path: root/drivers/edac/i5000_edac.c
2013-01-03Drivers: edac: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Mark Gross <mark.gross@intel.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Tim Small <tim@buttersideup.com> Cc: Ranganathan Desikan <ravi@jetztechnologies.com> Cc: "Arvind R." <arvino55@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <david.daney@cavium.com> Cc: Egor Martovetsky <egor@pasemi.com> Cc: Olof Johansson <olof@lixom.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-25i5000: Fix the memory size calculation with 2R memoriesMauro Carvalho Chehab
When 2R memories are found, the memory size should be multiplied by two, otherwise, it will report half of the memory size: +-----------------------------------------------+ | mc0 | | branch0 | branch1 | | channel0 | channel1 | channel0 | channel1 | -------+-----------------------------------------------+ slot3: | 0 MB | 0 MB | 0 MB | 0 MB | slot2: | 0 MB | 0 MB | 0 MB | 0 MB | -------+-----------------------------------------------+ slot1: | 0 MB | 0 MB | 0 MB | 0 MB | slot0: | 1024 MB | 1024 MB | 1024 MB | 1024 MB | -------+-----------------------------------------------+ (the above machine have 4 x 2GB 2R memories) Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-27edac i5000, i5400: fix pointer math in i5000_get_mc_regs()Dan Carpenter
"pvt->ambase" is a u64 datatype. The intent here is to fill the first half in the first call to pci_read_config_dword() and the other half in the second. Unfortunately the pointer math is wrong so we set the wrong data. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-12edac: edac_mc_handle_error(): add an error_count parameterMauro Carvalho Chehab
In order to avoid loosing error events, it is desirable to group error events together and generate a single trace for several identical errors. The trace API already allows reporting multiple errors. Change the handle_error function to also allow that. The changes at the drivers were made by this small script: $file .=$_ while (<>); $file =~ s/(edac_mc_handle_error)\s*\(([^\,]+)\,([^\,]+)\,/$1($2,$3, 1,/g; print $file; Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: remove arch-specific parameter for the error handlerMauro Carvalho Chehab
Remove the arch-dependent parameter, as it were not used, as the MCE tracepoint weren't implemented. It probably doesn't make sense to have an MCE-specific tracepoint, as this will cost more bytes at the tracepoint, and tracepoint is not free. The changes at the EDAC drivers were done by this small perl script: $file .=$_ while (<>); $file =~ s/(edac_mc_handle_error)\s*\(([^\;]+)\,([^\,\)]+)\s*\)/$1($2)/g; print $file; Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: Convert debugfX to edac_dbg(X,Joe Perches
Use a more common debugging style. Remove __FILE__ uses, add missing newlines, coalesce formats and align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: Use more normal debugging macro styleJoe Perches
Convert macros to a simpler style and enforce appropriate format checking when not CONFIG_EDAC_DEBUG. Use fmt and __VA_ARGS__, neaten macros. Move some string arrays to the debugfx uses and remove the now unnecessary CONFIG_EDAC_DEBUG variable block definitions. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: Don't add __func__ or __FILE__ for debugf[0-9] msgsMauro Carvalho Chehab
The debug macro already adds that. Most of the work here was made by this small script: $f .=$_ while (<>); $f =~ s/(debugf[0-9]\s*\(\s*)__FILE__\s*": /\1"/g; $f =~ s/(debugf[0-9]\s*\(\s*)__FILE__\s*/\1/g; $f =~ s/(debugf[0-9]\s*\(\s*)__FILE__\s*"MC: /\1"/g; $f =~ s/(debugf[0-9]\s*\(\")\%s[\:\,\(\)]*\s*([^\"]*\s*[^\)]+)__func__\s*\,\s*/\1\2/g; $f =~ s/(debugf[0-9]\s*\(\")\%s[\:\,\(\)]*\s*([^\"]*\s*[^\)]+),\s*__func__\s*\)/\1\2)/g; $f =~ s/(debugf[0-9]\s*\(\"MC\:\s*)\%s[\:\,\(\)]*\s*([^\"]*\s*[^\)]+)__func__\s*\,\s*/\1\2/g; $f =~ s/(debugf[0-9]\s*\(\"MC\:\s*)\%s[\:\,\(\)]*\s*([^\"]*\s*[^\)]+),\s*__func__\s*\)/\1\2)/g; $f =~ s/\"MC\: \\n\"/"MC:\\n"/g; print $f; After running the script, manual cleanups were done to fix it the remaining places. While here, removed the __LINE__ on most places, as it doesn't actually give useful info on most places. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: Get rid of the old kobj's from the edac mc codeMauro Carvalho Chehab
Now that al users for the old kobj raw access are gone, we can get rid of the legacy kobj-based structures and data. Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11edac: Rename the parent dev to pdevMauro Carvalho Chehab
As EDAC doesn't use struct device itself, it created a parent dev pointer called as "pdev". Now that we'll be converting it to use struct device, instead of struct devsys, this needs to be fixed. No functional changes. Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Mark Gross <mark.gross@intel.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: Tim Small <tim@buttersideup.com> Cc: Ranganathan Desikan <ravi@jetztechnologies.com> Cc: "Arvind R." <arvino55@gmail.com> Cc: Olof Johansson <olof@lixom.net> Cc: Egor Martovetsky <egor@pasemi.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Joe Perches <joe@perches.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Hitoshi Mitake <h.mitake@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Niklas Söderlund" <niklas.soderlund@ericsson.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28i5000: Fix the fatal error handlingMauro Carvalho Chehab
The fatal error channel bits point to a single channel, and not to a range of channels. Fix the code to properly report it, instead of printing messages like: kernel: EDAC MC0: INTERNAL ERROR: channel-b out of range (4 >= 4) Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28i5000_edac: Fix the logic that retrieves memory informationMauro Carvalho Chehab
The logic there is broken: it basically creates two csrows for each DIMM and assumes that all DIMM's are dual rank. Only one of the csrows will contain the entire DIMM size. If single rank memories are found, they'll be marked with 0 bytes. The check if the AMB is present were also wrong. Yet, as the error reports don't use the memory size in order to credit an error to the right DIMM, that part of the driver seems to work. That's why probably nobody detected the issue yet. After this patch, the memory layout is now properly reported, when debug mode is enabled, and the number of ranks per dimm is now shown: calculate_dimm_size: ---------------------------------------------------------- calculate_dimm_size: slot 3 0 MB | 0 MB | 0 MB | 0 MB | calculate_dimm_size: slot 2 0 MB | 0 MB | 0 MB | 0 MB | calculate_dimm_size: ---------------------------------------------------------- calculate_dimm_size: slot 1 0 MB | 0 MB | 0 MB | 0 MB | calculate_dimm_size: slot 0 512 MB 1R| 512 MB 1R| 512 MB 1R| 512 MB 1R| calculate_dimm_size: ---------------------------------------------------------- calculate_dimm_size: channel 0 | channel 1 | channel 2 | channel 3 | calculate_dimm_size: branch 0 | branch 1 | (1R above means that all memories on my test machine are single-ranked) Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28edac: Remove the legacy EDAC ABIMauro Carvalho Chehab
Now that all drivers got converted to use the new ABI, we can drop the old one. Acked-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28i5000_edac: convert driver to use the new edac ABIMauro Carvalho Chehab
The legacy edac ABI is going to be removed. Port the driver to use and benefit from the new API functionality. Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28edac: move nr_pages to dimm structMauro Carvalho Chehab
The number of pages is a dimm property. Move it to the dimm struct. After this change, it is possible to add sysfs nodes for the DIMM's that will properly represent the DIMM stick properties, including its size. A TODO fix here is to properly represent dual-rank/quad-rank DIMMs when the memory controller represents the memory via chip select rows. Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Mark Gross <mark.gross@intel.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: Tim Small <tim@buttersideup.com> Cc: Ranganathan Desikan <ravi@jetztechnologies.com> Cc: "Arvind R." <arvino55@gmail.com> Cc: Olof Johansson <olof@lixom.net> Cc: Egor Martovetsky <egor@pasemi.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Joe Perches <joe@perches.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Hitoshi Mitake <h.mitake@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Niklas Söderlund" <niklas.soderlund@ericsson.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28edac: Don't initialize csrow's first_page & friends when not neededMauro Carvalho Chehab
Almost all edac drivers initialize csrow_info->first_page, csrow_info->last_page and csrow_info->page_mask. Those vars are used inside the EDAC core, in order to calculate the csrow affected by an error, by using the routine edac_mc_find_csrow_by_page(). However, very few drivers actually use it: e752x_edac.c e7xxx_edac.c i3000_edac.c i82443bxgx_edac.c i82860_edac.c i82875p_edac.c i82975x_edac.c r82600_edac.c There also a few other drivers that have their own calculus formula internally using those vars. All the others are just wasting time by initializing those data. While initializing data without using them won't cause any troubles, as those information is stored at the wrong place (at csrows structure), it is better to remove what is unused, in order to simplify the next patch. Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Hitoshi Mitake <h.mitake@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Niklas Söderlund" <niklas.soderlund@ericsson.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-28edac: move dimm properties to struct dimm_infoMauro Carvalho Chehab
On systems based on chip select rows, all channels need to use memories with the same properties, otherwise the memories on channels A and B won't be recognized. However, such assumption is not true for all types of memory controllers. Controllers for FB-DIMM's don't have such requirements. Also, modern Intel controllers seem to be capable of handling such differences. So, we need to get rid of storing the DIMM information into a per-csrow data, storing it, instead at the right place. The first step is to move grain, mtype, dtype and edac_mode to the per-dimm struct. Reviewed-by: Aristeu Rozanski <arozansk@redhat.com> Reviewed-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Mark Gross <mark.gross@intel.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: Tim Small <tim@buttersideup.com> Cc: Ranganathan Desikan <ravi@jetztechnologies.com> Cc: "Arvind R." <arvino55@gmail.com> Cc: Olof Johansson <olof@lixom.net> Cc: Egor Martovetsky <egor@pasemi.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Joe Perches <joe@perches.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Hitoshi Mitake <h.mitake@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: James Bottomley <James.Bottomley@parallels.com> Cc: "Niklas Söderlund" <niklas.soderlund@ericsson.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Mike Williams <mike@mikebwilliams.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19EDAC: Make pci_device_id tables __devinitconst.Lionel Debroux
These const tables are currently marked __devinitdata, but Documentation/PCI/pci.txt says: "o The ID table array should be marked __devinitconst; this is done automatically if the table is declared with DEFINE_PCI_DEVICE_TABLE()." So use DEFINE_PCI_DEVICE_TABLE(x). Based on PaX and earlier work by Andi Kleen. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-04-19edac: Drop __DATE__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Doug Thompson <dougthompson@xmission.com> Cc: bluesmoke-devel@lists.sourceforge.net Cc: linux-edac@vger.kernel.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-11edac: i5000: improve handling of pci_enable_device() return valueKulikov Vasiliy
-EIO is not the only error code that pci_enable_device() may return, also the set of errors can be enhanced in future. We should compare return code with zero, not with concrete error value. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jeff Roberson <jroberson@jroberson.net> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27drivers/edac: convert logging messages direct uses of __FILE__ to %s, __FILEJoe Perches
Reduces text by eliminating multiple __FILE__ uses. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Tim Small <tim@buttersideup.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16edac: i5000_edac critical fix panic out of boundsTamas Vincze
EDAC MC0: INTERNAL ERROR: channel-b out of range (4 >= 4) Kernel panic - not syncing: EDAC MC0: Uncorrected Error (XEN) Domain 0 crashed: 'noreboot' set - not rebooting. This happens because FERR_NF_FBD bit 28 is not updated on i5000. Due to that, both bits 28 and 29 may be equal to one, returning channel = 3. As this value is invalid, EDAC core generates the panic. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14568 Signed-off-by: Tamas Vincze <tom@vincze.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5100 fix initialization codeKeith Mannthey
Allow csrows to properly initialize when the topology only has active channels on 2 and 3. This new check allows proper detection and initialization in this topology. Only checking the first mrt that represented channels 0 and 1 is not sufficient. I also fixed up the related debug information path. I can submit as a 2nd patch if needed. Signed-off-by: Keith Mannthey <kmannth@us.ibm.com> Acked-by: Aristeu Rozanski <aris@ruivo.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12i5000-edac: hold reference to mci kobjectDarrick J. Wong
It turns out that edac_mc_del_mc will kobject_put the last kref on the mci object. If the timing is just right, that means that the mci object is freed before before i5000_remove_one has a chance to free the resources associated with it, causing a null pointer exceptions when unloading the driver. Insert a kobject_{get,put} pair so that this doesn't happen. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16edac i5000: fix thermal issuesAristeu Rozanski
Make the Thermal messages (temperature got past Tmid) be displayed only once because: 1) it's the BIOS job to configure and handle the memory throttling 2) if the BIOS is broken or is aware about the condition, flooding the system logs won't help anything. 3) According to the specification update for Intel 5000 MCHs, all the revisions of this MCH have problems on the thermal sensors, making not automatic (a.k.a. intelligent thermal throttling) impossible. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16edac i5000: fix error messagesAristeu Rozanski
Update the i5000_edac messages, making everything pass through the EDAC (so the log controls will work) and being more specific about the errors. Also, it makes the miscellaneous errors optional and disabled by default. As I didn't found anywhere information about M23ERR-M26ERR (FERR_NF_THERMAL) on FERR_NF_FBD, I'm removing them. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edac: fix module initialization on several modules 2nd timeHitoshi Mitake
I implemented opstate_init() as a inline function in linux/edac.h. added calling opstate_init() to: i82443bxgx_edac.c i82860_edac.c i82875p_edac.c i82975x_edac.c I wrote a fixed patch of edac-fix-module-initialization-on-several-modules.patch, and tested building 2.6.25-rc7 with applying this. It was succeed. I think the patch is now correct. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/edac/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-11-14i5000_edac: no need to __stringify() KBUILD_BASENAMEDarrick J. Wong
The i5000_edac driver's PCI registration structure has the name ""i5000_edac"" (with extra set of double-quotes) which is probably not intentional. Get rid of __stringify. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: fix edac_mc init apisDoug Thompson
Refactoring of sysfs code necessitated the refactoring of the edac_mc_alloc() and edac_mc_add_mc() apis, of moving the index value to the alloc() function. This patch alters the in tree drivers to utilize this new api signature. Having the index value performed later created a chicken-and-the-egg issue. Moving it to the alloc() function allows for creating the necessary sysfs entries with the proper index number Cc: Alan Cox alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: i5000 code tidyingDouglas Thompson
Various code style conformance patches on the i5000 driver Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: i5000 define typoMarisuz Kozlowski
Found a typo in one of the #defines in the driver MTR_DIM_RANKS --> MTR_DIMM_RANK Signed-off-by: Marisuz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: cleanup spaces-gotos after Lindent messupDouglas Thompson
This patch fixes some remnant spaces inserted by the use of Lindent. Seems Lindent adds some spaces when it shoulded. These have been fixed. In addition, goto targets have issues, these have been fixed in this patch. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: drivers to use new PCI operationDave Jiang
Move x86 drivers to new pci controller setup Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: Lindent i5000Douglas Thompson
Ran e752x_edac.c file through Lindent for cleanup Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add dev_name getter functionDave Jiang
Move dev_name() macro to a more generic interface since it's not possible to determine whether a device is pci, platform, or of_device easily. Now each low level driver sets the name into the control structure, and the EDAC core references the control structure for the information. Better abstraction. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod use edac_core.hDouglas Thompson
In the refactoring of edac_mc.c into several subsystem files, the header file edac_mc.h became meaningless. A new header file edac_core.h was created. All the files that previously included "edac_mc.h" are changed to include "edac_core.h". Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add new nmi rescanDave Jiang
Provides a way for NMI reported errors on x86 to notify the EDAC subsystem pending ECC errors by writing to a software state variable. Here's the reworked patch. I added an EDAC stub to the kernel so we can have variables that are in the kernel even if EDAC is a module. I also implemented the idea of using the chip driver to select error detection mode via module parameter and eliminate the kernel compile option. Please review/test. Thx! Also, I only made changes to some of the chipset drivers since I am unfamiliar with the other ones. We can add similar changes as we go. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: new intel 5000 MC driverEric Wollesen
Eric Wollesen ported the Bluesmoke Memory Controller driver (written by Doug Thompson) for the Intel 5000X/V/P (Blackford/Greencreek) chipset to the in kernel EDAC model. This patch incorporates the module for the 5000X/V/P chipset family [m.kozlowski@tuxland.pl: edac i5000 parenthesis balance fix] Signed-off-by: Eric Wollesen <ericw@xmtp.net> Signed-off-by: Doug Thompson <norsk5@xmission.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
