path: root/drivers/connector
2006-06-23[PATCH] connector-exportsAndrew Morton
Put the connector exports at the functions so people can see them in context. Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Process Events - Header CleanupMatt Helsley
Move connector header include to precisely where it's needed. Remove unused time.h header file as well. This was leftover from previous iterations of the process events patches. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: Nguyen Anh Quynh <aquynh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[CONNECTOR]: Initialize subsystem earlier.Evgeniy Polyakov
Attached patch declares connector init function as subsys_init() and returns -EAGAIN in case connector is not initialized yet. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[CONNECTOR]: Fix warning in cn_queue.cAndreas Schwab
cn_queue.c:130: warning: value computed is not used There is no point in testing the atomic value if the result is thrown away. From Evgeniy: It was created to put implicit smp barrier, but it is not needed there. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[PATCH] sem2mutex: drivers: raw, connector, dcdbas, ppp_genericArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[CONNECTOR]: Use netlink_has_listeners() to avoind unnecessary allocations.Evgeniy Polyakov
Return -ESRCH from cn_netlink_send() when there are not listeners, just as it could be done by netlink_broadcast(). Propagate netlink_broadcast() error back to the caller. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[PATCH] Switch getnstimestamp() calls to ktime_get_ts()Matt Helsley
Use ktime_get_ts() to take the timestamp instead of getnstimestamp(). This patch prepares to remove getnstimestamp() by switching its only user to a different function with almost exactly the same code. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] drivers/connector/cn_proc.c typosDavid S. Miller
The parameter to put_cpu_var() is unreferenced by the implementation, and the compiler doesn't try to comprehend comments, so this wouldn't cause any problem, but if bugged me enough to post a fix :-) Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] Add timestamp field to process eventsMatt Helsley
This adds a timestamp field to the events sent via the process event connector. The timestamp allows listeners to accurately account the duration(s) between a process' events and offers strong means with which to determine the order of events with respect to a given task while also avoiding the addition of per-task data. This alters the size and layout of the event structure and hence would break compatibility if process events connector as it stands in 2.6.15-rc2 were released as a mainline kernel. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Process Events ConnectorMatt Helsley
This patch adds a connector that reports fork, exec, id change, and exit events for all processes to userspace. It replaces the fork_advisor patch that ELSA is currently using. Applications that may find these events useful include accounting/auditing (e.g. ELSA), system activity monitoring (e.g. top), security, and resource management (e.g. CKRM). Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[CONNECTOR]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in connector code: drivers/connector/connector.c:102:24: warning: implicit cast to nocast type drivers/connector/connector.c:114:45: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-26[CONNECTOR]: async connector mode.Evgeniy Polyakov
If input message rate from userspace is too high, do not drop them, but try to deliver using work queue allocation. Failing there is some kind of congestion control. It also removes warn_on on this condition, which scares people. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-11[NET]: Add netlink connector.Evgeniy Polyakov
Kernel connector - new userspace <-> kernel space easy to use communication module which implements easy to use bidirectional message bus using netlink as it's backend. Connector was created to eliminate complex skb handling both in send and receive message bus direction. Connector driver adds possibility to connect various agents using as one of it's backends netlink based network. One must register callback and identifier. When driver receives special netlink message with appropriate identifier, appropriate callback will be called. From the userspace point of view it's quite straightforward: socket(); bind(); send(); recv(); But if kernelspace want to use full power of such connections, driver writer must create special sockets, must know about struct sk_buff handling... Connector allows any kernelspace agents to use netlink based networking for inter-process communication in a significantly easier way: int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *)); void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask); struct cb_id { __u32 idx; __u32 val; }; idx and val are unique identifiers which must be registered in connector.h for in-kernel usage. void (*callback) (void *) - is a callback function which will be called when message with above idx.val will be received by connector core. Using connector completely hides low-level transport layer from it's users. Connector uses new netlink ability to have many groups in one socket. [ Incorporating many cleanups and fixes by myself and Andrew Morton -DaveM ] Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
