CPUFreq drivers that use clock frameworks interface,i.e. clk_get_rate(),
to get CPUs clk rate, have similar sort of code used in most of them.
This patch adds a generic ->get() which will do the same thing for them.
All those drivers are required to now is to set .get to cpufreq_generic_get()
and set their clk pointer in policy->clk during ->init().
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Sometimes boot loaders set CPU frequency to a value outside of frequency table
present with cpufreq core. In such cases CPU might be unstable if it has to run
on that frequency for long duration of time and so its better to set it to a
frequency which is specified in frequency table.
On some systems we can't really say what frequency we're running at the moment
and so for these we shouldn't check if we are running at a frequency present in
frequency table. And so we really can't force this for all the cpufreq drivers.
Hence we are created another flag here: CPUFREQ_NEED_INITIAL_FREQ_CHECK that
will be marked by platforms which want to go for this check at boot time.
Initially this is done for all ARM platforms but others may follow if required.
Add a routine check to see if the platform supplied the OPP table.
Incase there's no OPP table exist, it will try to initialise it.
It's been tested on iMX6SL board where the platform doesn't have
an OPP table.
Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
on i.MX6Q, cpu freq change need to follow below flows:
1. each setpoint has different VDDARM, VDDSOC/PU voltage, get the setpoint
table from dts;
2. when cpu freq is scaling up, need to increase VDDSOC/PU voltage before
VDDARM, if VDDPU is off, no need to change it;
3. when cpu freq is scaling down, need to decrease VDDARM voltage before
VDDSOC/PU, if VDDPU is off, no need to change it;
normally dts will pass vddsoc/pu freq/volt info to kernel, if not, will
use fixed value for vddsoc/pu voltage setting.
Signed-off-by: Anson Huang <b20788@freescale.com>
Most of the drivers do following in their ->target_index() routines:
struct cpufreq_freqs freqs;
freqs.old = old freq...
freqs.new = new freq...
cpufreq_notify_transition(policy, &freqs, CPUFREQ_PRECHANGE);
/* Change rate here */
cpufreq_notify_transition(policy, &freqs, CPUFREQ_POSTCHANGE);
This is replicated over all cpufreq drivers today and there doesn't exists a
good enough reason why this shouldn't be moved to cpufreq core instead.
There are few special cases though, like exynos5440, which doesn't do everything
on the call to ->target_index() routine and call some kind of bottom halves for
doing this work, work/tasklet/etc..
They may continue doing notification from their own code as flag:
CPUFREQ_ASYNC_NOTIFICATION is already set for them.
All drivers are also modified in this patch to avoid breaking 'git bisect', as
double notification would happen otherwise.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Lan Tianyu <tianyu.lan@intel.com>
Currently, the prototype of cpufreq_drivers target routines is:
int target(struct cpufreq_policy *policy, unsigned int target_freq,
unsigned int relation);
And most of the drivers call cpufreq_frequency_table_target() to get a valid
index of their frequency table which is closest to the target_freq. And they
don't use target_freq and relation after that.
So, it makes sense to just do this work in cpufreq core before calling
cpufreq_frequency_table_target() and simply pass index instead. But this can be
done only with drivers which expose their frequency table with cpufreq core. For
others we need to stick with the old prototype of target() until those drivers
are converted to expose frequency tables.
This patch implements the new light weight prototype for target_index() routine.
It looks like this:
int target_index(struct cpufreq_policy *policy, unsigned int index);
CPUFreq core will call cpufreq_frequency_table_target() before calling this
routine and pass index to it. Because CPUFreq core now requires to call routines
present in freq_table.c CONFIG_CPU_FREQ_TABLE must be enabled all the time.
This also marks target() interface as deprecated. So, that new drivers avoid
using it. And Documentation is updated accordingly.
It also converts existing .target() to newly defined light weight
.target_index() routine for many driver.
Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
drivers/cpufreq/omap-cpufreq.c
Since Operating Performance Points (OPP) functions are specific
to device specific power management, be specific and rename opp.h
to pm_opp.h
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Nishanth Menon <nm@ti.com>
Since Operating Performance Points (OPP) data structures are specific
to device specific power management, be specific and rename opp_* data
structures in OPP library with dev_pm_opp_* equivalent.
Affected structures are:
struct opp
enum opp_event
Minor checkpatch warning resulting of this change was fixed as well.
Since Operating Performance Points (OPP) functions are specific to
accessors in OPP library with dev_pm_opp_* equivalent.
Affected functions are:
opp_get_voltage
opp_get_freq
opp_get_opp_count
opp_find_freq_exact
opp_find_freq_floor
opp_find_freq_ceil
opp_add
opp_enable
opp_disable
opp_get_notifier
opp_init_cpufreq_table
opp_free_cpufreq_table
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Use generic cpufreq_generic_init() routine instead of replicating the same code
here.
Many common initializations of struct policy are moved to core now and hence
this driver doesn't need to do it. This patch removes such code.
Most recent of those changes is to call ->get() in the core after calling
->init().
Cc: Shawn Guo <shawn.guo@linaro.org>
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines
and .attr. So its better if we have generic routines for them which can be used
by cpufreq drivers then.
This patch uses these generic routines for in the imx6q driver.
Lets use cpufreq_table_validate_and_show() instead of calling
cpufreq_frequency_table_cpuinfo() and cpufreq_frequency_table_get_attr().
Commit cdc58d602d2e657602a90c190cbf745886c95977 "cpufreq: imx6q-cpufreq:
remove device tree parsing for cpu nodes" assumed the pdev->dev is set to
cpu0 device in the platform code. But it actually points to the virtual
cpufreq-cpu0 platform device which is not present in the device tree.
Most of the information needed by cpufreq is stored in cpu0 DT node.
So cpu_dev must point to cpu0 device.
This patch fixes the wrong assignment to cpu_dev.
Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
into pm-cpufreq
Pull cpufreq fixes for v3.12 from Viresh Kumar.
* 'cpufreq-fixes' of git://git.linaro.org/people/vireshk/linux:
cpufreq: imx6q: Fix clock enable balance
cpufreq: tegra: fix the wrong clock name
For changing the cpu frequency the i.MX6q has to be switched to some
intermediate clock during the PLL reprogramming. The driver tries
to be clever to keep the enable count correct but gets it wrong. If
the cpufreq is increased it calls clk_disable_unprepare twice
on pll2_pfd2_396m. This puts all other devices which get their clock
from pll2_pfd2_396m into a nonworking state.
Fix this by removing the clk enabling/disabling altogether since the
clk core will do this automatically during a reparent.
Now that the cpu device registration initialises the of_node(if available)
appropriately for all the cpus, parsing here is redundant.
This patch removes all DT parsing and uses cpu->of_node instead.
PRECHANGE and POSTCHANGE notifiers must be called in groups, i.e either both
should be called or both shouldn't be.
In case we have started PRECHANGE notifier and found an error, we must call
POSTCHANGE notifier with freqs.new = freqs.old to guarantee that sequence of
calling notifiers is complete.
This patch fixes it.
This also moves PRECHANGE notifier down so that we call it just before starting
frequency transition.
policy->cpus contains all online cpus that have single shared clock line. And
their frequencies are always updated together.
Many SMP system's cpufreq drivers take care of this in individual drivers but
the best place for this code is in cpufreq core.
This patch modifies cpufreq_notify_transition() to notify frequency change for
all cpus in policy->cpus and hence updates all users of this API.
In case of error, the function devm_regulator_get() returns
ERR_PTR() and never returns NULL. The NULL test in the return
value check should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Add an imx6q-cpufreq driver for Freescale i.MX6Q SoC to handle the
hardware specific frequency and voltage scaling requirements.
The driver supports module build and is instantiated by the platform
device/driver mechanism, so that it will not be instantiated on other
platforms, as IMX is built with multiplatform support.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
