path: root/drivers/clk/samsung
2014-01-28Merge tag 'clk-for-linus-3.14-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework changes from Mike Turquette: "The second half of the clock framework pull requeust for 3.14 is dominated by platform support for Qualcomm's MSM SoCs, DT binding updates for TI's OMAP-ish processors and additional support for Samsung chips. Additionally there are other smaller clock driver changes and several last minute fixes. This pull request also includes the HiSilicon support that depends on the already-merged arm-soc pull request" [ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ] * tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits) clk: sort Makefile clk: sunxi: fix overflow when setting up divided factors clk: Export more clk-provider functions dt-bindings: qcom: Fix warning with duplicate dt define clk: si5351: remove variant from platform_data clk: samsung: Remove unneeded semicolon clk: qcom: Fix modular build ARM: OMAP3: use DT clock init if DT data is available ARM: AM33xx: remove old clock data and link in new clock init code ARM: AM43xx: Enable clock init ARM: OMAP: DRA7: Enable clock init ARM: OMAP4: remove old clock data and link in new clock init code ARM: OMAP2+: io: use new clock init API ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT ARM: OMAP3: hwmod: initialize clkdm from clkdm_name ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm ARM: OMAP2+: clock: use driver API instead of direct memory read/write ARM: OMAP2+: clock: add support for indexed memmaps ARM: dts: am43xx clock data ARM: dts: AM35xx: use DT clock data ...
2014-01-23Merge tag 'clk-for-linus-3.14-part1' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework changes from Mike Turquette: "The first half of the clk framework pull request is made up almost entirely of new platform/driver support. There are some conversions of existing drivers to the common-clock Device Tree binding, and a few non-critical fixes to the framework. Due to an entirely unnecessary cyclical dependency with the arm-soc tree this pull request is broken into two pieces. The second piece will be sent out after arm-soc sends you the pull request that merged in core support for the HiSilicon 3620 platform. That same pull request from arm-soc depends on this pull request to merge in those HiSilicon bits without causing build failures" [ Just did the ARM SoC merges, so getting ready for the second clk tree pull request - Linus ] * tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits) devicetree: bindings: Document qcom,mmcc devicetree: bindings: Document qcom,gcc clk: qcom: Add support for MSM8660's global clock controller (GCC) clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8974's global clock controller (GCC) clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8960's global clock controller (GCC) clk: qcom: Add reset controller support clk: qcom: Add support for branches/gate clocks clk: qcom: Add support for root clock generators (RCGs) clk: qcom: Add support for phase locked loops (PLLs) clk: qcom: Add a regmap type clock struct clk: Add set_rate_and_parent() op reset: Silence warning in reset-controller.h clk: sirf: re-arch to make the codes support both prima2 and atlas6 clk: composite: pass mux_hw into determine_rate clk: shmobile: Fix MSTP clock array initialization clk: shmobile: Fix MSTP clock index ARM: dts: Add clock provider specific properties to max77686 node clk: max77686: Register OF clock provider ...
2014-01-23Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical fixes from Olof Johansson: "As usual, we have a batch of fixes that weren't considered significant enough to warrant going into the later -rcs for previous release, so they are queued up on this branch. A handful of these are for various DT fixups for Samsung platforms, and a handful of other minor things. There are also a couple of stable-marked patches for mvebu -- they came in quite late and we decided to keep them deferred until the first -stable release to get more coverage instead of squeezing them into 3.13" * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) ARM: at91: smc: bug fix in sam9_smc_cs_read() i2c: mv64xxx: Document the newly introduced Armada XP A0 compatible i2c: mv64xxx: Fix bus hang on A0 version of the Armada XP SoCs ARM: mvebu: Add quirk for i2c for the OpenBlocks AX3-4 board ARM: mvebu: Add support to get the ID and the revision of a SoC ARM: dts: msm: Fix gpio interrupt and reg length irqchip: sirf: set IRQ_LEVEL status_flags ARM: OMAP2+: gpmc: Move legacy GPMC width setting ARM: OMAP2+: gpmc: Introduce gpmc_set_legacy() ARM: OMAP2+: gpmc: Move initialization outside the gpmc_t condition ARM: OMAP2+: board-generic: update SoC compatibility strings Documentation: dt: OMAP: explicitly state SoC compatible strings ARM: OMAP2+: enable AM33xx SOC EVM audio ARM: OMAP2+: Select USB PHY for AM335x SoC ARM: bcm2835: Fix grammar in help message ARM: msm: trout: fix uninit var warning ARM: dts: Use MSHC controller for eMMC memory for exynos4412-trats2 ARM: dts: Fix definition of MSHC device tree nodes for exynos4x12 ARM: dts: add clock provider for mshc node for Exynos4412 SOC clk: samsung: exynos4: Fix definition of div_mmc_pre4 divider ...
2014-01-20Merge branch 'for-next' into for-linusTakashi Iwai
2014-01-17clk: samsung: Remove unneeded semicolonSachin Kamat
Semicolon not needed after switch statement. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-08clk: exynos-audss: add support for Exynos 5420Andrew Bresticker
The AudioSS block on Exynos 5420 has an additional clock gate for the ADMA bus clock. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2014-01-08clk: exynos5250: add clock ID for div_pcm0Andrew Bresticker
There is no gate for the PCM clock input to the AudioSS block, so the parent of sclk_pcm is div_pcm0. Add a clock ID for it so that we can reference it in device trees. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2014-01-08clk: exynos-audss: allow input clocks to be specified in device treeAndrew Bresticker
This allows the input clocks to the Exynos AudioSS block to be specified via device-tree bindings. Default names will be used when an input clock is not given. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2014-01-08clk: exynos-audss: convert to platform deviceAndrew Bresticker
The Exynos AudioSS clock controller will later be modified to allow input clocks to be specified via device-tree in order to support multiple Exynos SoCs. This will introduce a dependency on the core SoC clock controller being initialized first so that the AudioSS driver can look up its input clocks, but the order in which clock providers are probed in of_clk_init() is not guaranteed. Since deferred probing is not supported in of_clk_init() and the AudioSS block is not the core controller, we can initialize it later as a platform device. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Tomasz Figa <t.figa@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2014-01-08clk: exynos5440: replace clock ID private enums with IDs from DT headerAndrzej Hajda
The patch replaces private enum clock IDs in the driver with macros provided by the DT header. Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2014-01-08clk: exynos5420: replace clock ID private enums with IDs from DT headerAndrzej Hajda
2014-01-08clk: exynos5250: replace clock ID private enums with IDs from DT headerAndrzej Hajda
2014-01-08clk: exynos4: replace clock ID private enums with IDs from DT headerAndrzej Hajda
2014-01-08clk: exynos5250: register APLL rate tableAndrew Bresticker
Register the APLL rate table so that we can set the APLL rate from the cpufreq driver. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: exynos5250: Add CLK_SET_RATE_PARENT flag to mout_apllSachin Kamat
Add CLK_SET_RATE_PARENT flag to mout_apll clock. This will let us set the clock rate in the cpufreq driver. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Fix parents of gate clocks from MFC domainTomasz Figa
This patch adds mout_aclk333_sub mux clock and updates gate clocks from MFC domain to have it as their parent as specified in SoC documentation. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Correct parent list of audio muxesTomasz Figa
According to SoC documentation, input 5 of mout_audio muxes is connected to xxti (named fin_pll in the driver). This patch corrects defined parent arrays to match SoC documentation. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Add missing unpopulated mux parentsTomasz Figa
This patch updates mux parent arrays with unpopulated mux inputs, as all inputs need to be specified in parent arrays passed to clk_register_mux(), otherwise clk_set_parent() can generate out of bound accesses to the array. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Fix parent of gate clocks from DISP1 domainTomasz Figa
This patch adds mux_aclk_200_disp1_sub mux clock, which according to SoC documentation is the correct parent of DISP1 gate clocks. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Fix parents of gate clocks from GSCL domainTomasz Figa
This patch adds mout_aclk266_gscl_sub mux clock and adjusts definitions of GSCL domain gate clocks to use it as their parent, as specified in SoC documentation. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Make names of mux and div clocks consistentTomasz Figa
This patch renames all mux clocks to start with mout_ prefix and all div clocks to start with div_ prefix for consistency with other clocks already defined this way. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Sort definitions by registers and bitfieldTomasz Figa
This patch reorders clock definitions, so they are sorted by register addresses and bitfield shifts. When at it, blank lines are added to separate definitions of clocks from different registers. Overall this should make the driver more readable and reduce the number of potential conflicts when adding new entries. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30Merge branch 'samsung-fixes' into samsung-next-baseTomasz Figa
2013-12-30clk: exynos: File scope reg_save array should depend on PM_SLEEPKrzysztof Kozlowski
Move reg_save[] into CONFIG_PM_SLEEP dependency block as it is used only by suspend and resume functions. This fixes the warning on CONFIG_PM_SLEEP=n: drivers/clk/samsung/clk-exynos-audss.c:29:22: warning: ‘reg_save’ defined but not used [-Wunused-variable] Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Add CLK_IGNORE_UNUSED flag for the sysreg clockAbhilash Kesavan
The sysreg (system register) generates control signals for various blocks like disp1blk, i2c, mipi, usb etc. However, it gets disabled as an unused clock at boot-up. This can lead to failures in operation of above blocks, because they can not be configured properly if this clock is disabled. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> [t.figa: Updated patch description.] Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Add MDMA0 clocksAbhilash Kesavan
Adds gate clock for MDMA0 on Exynos5250 SoC. This is needed to ensure that the clock is enabled when MDMA0 is used on systems on which firmware gates the clockby default. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> [t.figa: Updated patch description.] Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos5250: Fix ACP gate register offsetAbhilash Kesavan
The CLK_GATE_IP_ACP register offset is incorrectly listed making definition of g2d clock incorrect, which may lead to system failures when trying to use G2D on systems on which firmware gates this clock by default. Fix this and the register ordering as well. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> [t.figa: Updated patch description.] Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: exynos5250: fix sysmmu_mfc{l,r} gate clocksAndrew Bresticker
The gate clocks for the MFC sysmmus appear to be flipped, i.e. GATE_IP_MFC[2] gates sysmmu_mfcl and GATE_IP_MFC[1] gates sysmmu_mfcr. Fix this so that the MFC will start up. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-30clk: samsung: exynos4: Correct SRC_MFC registerSeung-Woo Kim
The SRC_MFC register offset was incorrect, which could cause have caused wrong calculation of rate of sclk_mfc clock, that could in turn lead to incorrect operation of MFC. This patch corrects it. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> [t.figa: Updated patch description] Signed-off-by: Tomasz Figa <t.figa@samsung.com>
2013-12-21clk: samsung: exynos4: Fix definition of div_mmc_pre4 dividerTomasz Figa
The clock was missing CLK_SET_RATE_PARENT flag, which caused rate setting failures due to inability of reconfiguration of second divider behind it. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-04clk: exynos5420: fix cpll clock register offsetsChander Kashyap
Fixes cpll control and lock register offset values for Exynos5420 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-11-24clk: samsung: s3c64xx: Remove clock aliases of old DMA driverTomasz Figa
Since the old DMA driver got removed, these aliases are no longer necessary. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-24clk: samsung: s3c64xx: Add aliases for DMA clocksTomasz Figa
This patch adds clkdev aliases for clocks used by PL08x DMA driver. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17ARM: S3C64XX: Migrate clock handling to Common Clock FrameworkTomasz Figa
This patch migrates the s3c64xx platform to use the new clock driver using Common Clock Framework. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-09-09Merge tag 'clk-for-linus-3.12' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull clock framework changes from Michael Turquette: "The common clk framework changes for 3.12 are dominated by clock driver patches, both new drivers and fixes to existing. A high percentage of these are for Samsung platforms like Exynos. Core framework fixes and some new features like automagical clock re-parenting round out the patches" * tag 'clk-for-linus-3.12' of git://git.linaro.org/people/mturquette/linux: (102 commits) clk: only call get_parent if there is one clk: samsung: exynos5250: Simplify registration of PLL rate tables clk: samsung: exynos4: Register PLL rate tables for Exynos4x12 clk: samsung: exynos4: Register PLL rate tables for Exynos4210 clk: samsung: exynos4: Reorder registration of mout_vpllsrc clk: samsung: pll: Add support for rate configuration of PLL46xx clk: samsung: pll: Use new registration method for PLL46xx clk: samsung: pll: Add support for rate configuration of PLL45xx clk: samsung: pll: Use new registration method for PLL45xx clk: samsung: exynos4: Rename exynos4_plls to exynos4x12_plls clk: samsung: exynos4: Remove checks for DT node clk: samsung: exynos4: Remove unused static clkdev aliases clk: samsung: Modify _get_rate() helper to use __clk_lookup() clk: samsung: exynos4: Use separate aliases for cpufreq related clocks clocksource: samsung_pwm_timer: Get clock from device tree ARM: dts: exynos4: Specify PWM clocks in PWM node pwm: samsung: Update DT bindings documentation to cover clocks clk: Move symbol export to proper location clk: fix new_parent dereference before null check clk: wm831x: Initialise wm831x pointer on init ...
2013-09-06clk: samsung: exynos5250: Simplify registration of PLL rate tablesTomasz Figa
Since the _get_rate() helper has been modified to use __clk_lookup() internally, checking of PLL input rates can be done using it and so the registration code can be simplified. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Register PLL rate tables for Exynos4x12Tomasz Figa
This patch adds rate tables for PLLs that can be reconfigured at runtime for Exynos4x12 SoCs. Provided tables contain PLL coefficients for input clock of 24 MHz and so are registered only in this case. MPLL does not need runtime reconfiguration and so table for it is not provided. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Register PLL rate tables for Exynos4210Tomasz Figa
This patch adds rate tables for PLLs that can be reconfigured at runtime for Exynos4210 SoCs. Provided tables contain PLL coefficients for input clock of 24 MHz and so are registered only in this case. MPLL does not need runtime reconfiguration and so table for it is not provided. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Reorder registration of mout_vpllsrcTomasz Figa
Since PLL input frequency must be known before PLL registration, mout_vpllsrc clock which is a reference clock of VPLL must be registered before VPLL. This patch reorders clock registration to register mout_vpllsrc before VPLL. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: pll: Add support for rate configuration of PLL46xxTomasz Figa
This patch implements round_rate and set_rate callbacks of PLL46xx driver to allow reconfiguration of PLL at runtime. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: pll: Use new registration method for PLL46xxTomasz Figa
This patch modifies PLL46xx support code and its users to use the recently introduced common PLL registration helper. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: pll: Add support for rate configuration of PLL45xxTomasz Figa
This patch implements round_rate and set_rate callbacks of PLL45xx driver to allow reconfiguration of PLL at runtime. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: pll: Use new registration method for PLL45xxTomasz Figa
This patch modifies PLL45xx support code and its users to use the recently introduced common PLL registration helper. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Rename exynos4_plls to exynos4x12_pllsTomasz Figa
This array defines PLLs specific to Exynos 4x12 SoCs and not for all Exynos 4 SoCs, so the name should represent that. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Remove checks for DT nodeTomasz Figa
Exynos 4 supports only DT based bootup, so non-DT cases does not need to be handled anymore. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Remove unused static clkdev aliasesTomasz Figa
Since Exynos does not support legacy non-DT boot anymore, most of clock lookups happen using device tree, so most of static clkdev aliases are no longer necessary. This patch removes them. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: Modify _get_rate() helper to use __clk_lookup()Tomasz Figa
There is no need to use clkdev inside the clock driver to retrieve the clocks for internal use. Instead __clk_lookup() helper can be used to look up clocks by their platform name. This patch modifies the behavior of _get_rate() helper to look up clocks by platform name and adjusts all users of it to pass platform names instead of clkdev aliases. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-09-06clk: samsung: exynos4: Use separate aliases for cpufreq related clocksTomasz Figa
Exynos cpufreq driver is the only remaining piece of code that needs static clkdev aliases for operation, because it can not do device tree based clock lookups yet. This patch moves clock alias definitions for those clocks to separate arrays that can be used with samsung_clk_register_alias() helper. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-08-29clk/exynos5420: assign dout_pixel id to pixel clock dividerRahul Sharma
dout_pixel is a new ID allocated for pixel clock divider. It is queried in the driver to pass as the parent to hdmi clock while switching between parents. Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com> Acked-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-08-29clk/exynos5420: add hdmi mux to change parents in hdmi driverRahul Sharma
hdmi driver needs to change the parent of hdmi clock to pixel clock or hdmiphy clock, based on the stability of hdmiphy. This patch is exposing the mux for changing the parent. Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com> Acked-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
