The newly added clock notifier may return an error code but so far the
error output in the function would only return an error pointer from
registering the clock.
So when the clock notifier fails the clock would be unregistered but the
return would still be the clock pointer which could then not be
dereferenced correctly. So fix the error handling to prevent that.
Fixes: 60cf09e45fbc ("clk: rockchip: Restore the clock phase after the rate was changed")
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We can't restore every phase, for instance the invalid phase and
the phase for coming rate which is out of the scope of boards'
ability. And this patch also corrects the error path to return
invalid pointer to clk if clk_notifier_register failed introduced
by the same offending commit.
Reported-by: wlq <wlq@rock-chips.com>
Tested-by: wlq <wlq@rock-chips.com>
There are many factors affecting the clock phase, including clock
rate, temperature, logic voltage and silicon process, etc. But clock
rate is the most significant one here, and the driver should be aware
of the change of the clock rate. As mmc controller need a fixed phase
after tuning was completed, at least before explicitly doing re-tune,
so this patch try to restore the clock phase by monitoring the event
of rate change.
The MMC sample and drv clock for rockchip platforms are derived from
the bus clock output to the MMC/SDIO card. So it should never happens
that the clk rate is zero given it should inherits the clock rate from
its parent. If something goes wrong and makes the clock rate to be zero,
the calculation would be wrong but may still make the mmc tuning process
work luckily. However it makes people harder to debug when the following
data transfer is unstable.
initialization"
This reverts commit 7a03fe6f48f3 ("clk: rockchip: reset init state
before mmc card initialization").
Though not totally obvious from the commit message nor from the source
code, that commit appears to be trying to reset the "_drv" MMC clocks to
90 degrees (note that the "_sample" MMC clocks have a shift of 0 so are
not touched).
The major problem here is that it doesn't properly reset things. The
phase is a two bit field and the commit only touches one of the two
bits. Thus the commit had the following affect:
- phase 0 => phase 90
- phase 90 => phase 90
- phase 180 => phase 270
- phase 270 => phase 270
Things get even weirder if you happen to have a bootloader that was
actually using delay elements (should be no reason to, but you never
know), since those are additional bits that weren't touched by the
original patch.
This is unlikely to be what we actually want. Checking on rk3288-veyron
devices, I can see that the bootloader leaves these clocks as:
- emmc: phase 180
- sdmmc: phase 90
- sdio0: phase 90
Thus on rk3288-veyron devices the commit we're reverting had the effect
of changing the eMMC clock to phase 270. This probably explains the
scattered reports I've heard of eMMC devices not working on some veyron
devices when using the upstream kernel.
The original commit was presumably made because previously the kernel
didn't touch the "_drv" phase at all and relied on whatever value was
there when the kernel started. If someone was using a bootloader that
touched the "_drv" phase then, indeed, we should have code in the kernel
to fix that. ...and also, to get ideal timings, we should also have the
kernel change the phase depending on the speed mode. In fact, that's
the subject of a recent patch I posted at
<https://patchwork.kernel.org/patch/9075141/>.
Ideally, we should take both the patch posted to dw_mmc and this
revert. Since those will likely go through different trees, here I
describe behavior with the combos:
1. Just this revert: likely will fix rk3288-veyron eMMC on some devices
+ other cases; might break someone with a strange bootloader that
sets the phase to 0 or one that uses delay elements (pretty
unpredicable what would happen in that case).
2. Just dw_mmc patch: fixes everyone. Effectly the dw_mmc patch will
totally override the broken patch and fix everything.
3. Both patches: fixes everyone. Once dw_mmc is initting properly then
any defaults from the clock code doesn't mattery.
Fixes: 7a03fe6f48f3 ("clk: rockchip: reset init state before mmc card initialization")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
[emmc and sdmmc still work on all current boards in mainline after this
revert, so they should take precedence over any out-of-tree board that
will hopefully again get fixed with the better upcoming dw_mmc change.]
The flags element of clk_init_data was never initialized for mmc-
phase-clocks resulting in the element containing a random value
and thus possibly enabling unwanted clock flags.
Fixes: 89bf26cbc1a0 ("clk: rockchip: Add support for the mmc clock phases using the framework")
Cc: stable@vger.kernel.org
We seem to have accumulated a bunch of checkpatch warnings, with mainly
overlong lines and two unnecessary allocation error messages.
Most were introduced with the recent multi-controller-support but some
were quite a bit older.
Avoid return NULL if rockchip_clk_register_mmc fails, otherwise
rockchip_clk_register_branches print "unknown clock type". The acutal
case is that it's a known clock type but we fail to regiser it, which
may makes user confuse the reason of failure.
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"The majority of the changes are driver updates and new device support.
The core framework is mostly unchanged this time around, with only a
couple patches to expose a clk provider API and make getting clk
parent names from DT more robust.
Driver updates:
- Support for clock controllers found on Broadcom Northstar SoCs and
bcm2835 SoC
- Support for Allwinner audio clocks
- A few cleanup patches for Tegra drivers and support for the highest
DFLL frequencies on Tegra124
- Samsung exynos7 fixes and improvements
- i.Mx SoC updates to add a few missing clocks and keep debug uart
clocks on during kernel intialization
- Some mediatek cleanups and support for more subsystem clocks
- Support for msm8916 gpu/audio clocks and qcom's GDSC power domain
controllers
- A new driver for the Silabs si514 clock chip"
* tag 'clk-for-linus-20151104' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (143 commits)
clk: qcom: msm8960: Fix dsi1/2 halt bits
clk: lpc18xx-cgu: fix potential system hang when disabling unused clocks
clk: lpc18xx-ccu: fix potential system hang when disabling unused clocks
clk: Add clk_hw_is_enabled() for use by clk providers
clk: Add stubs for of_clk_*() APIs when CONFIG_OF=n
clk: versatile-icst: fix memory leak
clk: Remove clk_{register,unregister}_multiplier()
clk: iproc: define Broadcom NS2 iProc clock binding
clk: iproc: define Broadcom NSP iProc clock binding
clk: ns2: add clock support for Broadcom Northstar 2 SoC
clk: iproc: Separate status and control variables
clk: iproc: Split off dig_filter
clk: iproc: Add PLL base write function
clk: nsp: add clock support for Broadcom Northstar Plus SoC
clk: iproc: Add PWRCTRL support
clk: cygnus: Convert all macros to all caps
ARM: cygnus: fix link failures when CONFIG_COMMON_CLK_IPROC is disabled
clk: imx31: add missing of_node_put
clk: imx27: add missing of_node_put
clk: si5351: add missing of_node_put
Let's use DIV_ROUND_CLOSEST for rounding, not just truncating
division. This lets us get closer to the right rate.
Before this:
set_phase(86) delay_nums=26 reg[0xf000420c]=0x468 actual_degrees=83
set_phase(89) delay_nums=27 reg[0xf000420c]=0x46c actual_degrees=86
After this:
set_phase(86) delay_nums=27 reg[0xf000420c]=0x46c actual_degrees=86
set_phase(89) delay_nums=28 reg[0xf000420c]=0x470 actual_degrees=90
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Because of the inexact nature of the extra MMC delay elements (it's
not possible to keep the phase monotonic and to also make phases (mod
90) > 70), we previously only allowed phases (mod 90) of 22.5, 45,
and 67.5.
But it's not the end of the world if the MMC clock phase goes
non-monotonic. At most we'll be 25 degrees off. It's way better to
test more phases to look for bad ones than to be 25 degrees off, because
in the case of MMC really the point is to find bad phases and get as far
asway from the as possible. If we get to test extra phases by going
slightly non-monotonic then that might be fine. Worst case we would
end up at a phases that's slight differnt than the one we wanted, but
at least we'd still be quite far away from the a bad phase.
Fold in more precise variance-values of 44-77 instead of 40-80.
Fold in the actual removal of the monotonic requirement and adapt
patch message accordingly.
mmc host controller's IO input/output timing is unpredictable if
bootloader execute tuning for HS200 mode. It might make kernel failed
to initialize mmc card in identification mode. The root cause is
tuning phase and degree setting for HS200 mode in bootloader aren't
applicable to that of identification mode in kernel stage. Anyway, we
can't force all bootloaders to reset tuning phase and degree setting
before into kernel. Simply reset it in rockchip_clk_register_mmc.
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Use the provider based method to get a clock's name so that we
can get rid of the clk member in struct clk_hw one day. Mostly
converted with the following coccinelle script.
struct clk_hw *E;
-__clk_get_name(E->clk)
+clk_hw_get_name(E)
Acked-by: Heiko Stuebner <heiko@sntech.de>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Peter De Schrijver <pdeschrijver@nvidia.com>
Cc: Prashant Gaikwad <pgaikwad@nvidia.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Thierry Reding <treding@nvidia.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
Cc: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Cc: Kevin Cernekee <cernekee@chromium.org>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Cc: linux-rockchip@lists.infradead.org
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: linux-omap@vger.kernel.org
* cleanup-clk-h-includes: (62 commits)
clk: Remove clk.h from clk-provider.h
clk: h8300: Remove clk.h and clkdev.h includes
clk: at91: Include clk.h and slab.h
clk: ti: Switch clk-provider.h include to clk.h
clk: pistachio: Include clk.h
clk: ingenic: Include clk.h
clk: si570: Include clk.h
clk: moxart: Include clk.h
clk: cdce925: Include clk.h
clk: Include clk.h in clk.c
clk: zynq: Include clk.h
clk: ti: Include clk.h
clk: sunxi: Include clk.h and remove unused clkdev.h includes
clk: st: Include clk.h
clk: qcom: Include clk.h
clk: highbank: Include clk.h
clk: bcm: Include clk.h
clk: versatile: Remove clk.h and clkdev.h includes
clk: ux500: Remove clk.h and clkdev.h includes
clk: tegra: Properly include clk.h
Clock provider drivers generally shouldn't include clk.h because
it's the consumer API. Only include clk.h if it's actually used.
Cc: Heiko Stuebner <heiko@sntech.de>
The review for the new inverter clock type uncovered some issues (missing
headers and name handling) that are also present in the mmc-phase clock
type, I got (to much) inspiration from. Fix these there too.
Since commit 2893c379461a ("clk: make strings in parent name arrays
const") the name of parent clocks can be const. So add more const in
several clock drivers.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
This patch adds the 2 physical clocks for the mmc (drive and sample). They're
mostly there for the phase properties, but they also show the true clock
(by dividing by RK3288_MMC_CLKGEN_DIV).
The drive and sample phases are generated by dividing an upstream parent clock
by 2, this allows us to adjust the phase by 90 deg.
There's also an option to have up to 255 delay elements (40-80 picoseconds long).
This driver uses those elements (under the assumption that they're 60 ps long)
to generate approximate 22.5 degrees options. 67.5 (22.5*3) might be as high as
90 deg if the delay elements are as big as 80 ps, so a finer division (smaller
than 22.5) was not picked because the phase might not be monotonic anymore.
Suggested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Alexandru M Stan <amstan@chromium.org>
