path: root/drivers/clocksource/Kconfig
2012-07-23Merge tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull support for three new arm SoC types from Arnd Bergmann: - The mvebu platform includes Marvell's Armada XP and Armada 370 chips, made by the mvebu business unit inside of Marvell. Since the same group also made the older but similar platforms we call "orion5x", "kirkwood", "mv78xx0" and "dove", we plan to move all of them into the mach-mvebu directory in the future. - socfpga is Altera's platform based on Cortex-A9 cores and a lot of FPGA space. This is similar to the Xilinx zynq platform we already support. The code is particularly clean, which is helped by the fact that the hardware doesn't do much besides the parts that are expected to get added in the FPGA. - The OMAP subarchitecture gains support for the latest generation, the OMAP5 based on the new Cortex-A15 core. Support is rather rudimentary for now, but will be extended in the future. * tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: socfpga: initial support for Altera's SOCFPGA platform arm: mvebu: generate DTBs for supported SoCs ARM: mvebu: MPIC: read number of interrupts from control register arm: mach-mvebu: add entry to MAINTAINERS arm: mach-mvebu: add compilation/configuration change arm: mach-mvebu: add defconfig arm: mach-mvebu: add documentation for new device tree bindings arm: mach-mvebu: add support for Armada 370 and Armada XP with DT arm: mach-mvebu: add source files arm: mach-mvebu: add header clocksource: time-armada-370-xp: Marvell Armada 370/XP SoC timer driver ARM: Kconfig update to support additional GPIOs in OMAP5 ARM: OMAP5: Add the build support arm/dts: OMAP5: Add omap5 dts files ARM: OMAP5: board-generic: Add device tree support ARM: omap2+: board-generic: clean up the irq data from board file ARM: OMAP5: Add SMP support ARM: OMAP5: Add the WakeupGen IP updates ARM: OMAP5: l3: Add l3 error handler support for omap5 ARM: OMAP5: gpmc: Update gpmc_init() ... Conflicts: Documentation/devicetree/bindings/arm/omap/omap.txt arch/arm/mach-omap2/Makefile drivers/clocksource/Kconfig drivers/clocksource/Makefile
2012-07-12clocksource: dw_apb_timer: Add common DTS glue for dw_apb_timerDinh Nguyen
Make a common device tree glue for clocksource/dw_apb_timer. Move mach-picoxcell/time.c to be a generic device tree application of the dw_apb_timer. Configure mach-picoxcell to use the dw_apb_timer_of device tree implementation in drivers/clocksource. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-10clocksource: time-armada-370-xp: Marvell Armada 370/XP SoC timer driverGregory CLEMENT
Timer 0 is used as free-running clocksource, while timer 1 is used as clock_event_device. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Lior Amsalem <alior@marvell.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Yehuda Yitschak <yehuday@marvell.com> Tested-by: Lior Amsalem <alior@marvell.com> Acked-by: Andrew Lunn <andrew@lunn.ch> CC: Thomas Gleixner <tglx@linutronix.de> CC: John Stultz <johnstul@us.ibm.com>
2012-05-02ARM: ux500: delete U5500 supportLinus Walleij
This platform has been obsoleted and was only available inside of ST-Ericsson, no users of this code are left in the world. This deletes the core U5500 support entirely in the same manner as the obsoleted U8500 silicon was previously deleted. The cpu_is_u5500() macros that can read out the CPU ID is left until the next kernel cycle, this makes it possible to merge deletion of dependent drivers without breakage. This also has the upside of removing the mailbox driver which was our only driver that was outside the drivers/* hiearchy, now the machine directory only handles machines and nothing else. Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Jonas Aberg <jonas.aberg@stericsson.com> Cc: Per Forlin <per.forlin@stericsson.com> Cc: Ulf Hansson <ulf.hansson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-27Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig.debug arch/arm/plat-versatile/Kconfig Merge fixes: arch/arm/mach-integrator/Kconfig drivers/clocksource/Kconfig
2011-09-22clocksource: add DBX500 PRCMU Timer supportMattias Wallin
This patch adds the DBX500 PRCMU Timer driver as a clocksource and as sched_clock. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-07-23Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: apb: Share APB timer code with other platforms
2011-07-01i8253: Create common clockevent implementationThomas Gleixner
arm, mips and x86 implement i8253 based clockevents. All the same code copied. Create a common implementation in drivers/clocksource/i8253.c. About time to rename drivers/clocksource/ to something else. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20110609130621.921710458@linutronix.de
2011-06-27clocksource: apb: Share APB timer code with other platformsJamie Iles
The APB timers are an IP block from Synopsys (DesignWare APB timers) and are also found in other systems including ARM SoC's. This patch adds functions for creating clock_event_devices and clocksources from APB timers but does not do the resource allocation. This is handled in a higher layer to allow the timers to be created from multiple methods such as platform_devices. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-09i8253: Consolidate all kernel definitions of i8253_lockRalf Baechle
Move them to drivers/clocksource/i8253.c and remove the implementations in arch/ [ tglx: Avoid the extra file in lib - folded arch patches in. The export will become conditional in a later step ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-23clocksource: add common mmio clocksourceRussell King
Add a generic mmio clocksource, covering both 32-bit and 16-bit register access sizes, for up or down counters. This can be used to easily create clocksources for simple counter-based implementations. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Colin Cross <ccross@android.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Erik Gilling <konkers@android.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: linux-omap@vger.kernel.org Acked-by: Nicolas Pitre <nico@fluxnic.net> Cc: Olof Johansson <olof@lixom.net> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-14clocksource: add common i8253 PIT clocksourceRussell King
This is based upon both arch/arm/mach-footbridge/isa-timer.c and arch/x86/kernel/i8253.c. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-06MFGPT: move clocksource menuRandy Dunlap
Move the CS5535 MFGPT hrtimer kconfig option to be with the other MFGPT options. This makes it easier to find and also removes it from the main "Device Drivers" menu, where it should not have been. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15cs5535: add a generic clock event MFGPT driverAndres Salomon
This is based on the old code in arch/x86/kernel/mfgpt_32.c, but is modular and not Geode-specific. There's no reason why the clock event device needs to be registered so early at boot; the clockevent code is perfectly capable of dynamic switching. [akpm@linux-foundation.org: add linux/irq.h include] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
