Pavel Machek reports that this config is exposed on x86 where the
ARM architected timers aren't even present. Make it depend on the
ARM architected timers being selected so that non-ARM builds
aren't asked about it.
Reported-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Prepare the clock at probe time, as there is no other appropriate place
in the driver where we're allowed to sleep.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Fix the probe error path to release the clock resource when the
sh_tmu_register() call fails.
sh_mtu2_register() call fails.
IRQF_DISABLED is a no-op nowadays, so we can safely remove it.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
We need to wait for at least 2 clock cycles whenever we reprogram our
clockevent timer. Report that the minimum number of ticks we can handle
is 3 ticks, and remove 3 ticks to the interval programmed to reflect
this.
The Allwinner SoCs timer use the clocksource MMIO functions. We thus
need to select them in Kconfig.
An efm32 features 4 16-bit timers with a 10-bit prescaler. This driver
provides clocksource and clock event device using one timer instance
each.
Add calls to clk_prepare and unprepare so that EMMA Mobile EV2 can
migrate to the common clock framework.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi.px@renesas.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Commit:
65cd4f6 ("arch_timer: Move to generic sched_clock framework")
added code to register the arch_sys_counter in arch_timer_register(),
but it is already registered in arch_counter_register().
This results in the timer being added to the clocksource list twice,
therefore causing an infinite loop in the list.
Remove the duplicate registration and register the scheduler
clock after the original registration instead.
This fixes a hang during boot on Tegra114 (Cortex-A15).
[ While I've only tested this on Tegra114, I suspect the same hang
during boot happens for all processors that use this clock source. ]
Signed-off-by: Thierry Reding <treding@nvidia.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Link: http://lkml.kernel.org/r/1381843911-31962-1-git-send-email-treding@nvidia.com
git://git.linaro.org/people/jstultz/linux into timers/core
Pull more timekeeping items for v3.13 from John Stultz:
* Small cleanup in the clocksource code.
* Fix for rtc-pl031 to let it work with alarmtimers.
* Move arm64 to using the generic sched_clock framework & resulting
cleanup in the generic sched_clock code.
Register with the generic sched_clock framework now that it
supports 64 bits. This fixes two problems with the current
sched_clock support for machines using the architected timers.
First off, we don't subtract the start value from subsequent
sched_clock calls so we can potentially start off with
sched_clock returning gigantic numbers. Second, there is no
support for suspend/resume handling so problems such as discussed
in 6a4dae5 (ARM: 7565/1: sched: stop sched_clock() during
suspend, 2012-10-23) can happen without this patch. Finally, it
allows us to move the sched_clock setup into drivers clocksource
out of the arch ports.
Cc: Christopher Covington <cov@codeaurora.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Remove the deprecated IRQF_DISABLED flag.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Check function return values to avoid false positive driver init.
clk_prepare_enable/disable_unprepare
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
clockevents/3.13
Adds support to configure the rate and enable the event stream for architected
timer. The event streams can be used to impose a timeout on a wfe, to safeguard
against any programming error in case an expected event is not generated or
even to implement wfe-based timeouts for userspace locking implementations.
This feature can be disabled(enabled by default).
Since the timer control register is reset to zero on warm boot, CPU PM notifier
is added to save and restore the value.
git://git.linaro.org/people/dlezcano/linux into timers/core
Pull (mostly) ARM clocksource driver updates from Daniel Lezcano:
" - Soren Brinkmann added FEAT_PERCPU to a clock device when it is local
per cpu. This feature prevents the clock framework to choose a per cpu
timer as a broadcast timer. This problem arised when the ARM global
timer is used when switching to the broadcast timer which is the case
now on Xillinx with its cpuidle driver.
- Stephen Boyd extended the generic sched_clock code to support 64bit
counters and removes the setup_sched_clock deprecation, as that causes
lots of warnings since there's still users in the arch/arm tree. He
added also the CLOCK_SOURCE_SUSPEND_NONSTOP flag on the architected
timer as they continue counting during suspend.
- Uwe Kleine-König added some missing __init sections and consolidated the
code by moving the of_node_put call from the drivers to the function
clocksource_of_init. "
The ARM architected timers keep counting during suspend so we can
mark this clocksource with the CLOCK_SOURCE_SUSPEND_NONSTOP flag.
This flag will indicate that this clocksource can be used for
calculating suspend time and injecting sleep time into the
timekeeping core. This should be more accurate than using an
external RTC or architecture specific persistent clock.
Cc: Mark Rutland <mark.rutland@arm.com>
These are all only called by dw_apb_timer_init which is an __init
function, too
Instead of letting each driver call of_node_put do it centrally in the
loop that also calls the CLOCKSOURCE_OF_DECLARE callbacks. This is less
prone to error and also moves getting and putting the references into the
same function.
Consequently all respective of_node_put calls in drivers are removed.
Acked-by: David Brown <davidb@codeaurora.org>
The arm_global_timer is a per cpu device. Set the appropriate flag.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
fordlezcano/3.13/sched-clock64-conversion
Update to tip/timers/core and resolve minor conflict.
drivers/clocksource/samsung_pwm_timer.c
Few control settings done in architected timer as part of initialisation
can be lost when CPU enters deeper power states. They need to be
restored when the CPU is (warm)reset again.
This patch adds CPU PM notifiers to save the counter control register
when entering low power modes and restore it when CPU exits low power.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Acked-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
The ARM architected timer can generate events (used for waking up
CPUs executing the wfe instruction) at a frequency represented as a
power-of-2 divisor of the clock rate.
An event stream might be used:
- To implement wfe-based timeouts for userspace locking implementations.
- To impose a timeout on a wfe for safeguarding against any programming
error in case an expected event is not generated.
This patch computes the event stream frequency aiming for a period
of 100us between events. It uses ARM/ARM64 specific backends to configure
and enable the event stream.
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[sudeep: moving ARM/ARM64 changes into separate patches
and adding Kconfig option]
Update the STI driver by setting cpu_possible_mask to make EMEV2
SMP work as expected together with the ARM broadcast timer.
This breakage was introduced by:
f7db706 ARM: 7674/1: smp: Avoid dummy clockevent being preferred over real hardware clock-event
Without this fix SMP operation is broken on EMEV2 since no
broadcast timer interrupts trigger on the secondary CPU cores.
Signed-off-by: Magnus Damm <damm@opensource.se>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Clocksource devices provided by DT can be disabled (status != "okay").
Instead of registering clocksource drivers for disabled nodes, respect
the device's status by skiping disabled nodes.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Some variants of Exynos MCT, namely exynos4210-mct at the moment, use
normal, shared interrupts for local timers. This means that each
interrupt must have correct affinity set to fire only on CPU
corresponding to given local timer.
However after recent conversion of clocksource drivers to not use the
local timer API for local timer initialization any more, the point of
time when local timers get initialized changed and irq_set_affinity()
fails because the CPU is not marked as online yet.
This patch fixes this by moving the call to irq_set_affinity() to
CPU_ONLINE notification, so the affinity is being set when the CPU goes
online.
This fixes a regression introduced by commit
ee98d27df6 ARM: EXYNOS4: Divorce mct from local timer API
which rendered all Exynos4210 based boards unbootable due to
failing irq_set_affinity() making local timers inoperatible.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
This commit:
573145f08c2b92c45498468afbbba909f6ce6135
clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE
replaced a call to the driver's timer initialization by a call to
clocksource_of_init(). However, it failed to select CONFIG_CLKSRC_OF.
Fix this by selecting CONFIG_CLKSRC_OF for Armada370/XP machines.
Without this change the kernel is stuck at: 'Calibrating delay loop...'.
Signed-off-by: Jean Pihet <jean.pihet@linaro.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull timer code update from Thomas Gleixner:
- armada SoC clocksource overhaul with a trivial merge conflict
- Minor improvements to various SoC clocksource drivers
* 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding
clocksource: armada-370-xp: Get reference fixed-clock by name
clocksource: armada-370-xp: Replace WARN_ON with BUG_ON
clocksource: armada-370-xp: Fix device-tree binding
clocksource: armada-370-xp: Introduce new compatibles
clocksource: armada-370-xp: Simplify TIMER_CTRL register access
clocksource: armada-370-xp: Use BIT()
ARM: timer-sp: Set dynamic irq affinity
ARM: nomadik: add dynamic irq flag to the timer
clocksource: sh_cmt: 32-bit control register support
clocksource: em_sti: Convert to devm_* managed helpers
Pull clock framework changes from Michael Turquette:
"The common clk framework changes for 3.12 are dominated by clock
driver patches, both new drivers and fixes to existing. A high
percentage of these are for Samsung platforms like Exynos. Core
framework fixes and some new features like automagical clock
re-parenting round out the patches"
* tag 'clk-for-linus-3.12' of git://git.linaro.org/people/mturquette/linux: (102 commits)
clk: only call get_parent if there is one
clk: samsung: exynos5250: Simplify registration of PLL rate tables
clk: samsung: exynos4: Register PLL rate tables for Exynos4x12
clk: samsung: exynos4: Register PLL rate tables for Exynos4210
clk: samsung: exynos4: Reorder registration of mout_vpllsrc
clk: samsung: pll: Add support for rate configuration of PLL46xx
clk: samsung: pll: Use new registration method for PLL46xx
clk: samsung: pll: Add support for rate configuration of PLL45xx
clk: samsung: pll: Use new registration method for PLL45xx
clk: samsung: exynos4: Rename exynos4_plls to exynos4x12_plls
clk: samsung: exynos4: Remove checks for DT node
clk: samsung: exynos4: Remove unused static clkdev aliases
clk: samsung: Modify _get_rate() helper to use __clk_lookup()
clk: samsung: exynos4: Use separate aliases for cpufreq related clocks
clocksource: samsung_pwm_timer: Get clock from device tree
ARM: dts: exynos4: Specify PWM clocks in PWM node
pwm: samsung: Update DT bindings documentation to cover clocks
clk: Move symbol export to proper location
clk: fix new_parent dereference before null check
clk: wm831x: Initialise wm831x pointer on init
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
When booting with device tree static clkdev aliases should not be used.
This patch modifies the samsung_pwm_timer driver to use DT-based clock
lookup when booting with device tree.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
The Armada XP timer has two mandatory clock inputs: nbclk and refclk,
as specified by the device-tree binding.
This commit fixes the clock selection. Instead of hard-coding the clock
rate for the 25 MHz reference fixed-clock, obtain the clock by its name.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
If the clock fails to be obtained and the timer fails to be properly
registered, the kernel will freeze real soon. Instead, let's BUG()
where the actual problem is located.
The Armada XP SoC clocksource driver cannot work without the 25 MHz
fixed timer. Therefore it's appropriate to introduce a new compatible
string and use it to set the 25 MHz fixed timer.
The 'marvell,timer-25MHz' property will be marked as deprecated.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
This is almost cosmetic: we achieve a bit of consistency with
other clocksource drivers by using the CLOCKSOURCE_OF_DECLARE
macro for the boilerplate code.
This commit creates two functions to access the TIMER_CTRL register:
one for global one for the per-cpu. This makes the code much more
readable. In addition, since the TIMER_CTRL register is also used for
watchdog, this is preparation work for future thread-safe improvements.
This is a purely cosmetic commit: we replace hardcoded values that
representing bits by BIT(), which is slightly more readable.
Using 0x%# emits 0x0x. Only one is necessary.
Acked-by: Takashi Iwai <tiwai@suse.de>
Add the dynamic irq affinity feature to the timer clock device.
Reviewed-by: Vincent Guittot <vincent.guittot@linaro.org>
Acked-by: Rickard Andersson <rickard.andersson@stericsson.com>
Add support for CMT hardware with 32-bit control and counter
registers, as found on r8a73a4 and r8a7790. To use the CMT
with 32-bit hardware a second I/O memory resource needs to
point out the CMSTR register and it needs to be 32 bit wide.
Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Replace kzalloc, clk_get, ioremap and request_irq by their managed
counterparts to simplify error paths.
git://git.linaro.org/people/dlezcano/clockevents into timers/core
* Support for memory mapped arch_timers
* Trivial fixes to the moxart timer code
* Documentation updates
Trivial conflicts in drivers/clocksource/arm_arch_timer.c. Fixed up
the newly added __cpuinit annotations as well.
Reason: Get upstream changes on which new patches depend on.
[ this is a follow-up to this discussion:
http://archive.arm.linux.org.uk/lurker/message/20130730.230827.a1ceb12a.en.html ]
This patchset renames all uses of "bcm," name bindings to
"brcm," as they were done prior to knowing that brcm had
already been standardized as Broadcom vendor prefix
(in Documentation/devicetree/bindings/vendor-prefixes.txt).
This will not cause any churn on devices because none of
these bindings have made it into production yet.
Signed-off-by: Christian Daudt <csd@broadcom.com>
next/cleanup
From Tomasz Figa:
Here is the Samsung PWM cleanup series. Particular patches of the series
involve following modifications:
- fixing up few things in samsung_pwm_timer clocksource driver,
- moving remaining Samsung platforms to the new clocksource driver,
- removing old clocksource driver,
- adding new multiplatform- and DT-aware PWM driver,
- moving all Samsung platforms to use the new PWM driver,
- removing old PWM driver,
- removing all PWM-related code that is not used anymore.
* tag 'v3.12-pwm-cleanup-for-olof' of git://github.com/tom3q/linux: (684 commits)
pwm: samsung: Rename to pwm-samsung-legacy
ARM: SAMSUNG: Remove unused PWM timer IRQ chip code
ARM: SAMSUNG: Remove old samsung-time driver
ARM: SAMSUNG: Move all platforms to new clocksource driver
ARM: SAMSUNG: Set PWM platform data
ARM: SAMSUNG: Add new PWM platform device
ARM: SAMSUNG: Unify base address definitions of timer block
clocksource: samsung_pwm_timer: Handle suspend/resume correctly
clocksource: samsung_pwm_timer: Do not use clocksource_mmio
clocksource: samsung_pwm_timer: Cache clocksource register address
clocksource: samsung_pwm_timer: Correct definition of AUTORELOAD bit
clocksource: samsung_pwm_timer: Do not request PWM mem region
+ v3.11-rc4
arch/arm/Kconfig.debug
Current suspend/resume handling of the driver was broken, because:
- periodic timer was being enabled in CLOCK_EVT_MODE_RESUME mode, which
does not seem to be correct behavior looking at other platforms,
- PWM divisors need to be restored, but they were not,
- clockevent interrupt mask needs to be restored, but it was not,
- clocksource was being restored in clockevent resume callback.
This patch fixes issues mentioned above, making suspend/resume handling
in the driver correct.
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Mark Brown <broonie@linaro.org>
Tested-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com>
