Add files for imx8dxl clk driver which is based on imx8qxp clock driver.
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add imx8qm clock valid resource checking mechanism
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
clk-imx8qxp is a common SCU clock driver used by both QM and QXP
platforms. The clock numbers vary a bit between those two platforms.
This patch introduces a mechanism to only register the valid clocks
for one platform by checking the clk resource id table.
Clean up gpr clocks by defining a common scu gpr clock.
Like other scu gpr clocks, change the name to be more accurate.
LPCG clock state may be lost when it's power domain is completely
off during system suspend/resume and we need save and restore the
state properly.
Used to support runtime pm.
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Michael Turquette <mturquette@baylibre.com>
This patch implements the new two cells binding for SCU clocks.
The usage is as follows:
clocks = <&uart0_clk IMX_SC_R_UART_0 IMX_SC_PM_CLK_PER>
Due to each SCU clock is associated with a power domain, without power
on the domain, the SCU clock can't work. So we create platform devices
for each domain clock respectively and manually attach the required domain
before register the clock devices, then we can register clocks in the
clock platform driver accordingly.
Note because we do not have power domain info in device tree and the SCU
resource ID is the same for power domain and clock, so we use resource ID
to find power domains.
Later, we will also use this clock platform driver to support suspend/resume
and runtime pm.
On i.MX8QM/QXP platforms, some clocks tree use GPR to set clock
gate, add scu clock gate driver support.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
i.MX8QM/QXP platforms some clocks tree use GPR to set clock
divider value, or select the clock source.
So add scu divider and mux clock driver support.
Add clk scu set parents support.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
[sboyd@kernel.org: Remove le32_to_cpu() on get_parent op]
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
The Low-Power Clock Gate (LPCG) modules contain a local programming
model to control the clock gates for the peripherals. An LPCG module
is used to locally gate the clocks for the associated peripheral.
And they're bedind the SCU clock.
Add SCU clock common part which will be used by client clock drivers.
SCU clocks are totally different from the legacy clocks (No much
legacy things can be reused), it's using a firmware interface now based
on SCU protocol. So a new configuration option CONFIG_MXC_CLK_SCU is added.
[sboyd@kernel.org: Mark ccm_ipc_handle static]
