path: root/drivers/crypto/Makefile
2008-07-10crypto: ixp4xx - Hardware crypto support for IXP4xx CPUsChristian Hohnstaedt
Add support for the hardware crypto engine provided by the NPE C of the Intel IXP4xx networking processor series. Supported ciphers: des, des3, aes and a combination of them with md5 and sha1 hmac Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: talitos - Freescale integrated security engine (SEC) driverKim Phillips
Add support for the SEC available on a wide range of PowerQUICC devices, e.g. MPC8349E, MPC8548E. This initial version supports authenc(hmac(sha1),cbc(aes)) for use with IPsec. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn_795x: HIFN 795x driverEvgeniy Polyakov
This is a driver for HIFN 795x crypto accelerator chips. It passed all tests for AES, DES and DES3_EDE except weak test for DES, since hardware can not determine weak keys. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] padlock: Remove pointless padlock moduleSimon Arlott
When this is compiled in it is run too early to do anything useful: [ 6.052000] padlock: No VIA PadLock drivers have been loaded. [ 6.052000] padlock: Using VIA PadLock ACE for AES algorithm. [ 6.052000] padlock: Using VIA PadLock ACE for SHA1/SHA256 algorithms. When it's a module it isn't doing anything special, the same functionality can be provided in userspace by "probeall padlock padlock-aes padlock-sha" in modules.conf if it is required. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Cc: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[PATCH] crypto: Add support for the Geode LX AES hardwareJordan Crouse
Add a driver to support the AES hardware on the Geode LX processor. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Helper module padlock.koMichal Ludvig
Compile a helper module padlock.ko that will try to autoload all configured padlock algorithms. This also provides backward compatibility with the ancient times before padlock.ko was renamed to padlock-aes.ko Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Driver for SHA1 / SHA256 algorithmsMichal Ludvig
Support for SHA1 / SHA256 algorithms in VIA C7 processors. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] padlock: Get rid of padlock-generic.cMichal Ludvig
Merge padlock-generic.c into padlock-aes.c and compile AES as a standalone module. We won't make a monolithic padlock.ko with all supported algorithms, instead we'll compile each driver into its own module. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
