path: root/drivers/edac/amd8131_edac.c
2009-05-29edac: AMD8111 & AMD8131 use dev_name()Harry Ciao
The "bus_id" member in the device structure has been obsolete, use dev_name() instead. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02edac: AMD8131 driver source fileHarry Ciao
Introduce AMD8131 EDAC driver source file, which makes use of error detections on the PCI-X Bridge Controllers on the AMD8131 HyperTransport PCI-X Tunnel. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
