Some algorithms initialize their .cra_list prior to registration.
But this is unnecessary since crypto_register_alg() will overwrite
.cra_list when adding the algorithm to the 'crypto_alg_list'.
Apparently the useless assignment has just been copy+pasted around.
So, remove the useless assignments.
Exception: paes_s390.c uses cra_list to check whether the algorithm is
registered or not, so I left that as-is for now.
This patch shouldn't change any actual behavior.
In the quest to remove all stack VLA usage from the kernel[1], this
replaces struct crypto_skcipher and SKCIPHER_REQUEST_ON_STACK() usage
with struct crypto_sync_skcipher and SYNC_SKCIPHER_REQUEST_ON_STACK(),
which uses a fixed stack size.
[1] https://lkml.kernel.org/r/CA+55aFzCG-zNmZwX4A2FQpadafLfEzK6CC=qPXydAacU1RqZWA@mail.gmail.com
Cc: Himanshu Jha <himanshujha199640@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the bit set of char/misc drivers for 4.19-rc1
There is a lot here, much more than normal, seems like everyone is
writing new driver subsystems these days... Anyway, major things here
are:
- new FSI driver subsystem, yet-another-powerpc low-level hardware
bus
- gnss, finally an in-kernel GPS subsystem to try to tame all of the
crazy out-of-tree drivers that have been floating around for years,
combined with some really hacky userspace implementations. This is
only for GNSS receivers, but you have to start somewhere, and this
is great to see.
Other than that, there are new slimbus drivers, new coresight drivers,
new fpga drivers, and loads of DT bindings for all of these and
existing drivers.
All of these have been in linux-next for a while with no reported
issues"
* tag 'char-misc-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (255 commits)
android: binder: Rate-limit debug and userspace triggered err msgs
fsi: sbefifo: Bump max command length
fsi: scom: Fix NULL dereference
misc: mic: SCIF Fix scif_get_new_port() error handling
misc: cxl: changed asterisk position
genwqe: card_base: Use true and false for boolean values
misc: eeprom: assignment outside the if statement
uio: potential double frees if __uio_register_device() fails
eeprom: idt_89hpesx: clean up an error pointer vs NULL inconsistency
misc: ti-st: Fix memory leak in the error path of probe()
android: binder: Show extra_buffers_size in trace
firmware: vpd: Fix section enabled flag on vpd_section_destroy
platform: goldfish: Retire pdev_bus
goldfish: Use dedicated macros instead of manual bit shifting
goldfish: Add missing includes to goldfish.h
mux: adgs1408: new driver for Analog Devices ADGS1408/1409 mux
dt-bindings: mux: add adi,adgs1408
Drivers: hv: vmbus: Cleanup synic memory free path
Drivers: hv: vmbus: Remove use of slow_virt_to_phys()
Drivers: hv: vmbus: Reset the channel callback in vmbus_onoffer_rescind()
Some crypto API users allocating a tfm with crypto_alloc_$FOO() are also
specifying the type flags for $FOO, e.g. crypto_alloc_shash() with
CRYPTO_ALG_TYPE_SHASH. But, that's redundant since the crypto API will
override any specified type flag/mask with the correct ones.
So, remove the unneeded flags.
At over 4000 #includes, <linux/platform_device.h> is the 9th most
#included header file in the Linux kernel. It does not need
<linux/mod_devicetable.h>, so drop that header and explicitly add
<linux/mod_devicetable.h> to source files that need it.
4146 #include <linux/platform_device.h>
After this patch, there are 225 files that use <linux/mod_devicetable.h>,
for a reduction of around 3900 times that <linux/mod_devicetable.h>
does not have to be read & parsed.
225 #include <linux/mod_devicetable.h>
This patch was build-tested on 20 different arch-es.
It also makes these drivers SubmitChecklist#1 compliant.
Reported-by: kbuild test robot <lkp@intel.com> # drivers/media/platform/vimc/
Reported-by: kbuild test robot <lkp@intel.com> # drivers/pinctrl/pinctrl-u300.c
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.15:
API:
- Disambiguate EBUSY when queueing crypto request by adding ENOSPC.
This change touches code outside the crypto API.
- Reset settings when empty string is written to rng_current.
Algorithms:
- Add OSCCA SM3 secure hash.
Drivers:
- Remove old mv_cesa driver (replaced by marvell/cesa).
- Enable rfc3686/ecb/cfb/ofb AES in crypto4xx.
- Add ccm/gcm AES in crypto4xx.
- Add support for BCM7278 in iproc-rng200.
- Add hash support on Exynos in s5p-sss.
- Fix fallback-induced error in vmx.
- Fix output IV in atmel-aes.
- Fix empty GCM hash in mediatek.
Others:
- Fix DoS potential in lib/mpi.
- Fix potential out-of-order issues with padata"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (162 commits)
lib/mpi: call cond_resched() from mpi_powm() loop
crypto: stm32/hash - Fix return issue on update
crypto: dh - Remove pointless checks for NULL 'p' and 'g'
crypto: qat - Clean up error handling in qat_dh_set_secret()
crypto: dh - Don't permit 'key' or 'g' size longer than 'p'
crypto: dh - Don't permit 'p' to be 0
crypto: dh - Fix double free of ctx->p
hwrng: iproc-rng200 - Add support for BCM7278
dt-bindings: rng: Document BCM7278 RNG200 compatible
crypto: chcr - Replace _manual_ swap with swap macro
crypto: marvell - Add a NULL entry at the end of mv_cesa_plat_id_table[]
hwrng: virtio - Virtio RNG devices need to be re-registered after suspend/resume
crypto: atmel - remove empty functions
crypto: ecdh - remove empty exit()
MAINTAINERS: update maintainer for qat
crypto: caam - remove unused param of ctx_map_to_sec4_sg()
crypto: caam - remove unneeded edesc zeroization
crypto: atmel-aes - Reset the controller before each use
crypto: atmel-aes - properly set IV after {en,de}crypt
hwrng: core - Reset user selected rng by writing "" to rng_current
The qce driver starts several async crypto ops and waits for their
completions. Move it over to generic code doing the same.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Use PTR_ERROR_ZERO rather than if(IS_ERR(...)) + PTR_ERR.
Build successfully.
Signed-off-by: Himanshu Jha <himanshujha199640@gmail.com>
This patch replaces use of the obsolete ablkcipher with skcipher.
The sg_nents_for_len() function could fail, this patch add a check for
its return value.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
The qce driver use two dma_map_sg path according to SG are chained
or not.
Since dma_map_sg can handle both case, clean the code with all
references to sg chained.
Thus removing qce_mapsg, qce_unmapsg and qce_countsg functions.
[hch: split from a larger patch by Dan]
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Jens Axboe <axboe@fb.com>
Modify crypto drivers to use the generic SG helper since
both of them are equivalent and the one from crypto is redundant.
See also:
468577abe37ff7b453a9ac613e0ea155349203ae reverted in
b2ab4a57b018aafbba35bff088218f5cc3d2142e
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Commit 7bced397510a ("net_dma: simple removal") removed the long-dead
net_dma code, but unintentionally broke the build for the qualcomm
crypto engine (qce) that had accidentally depended on the inclusion of
<linux/dmaengine.h> through the networking header files that used to
have it.
Add the required dmaengine.h include explicitly to fix the breakage.
Fix few sparse warnings of type:
- sparse: incorrect type in argument
- sparse: incorrect type in initializer
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Modify crypto Kconfig and Makefile in order to build the qce
driver and adds qce Makefile as well.
The driver is separated by functional parts. The core part
implements a platform driver probe and remove callbaks.
The probe enables clocks, checks crypto version, initialize
and request dma channels, create done tasklet and init
crypto queue and finally register the algorithms into crypto
core subsystem.
- DMA and SG helper functions
implement dmaengine and sg-list helper functions used by
other parts of the crypto driver.
- ablkcipher algorithms
implementation of AES, DES and 3DES crypto API callbacks,
the crypto register alg function, the async request handler
and its dma done callback function.
- SHA and HMAC transforms
implementation and registration of ahash crypto type.
It includes sha1, sha256, hmac(sha1) and hmac(sha256).
- infrastructure to setup the crypto hw
contains functions used to setup/prepare hardware registers for
all algorithms supported by the crypto block. It also exports
few helper functions needed by algorithms:
- to check hardware status
- to start crypto hardware
- to translate data stream to big endian form
Adds register addresses and bit/masks used by the driver
as well.
