ondemand micro-accounting of idle time changes broke ignore_nice_load
sysfs setting due to a thinko in the code.
The bug entry:
http://bugzilla.kernel.org/show_bug.cgi?id=12310
Reported-by: Jim Bray <jimsantelmo@gmail.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Impact: use new cpumask API to reduce memory usage
This is part of an effort to reduce structure sizes for machines
configured with large NR_CPUS. cpumask_t gets replaced by
cpumask_var_t, which is either struct cpumask[1] (small NR_CPUS) or
struct cpumask * (large NR_CPUS).
Signed-off-by: Mike Travis <travis@sgi.com>
Acked-by: Dave Jones <davej@redhat.com>
Use get_cpu()/put_cpu() in cpufreq_ondemand init routine, instead of
smp_processor_id() to avoid the following BUG:
[ 35.313118] BUG: using smp_processor_id() in preemptible [00000000] code=: modprobe/4952
[ 35.313132] caller is cpufreq_gov_dbs_init+0xa/0x8f [cpufreq_ondemand]
[ 35.313140] Pid: 4952, comm: modprobe Not tainted 2.6.27-rc5-mm1 #23
[ 35.313145] Call Trace:
[ 35.313158] [<ffffffff80361ff7>] debug_smp_processor_id+0xd7/0xe0
[ 35.313167] [<ffffffffa010800a>] cpufreq_gov_dbs_init+0xa/0x8f [cpufreq_ondemand]
[ 35.313176] [<ffffffff8020903b>] _stext+0x3b/0x160
[ 35.313185] [<ffffffff804768c5>] __mutex_unlock_slowpath+0xe5/0x190
[ 35.313195] [<ffffffff8026236a>] trace_hardirqs_on_caller+0xca/0x140
[ 35.313205] [<ffffffff8026ef4c>] sys_init_module+0xdc/0x210
[ 35.313212] [<ffffffff8020b7cb>] system_call_fastpath+0x16/0x1b
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
We don't need to export the governors for use as the default governor,
because the default governor will be built-in anyway and we can access
the symbol directly.
This also fixes the following sparse warnings:
drivers/cpufreq/cpufreq_conservative.c:578:25: warning: symbol 'cpufreq_gov_conservative' was not declared. Should it be static?
drivers/cpufreq/cpufreq_ondemand.c:582:25: warning: symbol 'cpufreq_gov_ondemand' was not declared. Should it be static?
drivers/cpufreq/cpufreq_performance.c:39:25: warning: symbol 'cpufreq_gov_performance' was not declared. Should it be static?
drivers/cpufreq/cpufreq_powersave.c:38:25: warning: symbol 'cpufreq_gov_powersave' was not declared. Should it be static?
drivers/cpufreq/cpufreq_userspace.c:190:25: warning: symbol 'cpufreq_gov_userspace' was not declared. Should it be static?
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Use get_cpu_idle_time_us() to get micro-accounted idle information.
This enables ondemand to get more accurate idle and busy timings
than the jiffy based calculation. As a result, we can decrease
the ondemand safety gaurd band from 80-10 to 95-3.
Results in more aggressive power savings.
Use a parameter for down differential, instead of hardcoded 10%. Follow-on
patch changes the down-differential dynamically, based on whether
we are using idle micro-accounting or not.
idle-microaccounting
Preparatory changes for doing idle micro-accounting in ondemand governor.
get_cpu_idle_time() gets extra parameter and returns idle time and also the
wall time that corresponds to the idle time measurement.
coordination
Change the load calculation algorithm in ondemand to work well with software
coordination of frequency across the dependent cpus.
Multiply individual CPU utilization with the average freq of that logical CPU
during the measurement interval (using getavg call). And find the max CPU
utilization number in terms of CPU freq. That number is then used to
get to the target freq for next sampling interval.
Add a cpu parameter to __cpufreq_driver_getavg(). This is needed for software
cpufreq coordination where policy->cpu may not be same as the CPU on which we
want to getavg frequency.
A follow-on patch will use this parameter to getavg freq from all cpus
in policy->cpus.
Change since last patch. Fix the offline/online and suspend/resume
oops reported by Youquan Song <youquan.song@intel.com>
Add error handling for cpufreq_register_governor() error
Cc: cpufreq@lists.linux.org.uk
Change references from for_each_cpu_mask to for_each_cpu_mask_nr
where appropriate
Reviewed-by: Paul Jackson <pj@sgi.com>
Reviewed-by: Christoph Lameter <clameter@sgi.com>
When the cpufreq driver starts up at boot time, it calls into the default
governor which might not be initialised yet. This hurts when the
governor's worker function relies on memory that is not yet set up by its
init function.
This migrates all governors from module_init() to fs_initcall() when being
the default, as was already done in cpufreq_performance when it was the
only possible choice. The performance governor is always initialized early
because it might be used as fallback even when not being the default.
Fixes at least one actual oops where ondemand is the default governor and
cpufreq_governor_dbs() uses the uninitialised kondemand_wq work-queue
during boot-time.
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
default
Depending on the transition latency of the HW for cpufreq switches, the
ondemand or conservative governor cannot be used with certain cpufreq
drivers. Still the ondemand should be the default governor on a wide range
of systems. This patch allows this and lets the governor fallback to the
performance governor at cpufreq driver load time, if the driver does not
support fast enough frequency switching.
Main benefit is that on e.g. installation or other systems without
userspace support a working dynamic cpufreq support can be achieved on most
systems by simply loading the cpufreq driver. This is especially essential
for recent x86(_64) laptop hardware which may rely on working dynamic
cpufreq OS support.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: Andi Kleen <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
With tickless kernel and software coordination os P-states, ondemand
can look at wrong idle statistics. This can happen when ondemand sampling
is happening on CPU 0 and due to software coordination sampling also looks at
utilization of CPU 1. If CPU 1 is in tickless state at that moment, its idle
statistics will not be uptodate and CPU 0 thinks CPU 1 is idle for less
amount of time than it actually is.
This can be resolved by looking at all the busy times of CPUs, which is
accurate, even with tickless, and use that to determine idle time in a
round about way (total time - busy time).
Thanks to Arjan for originally reporting the ondemand bug on
Lenovo T61.
Due to rounding and inexact jiffy accounting, idle_ticks can sometimes
be higher than total_ticks. Make sure those cases are handled as
zero load case.
Add a new deferrable delayed work init. This can be used to schedule work
that are 'unimportant' when CPU is idle and can be called later, when CPU
eventually comes out of idle.
Use this init in cpufreq ondemand governor.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Looks like dbs_timer() is very careful wrt per_cpu(cpu_dbs_info),
and it doesn't need the help of WORK_STRUCT_NOAUTOREL.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-By: David Howells <dhowells@redhat.com>
Eliminate flush_workqueue in cpufreq_governor(STOP) callpath. Using flush
there has a deadlock potential as in
http://uwsg.iu.edu/hypermail/linux/kernel/0611.3/1223.html
Also, cleanup the locking issues with do_dbs_timer delayed_work callback. As
it changes the CPU frequency using __cpufreq_target, it needs to have
policy_rwsem in write mode, which also protects it from hot plug.
Cc: Gautham R Shenoy <ego@in.ibm.com>
Restructure the delayed_work callback in ondemand.
This eliminates the need for smp_processor_id in the callback function and
also helps in proper locking and avoiding flush_workqueue when stopping the
governor (done in subsequent patch).
The hotplug CPU locking in cpufreq is horrendous. No-one seems to care
enough to fix it, so just remove it so that the 99.9% of the real world
users of this code can use cpufreq without being bothered by warnings.
drivers/cpufreq/cpufreq.c
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Clean up cpufreq subsystem to fix coding style issues and to improve
the readability.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Enable ondemand governor and acpi-cpufreq to use IA32_APERF and IA32_MPERF MSR
to get active frequency feedback for the last sampling interval. This will
make ondemand take right frequency decisions when hardware coordination of
frequency is going on.
Without APERF/MPERF, ondemand can take wrong decision at times due
to underlying hardware coordination or TM2.
Example:
* CPU 0 and CPU 1 are hardware cooridnated.
* CPU 1 running at highest frequency.
* CPU 0 was running at highest freq. Now ondemand reduces it to
some intermediate frequency based on utilization.
* Due to underlying hardware coordination with other CPU 1, CPU 0 continues to
run at highest frequency (as long as other CPU is at highest).
* When ondemand samples CPU 0 again next time, without actual frequency
feedback from APERF/MPERF, it will think that previous frequency change
was successful and can go to wrong target frequency. This is because it
thinks that utilization it has got this sampling interval is when running at
intermediate frequency, rather than actual highest frequency.
More information about IA32_APERF IA32_MPERF MSR:
Refer to IA-32 Intel® Architecture Software Developer's Manual at
http://developer.intel.com
drivers/cpufreq/cpufreq_ondemand.c:323:2: warning: Using plain integer as NULL pointer
This patch makes the needlessly global powersave_bias_target() static.
ondemand selects the minimum frequency that can retire
a workload with negligible idle time -- ideally resulting in the highest
performance/power efficiency with negligible performance impact.
But on some systems and some workloads, this algorithm
is more performance biased than necessary, and
de-tuning it a bit to allow some performance impact
can save measurable power.
This patch adds a "powersave_bias" tunable to ondemand
to allow it to reduce its target frequency by a specified percent.
By default, the powersave_bias is 0 and has no effect.
powersave_bias is in units of 0.1%, so it has an effective range
of 1 through 1000, resulting in 0.1% to 100% impact.
In practice, users will not be able to detect a difference between
0.1% increments, but 1.0% increments turned out to be too large.
Also, the max value of 1000 (100%) would simply peg the system
in its deepest power saving P-state, unless the processor really has
a hardware P-state at 0Hz:-)
For example, If ondemand requests 2.0GHz based on utilization,
and powersave_bias=100, this code will knock 10% off the target
and seek a target of 1.8GHz instead of 2.0GHz until the
next sampling. If 1.8 is an exact match with an hardware frequency
we use it, otherwise we average our time between the frequency
next higher than 1.8 and next lower than 1.8.
Note that a user or administrative program can change powersave_bias
at run-time depending on how they expect the system to be used.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi at intel.com>
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy at intel.com>
Try to make dbs_check_cpu() call on all CPUs at the same jiffy.
This will help when multiple cores share P-states via Hardware Coordination.
The patch below moves the cpu hotplugging higher up in the cpufreq
layering; this is needed to avoid recursive taking of the cpu hotplug
lock and to otherwise detangle the mess.
The new rules are:
1. you must do lock_cpu_hotplug() around the following functions:
__cpufreq_driver_target
__cpufreq_governor (for CPUFREQ_GOV_LIMITS operation only)
__cpufreq_set_policy
2. governer methods (.governer) must NOT take the lock_cpu_hotplug()
lock in any way; they are called with the lock taken already
3. if your governer spawns a thread that does things, like calling
__cpufreq_driver_target, your thread must honor rule #1.
4. the policy lock and other cpufreq internal locks nest within
the lock_cpu_hotplug() lock.
I'm not entirely happy about how the __cpufreq_governor rule ended up
(conditional locking rule depending on the argument) but basically all
callers pass this as a constant so it's not too horrible.
The patch also removes the cpufreq_governor() function since during the
locking audit it turned out to be entirely unused (so no need to fix it)
The patch works on my testbox, but it could use more testing
(otoh... it can't be much worse than the current code)
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Shutting down the ondemand policy was fraught with potential
problems, causing issues for SMP suspend (which wants to hot-
unplug) all but the last CPU.
This should fix at least the worst problems (divide-by-zero
and infinite wait for the workqueue to shut down).
Misc cleanups in ondemand. Should have zero functional impact.
Also adding Alexey as author.
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com>
sampling path.
Make ondemand sampling per CPU and remove the mutex usage in sampling path.
Remove slowdown from ondemand sampling path. This reduces the code path length
in dbs_check_cpu() by half. slowdown was not used by ondemand by default.
If there are any user level tools that were using this tunable, they
may report error now.
drivers/cpufreq/cpufreq_ondemand.c: In function 'do_dbs_timer':
drivers/cpufreq/cpufreq_ondemand.c:374: warning: implicit declaration of function 'lock_cpu_hotplug'
drivers/cpufreq/cpufreq_ondemand.c:381: warning: implicit declaration of function 'unlock_cpu_hotplug'
drivers/cpufreq/cpufreq_conservative.c: In function 'do_dbs_timer':
drivers/cpufreq/cpufreq_conservative.c:425: warning: implicit declaration of function 'lock_cpu_hotplug'
drivers/cpufreq/cpufreq_conservative.c:432: warning: implicit declaration of function 'unlock_cpu_hotplug'
Rootcaused the bug to a deadlock in cpufreq and ondemand. Due to non-existent
ordering between cpu_hotplug lock and dbs_mutex. Basically a race condition
between cpu_down() and do_dbs_timer().
cpu_down() flow:
* cpu_down() call for CPU 1
* Takes hot plug lock
* Calls pre down notifier
* cpufreq notifier handler calls cpufreq_driver_target() which takes
cpu_hotplug lock again. OK as cpu_hotplug lock is recursive in same
process context
* CPU 1 goes down
* Calls post down notifier
* cpufreq notifier handler calls ondemand event stop which takes dbs_mutex
So, cpu_hotplug lock is taken before dbs_mutex in this flow.
do_dbs_timer is triggerred by a periodic timer event.
It first takes dbs_mutex and then takes cpu_hotplug lock in
cpufreq_driver_target().
Note the reverse order here compared to above. So, if this timer event happens
at right moment during cpu_down, system will deadlok.
Attached patch fixes the issue for both ondemand and conservative.
Taking the cpu hotplug semaphore in a normal events workqueue
is unsafe because other tasks can wait for any workqueues with
it hold. This results in a deadlock.
Move the DBS timer into its own work queue which is not
affected by other work queue flushes to avoid this.
Has been acked by Venkatesh.
Cc: venkatesh.pallipadi@intel.com
Signed-off-by: Andi Kleen <ak@suse.de>
Assert that cpufreq_target is, at least, called with the minimum frequency
allowed by this policy, not something lower. It triggered problems on ARM.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Keep the value of ignore_nice_load of the ondemand governor even after
the governor has been deselected and selected back. This is the behavior
of the other exported values of the ondemand governor and it's much more
user-friendly.
Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
latency
Display a warning if the ondemand governor can not be selected due to a
transition latency of the cpufreq driver which is too long.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
The use of the 'ignore_nice' sysfs file is confusing to anyone using it.
This removes the sysfs file 'ignore_nice' and in its place creates a
'ignore_nice_load' entry that defaults to '0'; meaning nice'd processes
_are_ counted towards the 'business' calculation.
WARNING: this obvious breaks any userland tools that expected ignore_nice'
to exist, to draw attention to this fact it was concluded on the mailing
list that the entry should be removed altogether so the userland app breaks
and so the author can build simple to detect workaround. Having said that
it seems currently very few tools even make use of this functionality; all
I could find was a Gentoo Wiki entry.
Signed-off-by: Alexander Clouter <alex-kernel@digriz.org.uk>
for stats.
The problem is in the ondemand governor, there is a periodic measurement
of the CPU usage. This CPU usage is updated by the scheduler after every
tick (basically, by adding 1 either to "idle" or to "user" or to
"system"). So if the frequency of the governor is too high, the stat
will be meaningless (as mostly no number have changed).
So this patch checks that the measurements are separated by at least 10
ticks. It means that by default, stats will have about 5% error (20
ticks). Of course those numbers can be argued but, IMHO, they look sane.
The patch also includes a small clean-up to check more explictly the
result of the conversion from ns to µs being null.
Let's note that (on x86) this has never been really needed before 2.6.13
because HZ was always 1000. Now that HZ can be 100, some CPU might be
affected by this problem. For instance when HZ=100, the centrino ,which
has a 10µs transition latency, would lead to the governor allowing to
read stats every tick (10ms)!
[PATCH] [5/5] ondemand governor default sampling downfactor as 1
Make default sampling downfactor 1.
This works better with earlier auto downscaling change in ondemand governor.
[PATCH] [4/5] ondemand governor automatic downscaling
Here is a change of policy for the ondemand governor. The modification
concerns the frequency downscaling. Instead of decreasing to a lower
frequency when the CPU usage is under 20%, this new policy automatically
scales to the optimal frequency. The optimal frequency being the lowest
frequency which provides enough power to not trigger the upscaling policy.
[PATCH] [3/5] ondemand,conservative governor idle_tick clean-up
Ondemand and conservative governor clean-up, it factorises the idle ticks
measurement.
[PATCH] [2/5] ondemand,conservative governor store the idle ticks for all cpus
Ondemand, conservative governor did not store prev_cpu_idle_up into
prev_cpu_idle_down for other CPUs than the current CPU.
[PATCH] [1/5] ondemand,conservative minor bug-fix and cleanup
Attached patch fixes some minor issues with Alexander's patch and related
cleanup in both ondemand and conservative governor.
