commit be17ca6ac76a5cfd07cc3a0397dd05d6929fcbbb upstream.
PLLs with tuner_en bit, such as APLL1, need to disable
tuner_en before apply new frequency settings, or the new frequency
settings (pcw) will not be applied.
The tuner_en bit will be disabled during changing PLL rate
and be restored after new settings applied.
Fixes: e2f744a82d725 (clk: mediatek: Add MT2712 clock support)
Cc: <stable@vger.kernel.org>
Signed-off-by: Owen Chen <owen.chen@mediatek.com>
Signed-off-by: Weiyi Lu <weiyi.lu@mediatek.com>
Reviewed-by: James Liao <jamesjj.liao@mediatek.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
Since the previous setup always sets the PLL using crystal 26MHz, this
doesn't always happen in every MediaTek platform. So the patch added
flexibility for assigning extra member for determining the PLL source
clock.
Signed-off-by: Chen Zhong <chen.zhong@mediatek.com>
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Add MT2712 clock support, include topckgen, apmixedsys,
infracfg, pericfg, mcucfg and subsystem clocks.
[sboyd@codeaurora.org: Static on top_clk_data]
Add MT2701 clock support, include topckgen, apmixedsys,
infracfg, pericfg and subsystem clocks.
Signed-off-by: Shunli Wang <shunli.wang@mediatek.com>
Signed-off-by: James Liao <jamesjj.liao@mediatek.com>
Signed-off-by: Erin Lo <erin.lo@mediatek.com>
Tested-by: John Crispin <blogic@openwrt.org>
Remove __init from functions that will be used by init functions
that support probe deferral.
Add REF2USB_TX clock support into MT8173 APMIXEDSYS. This clock
is needed by USB 3.0.
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
MT8173 MMPLL frequency settings are different from common PLLs.
It needs different post divider settings for some ranges of frequency.
This patch add support for MT8173 MMPLL frequency setting by adding
div-rate table to lookup suitable post divider setting under a
specified frequency.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Avoid u32 overflow when calculate post divider setting, and
increase the max post divider setting from 3 (/8) to 4 (/16).
Write postdiv and pcw settings at the same time for PLLs if postdiv
and pcw settings are on the same register.
This is need by PLLs such as MT8173 MMPLL and ARM*PLL.
The variable init (struct clk_init_data) is allocated on the stack.
We weren't initializing the .flags field, so it contains random junk,
which can cause all kinds of interesting issues when the flags are
parsed by clk_register.
Signed-off-by: Ricky Liang <jcliang@chromium.org>
This patch adds common clock support for Mediatek SoCs, including plls,
muxes and clock gates.
Signed-off-by: Henry Chen <henryc.chen@mediatek.com>
[sboyd@codeaurora.org: Squelch checkpatch warning in clk-mtk.h]
