path: root/drivers/crypto/Makefile
2006-09-21[CRYPTO] padlock: Helper module padlock.koMichal Ludvig
Compile a helper module padlock.ko that will try to autoload all configured padlock algorithms. This also provides backward compatibility with the ancient times before padlock.ko was renamed to padlock-aes.ko Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Driver for SHA1 / SHA256 algorithmsMichal Ludvig
Support for SHA1 / SHA256 algorithms in VIA C7 processors. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Get rid of padlock-generic.cMichal Ludvig
Merge padlock-generic.c into padlock-aes.c and compile AES as a standalone module. We won't make a monolithic padlock.ko with all supported algorithms, instead we'll compile each driver into its own module. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
