path: root/drivers/cpufreq/s3c2412-cpufreq.c
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-09cpufreq: Use consistent prefixing via pr_fmtJoe Perches
Use the more common kernel style adding a define for pr_fmt. Miscellanea: o Remove now unused PFX defines Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-09cpufreq: Convert printk(KERN_<LEVEL> to pr_<level>Joe Perches
Use the more common logging style. Miscellanea: o Coalesce formats o Realign arguments o Add a missing space between a coalesced format Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-19cpufreq: s3c24xx: Remove some dead codeTomasz Figa
There is no use for the .resume_clocks() callback now and in fact all the provided functions are empty, so this patch just removes it in preparation for further patches. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-05-20cpufreq: s3c24xx: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of Samsung's ARM based s3c24xx platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
