path: root/drivers/clocksource/Makefile
2011-09-22clocksource: add DBX500 PRCMU Timer supportMattias Wallin
This patch adds the DBX500 PRCMU Timer driver as a clocksource and as sched_clock. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-07-23Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: apb: Share APB timer code with other platforms
2011-06-27clocksource: apb: Share APB timer code with other platformsJamie Iles
The APB timers are an IP block from Synopsys (DesignWare APB timers) and are also found in other systems including ARM SoC's. This patch adds functions for creating clock_event_devices and clocksources from APB timers but does not do the resource allocation. This is handled in a higher layer to allow the timers to be created from multiple methods such as platform_devices. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-09i8253: Consolidate all kernel definitions of i8253_lockRalf Baechle
Move them to drivers/clocksource/i8253.c and remove the implementations in arch/ [ tglx: Avoid the extra file in lib - folded arch patches in. The export will become conditional in a later step ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-23clocksource: add common mmio clocksourceRussell King
Add a generic mmio clocksource, covering both 32-bit and 16-bit register access sizes, for up or down counters. This can be used to easily create clocksources for simple counter-based implementations. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Colin Cross <ccross@android.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Erik Gilling <konkers@android.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: linux-omap@vger.kernel.org Acked-by: Nicolas Pitre <nico@fluxnic.net> Cc: Olof Johansson <olof@lixom.net> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-14clocksource: add common i8253 PIT clocksourceRussell King
This is based upon both arch/arm/mach-footbridge/isa-timer.c and arch/x86/kernel/i8253.c. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-15cs5535: add a generic clock event MFGPT driverAndres Salomon
This is based on the old code in arch/x86/kernel/mfgpt_32.c, but is modular and not Geode-specific. There's no reason why the clock event device needs to be registered so early at boot; the clockevent code is perfectly capable of dynamic switching. [akpm@linux-foundation.org: add linux/irq.h include] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-03clocksource: SuperH TMU Timer driverMagnus Damm
This patch adds a TMU driver for the SuperH architecture. The TMU driver is a platform driver with early platform support to allow using a TMU channel as clockevent or clocksource during system bootup or later. Clocksource or clockevent can be selected. Both periodic and oneshot clockevents are supported. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-03clocksource: SuperH MTU2 Timer driverMagnus Damm
This patch adds a MTU2 driver for the SuperH architecture. The MTU2 driver is a platform driver with early platform support to allow using a MTU2 channel as only clockevent during system bootup. Clocksource on sh2a is currently unsupported due to code generation issues with 64-bit math, so at this point only periodic clockevent support is in place. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-01-29sh: CMT clockevent platform driverMagnus Damm
SuperH CMT clockevent driver. Both 16-bit and 32-bit CMT versions are supported, but only 32-bit is tested. This driver contains support for both clockevents and clocksources, but no unregistration is supported at this point. Works fine as clock source and/or event in periodic or oneshot mode. Tested on sh7722 and sh7723, but should work with any cpu/architecture. This version is lacking clocksource and early platform driver support for now - this to minimize the amount of dependencies. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-04atmel_tc clocksource/clockevent codeDavid Brownell
Clocksource and clockevent device based on the Atmel TC blocks. The clockevent device handles both periodic and oneshot modes, so this enables NO_HZ and high res timers on some platforms that previously couldn't use those mechanisms. This works on both AVR32 and AT91 chips, given relevant patches for tclib support (always) and clockevents (or else this will only look like a higher precision clocksource). It's an updated and modularized version of an AT91-only patch that has circulated for some time now. Changes relative to the original patch: * Update to use new tclib API * Replace open-coded do-while loop using goto with a real do-while loop * Minor irq handler optimization: Load register base address from dev_id instead of a global variable. * Aggressively turn off clocks when the clockevent isn't being used * Include the clockevent code on AT91RM9200 as well. The rating is lower than the System Timer, so the clock will usually stay off. * Don't assume that the number of clocks is always equal to the number of irqs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-06-26[PATCH] GTOD: add scx200 HRT clocksourceJim Cromie
Add a GTOD clocksource driver based on the Geode SCx200's Hi-Res Timer. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: i386 Clocksource Driversjohn stultz
Implement the time sources for i386 (acpi_pm, cyclone, hpet, pit, and tsc). With this patch, the conversion of the i386 arch to the generic timekeeping code should be complete. The patch should be fairly straight forward, only adding the new clocksources. [hirofumi@mail.parknet.co.jp: acpi_pm cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
