git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clock framework updates from Michael Turquette:
"The changes to the common clock framework for 4.2 are dominated by new
drivers and updates to existing ones, as usual.
There are some fixes to the framework itself and several cleanups for
sparse warnings, etc"
* tag 'clk-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (135 commits)
clk: stm32: Add clock driver for STM32F4[23]xxx devices
dt-bindings: Document the STM32F4 clock bindings
cpufreq: exynos: remove Exynos4210 specific cpufreq driver support
ARM: Exynos: switch to using generic cpufreq driver for Exynos4210
clk: samsung: exynos4: add cpu clock configuration data and instantiate cpu clock
clk: samsung: add infrastructure to register cpu clocks
clk: add CLK_RECALC_NEW_RATES clock flag for Exynos cpu clock support
doc: dt: add documentation for lpc1850-ccu clk driver
clk: add lpc18xx ccu clk driver
doc: dt: add documentation for lpc1850-cgu clk driver
clk: add lpc18xx cgu clk driver
clk: keystone: add support for post divider register for main pll
clk: mvebu: flag the crypto clk as CLK_IGNORE_UNUSED
clk: cygnus: remove Cygnus dummy clock binding
clk: cygnus: add clock support for Broadcom Cygnus
clk: Change bcm clocks build dependency
clk: iproc: add initial common clock support
clk: iproc: define Broadcom iProc clock binding
MAINTAINERS: update email for Michael Turquette
clk: meson: add some error handling in meson_clk_register_cpu()
Pull MIPS updates from Ralf Baechle:
- Improvements to the tlb_dump code
- KVM fixes
- Add support for appended DTB
- Minor improvements to the R12000 support
- Various platform improvments for BCM47xx
- The usual pile of minor cleanups
- A number of BPF fixes and improvments
- Some improvments to the support for R3000 and DECstations
- Some improvments to the ATH79 platform support
- A major patchset for the JZ4740 SOC adding support for the CI20 platform
- Add support for the Pistachio SOC
- Minor BMIPS/BCM63xx platform support improvments.
- Avoid "SYNC 0" as memory barrier when unlocking spinlocks
- Add support for the XWR-1750 board.
- Paul's __cpuinit/__cpuinitdata cleanups.
- New Malta CPU board support large memory so enable ZONE_DMA32.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits)
MIPS: spinlock: Adjust arch_spin_lock back-off time
MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA
MIPS: BCM47xx: Simplify handling SPROM revisions
MIPS: Cobalt Don't use module_init in non-modular MTD registration.
MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/
MIPS: use for_each_sg()
MIPS: BCM47xx: Don't select BCMA_HOST_PCI
MIPS: BCM47xx: Add helper variable for storing NVRAM length
MIPS: IRQ/IP27: Move IRQ allocation API to platform code.
MIPS: Replace smp_mb with release barrier function in unlocks.
MIPS: i8259: DT support
MIPS: Malta: Basic DT plumbing
MIPS: include errno.h for ENODEV in mips-cm.h
MIPS: Define GCR_GIC_STATUS register fields
MIPS: BPF: Introduce BPF ASM helpers
MIPS: BPF: Use BPF register names to describe the ABI
MIPS: BPF: Move register definition to the BPF header
MIPS: net: BPF: Replace RSIZE with SZREG
MIPS: BPF: Free up some callee-saved registers
MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers
Pull ARM SoC platform support updates from Kevin Hilman:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. Some highlights from this round:
- sunxi: SMP support for A23 SoC
- socpga: big-endian support
- pxa: conversion to common clock framework
- bcm: SMP support for BCM63138
- imx: support new I.MX7D SoC
- zte: basic support for ZX296702 SoC"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits)
ARM: zx: Add basic defconfig support for ZX296702
ARM: dts: zx: add an initial zx296702 dts and doc
clk: zx: add clock support to zx296702
dt-bindings: Add #defines for ZTE ZX296702 clocks
ARM: socfpga: fix build error due to secondary_startup
MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS
ARM: ep93xx: simone: support for SPI-based MMC/SD cards
MAINTAINERS: update Shawn's email to use kernel.org one
ARM: socfpga: support suspend to ram
ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10
ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5
ARM: EXYNOS: register power domain driver from core_initcall
ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs
ARM: SAMSUNG: Constify platform_device_id
ARM: EXYNOS: Constify irq_domain_ops
ARM: EXYNOS: add coupled cpuidle support for Exynos3250
ARM: EXYNOS: add exynos_get_boot_addr() helper
ARM: EXYNOS: add exynos_set_boot_addr() helper
ARM: EXYNOS: make exynos_core_restart() less verbose
ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
The driver supports decoding and statically modelling PLL state (i.e.
we inherit state from bootloader) and provides support for all
peripherals that support simple one-bit gated clocks. The covers all
peripherals whose clocks come from the AHB, APB1 or APB2 buses.
It has been tested on an STM32F429I-Discovery board. The clock counts
for TIM2, USART1 and SYSTICK are all set correctly and the wall clock
looks OK when checked with a stopwatch. I have also tested a prototype
driver for the RNG hardware. The RNG clock is correctly enabled by the
framework (also did inverse test and proved that by changing DT to
configure the wrong clock bit then we observe the RNG driver to fail).
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Reviewed-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
[sboyd@codeaurora.org: Silence sparse warnings]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Currently, code of Loongson-2/3 is under loongson directory and code of
Loongson-1 is under loongson1 directory. Besides, there are Kconfig
options such as MACH_LOONGSON and MACH_LOONGSON1. This naming style is
very ugly and confusing. Since Loongson-2/3 are both 64-bit general-
purpose CPU while Loongson-1 is 32-bit SoC, we rename both file names
and Kconfig symbols from loongson/loongson1 to loongson64/loongson32.
[ralf@linux-mips.org: Resolve a number of simple conflicts.]
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Cc: Kelvin Cheung <keguang.zhang@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/9790/
This driver supports the CGU clocks for Ingenic SoCs. It is generic
enough to be usable across at least the JZ4740 to the JZ4780, and will
be made use of on such devices in subsequent commits. This patch by
itself only adds the SoC-agnostic infrastructure that forms the bulk of
the CGU driver for the aforementioned further commits to make use of.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Co-authored-by: Paul Cercueil <paul@crapouillou.net>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Mike Turquette <mturquette@linaro.org>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: linux-clk@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10150/
Add driver for NXP LPC18xx/43xx Clock Generation Unit (CGU). The CGU
contains several clock generators and output stages that route the
clocks either directly to peripherals or to a Clock Control Unit
(CCU).
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
The clock code under drivers/clk/bcm now contains code for both the
Broadcom mobile SoCs and the iProc SoCs. Change the the makefile
dependency to be under config flag CONFIG_ARCH_BCM that's enabled for
both families of SoCs
Signed-off-by: Ray Jui <rjui@broadcom.com>
* zte/soc:
It adds a clock driver for zx296702 SoC to register the clock tree to
Common Clock Framework. All the clocks of bus topology and some the
peripheral clocks are ready with this commit. Some missing leaf clocks
for peripherals will be added later when needed.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
* clk-meson8b:
clk: meson8b: Add support for Meson8b clocks
clk: meson: Document bindings for Meson8b clock controller
clk: meson: Add support for Meson clock controller
This patchset adds the infrastructure for registering and managing the
core clocks found on Amlogic MesonX SoCs. In particular:
- PLLs
- CPU clock
- Fixed rate clocks, fixed factor clocks, ...
Signed-off-by: Carlo Caione <carlo@endlessm.com>
drivers/clk/Kconfig
This driver supports the TI CDCE925 programmable clock synthesizer.
The chip contains two PLLs with spread-spectrum clocking support and
five output dividers. The driver only supports the following setup,
and uses a fixed setting for the output muxes:
Y1 is derived from the input clock
Y2 and Y3 derive from PLL1
Y4 and Y5 derive from PLL2
Given a target output frequency, the driver will set the PLL and
divider to best approximate the desired output.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
Add clock drivers for hi6220 SoC, this driver controls the SoC
registers to supply different clocks to different IPs in the SoC.
We add one divider clock for hi6220 because the divider in hi6220
also has a mask bit but it doesnot obey the rule defined by flag
"CLK_DIVIDER_HIWORD_MASK", we can not get index of the mask bit by
left shift fixed bits (e.g. 16 bits), so we add this divider clock
to handle it.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
Signed-off-by: Bintian Wang <bintian.wang@huawei.com>
Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Reviewed-by: Zhangfei Gao <zhangfei.gao@linaro.org>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Tested-by: Kevin Hilman <khilman@linaro.org>
After the cleanup on clock drivers, they are now ready to be moved into
drivers/clk. Let's move them into drivers/clk/imx folder.
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
This patch adds common clock support for Mediatek SoCs, including plls,
muxes and clock gates.
Signed-off-by: James Liao <jamesjj.liao@mediatek.com>
Signed-off-by: Henry Chen <henryc.chen@mediatek.com>
[sboyd@codeaurora.org: Squelch checkpatch warning in clk-mtk.h]
"The changes to the common clock framework for 4.0 are mostly new clock
drivers and updates to existing ones for feature enhancements and bug
fixes.
There is more churn than usual in the framework core due to the change
to introduce per-user unique struct clk pointers in 4.0. This caused
several regressions to surface, some of which were sent as fixes to
4.0. New generic clock drivers were added for GPIO- and PWM-based
clock controllers.
Additionally the common clk-divider code recieved several fixes to the
way it rounds rates"
* tag 'clk-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (91 commits)
clk: check ->determine/round_rate() return value in clk_calc_new_rates
clk: at91: usb: propagate rate modification to the parent clk
clk: samsung: exynos4: Disable ARMCLK down feature on Exynos4210 SoC
clk: don't use __initconst for non-const arrays
clk: at91: change to using endian agnositc IO
clk: clk-gpio-gate: Fix active low
clk: Add PWM clock driver
clk: Add clock driver for mb86s7x
clk: pxa: pxa3xx: add missing os timer clock
clk: tegra: Use the proper parent for plld_dsi
clk: tegra: Use generic tegra_osc_clk_init() on Tegra114
clk: tegra: Model oscillator as clock
clk: tegra: Add peripheral registers for bank Y
clk: tegra: Register the proper number of resets
clk: tegra: Remove needless initializations
clk: tegra: Use consistent indentation
clk: tegra: Various whitespace cleanups
clk: tegra: Enable HDA to HDMI clocks on Tegra124
clk: tegra: Fix a bunch of sparse warnings
clk: tegra: Fix typo tabel -> table
Some board designers, when running out of clock output pads, decide to
(mis)use PWM output pads to provide a clock to external components.
This driver supports this practice by providing an adapter between the
PWM and clock bindings in the device tree. As the PWM bindings specify
the period in the device tree, this is a fixed clock.
Tested-by: Janusz Uzycki <j.uzycki@elproma.com.pl>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
The CRG11 clock controller is managed by remote f/w.
This driver simply maps Linux CLK ops onto mailbox api.
Signed-off-by: Andy Green <andy.green@linaro.org>
Signed-off-by: Vincent Yang <vincent.yang@socionext.com>
Signed-off-by: Tetsuya Nuriya <nuriya.tetsuya@socionext.com>
Add helpers for registering clocks and clock providers on Pistachio.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Cc: devicetree@vger.kernel.org
Cc: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Cc: James Hartley <james.hartley@imgtec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9318/
Provide CLK support for Alphascale ASM9260 SoC.
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
Freescale introduced new ARM-based socs which using the compatible
clock IP block with PowerPC-based socs'. So this driver can be used
on both platforms.
Updated relevant descriptions and renamed this driver to better
represent its meaning and keep the function of driver untouched.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
The driver allows using CDCE706 in its default configuration recorded in
EEPROM and adjusting of synthesized clocks by consumers.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
git://git.linaro.org/people/mike.turquette/linux
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
This is the initial version of the RK808 PMIC. This is a power management
IC for multimedia products. It provides regulators that are able to
supply power to processor cores and other components. The chip provides
other modules including RTC, Clockout.
Signed-off-by: Chris Zhong <zyw@rock-chips.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Samuel Ortiz <sameo@linux.intel.com> says:
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Olof Johansson <olof@lixom.net>
Cc: Dmitry Torokhov <dtor@chromium.org>
Cc: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Fix the building of pxa clock drivers so that the files are actually
compiled if and only if COMMON_CLK was selected by the architecture.
This prevents conflicts with mach-pxa clock legacy implementation.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Add a the common code used by all PXA variants.
This is the first step in the transition from architecture defined
clocks (in arch/arm/mach-pxa) towards clock framework. The goal is to
have the same features (and not all the features) of the existing
clocks, and enable the transition of PXA to device-tree.
All PXA rely on a "CKEN" type clock, which :
- has a gate (bit in CKEN register)
- is generated from a PLL, generally divided
- has an alternate low power clock
Each variant will specialize the CKEN clock :
- pxa25x have no low power clock
- pxa27x in low power use always the 13 MHz ring oscillator
- pxa3xx in low power have specific dividers for each clock
The device-tree provides a list of CLK_* (ex: CLK_USB or CLK_I2C) to get
a handle on the clock. While pxa-clock.h will describe all the clocks of
all the variants, each variant will only use a subset of it.
The added gpio-gate-clock is a basic clock that can be enabled and
disabled trough a gpio output. The DT binding document for the clock
is also added. For EPROBE_DEFER handling the registering of the clock
has to be delayed until of_clk_get() call time.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
The MAX77802 PMIC has two 32.768kHz Buffered Clock Outputs with
Low Jitter Mode. This patch adds support for these two clocks.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Maxim Integrated Power Management ICs are very similar with
regard to their clock outputs. Most of the clock drivers for
these chips are duplicating code and are simpler enough that
can be converted to use a generic driver to consolidate code
and avoid duplication.
This adds the clock driver for Cirrus Logic CLPS711X series SoCs
using common clock infrastructure.
Designed primarily for migration CLPS711X subarch for multiplatform & DT,
for this as the "OF" and "non-OF" calls implemented.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
This patch adds helper functions to configure clock parents and rates
as specified through 'assigned-clock-parents', 'assigned-clock-rates'
DT properties for a clock provider or clock consumer device.
The helpers are now being called by the bus code for the platform, I2C
and SPI busses, before the driver probing and also in the clock core
after registration of a clock provider.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Palmas class of devices can provide 32K clock(s) to be used by other devices
on the board. Depending on the actual device the provided clocks can be:
CLK32K_KG and CLK32K_KGAUDIO
or only one:
CLK32K_KG (TPS659039 for example)
Use separate compatible flags for the two 32K clock.
A system which needs or have only one of the 32k clock from
Palmas will need to add node(s) for each clock as separate section
in the dts file.
The two compatible property is:
"ti,palmas-clk32kg" for clk32kg clock
"ti,palmas-clk32kgaudio" for clk32kgaudio clock
Apart from the register control of the clocks - which is done via
the clock API there is a posibility to enable the external sleep
control. In this way the clock can be enabled/disabled on demand by the
user of the clock.
See the documentation for more details.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
git://git.linaro.org/people/mike.turquette/linux into next
Pull clock framework updates from Mike Turquette:
"The clock framework changes for 3.16 are pretty typical: mostly clock
driver additions and fixes. There are additions to the clock core
code for some of the basic types (e.g. the common divider type has
some fixes and featured added to it).
One minor annoyance is a last-minute dependency that wasn't handled
quite right. Commit ba0fae3b06a6 ("clk: berlin: add core clock driver
for BG2/BG2CD") in this pull request depends on
include/dt-bindings/clock/berlin2.h, which is already in your tree via
the arm-soc pull request. Building for the berlin platform will break
when the clk tree is built on it's own, but merged into your master
branch everything should be fine"
* tag 'clk-for-linus-3.16' of git://git.linaro.org/people/mike.turquette/linux: (75 commits)
mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs
clk: export __clk_round_rate for providers
clk: versatile: free icst on error return
clk: qcom: Return error pointers for unimplemented clocks
clk: qcom: Support msm8974pro global clock control hardware
clk: qcom: Properly support display clocks on msm8974
clk: qcom: Support display RCG clocks
clk: qcom: Return highest rate when round_rate() exceeds plan
clk: qcom: Fix mmcc-8974's PLL configurations
clk: qcom: Fix clk_rcg2_is_enabled() check
clk: berlin: add core clock driver for BG2Q
clk: berlin: add core clock driver for BG2/BG2CD
clk: berlin: add driver for BG2x complex divider cells
clk: berlin: add driver for BG2x simple PLLs
clk: berlin: add driver for BG2x audio/video PLL
clk: st: Terminate of match table
clk/exynos4: Fix compilation warning
ARM: shmobile: r8a7779: Add clock index macros for DT sources
clk: divider: Fix overflow in clk_divider_bestdiv
clk: u300: Terminate of match table
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into next
Pull ACPI and power management updates from Rafael Wysocki:
"ACPICA is the leader this time (63 commits), followed by cpufreq (28
commits), devfreq (15 commits), system suspend/hibernation (12
commits), ACPI video and ACPI device enumeration (10 commits each).
We have no major new features this time, but there are a few
significant changes of how things work. The most visible one will
probably be that we are now going to create platform devices rather
than PNP devices by default for ACPI device objects with _HID. That
was long overdue and will be really necessary to be able to use the
same drivers for the same hardware blocks on ACPI and DT-based systems
going forward. We're not expecting fallout from this one (as usual),
but it's something to watch nevertheless.
The second change having a chance to be visible is that ACPI video
will now default to using native backlight rather than the ACPI
backlight interface which should generally help systems with broken
Win8 BIOSes. We're hoping that all problems with the native backlight
handling that we had previously have been addressed and we are in a
good enough shape to flip the default, but this change should be easy
enough to revert if need be.
In addition to that, the system suspend core has a new mechanism to
allow runtime-suspended devices to stay suspended throughout system
suspend/resume transitions if some extra conditions are met
(generally, they are related to coordination within device hierarchy).
However, enabling this feature requires cooperation from the bus type
layer and for now it has only been implemented for the ACPI PM domain
(used by ACPI-enumerated platform devices mostly today).
Also, the acpidump utility that was previously shipped as a separate
tool will now be provided by the upstream ACPICA along with the rest
of ACPICA code, which will allow it to be more up to date and better
supported, and we have one new cpuidle driver (ARM clps711x).
The rest is improvements related to certain specific use cases,
cleanups and fixes all over the place.
Specifics:
- ACPICA update to upstream version 20140424. That includes a number
of fixes and improvements related to things like GPE handling,
table loading, headers, memory mapping and unmapping, DSDT/SSDT
overriding, and the Unload() operator. The acpidump utility from
upstream ACPICA is included too. From Bob Moore, Lv Zheng, David
Box, David Binderman, and Colin Ian King.
- Fixes and cleanups related to ACPI video and backlight interfaces
from Hans de Goede. That includes blacklist entries for some new
machines and using native backlight by default.
- ACPI device enumeration changes to create platform devices rather
than PNP devices for ACPI device objects with _HID by default. PNP
devices will still be created for the ACPI device object with
device IDs corresponding to real PNP devices, so that change should
not break things left and right, and we're expecting to see more
and more ACPI-enumerated platform devices in the future. From
Zhang Rui and Rafael J Wysocki.
- Updates for the ACPI LPSS (Low-Power Subsystem) driver allowing it
to handle system suspend/resume on Asus T100 correctly. From
Heikki Krogerus and Rafael J Wysocki.
- PM core update introducing a mechanism to allow runtime-suspended
devices to stay suspended over system suspend/resume transitions if
certain additional conditions related to coordination within device
hierarchy are met. Related PM documentation update and ACPI PM
domain support for the new feature. From Rafael J Wysocki.
- Fixes and improvements related to the "freeze" sleep state. They
affect several places including cpuidle, PM core, ACPI core, and
the ACPI battery driver. From Rafael J Wysocki and Zhang Rui.
- Miscellaneous fixes and updates of the ACPI core from Aaron Lu,
Bjørn Mork, Hanjun Guo, Lan Tianyu, and Rafael J Wysocki.
- Fixes and cleanups for the ACPI processor and ACPI PAD (Processor
Aggregator Device) drivers from Baoquan He, Manuel Schölling, Tony
Camuso, and Toshi Kani.
- System suspend/resume optimization in the ACPI battery driver from
Lan Tianyu.
- OPP (Operating Performance Points) subsystem updates from Chander
Kashyap, Mark Brown, and Nishanth Menon.
- cpufreq core fixes, updates and cleanups from Srivatsa S Bhat,
Stratos Karafotis, and Viresh Kumar.
- Updates, fixes and cleanups for the Tegra, powernow-k8, imx6q,
s5pv210, nforce2, and powernv cpufreq drivers from Brian Norris,
Jingoo Han, Paul Bolle, Philipp Zabel, Stratos Karafotis, and
Viresh Kumar.
- intel_pstate driver fixes and cleanups from Dirk Brandewie, Doug
Smythies, and Stratos Karafotis.
- Enabling the big.LITTLE cpufreq driver on arm64 from Mark Brown.
- Fix for the cpuidle menu governor from Chander Kashyap.
- New ARM clps711x cpuidle driver from Alexander Shiyan.
- Hibernate core fixes and cleanups from Chen Gang, Dan Carpenter,
Fabian Frederick, Pali Rohár, and Sebastian Capella.
- Intel RAPL (Running Average Power Limit) driver updates from Jacob
Pan.
- PNP subsystem updates from Bjorn Helgaas and Fabian Frederick.
- devfreq core updates from Chanwoo Choi and Paul Bolle.
- devfreq updates for exynos4 and exynos5 from Chanwoo Choi and
Bartlomiej Zolnierkiewicz.
- turbostat tool fix from Jean Delvare.
- cpupower tool updates from Prarit Bhargava, Ramkumar Ramachandra
and Thomas Renninger.
- New ACPI ec_access.c tool for poking at the EC in a safe way from
Thomas Renninger"
* tag 'pm+acpi-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (187 commits)
ACPICA: Namespace: Remove _PRP method support.
intel_pstate: Improve initial busy calculation
intel_pstate: add sample time scaling
intel_pstate: Correct rounding in busy calculation
intel_pstate: Remove C0 tracking
PM / hibernate: fixed typo in comment
ACPI: Fix x86 regression related to early mapping size limitation
ACPICA: Tables: Add mechanism to control early table checksum verification.
ACPI / scan: use platform bus type by default for _HID enumeration
ACPI / scan: always register ACPI LPSS scan handler
ACPI / scan: always register memory hotplug scan handler
ACPI / scan: always register container scan handler
ACPI / scan: Change the meaning of missing .attach() in scan handlers
ACPI / scan: introduce platform_id device PNP type flag
ACPI / scan: drop unsupported serial IDs from PNP ACPI scan handler ID list
ACPI / scan: drop IDs that do not comply with the ACPI PNP ID rule
ACPI / PNP: use device ID list for PNPACPI device enumeration
ACPI / scan: .match() callback for ACPI scan handlers
ACPI / battery: wakeup the system only when necessary
power_supply: allow power supply devices registered w/o wakeup source
This is a driver for the AVPLLs built upon a VCO with 8 channels each
found on Marvell Berlin2 SoCs. While both VCOs found on BG2/BG2CD share
the same register set, sometimes registers shifts for one of the VCOs
are a bit off. Nothing serious that should require a separate driver,
so deal with both VCOs in a single driver instead.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Add clk driver to support clock blocks found on the AXM55xx devices. The driver
provides clock implementations for three different types of clock devices on
the AXM55xx device: PLL clock, a clock divider and a clock mux.
Signed-off-by: Anders Berg <anders.berg@lsi.com>
Fractional divider clocks are fairly common. This adds basic
type for them.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
This patch replaces PLAT_SAMSUNG with COMMON_CLK_SAMSUNG for Samsung
common clock support. Any Samsung SoC want to use Samsung common clock
infrastructure can simply select COMMON_CLK_SAMSUNG.
CC: Mike Turquette <mturquette@linaro.org>
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Haifeng Yan <haifeng.yan@linaro.org>
Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org>
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Pull clock framework changes from Mike Turquette:
"The clock framework changes for 3.15 look similar to past pull
requests. Mostly clock driver updates, more Device Tree support in
the form of common functions useful across platforms and a handful of
features and fixes to the framework core"
* tag 'clk-for-linus-3.15' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: shmobile: fix setting paretn clock rate
clk: shmobile: rcar-gen2: fix lb/sd0/sd1/sdh clock parent to pll1
clk: Fix minor errors in of_clk_init() function comments
clk: reverse default clk provider initialization order in of_clk_init()
clk: sirf: update copyright years to 2014
clk: mmp: try to use closer one when do round rate
clk: mmp: fix the wrong calculation formula
clk: mmp: fix wrong mask when calculate denominator
clk: st: Adds quadfs clock binding
clk: st: Adds clockgen-vcc and clockgen-mux clock binding
clk: st: Adds clockgen clock binding
clk: st: Adds divmux and prediv clock binding
clk: st: Support for A9 MUX clocks
clk: st: Support for ClockGenA9/DDR/GPU
clk: st: Support for QUADFS inside ClockGenB/C/D/E/F
clk: st: Support for VCC-mux and MUX clocks
clk: st: Support for PLLs inside ClockGenA(s)
clk: st: Support for DIVMUX and PreDiv Clocks
clk: support hardware-specific debugfs entries
clk: s2mps11: Use of_get_child_by_name
The patch supports the DIVMUX and PreDiv clocks used by ClockGenA(s)
DIVMUX clock : Divider-Multiplexer-Gate inside ClockGenA(s)
It includes support for each channel : 3-parent Multiplexer,
Divider for each Parent, Gate to switch OFF the output channel. The
clock is implemented using generic clocks implemented in the kernel
clk_divider and clk_mux.
PreDiv clock : Fixed Divider Clock used inside ClockGenA(s) to divide
the oscillator clock by factor-of-16. The clock is implemented using
generic clocks implemented in the kernel clk_divider.
Signed-off-by: Pankaj Dev <pankaj.dev@st.com>
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
https://git.kernel.org/pub/scm/linux/kernel/git/hzhuang1/linux into clk-next-hisilcon
updating clock drivers for Hisilicon
Now only fixed rate clocks are appended into the clock driver.
MOXA ART SoCs allow to determine PLL output and APB frequencies
by reading registers holding multiplier and divisor information.
Add a clock driver for this SoC.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
Add code for device tree support of clocks in the BCM281xx family of
SoCs. Machines in this family use peripheral clocks implemented by
"Kona" clock control units (CCUs). (Other Broadcom SoC families use
Kona style CCUs as well, but support for them is not yet upstream.)
A BCM281xx SoC has multiple CCUs, each of which manages a set of
clocks on the SoC. A Kona peripheral clock is composite clock that
may include a gate, a parent clock multiplexor, and zero, one
or two dividers. There is a variety of gate types, and many gates
implement hardware-managed gating (often called "auto-gating").
Most dividers divide their input clock signal by an integer value
(one or more). There are also "fractional" dividers which allow
division by non-integer values. To accomodate such dividers,
clock rates and dividers are generally maintained by the code in
"scaled" form, which allows integer and fractional dividers to
be handled in a uniform way.
If present, the gate for a Kona peripheral clock must be enabled
when a change is made to its multiplexor or one of its dividers.
Additionally, dividers and multiplexors have trigger registers which
must be used whenever the divider value or selected parent clock is
changed. The same trigger is often used for a divider and
multiplexor, and a BCM281xx peripheral clock occasionally has two
triggers.
The gate, dividers, and parent clock selector are treated in this
code as "components" of a peripheral clock. Their functionality is
implemented directly--e.g. the common clock framework gate
implementation is not used for a Kona peripheral clock gate. (This
has being considered though, and the intention is to evolve this
code to leverage common code as much as possible.)
The source code is divided into three general portions:
drivers/clk/bcm/clk-kona.h
drivers/clk/bcm/clk-kona.c
These implement the basic Kona clock functionality,
including the clk_ops methods and various routines to
manipulate registers and interpret their values. This
includes some functions used to set clocks to a desired
initial state (though this feature is only partially
implemented here).
drivers/clk/bcm/clk-kona-setup.c
This contains generic run-time initialization code for
data structures representing Kona CCUs and clocks. This
encapsulates the clock structure initialization that can't
be done statically. Note that there is a great deal of
validity-checking code here, making explicit certain
assumptions in the code. This is mostly useful for adding
new clock definitions and could possibly be disabled for
production use.
drivers/clk/bcm/clk-bcm281xx.c
This file defines the specific CCUs used by BCM281XX family
SoCs, as well as the specific clocks implemented by each.
It declares a device tree clock match entry for each CCU
defined.
include/dt-bindings/clock/bcm281xx.h
This file defines the selector (index) values used to
identify a particular clock provided by a CCU. It consists
entirely of C preprocessor constants, to be used by both the
C source and device tree source files.
Signed-off-by: Alex Elder <elder@linaro.org>
Reviewed-by: Tim Kryger <tim.kryger@linaro.org>
Reviewed-by: Matt Porter <mporter@linaro.org>
Signed-off-by: Matt Porter <mporter@linaro.org>
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
