path: root/drivers/firmware
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix several typos in drivers/Matt LaPlante
2006-10-03[PATCH] pr_debug: dell_rbu: fix pr_debug argument warningsZach Brown
dell_rbu: fix pr_debug argument warnings Use size_t length modifier when outputting size_t and use %p instead of %lu for 'u8 *'. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] DMI: Decode and save OEM String informationShem Multinymous
This teaches dmi_decode() how to decode and save OEM Strings (type 11) DMI information, which is currently discarded silently. Existing code using DMI is not affected. Follows the "System Management BIOS (SMBIOS) Specification" (http://www.dmtf.org/standards/smbios), and also the userspace dmidecode.c code. OEM Strings are the only safe way to identify some hardware, e.g., the ThinkPad embedded controller used by the soon-to-be-submitted tp_smapi driver. This will also let us eliminate the long whitelist in the mainline hdaps driver (in a future patch). Signed-off-by: Shem Multinymous <multinymous@gmail.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] DMI: cleanup kernel-doc, add to DocBookRandy Dunlap
Add DMI interface functions to a new Firmware Interfaces chapter in the kernel-api DocBook. Clean up kernel-doc in drivers/firmware/dmi_scan.c. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] EDD isn't EXPERIMENTAL anymoreChris Wedgwood
Lots of people use this. Apparently RH has for over 18 months so lets drop EXPERIMENTAL. Signed-off-by: Chris Wedgwood <cw@f00f.org> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-14[PATCH] DMI: move dmi_scan.c from arch/i386 to drivers/firmware/Bjorn Helgaas
dmi_scan.c is arch-independent and is used by i386, x86_64, and ia64. Currently all three arches compile it from arch/i386, which means that ia64 and x86_64 depend on things in arch/i386 that they wouldn't otherwise care about. This is simply "mv arch/i386/kernel/dmi_scan.c drivers/firmware/" (removing trailing whitespace) and the associated Makefile changes. All three architectures already set CONFIG_DMI in their top-level Kconfig files. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andi Kleen <ak@muc.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andrey Panin <pazke@orbita1.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: drivers: raw, connector, dcdbas, ppp_genericArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] dcdbas: convert to the new platform device interfaceDmitry Torokhov
Do not use platform_device_register_simple() as it is going away, define dcdbas_driver and implement ->probe() and ->remove() functions so manual binding and unbinding will work with this driver. Also switch to using attribute_group when creating sysfs attributes and make sure to check and handle errors; explicitely remove attributes when detaching driver. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] dcdbas: dcdbas_pdev referenced after platform_device_unregister on exitDoug Warzecha
smi_data_buf_free() references dcdbas_pdev when calling dma_free_coherent(). In dcdbas_exit(), smi_data_buf_free() is called after platform_device_unregister(dcdbas_pdev). This patch moves platform_device_unregister(dcdbas_pdev) after smi_data_buf_free() in dcdbas_exit(). Signed-off-by: Doug Warzecha <Douglas_Warzecha@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] dell_rbu: fix Bug 5854Abhay Salunke
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=5854 Root cause: The dell_rbu driver creates entries in /sys/class/firmware/dell_rbu/ by calling request_firmware_nowait (without hotplug ) this function inturn starts a kernel thread which creates the entries in /sys/class/firmware/dell_rbu/loading , data and the thread waits on the user action to return control back to the callback fucntion of dell_rbu. The thread calls wait_on_completion which puts it in a D state until the user action happens. If there is no user action happening the load average goes up as the thread D state is taken in to account. Also after downloading the BIOS image the enrties go away momentarily but they are recreated from the callback function in dell_rbu. This causes the thread to get recreated causing the load average to permenently stay around 1. Fix: The dell_rbu also creates the entry /sys/devices/platform/dell_rbu/image_type at driver load time. The image type by default is mono if required the user can echo packet to image_type to make the BIOS update mechanism using packets. Also by echoing init in to image_type the /sys/class/firmware/dell_rbu entries can be created. The driver code was changed to not create /sys/class/firmware/dell_rbu entries during load time, and also to not create the above entries from the callback function. The entries are only created by echoing init to /sys/devices/platform/dell_rbu/image_type The user now needs to create the entries to download the image monolithic or packet. This fixes the issue since the kernel thread only is created when ever the user is ready to download the BIOS image; this minimizes the life span of the kernel thread and the load average goes back to normal. Signed off by Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[PATCH] dell_rbu: NULL noise removalAl Viro
2005-11-22[PATCH] dell_rbu driver depends on x86[64]Dave Jones
This driver only appears on IA32 & EM64T boxes. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] drivers/firmware: kmalloc + memset -> kzalloc conversionDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] dell_rbu: Adding BIOS memory floor supportAbhay Salunke
This patch has the changes to support the memory floor fix done in Dell BIOS. The BIOS incase of packet update mechanism would not accept packet placed in memory below a cretain address. This address is by default 128K but can change. The driver now can accept the memory floor if the user chooses to make it will try to allocate contiguous physical memory above the memory floor by allocating a set of packets till a valid memory allocation is made. All the allocates then are freed. This repeats for everty packet. This patch was created by Michael E Brown and has been tested on 2.6.14-rc5 Signed-of-by: Michael E Brown <Michael_E_Brown@Dell.com> Signed-off-by: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] Don't set dcdbas driver to default mAndi Kleen
It's nasty to set random drivers to default m because people who just press enter on make oldconfig get these. Remove the default m Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] CONFIG_IA32Brian Gerst
Add CONFIG_X86_32 for i386. This allows selecting options that only apply to 32-bit systems. (X86 && !X86_64) becomes X86_32 (X86 || X86_64) becomes X86 Signed-off-by: Brian Gerst <bgerst@didntduck.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-11[PATCH] dell_rbu: changes in packet update mechanismAbhay Salunke
In the current dell_rbu code ver 2.0 the packet update mechanism makes the user app dump every individual packet in to the driver. This adds in efficiency as every packet update makes the /sys/class/firmware/dell_rbu/loading and data files to disappear and reappear again. Thus the user app needs to wait for the files to reappear to dump another packet. This slows down the packet update tremendously in case of large number of packets. I am submitting a new patch for dell_rbu which will change the way we do packet updates; In the new method the user app will create a new single file which has already packetized the rbu image and all the packets are now staged in this file. This driver also creates a new entry in /sys/devices/platform/dell_rbu/packet_size ; the user needs to echo the packet size here before downloading the packet file. The user should do the following: create one single file which has all the packets stacked together. echo the packet size in to /sys/devices/platform/dell_rbu/packet_size. echo 1 > /sys/class/firmware/dell_rbu/loading cat the packetfile > /sys/class/firmware/dell_rbu/data echo 0 > /sys/class/firmware/dell_rbu/loading The driver takes the file which came through /sys/class/firmware/dell_rbu/data and takes chunks of paket_size data from it and place in contiguous memory. This makes packet update process very efficient and fast. As all the packet update happens in one single operation. The user can still read back the downloaded file from /sys/devices/platform/dell_rbu/data. Signed-off-by: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] dell_rbu tidyAndrew Morton
Whitespace standardisation. Cc: Abhay Salunke <Abhay_Salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] dell_rbu: enhancements and fixesAbhay Salunke
BUG fixes: The driver used to allocate memory with spinlock held which has been fixed in this patch. The driver was printing the entire buffer when it received a invalid entry in image_type. The fix is to only print a warning message and not the buffer. Usability enhancements: It is possible that due to user error the /sys/class/firmware/dell_rbu entries might be missing, this can happen if the user does the following echo 1 > /sys/class/firmware/dell_rbu/loading echo 0 > /sys/class/firmware/dell_rbu/loading This will make the entries in /sys/class/firmware/ to disappear and the only way get them back was bby unloading and loading the driver. This patch makes the user recreate these entries by echoing init in to image_type. This patch has been tested with Libsmbios and Dell OpenManage. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] dcdbas: add Dell Systems Management Base Driver with sysfs supportDoug Warzecha
This patch adds the Dell Systems Management Base Driver with sysfs support. This driver has been tested with Dell OpenManage. Signed-off-by: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] dell_rbu: new Dell BIOS update driverAbhay Salunke
Remote BIOS Update driver for updating BIOS images on Dell servers and desktops. See dell_rbu.txt for details. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] PCDP: if PCDP contains parity information, use itBjorn Helgaas
If the PCDP supplies parity, use it (only none/even/odd supported), and don't append parity/stop bit arguments unless baud is present. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[IA64] Make PCDP work again.David Mosberger-Tang
Mark's patch added "attribute((packed))" for pcdp_uart, without accounting for the fact that the structure definition _relied_ on implicit padding by 6 bytes. Fix is to make the padding explicit. Signed-off-by: David Mosberger-Tang <David.Mosberger@acm.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-28[IA64-SGI] pcdp: add PCDP pci interface supportMark Maule
Resend 2 with changes per Bjorn Helgaas comments. Changes from original: + Change globals to vga_console_iobase/vga_console_membase and make them unconditional. + Address style-related comments. Patch to extend the PCDP vga setup code to support PCI io/mem translations for the legacy vga ioport and ram spaces on architectures (e.g. altix) which need them. Summary of the changes: drivers/firmware/pcdp.c drivers/firmware/pcdp.h ----------------------- + add declaration for the spec-defined PCI interface struct (pcdp_if_pci) as well as support macros. + extend setup_vga_console() to know about pcdp_if_pci and add a couple of globals to hold the io and mem translation offsets if present. arch/ia64/kernel/setup.c ------------------------ + tweek early_console_setup() to allow multiple early console setup routines to be called. include/asm-ia64/vga.h ---------------------- + make VGA_MAP_MEM vga_console_membase aware Signed-off-by: Mark Maule <maule@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-25[PATCH] kfree cleanups for drivers/firmware/Jesper Juhl
Here's a patch with kfree() cleanups for drivers/firmware/efivars.c Patch removes redundant NULL checks before kfree and also makes a small whitespace cleanup - moves two statements on same line to separate lines. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] PCDP: handle tables that don't supply baud rateBjorn Helgaas
The HCDP specs (i.e., PCDP revision < 3) allow zero as a default value for baud rate and data bits. So if firmware doesn't supply them, let early_serial_console_init() probe for them rather than telling it the baud rate is zero. Also, update the URL for the PCDP spec. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] sysfs: (rest) if show/store is missing return -EIODmitry Torokhov
sysfs: fix the rest of the kernel so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0 or -EINVAL or -EPERM. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-31[PATCH] pcdp.c build fixPeter Chubb
In file included from drivers/firmware/pcdp.c:18: drivers/firmware/pcdp.h:48: error: field `addr' has incomplete type drivers/firmware/pcdp.c: In function `setup_serial_console': drivers/firmware/pcdp.c:27: error: `ACPI_ADR_SPACE_SYSTEM_MEMORY' undeclared (first use in this function) Cc: <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
