Currently cpufreq frequency table has two fields: frequency and driver_data.
driver_data is only for drivers' internal use and cpufreq core shouldn't use
it at all. But with the introduction of BOOST frequencies, this assumption
was broken and we started using it as a flag instead.
There are two problems due to this:
- It is against the description of this field, as driver's data is used by
the core now.
- if drivers fill it with -3 for any frequency, then those frequencies are
never considered by cpufreq core as it is exactly same as value of
CPUFREQ_BOOST_FREQ, i.e. ~2.
The best way to get this fixed is by creating another field flags which
will be used for such flags. This patch does that. Along with that various
drivers need modifications due to the change of struct cpufreq_frequency_table.
Reviewed-by: Gautham R Shenoy <ego@linux.vnet.ibm.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
cpufreq_generic_exit() is empty now and can be deleted.
Most of the drivers do following in their ->target_index() routines:
struct cpufreq_freqs freqs;
freqs.old = old freq...
freqs.new = new freq...
cpufreq_notify_transition(policy, &freqs, CPUFREQ_PRECHANGE);
/* Change rate here */
cpufreq_notify_transition(policy, &freqs, CPUFREQ_POSTCHANGE);
This is replicated over all cpufreq drivers today and there doesn't exists a
good enough reason why this shouldn't be moved to cpufreq core instead.
There are few special cases though, like exynos5440, which doesn't do everything
on the call to ->target_index() routine and call some kind of bottom halves for
doing this work, work/tasklet/etc..
They may continue doing notification from their own code as flag:
CPUFREQ_ASYNC_NOTIFICATION is already set for them.
All drivers are also modified in this patch to avoid breaking 'git bisect', as
double notification would happen otherwise.
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Lan Tianyu <tianyu.lan@intel.com>
Currently, the prototype of cpufreq_drivers target routines is:
int target(struct cpufreq_policy *policy, unsigned int target_freq,
unsigned int relation);
And most of the drivers call cpufreq_frequency_table_target() to get a valid
index of their frequency table which is closest to the target_freq. And they
don't use target_freq and relation after that.
So, it makes sense to just do this work in cpufreq core before calling
cpufreq_frequency_table_target() and simply pass index instead. But this can be
done only with drivers which expose their frequency table with cpufreq core. For
others we need to stick with the old prototype of target() until those drivers
are converted to expose frequency tables.
This patch implements the new light weight prototype for target_index() routine.
It looks like this:
int target_index(struct cpufreq_policy *policy, unsigned int index);
CPUFreq core will call cpufreq_frequency_table_target() before calling this
routine and pass index to it. Because CPUFreq core now requires to call routines
present in freq_table.c CONFIG_CPU_FREQ_TABLE must be enabled all the time.
This also marks target() interface as deprecated. So, that new drivers avoid
using it. And Documentation is updated accordingly.
It also converts existing .target() to newly defined light weight
.target_index() routine for many driver.
Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Many common initializations of struct policy are moved to core now and hence
this driver doesn't need to do it. This patch removes such code.
Most recent of those changes is to call ->get() in the core after calling
->init().
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines
and .attr. So its better if we have generic routines for them which can be used
by cpufreq drivers then.
This patch uses these generic routines in the elanfreq driver.
Lets use cpufreq_table_validate_and_show() instead of calling
cpufreq_frequency_table_cpuinfo() and cpufreq_frequency_table_get_attr().
We don't need to set .owner = THIS_MODULE any more in cpufreq drivers
as this field isn't used any more by the cpufreq core.
This patch removes it and updates all dependent drivers accordingly.
policy->cpus contains all online cpus that have single shared clock line. And
their frequencies are always updated together.
Many SMP system's cpufreq drivers take care of this in individual drivers but
the best place for this code is in cpufreq core.
This patch modifies cpufreq_notify_transition() to notify frequency change for
all cpus in policy->cpus and hence updates all users of this API.
This marks all the x86 cpuinfo tables to the CPU specific device drivers,
to allow auto loading by udev. This should simplify the distribution
startup scripts for this greatly.
I didn't add MODULE_DEVICE_IDs to the centrino and p4-clockmod drivers,
because those probably shouldn't be auto loaded and the acpi driver
be used instead (not fully sure on that, would appreciate feedback)
The old nforce drivers autoload based on the PCI ID.
ACPI cpufreq is autoloaded in another patch.
v3: Autoload gx based on PCI IDs only. Remove cpu check (Dave Jones)
v4: Use newly introduce HW_PSTATE feature for powernow-k8 loading
Cc: Dave Jones <davej@redhat.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Dave Jones <davej@redhat.com>
