path: root/drivers/extcon/Kconfig
2012-04-20Extcon: support generic GPIO extcon driverMyungJoo Ham
The generic GPIO extcon driver (an external connector device based on GPIO control) and imported from Android kernel. switch: switch class and GPIO drivers. (splitted) Author: Mike Lockwood <lockwood@android.com> switch: gpio: Don't call request_irq with interrupts disabled Author: Arve Hjønnevåg <arve@android.com> switch_gpio: Add missing #include <linux/interrupt.h> Author: Mike Lockwood <lockwood@android.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- Changed from v7: - Style updates mentioned by Stephen Boyd and Mark Brown Changed from v5: - Splitted at v5 from the main extcon patch. - Added debounce time for irq handlers. - Use request_any_context_irq instead of request_irq - User needs to specify irq flags for GPIO interrupts (was fixed to IRQF_TRIGGER_LOW before) - Use module_platform_driver(). Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20Extcon (external connector): import Android's switch class and modify.MyungJoo Ham
External connector class (extcon) is based on and an extension of Android kernel's switch class located at linux/drivers/switch/. This patch provides the before-extension switch class moved to the location where the extcon will be located (linux/drivers/extcon/) and updates to handle class properly. The before-extension class, switch class of Android kernel, commits imported are: switch: switch class and GPIO drivers. (splitted) Author: Mike Lockwood <lockwood@android.com> switch: Use device_create instead of device_create_drvdata. Author: Arve Hjønnevåg <arve@android.com> In this patch, upon the commits of Android kernel, we have added: - Relocated and renamed for extcon. - Comments, module name, and author information are updated - Code clean for successing patches - Bugfix: enabling write access without write functions - Class/device/sysfs create/remove handling - Added comments about uevents - Format changes for extcon_dev_register() to have a parent dev. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- Changes from v7 - Compiler error fixed when it is compiled as a module. - Removed out-of-date Kconfig entry Changes from v6 - Updated comment/strings - Revised "Android-compatible" mode. * Automatically activated if CONFIG_ANDROID && !CONFIG_ANDROID_SWITCH * Creates /sys/class/switch/*, which is a copy of /sys/class/extcon/* Changes from v5 - Split the patch - Style fixes - "Android-compatible" mode is enabled by Kconfig option. Changes from v2 - Updated name_show - Sysfs entries are handled by class itself. - Updated the method to add/remove devices for the class - Comments on uevent send - Able to become a module - Compatible with Android platform Changes from RFC - Renamed to extcon (external connector) from multistate switch - Added a seperated directory (drivers/extcon) - Added kerneldoc comments - Removed unused variables from extcon_gpio.c - Added ABI Documentation. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
