This patch updates license to use SPDX-License-Identifier
instead of verbose license text.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[rebased against clk-spdx]
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
Add "rwdt" clock to r8a7790_mod_clks. Also, since we may need to access
the watchdog registers at any time, declare the clock as critical.
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Signed-off-by: Ramesh Shanmugasundaram <ramesh.shanmugasundaram@bp.renesas.com>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Add a new R-Car H2 Clock Pulse Generator / Module Standby and Software
Reset driver, using the CPG/MSSR driver core. This will enable support
for module resets, which are not supported by the existing driver.
The old driver can still be used through a Kconfig option, to preserve
backward compatibility with old DTBs.
