path: root/drivers/crypto/caam/caamrng.c
2012-08-01crypto: caam - set descriptor sharing type to SERIALKim Phillips
SHARE_WAIT, whilst more optimal for association-less crypto, has the ability to start thrashing the CCB descriptor/key caches, given high levels of traffic across multiple security associations (and thus keys). Switch to using the SERIAL sharing type, which prefers the last used CCB for the SA. On a 2-DECO platform such as the P3041, this can improve performance by about 3.7%. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: caam - add backward compatible string sec4.0Shengzhou Liu
In some device trees of previous version, there were string "fsl,sec4.0". To be backward compatible with device trees, we first check "fsl,sec-v4.0", if it fails, then check for "fsl,sec4.0". Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> extended to include new hash and rng code, which was omitted from the previous version of this patch during a rebase of the SDK version. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-27crypto: caam - hwrng supportYuan Kang
caam_read copies random bytes from two buffers into output. caam rng can fill empty buffer 0xffff bytes at a time, but the buffer sizes are rounded down to multiple of cacheline size. Signed-off-by: Yuan Kang <Yuan.Kang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
