path: root/drivers/crypto/padlock-sha.c
2011-03-27crypto: padlock - Add SHA-1/256 module for VIA NanoBrilly Wu
Add new SHA-1/256 module that never needs any fallback and just calls the PadLock hardware instruction supported from VIA Nano processors to implement the "update" and "final" function. They are respectively named "sha1_alg_nano" and "sha256_alg_nano", and will be used on any VIA Nano processor or the later ones. On VIA C7 CPU, the "sha1_alg" and "sha256_alg" modules will still be used as before. Signed-off-by: Brilly Wu <brillywu@viatech.com.cn> Signed-off-by: Kary Jin <karyjin@viatech.com.cn> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-01-07crypto: padlock - Move padlock.h into include/cryptoHerbert Xu
This patch moves padlock.h from drivers/crypto into include/crypto so that it may be used by the via-rng driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-02crypto: padlock-sha - Add import/export supportHerbert Xu
As the padlock driver for SHA uses a software fallback to perform partial hashing, it must implement custom import/export functions. Otherwise hmac which depends on import/export for prehashing will not work with padlock-sha. Reported-by: Wolfgang Walter <wolfgang.walter@stwm.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-21crypto: padlock-sha - Fix stack alignmentHerbert Xu
The PadLock hardware requires the output buffer for SHA to be 128-bit aligned. We currentply place the buffer on the stack, and ask gcc to align it to 128 bits. That doesn't work on i386 because the kernel stack is only aligned to 32 bits. This patch changes the code to align the buffer by hand so that the hardware doesn't fault on unaligned buffers. Reported-by: Séguier Régis <rguier@e-teleport.net> Tested-by: Séguier Régis <rguier@e-teleport.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-16crypto: padlock - Fix hashing of partial blocksHerbert Xu
When we encounter partial blocks in finup, we'll invoke the xsha instruction with a bogus count that is not a multiple of the block size. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: padlock - Fix compile error on i386Herbert Xu
The previous change to allow hashing from states other than the initial broke compilation on i386 because the inline assembly tried to squeeze a u64 into a 32-bit register. As we've already checked for 32-bit overflows we can simply truncate it to u32, or unsigned long so that we don't truncate at all on x86-64. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: padlock - Switch sha to shashHerbert Xu
This patch converts the padlock-sha implementation to shash. In doing so the existing mechanism of storing the data until final is no longer viable as we do not have a way of allocating data in crypto_shash_init and then reliably freeing it. This is just as well because a better way of handling the problem is to hash everything but the last chunk using normal sha code and then provide the intermediate result to the padlock device. This is good enough because the primary application of padlock-sha is IPsec and there the data is laid out in the form of an hmac header followed by the rest of the packet. In essence we can provide all the data to the padlock as the hmac header only needs to be hashed once. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: padlock - Use shash fallback for shaHerbert Xu
This patch changes padlock sha fallback to shash instead of hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-26crypto: api - Fix module load deadlock with fallback algorithmsHerbert Xu
With the mandatory algorithm testing at registration, we have now created a deadlock with algorithms requiring fallbacks. This can happen if the module containing the algorithm requiring fallback is loaded first, without the fallback module being loaded first. The system will then try to test the new algorithm, find that it needs to load a fallback, and then try to load that. As both algorithms share the same module alias, it can attempt to load the original algorithm again and block indefinitely. As algorithms requiring fallbacks are a special case, we can fix this by giving them a different module alias than the rest. Then it's just a matter of using the right aliases according to what algorithms we're trying to find. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-13crypto: padlock - fix VIA PadLock instruction usage with irq_ts_save/restore()Suresh Siddha
Wolfgang Walter reported this oops on his via C3 using padlock for AES-encryption: ################################################################## BUG: unable to handle kernel NULL pointer dereference at 000001f0 IP: [<c01028c5>] __switch_to+0x30/0x117 *pde = 00000000 Oops: 0002 [#1] PREEMPT Modules linked in: Pid: 2071, comm: sleep Not tainted (2.6.26 #11) EIP: 0060:[<c01028c5>] EFLAGS: 00010002 CPU: 0 EIP is at __switch_to+0x30/0x117 EAX: 00000000 EBX: c0493300 ECX: dc48dd00 EDX: c0493300 ESI: dc48dd00 EDI: c0493530 EBP: c04cff8c ESP: c04cff7c DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 Process sleep (pid: 2071, ti=c04ce000 task=dc48dd00 task.ti=d2fe6000) Stack: dc48df30 c0493300 00000000 00000000 d2fe7f44 c03b5b43 c04cffc8 00000046 c0131856 0000005a dc472d3c c0493300 c0493470 d983ae00 00002696 00000000 c0239f54 00000000 c04c4000 c04cffd8 c01025fe c04f3740 00049800 c04cffe0 Call Trace: [<c03b5b43>] ? schedule+0x285/0x2ff [<c0131856>] ? pm_qos_requirement+0x3c/0x53 [<c0239f54>] ? acpi_processor_idle+0x0/0x434 [<c01025fe>] ? cpu_idle+0x73/0x7f [<c03a4dcd>] ? rest_init+0x61/0x63 ======================= Wolfgang also found out that adding kernel_fpu_begin() and kernel_fpu_end() around the padlock instructions fix the oops. Suresh wrote: These padlock instructions though don't use/touch SSE registers, but it behaves similar to other SSE instructions. For example, it might cause DNA faults when cr0.ts is set. While this is a spurious DNA trap, it might cause oops with the recent fpu code changes. This is the code sequence that is probably causing this problem: a) new app is getting exec'd and it is somewhere in between start_thread() and flush_old_exec() in the load_xyz_binary() b) At pont "a", task's fpu state (like TS_USEDFPU, used_math() etc) is cleared. c) Now we get an interrupt/softirq which starts using these encrypt/decrypt routines in the network stack. This generates a math fault (as cr0.ts is '1') which sets TS_USEDFPU and restores the math that is in the task's xstate. d) Return to exec code path, which does start_thread() which does free_thread_xstate() and sets xstate pointer to NULL while the TS_USEDFPU is still set. e) At the next context switch from the new exec'd task to another task, we have a scenarios where TS_USEDFPU is set but xstate pointer is null. This can cause an oops during unlazy_fpu() in __switch_to() Now: 1) This should happen with or with out pre-emption. Viro also encountered similar problem with out CONFIG_PREEMPT. 2) kernel_fpu_begin() and kernel_fpu_end() will fix this problem, because kernel_fpu_begin() will manually do a clts() and won't run in to the situation of setting TS_USEDFPU in step "c" above. 3) This was working before the fpu changes, because its a spurious math fault which doesn't corrupt any fpu/sse registers and the task's math state was always in an allocated state. With out the recent lazy fpu allocation changes, while we don't see oops, there is a possible race still present in older kernels(for example, while kernel is using kernel_fpu_begin() in some optimized clear/copy page and an interrupt/softirq happens which uses these padlock instructions generating DNA fault). This is the failing scenario that existed even before the lazy fpu allocation changes: 0. CPU's TS flag is set 1. kernel using FPU in some optimized copy routine and while doing kernel_fpu_begin() takes an interrupt just before doing clts() 2. Takes an interrupt and ipsec uses padlock instruction. And we take a DNA fault as TS flag is still set. 3. We handle the DNA fault and set TS_USEDFPU and clear cr0.ts 4. We complete the padlock routine 5. Go back to step-1, which resumes clts() in kernel_fpu_begin(), finishes the optimized copy routine and does kernel_fpu_end(). At this point, we have cr0.ts again set to '1' but the task's TS_USEFPU is stilll set and not cleared. 6. Now kernel resumes its user operation. And at the next context switch, kernel sees it has do a FP save as TS_USEDFPU is still set and then will do a unlazy_fpu() in __switch_to(). unlazy_fpu() will take a DNA fault, as cr0.ts is '1' and now, because we are in __switch_to(), math_state_restore() will get confused and will restore the next task's FP state and will save it in prev tasks's FP state. Remember, in __switch_to() we are already on the stack of the next task but take a DNA fault for the prev task. This causes the fpu leakage. Fix the padlock instruction usage by calling them inside the context of new routines irq_ts_save/restore(), which clear/restore cr0.ts manually in the interrupt context. This will not generate spurious DNA in the context of the interrupt which will fix the oops encountered and the possible FPU leakage issue. Reported-and-bisected-by: Wolfgang Walter <wolfgang.walter@stwm.de> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: padlock - Make module loading quieter when hardware isn't availableJeremy Katz
When loading aes or sha256 via the module aliases, the padlock modules also try to get loaded. Make the error message for them not being present only be a NOTICE rather than an ERROR so that use of 'quiet' will suppress the messages Signed-off-by: Jeremy Katz <katzj@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-27[CRYPTO] users: Fix up scatterlist conversion errorsHerbert Xu
This patch fixes the errors made in the users of the crypto layer during the sg_init_table conversion. It also adds a few conversions that were missing altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[CRYPTO] sha: Add header file for SHA definitionsJan Glauber
There are currently several SHA implementations that all define their own initialization vectors and size values. Since this values are idential move them to a header file under include/crypto. Signed-off-by: Jan Glauber <jang@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] sha: Load the SHA[1|256] module by an aliasSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Additionally it ensures that the generic implementation as well as the HW driver (if available) is loaded in case the HW driver needs the generic version as fallback in corner cases. Also remove the probe for sha1 in padlock's init code. Quote from Herbert: The probe is actually pointless since we can always probe when the algorithm is actually used which does not lead to dead-locks like this. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Convert padlock-sha to use crypto_hashHerbert Xu
This patch converts padlock-sha to use crypto_hash for its fallback. It also changes the fallback selection to use selection by type instead of name. This is done through the new CRYPTO_ALG_NEED_FALLBACK bit, which is set if and only if an algorithm needs a fallback of the same type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock-sha: TFMs don't need to be staticMichal Ludvig
TFMs are local variables. No need to declare them static. After all one is enough. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock-sha: Make 2 functions staticAdrian Bunk
This patch makes two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Driver for SHA1 / SHA256 algorithmsMichal Ludvig
Support for SHA1 / SHA256 algorithms in VIA C7 processors. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
