path: root/drivers/cpufreq
2015-02-13Merge branches 'pm-cpufreq', 'pm-cpuidle', 'pm-devfreq', 'pm-opp' and 'pm-tools'Rafael J. Wysocki
* pm-cpufreq: cpufreq: speedstep-smi: enable interrupts when waiting * pm-cpuidle: intel_idle: support additional Broadwell model * pm-devfreq: PM / devfreq: event: testing the wrong variable * pm-opp: PM / OPP / clk: Remove unnecessary OOM message * pm-tools: tools/power turbostat: support additional Broadwell model tools/power turbostat: update parameters, documentation tools/power turbostat: Skip printing disabled package C-states
2015-02-12cpufreq: speedstep-smi: enable interrupts when waitingMikulas Patocka
On Dell Latitude C600 laptop with Pentium 3 850MHz processor, the speedstep-smi driver sometimes loads and sometimes doesn't load with "change to state X failed" message. The hardware sometimes refuses to change frequency and in this case, we need to retry later. I found out that we need to enable interrupts while waiting. When we enable interrupts, the hardware blockage that prevents frequency transition resolves and the transition is possible. With disabled interrupts, the blockage doesn't resolve (no matter how long do we wait). The exact reasons for this hardware behavior are unknown. This patch enables interrupts in the function speedstep_set_state that can be called with disabled interrupts. However, this function is called with disabled interrupts only from speedstep_get_freqs, so it shouldn't cause any problem. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com Cc: All applicable <stable@vger.kernel.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-10Merge tag 'pm+acpi-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "We have a few new features this time, including a new SFI-based cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new devfreq class for providing its governors with raw utilization data and a new ACPI driver for AMD SoCs. Still, the majority of changes here are reworks of existing code to make it more straightforward or to prepare it for implementing new features on top of it. The primary example is the rework of ACPI resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with support for IOAPIC hotplug implemented on top of it, but there is quite a number of changes of this kind in the cpufreq core, ACPICA, ACPI EC driver, ACPI processor driver and the generic power domains core code too. The most active developer is Viresh Kumar with his cpufreq changes. Specifics: - Rework of the core ACPI resources parsing code to fix issues in it and make using resource offsets more convenient and consolidation of some resource-handing code in a couple of places that have grown analagous data structures and code to cover the the same gap in the core (Jiang Liu, Thomas Gleixner, Lv Zheng). - ACPI-based IOAPIC hotplug support on top of the resources handling rework (Jiang Liu, Yinghai Lu). - ACPICA update to upstream release 20150204 including an interrupt handling rework that allows drivers to install raw handlers for ACPI GPEs which then become entirely responsible for the given GPE and the ACPICA core code won't touch it (Lv Zheng, David E Box, Octavian Purdila). - ACPI EC driver rework to fix several concurrency issues and other problems related to events handling on top of the ACPICA's new support for raw GPE handlers (Lv Zheng). - New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power Subsystem) driver for Intel chips (Ken Xue). - Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko Nikula). - Two new blacklist entries for machines (Samsung 730U3E/740U3E and 510R) where the native backlight interface doesn't work correctly while the ACPI one does (Hans de Goede). - Rework of the ACPI processor driver's handling of idle states to make the code more straightforward and less bloated overall (Rafael J Wysocki). - Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht, Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei Bai). - PCI core power management modification to avoid resuming (some) runtime-suspended devices during system suspend if they are in the right states already (Rafael J Wysocki). - New SFI-based cpufreq driver for Intel platforms using SFI (Srinidhi Kasagar). - cpufreq core fixes, cleanups and simplifications (Viresh Kumar, Doug Anderson, Wolfram Sang). - SkyLake CPU support and other updates for the intel_pstate driver (Kristen Carlson Accardi, Srinivas Pandruvada). - cpufreq-dt driver cleanup (Markus Elfring). - Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla). - Generic power domains core code fixes and cleanups (Ulf Hansson). - Operating Performance Points (OPP) core code cleanups and kernel documentation update (Nishanth Menon). - New dabugfs interface to make the list of PM QoS constraints available to user space (Nishanth Menon). - New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso). - New devfreq class (devfreq_event) to provide raw utilization data to devfreq governors (Chanwoo Choi). - Assorted minor fixes and cleanups related to power management (Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel Machek, Todd E Brandt, Wonhong Kwon). - turbostat updates (Len Brown) and cpupower Makefile improvement (Sriram Raghunathan)" * tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits) tools/power turbostat: relax dependency on APERF_MSR tools/power turbostat: relax dependency on invariant TSC Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS tools/power turbostat: relax dependency on root permission ACPI / video: Add disable_native_backlight quirk for Samsung 510R ACPI / PM: Remove unneeded nested #ifdef USB / PM: Remove unneeded #ifdef and associated dead code intel_pstate: provide option to only use intel_pstate with HWP ACPI / EC: Add GPE reference counting debugging messages ACPI / EC: Add query flushing support ACPI / EC: Refine command storm prevention support ACPI / EC: Add command flushing support. ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag ACPI: add AMD ACPI2Platform device support for x86 system ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse() ACPI / EC: Update revision due to raw handler mode. ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp. ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode. ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model ...
2015-02-09Merge branch 'sfi' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-cpufreq Pull SFI-based cpufreq driver for v3.20 from Len Brown. * 'sfi' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: cpufreq: Add SFI based cpufreq driver support SFI: fix compiler warnings
2015-02-06intel_pstate: provide option to only use intel_pstate with HWPKristen Carlson Accardi
Allow users the option to disable the driver for any hardware which does not support HWP. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03cpufreq-dt: Drop unnecessary check before cpufreq_cooling_unregister() ↵Markus Elfring
invocation The cpufreq_cooling_unregister() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> [ rjw: Subject ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03cpufreq: Create for_each_governor()Viresh Kumar
To make code more readable and less error prone, lets create a helper macro for iterating over all available governors. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03cpufreq: Create for_each_policy()Viresh Kumar
To make code more readable and less error prone, lets create a helper macro for iterating over all active policies. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03cpufreq: Drop cpufreq_disabled() check from cpufreq_cpu_{get|put}()Viresh Kumar
When cpufreq is disabled, the per-cpu variable would have been set to NULL. Remove this unnecessary check. [ Changelog from Saravana Kannan. ] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03cpufreq: Set cpufreq_cpu_data to NULL before putting kobjectViresh Kumar
In __cpufreq_remove_dev_finish(), per-cpu 'cpufreq_cpu_data' needs to be cleared before calling kobject_put(&policy->kobj) and under cpufreq_driver_lock. Otherwise, if someone else calls cpufreq_cpu_get() in parallel with it, they can obtain a non-NULL policy from that after kobject_put(&policy->kobj) was executed. Consider this case: Thread A Thread B cpufreq_cpu_get() acquire cpufreq_driver_lock read-per-cpu cpufreq_cpu_data kobject_put(&policy->kobj); kobject_get(&policy->kobj); ... per_cpu(&cpufreq_cpu_data, cpu) = NULL And this will result in a warning like this one: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 4 at include/linux/kref.h:47 kobject_get+0x41/0x50() Modules linked in: acpi_cpufreq(+) nfsd auth_rpcgss nfs_acl lockd grace sunrpc xfs libcrc32c sd_mod ixgbe igb mdio ahci hwmon ... Call Trace: [<ffffffff81661b14>] dump_stack+0x46/0x58 [<ffffffff81072b61>] warn_slowpath_common+0x81/0xa0 [<ffffffff81072c7a>] warn_slowpath_null+0x1a/0x20 [<ffffffff812e16d1>] kobject_get+0x41/0x50 [<ffffffff815262a5>] cpufreq_cpu_get+0x75/0xc0 [<ffffffff81527c3e>] cpufreq_update_policy+0x2e/0x1f0 [<ffffffff810b8cb2>] ? up+0x32/0x50 [<ffffffff81381aa9>] ? acpi_ns_get_node+0xcb/0xf2 [<ffffffff81381efd>] ? acpi_evaluate_object+0x22c/0x252 [<ffffffff813824f6>] ? acpi_get_handle+0x95/0xc0 [<ffffffff81360967>] ? acpi_has_method+0x25/0x40 [<ffffffff81391e08>] acpi_processor_ppc_has_changed+0x77/0x82 [<ffffffff81089566>] ? move_linked_works+0x66/0x90 [<ffffffff8138e8ed>] acpi_processor_notify+0x58/0xe7 [<ffffffff8137410c>] acpi_ev_notify_dispatch+0x44/0x5c [<ffffffff8135f293>] acpi_os_execute_deferred+0x15/0x22 [<ffffffff8108c910>] process_one_work+0x160/0x410 [<ffffffff8108d05b>] worker_thread+0x11b/0x520 [<ffffffff8108cf40>] ? rescuer_thread+0x380/0x380 [<ffffffff81092421>] kthread+0xe1/0x100 [<ffffffff81092340>] ? kthread_create_on_node+0x1b0/0x1b0 [<ffffffff81669ebc>] ret_from_fork+0x7c/0xb0 [<ffffffff81092340>] ? kthread_create_on_node+0x1b0/0x1b0 ---[ end trace 89e66eb9795efdf7 ]--- The actual code flow is as follows: Thread A: Workqueue: kacpi_notify acpi_processor_notify() acpi_processor_ppc_has_changed() cpufreq_update_policy() cpufreq_cpu_get() kobject_get() Thread B: xenbus_thread() xenbus_thread() msg->u.watch.handle->callback() handle_vcpu_hotplug_event() vcpu_hotplug() cpu_down() __cpu_notify(CPU_POST_DEAD..) cpufreq_cpu_callback() __cpufreq_remove_dev_finish() cpufreq_policy_put_kobj() kobject_put() cpufreq_cpu_get() gets the policy from per-cpu variable cpufreq_cpu_data under cpufreq_driver_lock, and once it gets a valid policy it expects it to not be freed until cpufreq_cpu_put() is called. But the race happens when another thread puts the kobject first and updates cpufreq_cpu_data before or later. And so the first thread gets a valid policy structure and before it does kobject_get() on it, the second one has already done kobject_put(). Fix this by setting cpufreq_cpu_data to NULL before putting the kobject and that too under locks. Reported-by: Ethan Zhao <ethan.zhao@oracle.com> Reported-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: 3.12+ <stable@vger.kernel.org> # 3.12+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-30intel_pstate: honor user space min_perf_pct override on resumeKristen Carlson Accardi
If the user has requested an override of the min_perf_pct via sysfs, then it should be restored whenever policy is updated, such as on resume. Take the max of whatever the user requested and whatever the policy is. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-30intel_pstate: respect cpufreq policy requestSrinivas Pandruvada
When thermal or other subsystem requests to change the policy, use that irrepective of whether cpufreq policy is PERFORMANCE or not. Without this change, when thermal subsystem passive policy wants to reduce performance, it still runs at 100%. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-30intel_pstate: Add num_pstates to sysfsKristen Carlson Accardi
Add a sysfs interface to display the total number of supported pstates. This value is independent of whether turbo has been enabled or disabled. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-30intel_pstate: expose turbo range to sysfsKristen Carlson Accardi
This patch adds "turbo_pct" to the intel_pstate sysfs interface. turbo_pct will display the percentage of the total supported pstates that are in the turbo range. This value is independent of whether turbo has been disabled or not. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-30intel_pstate: Add support for SkyLakeKristen Carlson Accardi
Add SKL cpuid. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: drop unnecessary lockingViresh Kumar
There is no possibility of any race on updating last_index, trans_table or total_trans as these are updated only by cpufreq_stat_notifier_trans() which will be called sequentially. The only place where locking is still relevant is: cpufreq_stats_update(), which updates time_in_state and last_time. This can be called by two thread in parallel, that may result in races. The two threads being: - sysfs read of time_in_state - and frequency transition that calls cpufreq_stat_notifier_trans(). Remove locking from the first case mentioned above. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: don't update stats on false notifiersViresh Kumar
We need to call cpufreq_stats_update() to update 'time_in_state' for the last frequency. This is achieved by calling it from cpufreq_stat_notifier_trans(), which is called after frequency transition. But if we detect that the cpu's frequency haven't really changed and its a false POSTCHANGE notification, we don't really need to update time_in_state. It wouldn't cause any harm in calling cpufreq_stats_update() but we can avoid calling it here and call it when the frequency really changes. The result will be the same but more efficient. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: don't update stats from show_trans_table()Viresh Kumar
cpufreq_stats_update() updates time_in_state and nothing else. It should ideally be updated only in two cases: - User requested for the current value of time_in_state. - We have switched states and so need to update time for the last state. Currently, we are also doing this while user asks for the transition table of frequencies. It wouldn't do any harm, but no good as well. Its useless here. Remove it. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: time_in_state can't be NULL in cpufreq_stats_update()Viresh Kumar
'time_in_state' can't be NULL if 'stats' is valid. These are allocated together and only if time_in_state is allocated successfully, we update policy->stats. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: create sysfs group once we are readyViresh Kumar
Userspace is free to read value of any file from cpufreq/stats directory once they are created. __cpufreq_stats_create_table() is creating the sysfs files first and then allocating resources for them. Though it would be quite difficult to trigger the racy situation here, but for the sake of keeping sensible code lets create sysfs entries only after we are ready to go. This also does some makeup to the routine to make it look better. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: remove CPUFREQ_UPDATE_POLICY_CPU notificationsViresh Kumar
CPUFREQ_UPDATE_POLICY_CPU notifications were used only from cpufreq-stats which doesn't use it anymore. Remove them. This also decrements values of other notification macros defined after CPUFREQ_UPDATE_POLICY_CPU by 1 to remove gaps. Hopefully all users are using macro's instead of direct numbers and so they wouldn't break as macro values are changed now. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: drop 'cpu' field of struct cpufreq_statsViresh Kumar
'cpu' field of struct cpufreq_stats isn't used anymore and so can be dropped. This change makes cpufreq_stats_update_policy_cpu() empty and so that is removed as well. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: Remove (now) unused 'last_cpu' from struct cpufreq_policyViresh Kumar
'last_cpu' was used only from cpufreq-stats and isn't used anymore. Get rid of it. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: rename 'struct cpufreq_stats' objects as 'stats'Viresh Kumar
Currently we name objects of 'struct cpufreq_stats' as 'stat' and 'stats'. Use 'stats' to make it consistent. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: get rid of per-cpu cpufreq_stats_tableViresh Kumar
All CPUs sharing a cpufreq policy share stats too. For this reason, add a stats pointer to struct cpufreq_policy and drop per-CPU variable cpufreq_stats_table used for accessing cpufreq stats so as to reduce code complexity. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: pass 'stat' to cpufreq_stats_update()Viresh Kumar
It is better to pass a struct cpufreq_stats pointer to cpufreq_stats_update() instead of a CPU number, because that's all it needs. Even if we pass a cpu number to cpufreq_stats_update(), it reads the per-cpu variable to get 'stats' out of it. So we are doing these operations unnecessarily: - First getting the cpu number to pass to cpufreq_stats_update(), stat->cpu. - And then getting stats from the cpu, per_cpu(cpufreq_stats_table, cpu). Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: don't check for freq table while freeing statsViresh Kumar
While we allocate stats, we do need to check if freq-table is present or not as we need to use it then. But while freeing stats, all we need to know is if stats holds a valid pointer value. There is no use of testing if cpufreq table is present or not. Don't check it. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: initialize 'cur_time' on its definitionViresh Kumar
'cur_time' is defined in the first line and is then assigned a value in the next line. Initialize it while defining it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: remove unused cpufreq_stats_attributeViresh Kumar
It was never used, but is there since the first commit. Remove it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: return -EEXIST when stats are already allocatedViresh Kumar
__cpufreq_stats_create_table() is called from: - cpufreq notifier on creation of a new policy. Stats will always be NULL here. - cpufreq_stats_init() for all CPUs as cpufreq-stats might have been initialized after cpufreq driver. For any policy, 'stats' will be NULL for the first CPU only and will be valid for all other CPUs managed by the same policy. While we return for other CPUs, we don't return the right error value. It's not that we would fail with -EBUSY. But generally, this is what these return values mean: - EBUSY: we are busy right now, try again. And the retry attempt might be immediate. - EEXIST: We already have what you are trying to create and there is no need to create it again, and so no more tries are required. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: stats: Improve module description stringViresh Kumar
The MODULE_DESCRIPTION() string is just too long and then is broken into multiple lines just to make checkpatch happy. Rewrite it to make it more precise. Reviewed-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: move some initialization stuff to cpufreq_policy_alloc()Viresh Kumar
We need to initialize completion and work only on policy allocation and not really on the policy restore side and so we better move this piece of code to cpufreq_policy_alloc(). Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: check cpufreq_policy_list instead of scanning policies for all CPUsViresh Kumar
CPUFREQ_STICKY flag is set by drivers which don't want to get unregistered even if cpufreq-core isn't able to initialize policy for any CPU. When this flag isn't set, we try to unregister the driver. To find out which CPUs are registered and which are not, we try to check per_cpu cpufreq_cpu_data for all CPUs. Because we have a list of valid policies available now, we better check if the list is empty or not instead of the 'for' loop. That will be much more efficient. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: limit the scope of l_p_j variablesViresh Kumar
These variables are just used within adjust_jiffies() and so must be local to it. Also there is no need of a dummy routine for CONFIG_SMP case as we can take care of all that with help of macros in the same routine. It doesn't look that ugly. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: use light-weight cpufreq_cpu_get_raw() in __cpufreq_add_dev()Viresh Kumar
We just need to check if a 'policy' is already present for the cpu we are adding. We don't need to take all the locks and do kobject usage updates. Use the light-weight cpufreq_cpu_get_raw() routine instead. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: get rid of 'tpolicy' from __cpufreq_add_dev()Viresh Kumar
There is no need of this separate variable, use 'policy' instead. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: get rid of CONFIG_{HOTPLUG_CPU|SMP} messViresh Kumar
These are messing up more than the benefit they provide. It isn't a lot of code anyway, that we will compile without them. Kill them. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: update driver_data->flags only if we are registering driverViresh Kumar
We should first check if a cpufreq driver is already registered or not before updating driver_data->flags. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: pass policy to __cpufreq_get()Viresh Kumar
There is no point finding out the 'policy' again within __cpufreq_get() when all the callers already have it. Just make them pass policy instead. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: pass policy to cpufreq_out_of_syncViresh Kumar
There is no point finding out the 'policy' again within cpufreq_out_of_sync() when all the callers already have it. Just make them pass policy instead. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: No need to check for has_target()Viresh Kumar
Either we can be setpolicy or target type, nothing else. And so the else part of setpolicy will automatically be of has_target() type. And so we don't need to check it again. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: s/__find_governor/find_governorViresh Kumar
Remove unnecessary from find_governor's name. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: merge 'if' blocks in __cpufreq_remove_dev_prepare()Viresh Kumar
There are two 'if' blocks here, checking for !cpufreq_driver->setpolicy and has_target(). Both are actually doing the same thing, merge them. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: don't need line break in show_scaling_cur_freq()Viresh Kumar
No need of an unnecessary line break. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: remove extra parenthesisViresh Kumar
We can live without it and so we should. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: remove dangling commentViresh Kumar
It doesn't make any sense at all and is a leftover of some earlier commit. Remove it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: suspend cpufreq governors on shutdownDoug Anderson
We should stop cpufreq governors when we shut down the system. If we don't do this, we can end up with this deadlock: 1. cpufreq governor may be running on a CPU other than CPU0. 2. In machine_restart() we call smp_send_stop() which stops CPUs. If one of these CPUs was actively running a cpufreq governor then it may have the mutex / spinlock needed to access the main PMIC in the system (perhaps over I2C) 3. If a machine needs access to the main PMIC in order to shutdown then it will never get it since the mutex was lost when the other CPU stopped. 4. We'll hang (possibly eventually hitting the hard lockup detector). Let's avoid the problem by stopping the cpufreq governor at shutdown, which is a sensible thing to do anyway. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23cpufreq: drop owner assignment from platform_driversWolfram Sang
This platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-21Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: - Documentation updates. - Miscellaneous fixes. - Preemptible-RCU fixes, including fixing an old bug in the interaction of RCU priority boosting and CPU hotplug. - SRCU updates. - RCU CPU stall-warning updates. - RCU torture-test updates. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-06rcu: Make SRCU optional by using CONFIG_SRCUPranith Kumar
SRCU is not necessary to be compiled by default in all cases. For tinification efforts not compiling SRCU unless necessary is desirable. The current patch tries to make compiling SRCU optional by introducing a new Kconfig option CONFIG_SRCU which is selected when any of the components making use of SRCU are selected. If we do not select CONFIG_SRCU, srcu.o will not be compiled at all. text data bss dec hex filename 2007 0 0 2007 7d7 kernel/rcu/srcu.o Size of arch/powerpc/boot/zImage changes from text data bss dec hex filename 831552 64180 23944 919676 e087c arch/powerpc/boot/zImage : before 829504 64180 23952 917636 e0084 arch/powerpc/boot/zImage : after so the savings are about ~2000 bytes. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> CC: Josh Triplett <josh@joshtriplett.org> CC: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [ paulmck: resolve conflict due to removal of arch/ia64/kvm/Kconfig. ]
