path: root/drivers/connector/cn_queue.c
2009-10-02connector: Removed the destruct_data callback since it is always kfree_skb()Philipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-02connector: Provide the sender's credentials to the callbackPhilipp Reisner
2009-10-02connector: Keep the skb in cn_callback_dataPhilipp Reisner
2009-07-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwmc3200wifi/netdev.c net/wireless/scan.c
2009-07-21connector: maintainer/mail update.Evgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-17connector: make callback argument type explicitMike Frysinger
The connector documentation states that the argument to the callback function is always a pointer to a struct cn_msg, but rather than encode it in the API itself, it uses a void pointer everywhere. This doesn't make much sense to encode the pointer in documentation as it prevents proper C type checking from occurring and can easily allow people to use the wrong pointer type. So convert the argument type to an explicit struct cn_msg pointer. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-02connector: create connector workqueue only while needed onceFrederic Weisbecker
The netlink connector uses its own workqueue to relay the datas sent from userspace to the appropriate callback. If you launch the test from Documentation/connector and change it a bit to send a high flow of data, you will see thousands of events coming to the "cqueue" workqueue by looking at the workqueue tracer. This flow of events can be sent very quickly. So, to not encumber the kevent workqueue and delay other jobs, the "cqueue" workqueue should remain. But this workqueue is pointless most of the time, it will always be created (assuming you have built it of course) although only developpers with specific needs will use it. So avoid this "most of the time useless task", this patch proposes to create this workqueue only when needed once. The first jobs to be sent to connector callbacks will be sent to kevent while the "cqueue" thread creation will be scheduled to kevent too. The following jobs will continue to be scheduled to keventd until the cqueue workqueue is created, and then the rest of the jobs will continue to perform as usual, through this dedicated workqueue. Each time I tested this patch, only the first event was sent to keventd, the rest has been sent to cqueue which have been created quickly. Also, this patch fixes some trailing whitespaces on the connector files. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23connector: convert to single-threaded workqueueEvgeniy Polyakov
From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> We don't need one cqueue thread for each CPU. cqueue is used for receiving userspace datagrams, which are very rare and thus will happily live with a single queue. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CONNECTOR]: Cleanup struct cn_callback_entryLi Zefan
- 'cb' is a fake struct member. In a previous patch struct cn_callback was renamed to cn_callback_id, so 'cb' should have been deleted at that time. - 'nls' isn't used and is redundant, we can retrieve this data through cn_callback_entry.pdev->nls. - 'seq' and 'group' should be u32, as they are declared to be u32 in other places. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CONNECTOR]: Cleanup struct cn_queue_devLi Zefan
Struct member netlink_groups is never used, and I don't see how it can be useful. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[CONNECTOR]: Don't touch queue dev after decrement of ref count.Li Zefan
cn_queue_free_callback() will touch 'dev'(i.e. cbq->pdev), so it should be called before atomic_dec(&dev->refcnt). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-18[CONNECTOR]: Replace delayed work with usual work queue.Evgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-17[CONNECTOR]: Fix warning in cn_queue.cAndreas Schwab
cn_queue.c:130: warning: value computed is not used There is no point in testing the atomic value if the result is thrown away. From Evgeniy: It was created to put implicit smp barrier, but it is not needed there. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-26[CONNECTOR]: async connector mode.Evgeniy Polyakov
If input message rate from userspace is too high, do not drop them, but try to deliver using work queue allocation. Failing there is some kind of congestion control. It also removes warn_on on this condition, which scares people. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-11[NET]: Add netlink connector.Evgeniy Polyakov
Kernel connector - new userspace <-> kernel space easy to use communication module which implements easy to use bidirectional message bus using netlink as it's backend. Connector was created to eliminate complex skb handling both in send and receive message bus direction. Connector driver adds possibility to connect various agents using as one of it's backends netlink based network. One must register callback and identifier. When driver receives special netlink message with appropriate identifier, appropriate callback will be called. From the userspace point of view it's quite straightforward: socket(); bind(); send(); recv(); But if kernelspace want to use full power of such connections, driver writer must create special sockets, must know about struct sk_buff handling... Connector allows any kernelspace agents to use netlink based networking for inter-process communication in a significantly easier way: int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *)); void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask); struct cb_id { __u32 idx; __u32 val; }; idx and val are unique identifiers which must be registered in connector.h for in-kernel usage. void (*callback) (void *) - is a callback function which will be called when message with above idx.val will be received by connector core. Using connector completely hides low-level transport layer from it's users. Connector uses new netlink ability to have many groups in one socket. [ Incorporating many cleanups and fixes by myself and Andrew Morton -DaveM ] Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
