIO device using acpi_dev_gpio_irq_get() * merge some dependent I2C changes exploiting this. * support the ARM X-Gene GPIO standby driver. - make it possible for the generic GPIO driver to read back the value set registers to reflect current status. - loads of OMAP IRQ handling fixes. - incremental improvements to Kona, max732x, OMAP, MXC, RCAR, PCA953x, STP-XWAY, PCF857x, Crystalcove, TB10x. - janitorial (constification, checkpatch cleanups)" * tag 'gpio-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits) gpio: Fix checkpatch.pl issues gpio: pcf857x: handle only enabled irqs gpio / ACPI: Return -EPROBE_DEFER if the gpiochip was not found GPIO / ACPI: export acpi_gpiochip_request(free)_interrupts for module use gpio: improve error reporting on own descriptors gpio: promote own request failure to pr_err() gpio: Added support to Zynq Ultrascale+ MPSoC gpio: add ETRAXFS GPIO driver fix documentation after renaming gpiod_set_array to gpiod_set_array_value gpio: Add GPIO support for Broadcom STB SoCs gpio: xgene: add ACPI support for APM X-Gene GPIO standby driver gpio: tb10x: Drop unneeded free_irq() call gpio: crystalcove: set IRQCHIP_SKIP_SET_WAKE for the irqchip gpio: stp-xway: Use the of_property_read_u32 helper gpio: pcf857x: Check for irq_set_irq_wake() failures gpio-stp-xway: Fix enabling the highest bit of the PHY LEDs gpio: Prevent an integer overflow in the pca953x driver gpio: omap: rework omap_gpio_irq_startup to handle current pin state properly gpio: omap: rework omap_gpio_request to touch only gpio specific registers gpio: omap: rework omap_x_irq_shutdown to touch only irqs specific registers ...
2015-06-18gpio: gpio-mxc: Fix race in installing chained IRQ handlerRussell King
Fix a race where a pending interrupt could be received and the handler called before the handler's data has been setup, by converting to irq_set_chained_handler_and_data(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Lee Jones <lee.jones@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/E1Z4z0C-0002SX-Lj@rmk-PC.arm.linux.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-12gpio: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-11gpio: mxc: read output value from GPIO_DR registerVladimir Zapolskiy
All supported iMX GPIO controllers store configured GPIO output value in GPIO_DR data register, which is represented by GPIO generic reg_set. Provide a BGPIOF_READ_OUTPUT_REG_SET flag to bgpio_init() to allow correct getting of previously set output value. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20gpio: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-02gpio: mxc: Do not hard code return valueSachin Kamat
Silences the following warning: why not propagate 'port->irq' from platform_get_irq() instead of (-22)? Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-16gpio/mxc: add chained_irq_enter/exit() to mx2_gpio_irq_handlerUwe Kleine-König
Similar to commit 0e44b6e (gpio/mxc: add chained_irq_enter/exit() to mx3_gpio_irq_handler()) . It doesn't seem to be critical to make the irqs work, but still it is more correct. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-23gpio: gpio-mxc: Include "<linux/err.h>"Fabio Estevam
Commit 8cd73e4e (gpio: gpio-mxc: Use devm functions) causes the following build error on imx_v4_v7_defconfig: drivers/gpio/gpio-mxc.c:414:2: error: implicit declaration of function 'IS_ERR' [-Werror=implicit-function-declaration] drivers/gpio/gpio-mxc.c:415:3: error: implicit declaration of function 'PTR_ERR' [-Werror=implicit-function-declaration] Note: imx_v6_v7_defconfig does not give this build error, probably due to some indirect header file inclusion. Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-20gpio: gpio-mxc: Use devm functionsFabio Estevam
By using devm functions we can get a simpler code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-26arm: Move chained_irq_(enter|exit) to a generic fileCatalin Marinas
These functions have been introduced by commit 10a8c383 (irq: introduce entry and exit functions for chained handlers) in asm/mach/irq.h. This patch moves them to linux/irqchip/chained_irq.h so that generic irqchip drivers do not rely on architecture specific header files. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-07gpio/mxc: specify gpio base for device tree probeShawn Guo
Currently, unlike the non-DT probe where the gpio base is specified with pdev->id, the DT probe uses the base dynamically allocated by gpio core, which uses a completely different numbering scheme. This causes two issues to user space applications which access sysfs entry /sys/class/gpio/gpioN. * It breaks the compatibility with user space applications between non-DT and DT kernels. * It's not intuitive and sometimes hard for users to map the Linux gpio number to the actual hardware pin. Use alias to identify the gpio port/bank, and then the gpio base can be specified with port id to solve above issues. If alias is not defined in device tree, the base number dynamically allocated by gpio core will be used. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-08-07gpio/mxc: remove redundant shadow variables initializationShawn Guo
With commit 3e11f7b (gpio/generic: initialize basic_mmio_gpio shadow variables properly) in place, the shadow variables initialization is being done in generic driver bgpio_init call. Remove the redundant shadow variables initialization from gpio-mxc driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-26Merge tag 'gpio-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: - New driver for AMD-8111 southbridge GPIOs - New driver for Wolfson Micro Arizona devices - Propagate device tree parse errors - Probe deferral finalizations - all expected calls to GPIO will now hopefully request deferral where apropriate - Misc updates to TCA6424, WM8994, LPC32xx, PCF857x, Samsung MXC, OMAP and PCA953X drivers. Fix up gpio_idx conflicts in drivers/gpio/gpio-mxc.c * tag 'gpio-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: of_get_named_gpio_flags() return -EPROBE_DEFER if GPIO not yet available gpiolib: Defer failed gpio requests by default MAINTAINERS: add entry OMAP GPIO driver gpio/pca953x: increase variables size to support 24 bit of data GPIO: PCA953X: Increase size of invert variable to support 24 bit gpio/omap: move bank->dbck initialization to omap_gpio_mod_init() gpio/mxc: use the edge_sel feature if available gpio: propagate of_parse_phandle_with_args errors gpio: samsung: add flags specifier to device-tree binding gpiolib: Add support for Wolfson Microelectronics Arizona class devices gpio: gpio-lpc32xx: Add gpio_to_irq mapping gpio: pcf857x: share 8/16 bit access functions gpio: LPC32xx: Driver cleanup MAINTAINERS: Add Wolfson gpiolib drivers to the Wolfson entry gpiolib: wm8994: Convert to devm_kzalloc() gpiolib: wm8994: Use irq_domain mappings for gpios gpio: add a driver for GPIO pins found on AMD-8111 south bridge chips gpio/tca6424: merge I2C transactions, remove cast gpio/of: fix a typo of comment message
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-17gpio/mxc: use the edge_sel feature if availableBenoît Thébaudeau
Some mxc processors have an edge_sel feature, which allows the IRQ to be triggered by any edge. This patch makes use of this feature if available, which skips mxc_flip_edge(). Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Sascha Hauer <kernel@pengutronix.de> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-05gpio/mxc: make irqs work for fsl,imx21-gpio devicesUwe Kleine-König
The chained handler was set for the platform device with id == 0. When the gpio devices are instantiated by a device tree, all have id == -1 and so the handler was unset resulting in unusable gpio irqs on i.MX21 and i.MX27 (when using oftree). Acked-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-01gpio/mxc: move irq_domain_add_legacy call into gpio driverShawn Guo
Move irq_domain_add_legacy call from imx*-dt.c into gpio driver and have the gpio driver adopt irqdomain support for both DT and non-DT boot. With all imx platform code converted from static gpio irq number computation to use run-time gpio_to_irq call, we can now use irq_alloc_descs and irqdomain support to dynamically get irq_base and have the mapping between gpio and irq number available without using virtual_irq_start and MXC_GPIO_IRQ_START. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-05-19gpio/generic: initialize basic_mmio_gpio shadow variables properlyShawn Guo
It fixes the issue in gpio-generic that commit fb14921 (gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables) manged to fix in gpio-mxc driver, so that other platform specific drivers do not suffer from the same problem over and over again. Changes since v1: * Turn the last parameter of bgpio_init() "bool big_endian" into "unsigned long flags" and give those really quirky hardwares a chance to tell that reg_set and reg_dir are unreadable. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> [grant.likely: Fix big-endian usage to explicitly set BBGPIOF_BIG_ENDIAN] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-01Merge branch 'next/cleanup' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits) ARM: mach-mxs: fix machines' initializers order mmc: mxcmmc: explicitly includes mach/hardware.h arm/imx: explicitly includes mach/hardware.h in pm-imx27.c arm/imx: remove mx27_setup_weimcs() from mx27.h arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c arm/imx: remove mx31_setup_weimcs() from mx31.h ARM: tegra: devices.c should include devices.h ARM: tegra: cpu-tegra: unexport two functions ARM: tegra: cpu-tegra: sparse type fix ARM: tegra: dma: staticify some tables and functions ARM: tegra: tegra2_clocks: don't export some tables ARM: tegra: tegra_powergate_is_powered should be static ARM: tegra: tegra_rtc_read_ms should be static ARM: tegra: tegra_init_cache should be static ARM: tegra: pcie: 0 -> NULL changes ARM: tegra: pcie: include board.h ARM: tegra: pcie: don't cast __iomem pointers ARM: tegra: tegra2_clocks: 0 -> NULL changes ARM: tegra: tegra2_clocks: don't cast __iomem pointers ARM: tegra: timer: don't cast __iomem pointers ... Fix up trivial conflicts in arch/arm/mach-omap2/Makefile, arch/arm/mach-u300/{Makefile.boot,core.c} arch/arm/plat-{mxc,omap}/devices.c
2011-10-31drivers/gpio: Fix drivers who are implicit users of module.hPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in gpio are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-21gpio/mxc: add chained_irq_enter/exit() to mx3_gpio_irq_handler()Shawn Guo
The mx3_gpio_irq_handler() is also called on imx6q which has GIC as the primary interrupt controller. As GIC implements the fasteoi flow control, we need to add chained_irq_enter/exit() to mx3_gpio_irq_handler() for signaling EOI, otherwise system will hang whenever there is a gpio irq triggered. v2: use chained_irq_{enter,exit}() Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-17gpio/mxc: move irq_to_gpio() into gpio-mxc driverShawn Guo
As irq_to_gpio() is only being used by gpio-mxc driver, it should be moved from mach/gpio.h into gpio-mxc.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-16gpio/mxc: add .to_irq for gpio chipShawn Guo
It adds .to_irq support for gpio chip, so that __gpio_to_irq in gpiolib becomes usable. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-19gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renamingShawn Guo
The following commit renames irq_gc_ack() to irq_gc_ack_set_bit(), and makes gpio-mxc and gpio-mxs fail to build. 659fb32d1b67476f4ade25e9ea0e2642a5b9c4b5 genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd) The patch fixed a couple of typo of comma to semicolon. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08gpio/mxc: add device tree probe supportShawn Guo
The patch adds device tree probe support for gpio-mxc driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08gpio/mxc: get rid of the uses of cpu_is_mx()Shawn Guo
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes platform_device_id to distinguish the different gpio types, IMX1_GPIO on i.mx1, IMX21_GPIO on i.mx21 and i.mx27, IMX31_GPIO on all other i.mx SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-07gpio/mxc: add missing initialization of basic_mmio_gpio shadow variablesLothar Waßmann
The bgpio_init() function does not initialise the shadow register for the GPIO direction register. Thus, when configuring the first GPIO with gpio_set_direction() all other GPIOs of the same bank will be configured as inputs. Since the bgpio layer cannot know whether the register is readable, the initialisation should be done by the caller of bgpio_init(). Also, the 'data' shadow variable that is used inside basic_mmio_gpio to cache the current value of the GPIO_DR register is initialised from the GPIO_PSR register within bgpio_init(). Thus when setting the output value of a certain GPIO, the other GPIO outputs of the same bank will be set or cleared depending on the pin state of the GPIO inputs during bgpio_init(). Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-11gpio/mxc: fix a bug with gpio_get_value callingShawn Guo
When calling gpio_get_value, the gpio number other than bit offset should be passed as the argument. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-07gpio/mxc: convert gpio-mxc to use generic irq chipShawn Guo
The patch converts gpio-mxc driver to use generic irq chip. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/mxc: convert gpio-mxc to use basic_mmio_gpio libraryShawn Guo
The gpio-mxc controller complies with basic_mmio_gpio library. The patch convert the driver to use the library. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/mxc: Change gpio-mxc into an upstanding gpio driverShawn Guo
The patch makes necessary changes on gpio-mxc as below to turn it into an upstanding gpio driver. * Add a list to save all mx2 ports references, so that mx2_gpio_irq_handler can walk through all interrupt status registers * Use readl/writel to replace mach-specific accessors __raw_readl/__raw_writel * Change mxc_gpio_init into mxc_gpio_probe function * Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to be public at all, and also make some other cleanup on plat-mxc/include/mach/gpio.h at the same time And the patch then migrates mach-imx and mach-mx5 to the updated driver by adding corresponding platform devices. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/mxc: Move Freescale MXC gpio driver to drivers/gpioShawn Guo
GPIO drivers are getting moved to drivers/gpio for cleanup and consolidation. This patch moves the plat-mxc driver. Follow up patches will clean it up and make it a fine upstanding gpio driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
