Since hclk_sd and pclk_ddr source clock from CPLL or GPLL,
and these two PLL may change their frequency. If we do not
assign right id to pclk_ddr and hclk_sd, they will alway use
default cur register value, and may get the frequency
exceed their signed off frequency. So assign correct Id
for them, then we can assign frequency for them in dts.
Signed-off-by: Lin Huang <hl@rock-chips.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The newly added clock notifier may return an error code but so far the
error output in the function would only return an error pointer from
registering the clock.
So when the clock notifier fails the clock would be unregistered but the
return would still be the clock pointer which could then not be
dereferenced correctly. So fix the error handling to prevent that.
Fixes: 60cf09e45fbc ("clk: rockchip: Restore the clock phase after the rate was changed")
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
We can't restore every phase, for instance the invalid phase and
the phase for coming rate which is out of the scope of boards'
ability. And this patch also corrects the error path to return
invalid pointer to clk if clk_notifier_register failed introduced
by the same offending commit.
Reported-by: wlq <wlq@rock-chips.com>
Tested-by: wlq <wlq@rock-chips.com>
commit c420c1e4db22 ("clk: rockchip: Prevent calculating mmc phase if
clock rate is zero") catches some gremlins for clk-rk3328.c that the
parents of MMC phase clock should be clk_{sdmmc, sdio, emmc}, but not
sclk_{sdmmc, sdio, emmc}.
if clock rate is zero") catches one gremlin again for clk-rk3228.c
that the parent of SDMMC phase clock should be sclk_sdmmc0, but not
sclk_sdmmc. However, the naming of the sdmmc clocks varies in the
manual with the card clock having the 0 while the hclk is named
without appended 0. So standardize one one format to prevent
confusion, as there also is only one (non-sdio) mmc controller on
the soc.
We need this rate to generate 100, 200, and 228.57MHz from the same
PLL. 228.57MHz is useful for a pixel clock when the VPLL is used for
an external display.
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
There are many factors affecting the clock phase, including clock
rate, temperature, logic voltage and silicon process, etc. But clock
rate is the most significant one here, and the driver should be aware
of the change of the clock rate. As mmc controller need a fixed phase
after tuning was completed, at least before explicitly doing re-tune,
so this patch try to restore the clock phase by monitoring the event
of rate change.
The MMC sample and drv clock for rockchip platforms are derived from
the bus clock output to the MMC/SDIO card. So it should never happens
that the clk rate is zero given it should inherits the clock rate from
its parent. If something goes wrong and makes the clock rate to be zero,
the calculation would be wrong but may still make the mmc tuning process
work luckily. However it makes people harder to debug when the following
data transfer is unstable.
rockchip_clk_register_branch() and rockchip_clk_register_frac_branch()
should free the memory internally when seeing any failure.
dclk_lcdc can be sourced from a general pll source as well
as the hdmiphy's pll output. We will want to set this source
by hand (to the system-pll-source in most cases) and also
want rate changes to this clock to be able to also touch
the pll source clock if needed, so add CLK_SET_RATE_PARENT
and CLK_SET_RATE_NO_REPARENT for dclk_lcdc.
Signed-off-by: Zheng Yang <zhengyang@rock-chips.com>
[ammended commit message]
These are already marked as critical, so there is no need for an
additional ignore_unused flag.
NIU clocks are supplying the interconnect connections to specific
peripherals and are currently not controlled in any way.
So to prevent things falling apart at strange moments, mark all
niu clocks as critical.
Most of them where marked as CLK_IGNORE_UNUSED, but that doesn't
help if a parent clock then gets disabled.
This clock is one of the dw-hdmi supplying clocks and thus
needs to be exported.
The clock wrongly was called hclk_vio and exported, while it actually is
a clock of the interconnect-vio connection and should therefore be always
on till we actually model the interconnect.
So fix that and don't export it as HCLK_VIO.
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"We have two changes to the core framework this time around.
The first being a large change that introduces runtime PM support to
the clk framework. Now we properly call runtime PM operations on the
device providing a clk when the clk is in use. This helps on SoCs
where the clks provided by a device need something to be powered on
before using the clks, like power domains or regulators. It also helps
power those things down when clks aren't in use.
The other core change is a devm API addition for clk providers so we
can get rid of a bunch of clk driver remove functions that are just
doing of_clk_del_provider().
Outside of the core, we have the usual addition of clk drivers and
smattering of non-critical fixes to existing drivers. The biggest diff
is support for Mediatek MT2712 and MT7622 SoCs, but those patches
really just add a bunch of data.
By the way, we're trying something new here where we build the tree up
with topic branches. We plan to work this into our workflow so that we
don't step on each other's toes, and so the fixes branch can be merged
on an as-needed basis.
Summary:
Core:
- runtime PM support for clk providers
- devm API for of_clk_add_hw_provider()
New Drivers:
- Mediatek MT2712 and MT7622
- Renesas R-Car V3M SoC
Updates:
- runtime PM support for Samsung exynos5433/exynos4412 providers
- removal of clkdev aliases on Samsung SoCs
- convert clk-gpio to use gpio descriptors
- various driver cleanups to match kernel coding style
- Amlogic Video Processing Unit VPU and VAPB clks
- sigma-delta modulation for Allwinner audio PLLs
- Allwinner A83t Display clks
- support for the second display unit clock on Renesas RZ/G1E
- suspend/resume support for Renesas R-Car Gen3 CPG/MSSR
- new clock ids for Rockchip rk3188 and rk3368 SoCs
- various 'const' markings on clk_ops structures
- RPM clk support on Qualcomm MSM8996/MSM8660 SoCs"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (137 commits)
clk: stm32h7: fix test of clock config
clk: pxa: fix building on older compilers
clk: sunxi-ng: a83t: Fix i2c buses bits
clk: ti: dra7-atl-clock: fix child-node lookups
clk: qcom: common: fix legacy board-clock registration
clk: uniphier: fix DAPLL2 clock rate of Pro5
clk: uniphier: fix parent of miodmac clock data
clk: hi3798cv200: correct parent mux clock for 'clk_sdio0_ciu'
clk: hisilicon: Delete an error message for a failed memory allocation in hisi_register_clkgate_sep()
clk: hi3660: fix incorrect uart3 clock freqency
clk: kona-setup: Delete error messages for failed memory allocations
ARC: clk: fix spelling mistake: "configurarion" -> "configuration"
clk: cdce925: remove redundant check for non-null parent_name
clk: versatile: Improve sizeof() usage
clk: versatile: Delete error messages for failed memory allocations
clk: ux500: Improve sizeof() usage
clk: ux500: Delete error messages for failed memory allocations
clk: spear: Delete error messages for failed memory allocations
clk: ti: Delete error messages for failed memory allocations
clk: mmp: Adjust checks for NULL pointers
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into clk-next
Pull Rockchip clk drivers updates from Heiko Stuebner:
- new clock ids for rk3188 and rk3368
- removal of a superfluous memory allocation error message
* tag 'v4.15-rockchip-clk-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
clk: rockchip: use new cif/vdpu clock ids on rk3188
clk: rockchip: export clock pclk_efuse_256 for RK3368 SoCs
clk: rockchip: add more rk3188 graphics clock ids
clk: rockchip: add clock id for PCLK_EFUSE256 of RK3368 SoCs
clk: rockchip: Remove superfluous error message in rockchip_clk_register_cpuclk()
Use the new clock-ids for cif, vdpu, vepu on rk3188
This exports the clock for the pclk gate of the eFuse that is part of
the RK3368 SoCs. So we can use it from the dt-bindings.
Signed-off-by: Romain Perier <romain.perier@collabora.com>
Omit an extra message for a memory allocation failure in this function.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
sclk_timer5 is for arm arch counter, so need always on.
but no dts node to handle this clk, so make it as critical clock
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
A copy-paste error made them use the wrong bits in the register.
pclk_pmu need always on, and no dts node to handle this clk,
Silence the sparse warning
clk/rockchip/clk.c:172:6: warning: symbol 'rockchip_fractional_approximation' was not declared. Should it be static?
Cc: Elaine Zhang <zhangqing@rock-chips.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
The source clock ordering is wrong, as shown in the TRM:
cru_sel24_con[8]
rmii_extclk_sel
clock source select control register
1'b0: from internal PLL
1'b1: from external IO
Reviewed-by: David Wu <david.wu@rock-chips.com>
This MAC has no internal phy for rv1108 and the whole clock
infrastructure hasn't been used yet, so is safe to fix.
Add gmac aclk and pclk clock gates.
In some special circumstances, may be need to reparent clk for sclk_sdio_src.
>From Rockchips fractional divider description:
3.1.9 Fractional divider usage
To get specific frequency, clocks of I2S, SPDIF, UARTcan be generated by
fractional divider. Generally you must set that denominator is 20 times
larger than numerator to generate precise clock frequency. So the
fractional divider applies only to generate low frequency clock like
I2S, UART.
Therefore add a special approximation function that handles this
special requirement.
rk3128 and rk3126 have some gate registers describe differences.
So need to make some distinctions.
The RK3126 and RK3128 Same clock description we move it to
the common clock branches.
And the different clks description use the own clock branches.
the bus/periph/nclk_ddrupctl/pclk_ddrmon/pclk_acodecphy/pclk_pmu
no driver to handle them,
Chip design requirements for these clock to always on.
Rename some of clks to keep the consistency with the TRM.
1. fix up the parent name
2. remove the CLK_IGNORE_UNUSED flag for some clk not need to always on.
3. fix up some clks regs describe error.
Add the description of the missing clock,
make the clock more complete.
fix up the lock_shift describe error.
remove the ROCKCHIP_PLL_SYNC_RATE flag for gpll.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
fix up the cpuclk rates table for support more freqs.
fix up the mux_core_mask describe error.
The jtag clk no driver to handle them.
But this clk need enable,so make it as critical.
The ddrphy/ddrupctl clks no driver to handle them,
Chip design requirements for these clock to always on,
The pmu_hclk_otg0 is Chip design defect, must be always on,
The atclk/dbg/jtag/hsic-xin12m/pclk_core clks no driver to handle them.
But this clks need enable,so make it as ignore_unused for now.
The ddrupctl0/ddrupctl1/publ0/publ1 clks no driver to handle them,
The jtag/bus/peri/initmem/rom/stimer/phy clks no driver to handle them.
But this clks need enable,so make it as critical.
The ddrupctl/ddrmon/ddrphy clks no driver to handle them,
The hclk_otg_pmu is Chip design defect, must be always on,
The new document will update the description of this clock.
All these non-noc/non-arbi clocks,IC suggest always on,
Because it's have some order limitation, between the NOC clock switch
and bus IDLE(or pd on/off).
The software is not very good to solve this constraint.
Always on these clocks, has no effect on the system power consumption.
The new document will update the description of these clock.
No driver to handle this clk yet, but chip design requiress for this clock
supplying the ddr controller to be always on.
Add the clock tree definition for the new rk3128 SoC.
And it also applies to the RK3126 SoC.
This patch exports related BUS/VPU/RGA/HDCP/IEP/TSP/WIFI/
VIO/USB/EFUSE/GPU/CRYPTO clocks for dts reference.
clk_testout1 and clk_testout2 are used for camera handling, so add their ids.
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
support more cpu freq, and add armcore div setting.
Pull rockchip clk driver updates from Heiko Stuebner:
General rockchip clock changes for 4.12. Contains some new clock-ids
as well as fixups of the clock-ids on rk3368 timers, which were unused
and completely wrong (more and differently named timers).
Also there is one new clock on rk3328 using the muxgrf type, a fix for
pll enablement which should wait for the pll to lock before continuing,
some more critical clocks and the rename of the rk1108 to rv1108, as the
soc seems to have been using a preliminary name before its actual release.
The plan is to have the driver changes (pinctrl, clk) go through the
respective maintainer trees and once everything landed in mainline do
the rename of the devicetree files. With the dts-include change in the
clock rename, we also keep everything compiling and thus bisectability.
* tag 'v4.12-rockchip-clk1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
clk: rockchip: add pll_wait_lock for pll_enable
clk: rockchip: rename RK1108 to RV1108
dt-bindings: rk1108-cru: rename RK1108 to RV1108
clk: rockchip: mark some rk3368 core-clks as critical
clk: rockchip: export SCLK_TIMERXX id for timers on rk3368
clk: rockchip: describe clk_gmac using the new muxgrf type on rk3328
clk: rockchip: add clock ids for timer10-15 of RK3368 SoCs
clk: rockchip: fix up rk3368 timer-ids
clk: rockchip: add rk3328 clk_mac2io_ext ID
clk: rockchip: Set "ignore unused" for PMU M0 clocks on rk3399
If pll is power down,when power up pll need wait pll lock.
The reference documents section:
PLL frequency change and lock check
Rockchip finally named the SOC as RV1108, so change it.
[include rename in rk1108.dtsi to prevent compile errors]
Mark pclk_pd_alive, pclk_peri, hclk_peri as critical
With the newly introduced clk type for muxes in the grf we now can
describe some missing clocks, like the clk_gmac2io and clk_gmac2phy
that selects between clk_mac2io_src and gmac_clkin based on a bit
set in the general register files.
