adt_ctl_drv should be adf_ctl_drv
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Convert pr_info() and pr_err() log messages to dev_info() and dev_err(),
respectively, where able. This adds the module name and PCI B:D:F to
indicate which QAT device generated the log message. The "QAT:" is removed
from these log messages as that is now unnecessary. A few of these log
messages have additional spelling/contextual fixes.
When the device needs a reset, e.g. when an uncorrectable PCIe AER event
occurs, various services/data structures need to be cleaned up, the
hardware reset and the services/data structures initialized and started.
The code to perform the cleanup and initialization was not performed when
a device reset was done.
This patch moves some of the initialization code out of the .probe entry-
point into a separate function that is now called during probe as well as
after the hardware has been reset. Similarly, a new function is added for
first cleaning up these services/data structures prior to resetting. The
new functions are adf_dev_init() and adf_dev_shutdown(), respectively, for
which there are already prototypes but no actual functions just yet and are
now called when the device is reset and during probe/cleanup of the driver.
The down and up flows via ioctl calls has similarly been updated.
In addition, there are two other bugs in the reset flow - one in the logic
for determining whether to schedule a device reset upon receiving an
uncorrectable AER event which prevents the reset flow from being initiated,
and another with clearing the status bit indicating a device is configured
(when resetting the device the configuration remains across the reset so
the bit should not be cleared, otherwise, the necessary services will not
be re-started in adf_dev_start() after the reset - clear the bit only when
actually deleting the configuration).
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
Pull crypto update from Herbert Xu:
- add multibuffer infrastructure (single_task_running scheduler helper,
OKed by Peter on lkml.
- add SHA1 multibuffer implementation for AVX2.
- reenable "by8" AVX CTR optimisation after fixing counter overflow.
- add APM X-Gene SoC RNG support.
- SHA256/SHA512 now handles unaligned input correctly.
- set lz4 decompressed length correctly.
- fix algif socket buffer allocation failure for 64K page machines.
- misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (47 commits)
crypto: sha - Handle unaligned input data in generic sha256 and sha512.
Revert "crypto: aesni - disable "by8" AVX CTR optimization"
crypto: aesni - remove unused defines in "by8" variant
crypto: aesni - fix counter overflow handling in "by8" variant
hwrng: printk replacement
crypto: qat - Removed unneeded partial state
crypto: qat - Fix typo in name of tasklet_struct
crypto: caam - Dynamic allocation of addresses for various memory blocks in CAAM.
crypto: mcryptd - Fix typos in CRYPTO_MCRYPTD description
crypto: algif - avoid excessive use of socket buffer in skcipher
arm64: dts: add random number generator dts node to APM X-Gene platform.
Documentation: rng: Add X-Gene SoC RNG driver documentation
hwrng: xgene - add support for APM X-Gene SoC RNG support
crypto: mv_cesa - Add missing #define
crypto: testmgr - add test for lz4 and lz4hc
crypto: lz4,lz4hc - fix decompression
crypto: qat - Use pci_enable_msix_exact() instead of pci_enable_msix()
crypto: drbg - fix maximum value checks on 32 bit systems
crypto: drbg - fix sparse warning for cpu_to_be[32|64]
crypto: sha-mb - sha1_mb_alg_state can be static
This patch fix spelling typo in printk.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
In case of error, the function device_create() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check
should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This patch adds a common infractructure that will be used by all Intel(R)
QuickAssist Technology (QAT) devices.
v2 - added ./drivers/crypto/qat/Kconfig and ./drivers/crypto/qat/Makefile
v4 - splits common part into more, smaller patches
Acked-by: John Griffin <john.griffin@intel.com>
Reviewed-by: Bruce W. Allan <bruce.w.allan@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
