sdma_disable_channel() cannot ensure dma is stopped to access
module's FIFOs. There is chance SDMA core is running and accessing
BD when disable of corresponding channel, this may cause sometimes
even after call of .sdma_disable_channel(), SDMA core still be
running and accessing module's FIFOs.
According to NXP R&D team a delay of one BD SDMA cost time (maximum
is 1ms) should be added after disable of the channel bit, to ensure
SDMA core has really been stopped after SDMA clients call
.device_terminate_all.
This patch introduces adds a new function sdma_disable_channel_with_delay()
which simply adds 1ms delay after call sdma_disable_channel(),
and set it as .device_terminate_all.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The SDMA hardware/driver does not actually report the transfer residue at
burst size granularity, but in fact is only able to report residue after
each finished segment.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
The residue calculation was taking in consideration that dma
transaction status will be always retrieved in the dma callback
used to inform that dma transfer is complete. However this is not
the case for all subsystems that use dma. Some subsystems use a
timer to check the dma status periodically.
Therefore the calculation was updated and residue is calculated
accordingly by a) update the residue calculation taking in
consideration the last used buffer index by using *buf_ptail* variable
and b) chn_real_count (number of bytes transferred) is initialized to
zero, when dma channel is created, to avoid using an uninitialized
value in residue calculation when dma status is checked without
waiting dma complete event.
Signed-off-by: Nandor Han <nandor.han@ge.com>
Acked-by: Peter Senna Tschudin <peter.senna@collabora.com>
Tested-by: Peter Senna Tschudin <peter.senna@collabora.com>
Tested-by: Marek Vasut <marex@denx.de>
Pull dmaengine updates from Vinod Koul:
"This is bit large pile of code which bring in some nice additions:
- Error reporting: we have added a new mechanism for users of
dmaenegine to register a callback_result which tells them the
result of the dma transaction. Right now only one user (ntb) is
using it.
- As we discussed on KS mailing list and pointed out NO_IRQ has no
place in kernel, this also remove NO_IRQ from dmaengine subsystem
(both arm and ppc users)
- Support for IOMMU slave transfers and its implementation for arm.
- To get better build coverage, enable COMPILE_TEST for bunch of
driver, and fix the warning and sparse complaints on these.
- Apart from above, usual updates spread across drivers"
* tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (169 commits)
async_pq_val: fix DMA memory leak
dmaengine: virt-dma: move function declarations
dmaengine: omap-dma: Enable burst and data pack for SG
DT: dmaengine: rcar-dmac: document R8A7743/5 support
dmaengine: fsldma: Unmap region obtained by of_iomap
dmaengine: jz4780: fix resource leaks on error exit return
dma-debug: fix ia64 build, use PHYS_PFN
dmaengine: coh901318: fix integer overflow when shifting more than 32 places
dmaengine: edma: avoid uninitialized variable use
dma-mapping: fix m32r build warning
dma-mapping: fix ia64 build, use PHYS_PFN
dmaengine: ti-dma-crossbar: enable COMPILE_TEST
dmaengine: omap-dma: enable COMPILE_TEST
dmaengine: edma: enable COMPILE_TEST
dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usage
dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameter
dmaengine/ARM: omap-dma: Fix the DMAengine compile test on non OMAP configs
dmaengine: edma: Rename set_bits and remove unused clear_bits helper
dmaengine: edma: Use correct type for of_find_property() third parameter
dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC)
The calculation of the DMA transaction residue supports only fixed
size data transfers. This implementation is not covering all
operations (e.g. data receiving) when we need to know the exact amount
of bytes transferred.
The loop channels handling was changed to clear the buffer
descriptor errors and use the bd->mode.count to calculate the
residue.
Reviewed-by: Vinod Koul <vinod.koul@intel.com>
Having the SDMA driver use a tasklet for running the clients
callback introduce some issues:
- probability to have desynchronized data because of the
race condition created since the DMA transaction status
is retrieved only when the callback is executed, leaving
plenty of time for transaction status to get altered.
- inter-transfer latency which can leave channels idle.
Move the callback execution, for cyclic channels, to SDMA
interrupt (as advised in `Documentation/dmaengine/provider.txt`)
to (a)reduce the inter-transfer latency and (b) eliminate the
race condition possibility where DMA transaction status might
be changed by the time is read.
The responsibility of the SDMA interrupt latency
is moved to the SDMA clients which case by case should defer
the work to bottom-halves when needed.
Allow i.MX7 to work with the imx-sdma driver.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
This is in preperation of moving to a callback that provides results to the
callback for the transaction. The conversion will maintain current behavior
and the driver must convert to new callback mechanism at a later time in
order to receive results.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
David reported:
[drivers/dma/imx-sdma.c:769]: (style) Variable 'emi_2_emi' is assigned a value that is never used
Since emi_2_emi is never used afterwards, remove thsi as well
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
David reported:
drivers/dma/imx-sdma.c:1003]: (style) Same expression on both sides of '|='
ORing with itself yields same result, So remove this
dmaengine device should explicitly call devm_free_irq() when using
devm_request_irq().
The irq is still ON when devices remove is executed and irq should be
quiesced before remove is completed.
Currently the handler ignores the channel 0 interrupt and thus doesn't ack
it properly. This is done in order to allow sdma_run_channel0() to poll
on the irq status bit, as this function may be called in atomic context,
but needs to know when the channel has finished.
This works mostly, as the polling happens under a spinlock, disabling IRQs
on the local CPU, leaving only a very slight race window for a spurious
IRQ to happen if the handler is executed on another CPU in an SMP system.
Still this is clearly suboptimal.
This behavior turns into a real problem on an RT system, where the spinlock
doesn't disable IRQs on the local CPU. Not acking the IRQ in the handler
in such a setup is very likely to drown the CPU in an IRQ storm, leaving
it unable to make any progress in the polling loop, leading to the IRQ
never being acked.
Fix this by properly acknowledging the channel 0 IRQ in the handler.
As the IRQ status bit can no longer be used to poll for the channel
completion, switch over to using the SDMA_H_STATSTOP register for this
purpose, where bit 0 is cleared by the hardware when the channel is done.
Signed-off-by: Michael Olbrich <m.olbrich@pengutronix.de>
The sdma_probe function will call sdma_event_remap, but sdma_event_remap
marked with the __init annotation which make the kbuild complains as the
following log:
WARNING: drivers/dma/built-in.o(.text+0x56fc): Section mismatch in reference
from the function sdma_probe() to the function .init.text:sdma_event_remap()
The function sdma_probe() references
the function __init sdma_event_remap().
This is often because sdma_probe lacks a __init
annotation or the annotation of sdma_event_remap is wrong.
Remove the __init annotation on sdma_event_remap to kill this build warning
Signed-off-by: Jason Liu <r64343@freescale.com>
There is no need to print that the driver has been initialized
or removed, so remove such messages.
Since commit d078cd1b4185 ("dmaengine: imx-sdma: Add imx6sx platform
support") we get this message on every boot on mx6q:
imx-sdma 20ec000.sdma: no event needs to be remapped
, which is not very helpful.
Move the message to debug level instead.
Cc: Zidan Wang <zidan.wang@freescale.com>
clk_enable() may fail, so we should better check the return value and
propagate it in the case of error.
The new Solo X has more requirements for SDMA events. So it creates
a event mux to remap most of event numbers in GPR (General Purpose
Register). If we want to use SDMA support for those module who do
not get the even number as default, we need to configure GPR first.
Thus this patch adds this support of GPR event remapping configuration
to the SDMA driver.
Signed-off-by: Zidan Wang <zidan.wang@freescale.com>
This patch adds DEV_TO_DEV support for i.MX SDMA driver to support data
transfer between two peripheral FIFOs.
The per_2_per script requires two peripheral addresses and two DMA
requests, and it need to check the src addr and dst addr is in the SPBA
bus space or in the AIPS bus space.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
The platform_device_id is not modified by the driver and core uses it as
const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
Currently when version 3.1 of the mx6q SDMA firmware is used we get:
[ 0.392169] imx-sdma 20ec000.sdma: unknown firmware version
[ 0.399281] imx-sdma 20ec000.sdma: initialized
Add support for it.
Based on a patch from Shengjiu Wang from the internal FSL kernel.
Below comments got from Page4724 of Reference Manual of i.mx6q:
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
--"Static context mode should be used for the first channel called
after reset to ensure that the all context RAM for that channel is
initialized during the context SAVE phase when the channel is
done or yields. Subsequent calls to the same channel or
different channels may use any of the dynamic context modes.
This will ensure that all context locations for the bootload
channel are initialized, and prevent undefined values in context
RAM from being loaded during the context restore if the
channel is re-started later"
Unfortunately, the rule was broken by commit(5b28aa319bba96987316425a1131813d87cbab35)
.This patch just take them back.
Signed-off-by: Robin Gong <b38343@freescale.com>
There is no need to return a 'fake' value upon platform_get_irq() failure.
Just propagate the real error instead.
By using devm functions we can make the code shorter and cleaner.
Since ecc19d17868be9c ("dmaengine: Add a warning for drivers not using the
generic slave caps retrieval") the following warning is observed:
[ 0.224981] ------------[ cut here ]------------
[ 0.225013] WARNING: CPU: 0 PID: 1 at drivers/dma/dmaengine.c:830 dma_async_device_register+0x2a0/0x4c8()
[ 0.225023] this driver doesn't support generic slave capabilities reporting
Declare the slave capabilities to avoid such warning.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Split the device_control callback of the Freescale IMX SDMA driver to make use
of the newly introduced callbacks, that will eventually be used to retrieve
slave capabilities.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Fixed a coding style error, switch and case should be at the same indent
Signed-off-by: Asaf Vertz <asaf.vertz@tandemg.com>
When a firmware cannot be found for the SDMA engine then we can
continue with the internal ROM firmware.
The meaning of this message is frequently asked for, so make clear
that the driver still works with the internal ROM firmware and reduce
the loglevel from err to info.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
This patch simply adds a new DMATYPE for SAI which's included
in i.MX6 Solo X.
Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com>
When platform_driver_probe() is not used, sdma_probe() can be called
by bind/unbind via sysfs. In addition, sdma_init() can be called by
sdma_probe(). Thus, __init annotation should be removed from sdma_init(),
Also, this patch fixes section mismatch warning.
WARNING: drivers/dma/built-in.o(.text+0xd6e4): Section mismatch in reference from the function sdma_probe() to the function
.init.text:sdma_init()
the function __init sdma_init().
annotation or the annotation of sdma_init is wrong.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
In e34b731faa7d1 ("dma: imx-sdma: Remove spurious __init annotation on
sdma_probe()"), Mark found an extraneous __init label and fixed it.
However, he missed another one, because now we get this other warning:
WARNING: drivers/dma/imx-sdma.o(.text+0x3bb4): Section mismatch in reference from the function sdma_probe() to the function .init.text:sdma_get_firmware()
the function __init sdma_get_firmware().
Same reasoning as the last time, the function may get called at
runtime, so it can't be __init.
We can't annotate probe functions as __init since binding can occur at
any time, not just during kernel init.
Signed-off-by: Mark Brown <broonie@linaro.org>
Several dma drivers calls tasklet_kill() in remove function. This is done
because all running tasklets should be killed on remove. This is missing
in imx sdma driver, so adding tasklet_kill() in sdma_remove function.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Currently there is no module_exit declared in SDMA driver, so that once
sdma module is inserted, it's shown with permanent attribute by lsmod,
and it can't be removed.
Use module_platform_driver to register/unregister SDMA driver and modify
SDMA's remove operation, to make SDMA driver possible to be removed.
The argument is always set to NULL and never used. Remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Shared Peripheral ASRC, running on SPBA, needs to use shp sciprts for
DMA transfer. So this patch just adds a new DMATYPE for it.
The filter() function is currently called by xlate() while it transfers
imx_dma_data as a local variable to the filter() but releases the data
right after returning a DMA channel pointer, which results chan->private
pointing an invalid memory space.
So this patch just stores the imx_dma_data into sdmac to make usre the
private pointer valid as long as the channel exists.
Use the zeroing function instead of dma_alloc_coherent & memset(,0,)
I received a report this morning from one of the Novena developers that
the behaviour of the iMX6 ASoC codec driver (using imx-pcm-dma.c) was
sub-optimal under high system load.
While there are issues relating to system load remaining, upon reviewing
the ASoC imx-pcm-dma.c driver, it was noticed that it not using the
residue support, because SDMA doesn't support it. This has the effect
that SDMA has to make multiple calls into the ASoC and ALSA code, one
for each period.
Since ALSA's snd_pcm_elapsed() does not need to be called multiple times
and it is entirely sufficient to call it once to update ALSA with the
current buffer position via the pointer method, we can do better here.
We can also avoid stopping the DMA entirely, just like real cyclic DMA
implementations behave. While this means that we replay some old samples,
this is a nicer behaviour than having audio stop and restart.
The changes to achieve this are relatively minor - imx-sdma.c can track
where the DMA is to the nearest descriptor boundary - it does this
already when deciding how many callbacks to issue. In doing this,
buf_tail always points at the descriptor which will complete next.
The residue is defined by the bytes remaining to the end of the buffer,
when the buffer is viewed as a single block of memory [start...end].
So, when we start out, there's a full buffer worth of residue, and this
counts down as we approach the end of the buffer, eventually becoming
zero at the end, before returning to the full buffer worth when we
wrap back to the start.
Moving the walking of the descriptors into the interrupt handler means
that we can update the BD_DONE flag at interrupt time, thus avoiding
a delayed tasklet stopping the cyclic DMA.
This means that the residue can be calculated from (total descriptors -
buf_tail) * descriptor size. This is what the change below does. We
update imx-pcm-dma.c to remove the NO_RESIDUE flag since we now provide
the residue.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
In cyclic dma tx's handler sdma_handle_channel_loop(),
SDMA channel statue is set to either DMA_ERROR or DMA_IN_PROGRESS
based on each period's status. This has the following issues:
1) If one period's status is BD_RROR, then channel status
will be set to DMA_ERROR, but it will be overwritten to DMA_IN_PROGRESS
if the following periods are OK.
2) DMA client may call sdma_control(DMA_TERMINATE_ALL) to stop the cyclic dma
operation, sdma channel status will be set to DMA_ERROR,
but if after this handler is called, then again the channel status will be overwritten
to DMA_IN_PROGRESS. Then the following dmaengine_prep_dma_cyclic() will always fail,
as channel status is DMA_IN_PROGRESS.
As in cyclic dma tx, channel status will be initially set to DMA_IN_PROGRESS,
driver only needs to change it to DMA_ERROR, when something wrong happens
(one period status is wrong, or stoped by client explicitly).
imx25 did not work without a firmware previously.
This patch adds a DT compatible to pass the correct data with the
default script addresses for imx25.
Add imx25 compatible to the list of compatibles in the binding
documentation.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
i.MX series have inner firmware in its ROM code: when SDMA isn't provided
any firmware from Kernel or rootfs, the default inner ROM firmware will be
activated. However the current driver doesn't assign any script number to
this situation, and those platform running in this case would be broken.
Thus this patch adds a default script number when no external firmware being
loaded so that people would continue to be able to use basic scripts to run
their platform without any firmware.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds a new DMA_TYPE for SSI dual FIFO script, included
in SDMA firmware version 2. This script would allow SSI use dual
fifo mode to transimit/receive data without occasional hardware
underrun/overrun.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
Acked-by: Kumar Gala <galak@codeaurora.org>
On i.MX5/6 series, SDMA is using new version firmware to support SSI
dual FIFO feature and HDMI Audio (i.MX6Q/DL only). Thus add it.
Pull slave-dmaengine changes from Vinod Koul:
"This brings for slave dmaengine:
- Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as
dmaengine can only transfer and not verify validaty of dma
transfers
- Bunch of fixes across drivers:
- cppi41 driver fixes from Daniel
- 8 channel freescale dma engine support and updated bindings from
Hongbo
- msx-dma fixes and cleanup by Markus
- DMAengine updates from Dan:
- Bartlomiej and Dan finalized a rework of the dma address unmap
implementation.
- In the course of testing 1/ a collection of enhancements to
dmatest fell out. Notably basic performance statistics, and
fixed / enhanced test control through new module parameters
'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and
Linus [Walleij] for their review.
- Testing the raid related corner cases of 1/ triggered bugs in
the recently added 16-source operation support in the ioatdma
driver.
- Some minor fixes / cleanups to mv_xor and ioatdma"
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits)
dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers
dma: mv_xor: Remove unneeded NULL address check
ioat: fix ioat3_irq_reinit
ioat: kill msix_single_vector support
raid6test: add new corner case for ioatdma driver
ioatdma: clean up sed pool kmem_cache
ioatdma: fix selection of 16 vs 8 source path
ioatdma: fix sed pool selection
ioatdma: Fix bug in selftest after removal of DMA_MEMSET.
dmatest: verbose mode
dmatest: convert to dmaengine_unmap_data
dmatest: add a 'wait' parameter
dmatest: add basic performance metrics
dmatest: add support for skipping verification and random data setup
dmatest: use pseudo random numbers
dmatest: support xor-only, or pq-only channels in tests
dmatest: restore ability to start test at module load and init
dmatest: cleanup redundant "dmatest: " prefixes
dmatest: replace stored results mechanism, with uniform messages
Revert "dmatest: append verify result to results"
This resolves a number of warnings such as the below when building with
64-bit dma_addr_t on arm:
drivers/dma/imx-sdma.c:1092:3: warning: format '%x' expects argument of
type 'unsigned int', but argument 6 has type 'dma_addr_t' [-Wformat=]
..by upcasting to u64 and using %llx.
The dma mask is not configured in the current code.
This was triggered by soc-dmaengine-pcm which allocate the dma
buffers with the imx-sdma as device.
This commit fix audio on imx31.
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch>
Acked-by: Vinod Koul <vinod.koul@intel.com>
