path: root/drivers/dma
2011-03-22Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits) avr32: at32ap700x: fix typo in DMA master configuration dmaengine/dmatest: Pass timeout via module params dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs fsldma: make halt behave nicely on all supported controllers fsldma: reduce locking during descriptor cleanup fsldma: support async_tx dependencies and automatic unmapping fsldma: fix controller lockups fsldma: minor codingstyle and consistency fixes fsldma: improve link descriptor debugging fsldma: use channel name in printk output fsldma: move related helper functions near each other dmatest: fix automatic buffer unmap type drivers, pch_dma: Fix warning when CONFIG_PM=n. dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize dw_dmac: Setting Default Burst length for transfers as 16. dw_dmac: Allow src/dst msize & flow controller to be configured at runtime dw_dmac: Changing type of src_master and dest_master to u8. dw_dmac: Pass Channel Priority from platform_data dw_dmac: Pass Channel Allocation Order from platform_data ...
2011-03-22dmaengine/dmatest: Pass timeout via module paramsViresh Kumar
When we try to test all channels present on our controller together, some channels of lower priority may be very slow as compared to others. If number of transfers is unlimited, some channels may timeout and will not finish within 3 seconds. Thus, while doing such regress testing we may need to have higher value of timeouts. This patch adds support for passing timeout value via module parameters. Default value is 3 msec, a negative value means max timeout possible. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-22dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCsUwe Kleine-König
As a side effect this makes IMX_DMA selectable on i.MX21 again, because the symbol ARCH_MX21 doesn't exist (MACH_MX21 would have been more correct). Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17dma: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-11fsldma: make halt behave nicely on all supported controllersIra Snyder
The original dma_halt() function set the CA (channel abort) bit on both the 83xx and 85xx controllers. This is incorrect on the 83xx, where this bit means TEM (transfer error mask) instead. The 83xx doesn't support channel abort, so we only do this operation on 85xx. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: reduce locking during descriptor cleanupIra Snyder
This merges the fsl_chan_ld_cleanup() function into the dma_do_tasklet() function to reduce locking overhead. In the best case, we will be able to keep the DMA controller busy while we are freeing used descriptors. In all cases, the spinlock is grabbed two times fewer than before on each transaction. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: support async_tx dependencies and automatic unmappingIra Snyder
Previous to this patch, the dma_run_dependencies() function has been called while holding desc_lock. This function can call tx_submit() for other descriptors, which may try to re-grab the lock. Avoid this by moving the descriptors to be cleaned up to a temporary list, and dropping the lock before cleanup. At the same time, add support for automatic unmapping of src and dst buffers, as offered by the DMAEngine API. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: fix controller lockupsIra Snyder
Enabling poisoning in the dmapool API quickly showed that the DMA controller was fetching descriptors that should not have been in use. This has caused intermittent controller lockups during testing. I have been unable to figure out the exact set of conditions which cause this to happen. However, I believe it is related to the driver using the hardware registers to track whether the controller is busy or not. The code can incorrectly decide that the hardware is idle due to lag between register writes and the hardware actually becoming busy. To fix this, the driver has been reworked to explicitly track the state of the hardware, rather than try to guess what it is doing based on the register values. This has passed dmatest with 10 threads per channel, 100000 iterations per thread several times without error. Previously, this would fail within a few seconds. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: minor codingstyle and consistency fixesIra Snyder
This fixes some minor violations of the coding style. It also changes the style of the device_prep_dma_*() function definitions so they are identical. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: improve link descriptor debuggingIra Snyder
This adds better tracking to link descriptor allocations, callbacks, and frees. This makes it much easier to track errors with link descriptors. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: use channel name in printk outputIra Snyder
This makes debugging the driver much easier when multiple channels are running concurrently. In addition, you can see how much descriptor memory each channel has allocated via the dmapool API in sysfs. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: move related helper functions near each otherIra Snyder
This is a purely cosmetic cleanup. It is nice to have related functions right next to each other in the code. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11dmatest: fix automatic buffer unmap typeIra Snyder
The dmatest code relies on the DMAEngine API to automatically call dma_unmap_single() on src buffers. The flags it passes are incorrect, fix them. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-07drivers, pch_dma: Fix warning when CONFIG_PM=n.Rakib Mullick
When CONFIG_PM=n, we get the following warning: drivers/dma/pch_dma.c:741: warning: ‘pch_dma_suspend’ defined but not used drivers/dma/pch_dma.c:755: warning: ‘pch_dma_resume’ defined but not used To fix it, wrap pch_dma_{suspend,resume} and pch_dma_{save,restore}_regs functions with CONFIG_PM. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writelViresh Kumar
On ARMv7 cores, device memory mapped as Normal Non-cacheable, may not guarantee ordered access causing failures in device drivers that do not use the mandatory memory barriers. readl & writel versions contain necessary memory barriers for this. commit 79f64dbf68c8a9779a7e9a25e0a9f0217a25b57a: "ARM: 6273/1: Add barriers to the I/O accessors if ARM_DMA_MEM_BUFFERABLE" can be referred for more information on this. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Setting Default Burst length for transfers as 16.Viresh Kumar
This patch sets default Burst length for all transfer to 16. This will enhance performance when user doesn't have any chan->private data. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Allow src/dst msize & flow controller to be configured at runtimeViresh KUMAR
Msize or Burst Size is peripheral dependent in case of prep_slave_sg and cyclic_prep transfers, and in case of memcpy transfers it is platform dependent. So msize configuration must come from platform data. Also some peripherals (ex: JPEG), need to be flow controller for dma transfers, so this information in case of slave_sg & cyclic_prep transfers must come from platform data. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Pass Channel Priority from platform_dataViresh Kumar
In Synopsys designware, channel priority is programmable. This patch adds support for passing channel priority through platform data. By default Ascending channel priority will be followed, i.e. channel 0 will get highest priority and channel 7 will get lowest. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Pass Channel Allocation Order from platform_dataViresh Kumar
In SPEAr Platform channels 4-7 have more Fifo depth. So we must get better channel first. This patch introduces concept of channel allocation order in dw_dmac. If user doesn't pass anything or 0, than normal (ascending) channel allocation will follow, else channels will be allocated in descending order. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Mark all tx_descriptors with DMA_CRTL_ACK after xfer finishViresh Kumar
dwc_desc_get checks all descriptors for DMA_CTRL_ACK before allocating them for transfers. And descriptors are not marked with DMA_CRTL_ACK after transfer finishes. Thus descriptor once used is not usable again. This patch marks descriptors with DMA_CRTL_ACK after dma xfer finishes Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Change value of DWC_MAX_COUNT to 4095.Viresh Kumar
Every descriptor can transfer a maximum count of 4095 (12 bits, in control reg), So we must have DWC_MAX_COUNT as 4095 instead of 2048. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Adding support for 64 bit access width for memcpy xfersViresh Kumar
2011-03-07dw_dmac: Calling dwc_scan_descriptors from dwc_tx_status() after taking lockViresh Kumar
Lock must be taken before calling dwc_scan_descriptors, as this may access/modify shared data and queues. dwc_tx_status wasn't taking lock before calling this routine. This patch add code that takes lock before calling dwc_scan_descriptors. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Move single descriptor from dwc->queue to dwc->active_list in ↵Viresh Kumar
dwc_complete_all dwc_complete_all and other routines was removing all descriptors from dwc->queue and pushing them to dwc->active_list. Only one was required to be removed. Also we are calling dwc_dostart, once list is fixed. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Replace module_init() with subsys_initcall()Viresh Kumar
In some cases users of dw_dmac are initialized before dw_dmac, and if they try to use dw_dmac, they simply fail. So its better we register init() routine of driver using subsys_initcall() instead of module_init(), so that dma driver is available at the earliest possible. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-07dw_dmac: Remove compilation dependency from AVR32 and put on HAVE_CLKViresh Kumar
This driver will now be used in atleast two platforms AVR32 & ARM. And there is no actual hardware dependency of this driver over AVR32 or ARM. So this dependency can be removed altogether. Also dw_dmac driver uses clk framework and must have compilation dependency on HAVE_CLK Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-02dmaengine: mxs-dma: add dma support for i.MX23/28Shawn Guo
This patch adds dma support for Freescale MXS-based SoC i.MX23/28, including apbh-dma and apbx-dma. * apbh-dma and apbx-dma are supported in the driver as two mxs-dma instances. * apbh-dma is different between mx23 and mx28, hardware version register is used to differentiate. * mxs-dma supports pio function besides data transfer. The driver uses dma_data_direction DMA_NONE to identify the pio mode, and steals sgl and sg_len to get pio words and numbers from clients. * mxs dmaengine has some very specific features, like sense function and the special NAND support (nand_lock, nand_wait4ready). These are too specific to implemented in generic dmaengine driver. * The driver refers to imx-sdma and only a single descriptor is statically assigned to each channel. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-28dt/powerpc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/powerpc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-26pch_dma: set the number of array correctlyTomoya MORINAGA
set the number of array correctly. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-02-26pch_dma: fix kernel error issueTomoya MORINAGA
fix the following kernel error ------------[ cut here ]------------ WARNING: at kernel/softirq.c:159 _local_bh_enable_ip.clone.5+0x35/0x71() Hardware name: To be filled by O.E.M. Modules linked in: pch_uart pch_dma fuse mga drm cpufreq_ondemand acpi_cpufreq mperf ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables ipv6 uinput snd_hda_codec_realtek snd_hda_intel snd_hda_codec matroxfb_base snd_hwdep 8250_pnp snd_seq snd_seq_device matroxfb_DAC1064 snd_pcm joydev 8250 matroxfb_accel snd_timer matroxfb_Ti3026 ppdev pegasus parport_pc snd parport matroxfb_g450 g450_pll serial_core video output matroxfb_misc soundcore snd_page_alloc serio_raw pcspkr ext4 jbd2 crc16 sdhci_pci sdhci mmc_core floppy [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Not tainted 2.6.37.upstream_check+ #8 Call Trace: [<c0433add>] warn_slowpath_common+0x65/0x7a [<c043825b>] ? _local_bh_enable_ip.clone.5+0x35/0x71 [<c0433b01>] warn_slowpath_null+0xf/0x13 [<c043825b>] _local_bh_enable_ip.clone.5+0x35/0x71 [<c043829f>] local_bh_enable_ip+0x8/0xa [<c06ec471>] _raw_spin_unlock_bh+0x10/0x12 [<f82b57dd>] pd_prep_slave_sg+0xba/0x200 [pch_dma] [<f82f7b7a>] pch_uart_interrupt+0x44d/0x6aa [pch_uart] [<c046fa97>] handle_IRQ_event+0x1d/0x9e [<c047146f>] handle_fasteoi_irq+0x90/0xc7 [<c04713df>] ? handle_fasteoi_irq+0x0/0xc7 <IRQ> [<c04045af>] ? do_IRQ+0x3e/0x89 [<c04035a9>] ? common_interrupt+0x29/0x30 [<c04400d8>] ? sys_getpriority+0x12d/0x1a2 [<c058bb2b>] ? arch_local_irq_enable+0x5/0xb [<c058c740>] ? acpi_idle_enter_bm+0x22a/0x261 [<c0648b11>] ? cpuidle_idle_call+0x70/0xa1 [<c0401f44>] ? cpu_idle+0x49/0x6a [<c06d9fc4>] ? rest_init+0x58/0x5a [<c089e762>] ? start_kernel+0x2d0/0x2d5 [<c089e0ce>] ? i386_start_kernel+0xce/0xd5 Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-02-23ARM: amba: make probe() functions take const id tablesRussell King
Make Primecell driver probe functions take a const pointer to their ID tables. Drivers should never modify their ID tables in their probe handler. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17coh901318.c: Change initate to initiate.Justin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-02-14Merge branch 'dw_dmac' into dmaengineDan Williams
2011-02-14Merge branch 'dma40' into dmaengineDan Williams
2011-02-14Merge branch 'imx' into dmaengine-fixesDan Williams
2011-02-14dma: ipu_idmac: do not lose valid received data in the irq handlerAnatolij Gustschin
Currently when two or more buffers are queued by the camera driver and so the double buffering is enabled in the idmac, we lose one frame comming from CSI since the reporting of arrival of the first frame is deferred by the DMAIC_7_EOF interrupt handler and reporting of the arrival of the last frame is not done at all. So when requesting N frames from the image sensor we actually receive N - 1 frames in user space. The reason for this behaviour is that the DMAIC_7_EOF interrupt handler misleadingly assumes that the CUR_BUF flag is pointing to the buffer used by the IDMAC. Actually it is not the case since the CUR_BUF flag will be flipped by the FSU when the FSU is sending the <TASK>_NEW_FRM_RDY signal when new frame data is delivered by the CSI. When sending this singal, FSU updates the DMA_CUR_BUF and the DMA_BUFx_RDY flags: the DMA_CUR_BUF is flipped, the DMA_BUFx_RDY is cleared, indicating that the frame data is beeing written by the IDMAC to the pointed buffer. DMA_BUFx_RDY is supposed to be set to the ready state again by the MCU, when it has handled the received data. DMAIC_7_CUR_BUF flag won't be flipped here by the IPU, so waiting for this event in the EOF interrupt handler is wrong. Actually there is no spurious interrupt as described in the comments, this is the valid DMAIC_7_EOF interrupt indicating reception of the frame from CSI. The patch removes code that waits for flipping of the DMAIC_7_CUR_BUF flag in the DMAIC_7_EOF interrupt handler. As the comment in the current code denotes, this waiting doesn't help anyway. As a result of this removal the reporting of the first arrived frame is not deferred to the time of arrival of the next frame and the drivers software flag 'ichan->active_buffer' is in sync with DMAIC_7_CUR_BUF flag, so the reception of all requested frames works. This has been verified on the hardware which is triggering the image sensor by the programmable state machine, allowing to obtain exact number of frames. On this hardware we do not tolerate losing frames. This patch also removes resetting the DMA_BUFx_RDY flags of all channels in ipu_disable_channel() since transfers on other DMA channels might be triggered by other running tasks and the buffers should always be ready for data sending or reception. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Tested-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-01-31Merge branch 'dmaengine-shawn' into dmaengineSascha Hauer
2011-01-31Merge branch 'dmaengine-sdma' into dmaengineSascha Hauer
2011-01-31dmaengine: imx-sdma: fix up param for the last BD in sdma_prep_slave_sg()Shawn Guo
As per the reference manual, bit "L" should be set while bit "C" should be cleared for the last buffer descriptor in the non-cyclic chain, so that sdma can stop trying to find the next BD and end the transfer. In case of sdma_prep_slave_sg(), BD_LAST needs to be set and BD_CONT be cleared for the last BD. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine: imx-sdma: correct sdmac->status in sdma_handle_channel_loop()Shawn Guo
sdma_handle_channel_loop() is the handler of cyclic tx. One period success does not really mean the success of the tx. Instead of DMA_SUCCESS, DMA_IN_PROGRESS should be the one to tell. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine: imx-sdma: return sdmac->status in sdma_tx_status()Shawn Guo
The sdmac->status was designed to reflect the status of the tx, so simply return it in sdma_tx_status(). Then dma client can call dma_async_is_tx_complete() to know the status of the tx. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine: imx-sdma: set sdmac->status to DMA_ERROR in err_out of ↵Shawn Guo
sdma_prep_slave_sg() sdma_prep_dma_cyclic() sets sdmac->status to DMA_ERROR in err_out, and sdma_prep_slave_sg() needs to do the same. Otherwise, sdmac->status stays at DMA_IN_PROGRESS, which will make the function return immediately next time it gets called. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine: imx-sdma: remove IMX_DMA_SG_LOOP handling in sdma_prep_slave_sg()Shawn Guo
This is a leftover from the time that the driver did not have sdma_prep_dma_cyclic callback and implemented sound dma as a looped sg chain. And it can be removed now. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine i.MX dma: initialize dma capabilities outside channel loopSascha Hauer
The capabilities are device specific fields, not channel specific fields. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-31dmaengine i.MX DMA: do not initialize chan_id fieldSascha Hauer
