Using parent_data and parent_hws, instead of parent_names, does protect
against some cases of incompletely defined clock trees. While it turns
out that the bug being chased this time was totally unrelated, this
patch converts the SDM660 GCC driver to avoid such issues.
The "xo" fixed_factor clock is unused within the gcc driver, but
referenced from the DSI PHY. So it's left in place until the DSI driver
is updated.
Tested-by: Marijn Suijten <marijn.suijten@somainline.org>
Reviewed-by: AngeloGioacchino Del Regno <angelogioacchino.delregno@somainline.org>
Reviewed-by: Marijn Suijten <marijn.suijten@somainline.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Link: https://lore.kernel.org/r/20210825204517.1278130-1-bjorn.andersson@linaro.org
[sboyd@kernel.org: Reduce diff by moving enum and tables back to
original position in previous patch]
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
In the next patch we're going to change these tables to reference the
PLL structures directly. Let's move them here so the diff is easier to
read. No functional change in this patch.
This clock is critical for any access to the GPU: gating it will
crash the system when the GPU has been initialized (so, you cannot
gate it unless you deinit the Adreno completely).
So, to achieve a working state with GPU on, set the CLK_IS_CRITICAL
flag to this clock.
Signed-off-by: AngeloGioacchino Del Regno <angelogioacchino.delregno@somainline.org>
Link: https://lore.kernel.org/r/20210113183817.447866-3-angelogioacchino.delregno@somainline.org
Similarly to MSM8998, any access to the MMSS depends on this clock.
Gating it will crash the system when RPMCC inits mmssnoc_axi_rpm_clk.
Link: https://lore.kernel.org/r/20210113183817.447866-2-angelogioacchino.delregno@somainline.org
This was likely overlooked while porting the driver upstream.
Reported-by: Pavel Dubrova <pashadubrova@gmail.com>
Signed-off-by: Konrad Dybcio <konradybcio@gmail.com>
Link: https://lore.kernel.org/r/20200922120909.97203-1-konradybcio@gmail.com
Fixes: f2a76a2955c0 ("clk: qcom: Add Global Clock controller (GCC) driver for SDM660")
Add missing halt_check, hwcg_reg and hwcg_bit properties.
These were likely omitted when porting the driver upstream.
Link: https://lore.kernel.org/r/20200726111215.22361-9-konradybcio@gmail.com
This will be required in order to support the
modem upstream.
Link: https://lore.kernel.org/r/20200726111215.22361-2-konradybcio@gmail.com
Update global clock controller SDCC2/4 clocks to use the floor rcg ops,
so as to use the rounded down clock rates for these clocks.
Signed-off-by: Taniya Das <tdas@codeaurora.org>
Link: https://lkml.kernel.org/r/20190909074410.18977-1-tdas@codeaurora.org
Several clock controller drivers define a list of clk_hw devices, and then
register those devices in probe() before using common code to process the
rest of initialization. Extend the common code to accept a list of clk_hw
devices to process, thus eliminating many duplicate implementations.
Signed-off-by: Jeffrey Hugo <jhugo@codeaurora.org>
Suggested-by: Stephen Boyd <sboyd@kernel.org>
Reviewed-by: Vinod Koul <vkoul@kernel.org>
Tested-by: Vinod Koul <vkoul@kernel.org>
Add a module license to match the license at the top of this file and
silence a build warning.
Add support for the global clock controller found on SDM660
based devices. This should allow most non-multimedia device
drivers to probe and control their clocks.
Based on CAF implementation.
[craig: rename parents to fit upstream, and other cleanups]
Signed-off-by: Craig Tatlor <ctatlor97@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
[sboyd@kernel.org: Rename gcc_660 to gcc_sdm660 and fix numbering of
defines to avoid duplicates]
