path: root/drivers/char
2006-06-21[PATCH] TTY: return class device pointer from tty_register_device()Hansjoerg Lipp
Let tty_register_device() return a pointer to the class device it creates. This allows registrants to add their own sysfs files under the class device node. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-20Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [SPARC64]: Don't double-export synchronize_irq. [SPARC64]: Move over to GENERIC_HARDIRQS. [SPARC64]: Virtualize IRQ numbers. [SPARC64]: Kill ino_bucket->pil [SPARC]: Kill __irq_itoa(). [SPARC64]: bp->pil can never be zero [SPARC64]: Send all device interrupts via one PIL. [SPARC]: Fix iommu_flush_iotlb end address [SPARC]: Mark smp init functions as cpuinit [SPARC]: Add missing rw can_lock macros [SPARC]: Setup cpu_possible_map [SPARC]: Add topology_init()
2006-06-20Merge branch 'rio.b19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bird * 'rio.b19' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/bird: [PATCH] missing readb/readw in rio [PATCH] copy_to_user() from iomem is a bad thing [PATCH] forgotten swap of copyout() arguments [PATCH] handling rio MEMDUMP [PATCH] fix rio_copy_to_card() for OLDPCI case [PATCH] uses of ->Copy() in rioroute are bogus [PATCH] bogus order of copy_from_user() arguments [PATCH] rio ->Copy() expects the sourse as first argument [PATCH] trivial annotations in rio
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-19Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] alpha-agp warning fix [AGPGART] uninorth-agp warning fixes [AGPGART] Remove pointless initialisation in intel-agp [AGPGART] Remove pointless code from agp_generic_create_gatt_table()
2006-06-11[PATCH] Fix for the PPTP hangs that have been reportedPaul Mackerras
People have been reporting that PPP connections over ptys, such as used with PPTP, will hang randomly when transferring large amounts of data, for instance in http://bugzilla.kernel.org/show_bug.cgi?id=6530. I have managed to reproduce the problem, and the patch below fixes the actual cause. The problem is not in fact in ppp_async.c but in n_tty.c. What happens is that when pptp reads from the pty, we call read_chan() in drivers/char/n_tty.c on the master side of the pty. That copies all the characters out of its buffer to userspace and then calls check_unthrottle(), which calls the pty unthrottle routine, which calls tty_wakeup on the slave side, which calls ppp_asynctty_wakeup, which calls tasklet_schedule. So far so good. Since we are in process context, the tasklet runs immediately and calls ppp_async_process(), which calls ppp_async_push, which calls the tty->driver->write function to send some more output. However, tty->driver->write() returns zero, because the master tty->receive_room is still zero. We haven't returned from check_unthrottle() yet, and read_chan() only updates tty->receive_room _after_ calling check_unthrottle. That means that the driver->write call in ppp_async_process() returns 0. That would be fine if we were going to get a subsequent wakeup call, but we aren't (we just had it, and the buffer is now empty). The solution is for n_tty.c to update tty->receive_room _before_ calling the driver unthrottle routine. The patch below does this. With this patch I was able to transfer a 900MB file over a PPTP connection (taking about 25 minutes), whereas without the patch the connection would always stall in under a minute. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[PATCH] powerpc: console_initcall ordering issuesMilton Miller
From: Milton Miller <miltonm@bga.com> The add_preferred_console call in rtas_console.c was not causing the console to be selected. It turns out that the add_preferred_console was being called after the hvc_console driver was registered. It only works when it is called before the console driver is registered. Reorder hvc_console.o after the hvc_console drivers to allow the selection during console_initcall processing. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-08[AGPGART] alpha-agp warning fixAndrew Morton
drivers/char/agp/alpha-agp.c:138: warning: initialization from incompatible pointer type drivers/char/agp/alpha-agp.c:139: warning: initialization from incompatible pointer type Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-08[AGPGART] uninorth-agp warning fixesAndrew Morton
drivers/char/agp/uninorth-agp.c: In function `agp_uninorth_suspend': drivers/char/agp/uninorth-agp.c:332: warning: cast to pointer from integer of different size drivers/char/agp/uninorth-agp.c: In function `agp_uninorth_resume': drivers/char/agp/uninorth-agp.c:354: warning: cast from pointer to integer of different size Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-02[PATCH] pcmcia: fix zeroing of cm4000_cs.c dataDominik Brodowski
Fix the incorrect calculation of how much to zero out in struct cm4000_dev on device initialization. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-05-31[PATCH] revert "swsusp add check for suspension of X controlled devices"Andrew Morton
From: Andrew Morton <akpm@osdl.org> Revert commit ff4da2e262d2509fe1bacff70dd00934be569c66. It broke APM suspend, probably because APM doesn't switch back to a VT when suspending. Tracked down by Matt Mackall <mpm@selenic.com> Rafael sayeth: "It only fixed the theoretical issue that a quick-handed user could switch to X after processes have been frozen and before the devices are suspended. With the current userland suspend tools it shouldn't be necessary." Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] IPMI: reserve I/O ports separatelyCorey Minyard
From: Corey Minyard <minyard@acm.org> This patch is pretty important to get in for IPMI, new systems have been changing the way ACPI and IPMI interact, and this works around the problems for now. This is a temporary fix until we get proper ACPI handling in IPMI. Fixed releasing already-allocated regions when a later request fails, and forward-ported it to HEAD. Some BIOSes reserve disjoint I/O regions in their ACPI tables for the IPMI controller. This causes problems when trying to register the entire I/O region. Therefore we must register each I/O port separately. Signed-off-by: Jordan Hargrave <Jordan_Hargrave@dell.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] tpm: more bios log parsing fixesSeiji Munetoh
From: Seiji Munetoh <seiji.munetoh@gmail.com> Change the binary output format to actual ACPI TCPA log structure since the current format does not contain all event-data information that need to verify the PCRs in TPM. tpm_binary_bios_measurements_show() uses get_event_name() to convert the binary event-data to ascii format, and puts them as binary. However, to verify the PCRs, the event-data must be a actual binary event-data used by SHA1 calc. in BIOS. So, I think actual ACPI TCPA log is good for this binary output format. That way, any userland tools easily parse this data with reference to TCG PC specification. Signed-off-by: Seiji Munetoh <seiji.munetoh@gmail.com> Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] tpm: bios log parsing fixesSeiji Munetoh
From: Seiji Munetoh <seiji.munetoh@gmail.com> Fix "tcpa_pc_event" misalignment between enum, strings and TCG PC spec and output of the event which contains a hash data. Signed-off-by: Seiji Munetoh <seiji.munetoh@gmail.com> Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[AGPGART] Remove pointless initialisation in intel-agpDave Jones
2006-05-30[AGPGART] Remove pointless code from agp_generic_create_gatt_table()Dave Jones
2006-05-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] VIA PT880 Ultra support. [AGPGART] Fix Nforce3 suspend on amd64. [AGPGART] Enable SIS AGP driver on x86-64 for EM64T systems
2006-05-27[PATCH] missing readb/readw in rioAl Viro
2006-05-27[PATCH] copy_to_user() from iomem is a bad thingAl Viro
2006-05-27[PATCH] forgotten swap of copyout() argumentsAl Viro
2006-05-27[PATCH] handling rio MEMDUMPAl Viro
it copies data _from_ iomem, so it should be rio_memcpy_fromio(), not ->Copy(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-27[PATCH] fix rio_copy_to_card() for OLDPCI caseAl Viro
It replaced old rio_pcicopy(). That puppy did _not_ do readb() (unlike rio_memcpy_toio()) and current implementation is simply broken - readb(NULL) is never a valid thing to do. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-27[PATCH] uses of ->Copy() in rioroute are bogusAl Viro
... there we are building a command in normal memory; it will be copied to iomem (by ->Copy()) later. Use memcpy()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-27[PATCH] bogus order of copy_from_user() argumentsAl Viro
... aka "somebody forgot to swap arguments when converting from copyin()" Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-27[PATCH] rio ->Copy() expects the sourse as first argumentAl Viro
... so conversion from rio_pcicopy() to rio_copy_to_card() had broken the damn thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-27[PATCH] trivial annotations in rioAl Viro
2006-05-26[PATCH] tpm: fix bug for TPM on ThinkPad T60 and Z60Kylene Jo Hall
The TPM chip on the ThinkPad T60 and Z60 machines is returning 0xFFFF for the vendor ID which is a check the driver made to double check it was actually talking to the memory mapped space of a TPM. This patch removes the check since it isn't absolutely necessary and was causing device discovery to fail on these machines. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-23[PATCH] tty_insert_flip_string_flags() license fixTobias Powalowski
We still don't have the tty layer licensing compatibility quite right. tty_insert_flip_char() used to be inlined in include/linux/tty_flip.h. It is now out-of-lined and hence needs EXPORT_SYMBOL() to be back-compatible. One known offender is the Intel Modem driver. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-22[AGPGART] VIA PT880 Ultra support.Magnus Kessler
This patch enables agpgart on a Via "PT880 Ultra" based motherboard (Asus P4V800D-X). The PCI ID of the PT880 Ultra is 0x0308 instead of 0x0258 of the PT880. The patched via-agp passes testgart. Signed-off-by: Magnus Kessler <Magnus.Kessler@gmx.net> Signed-off-by: Dave Jones <davej@redhat.com>
2006-05-21[AGPGART] Fix Nforce3 suspend on amd64.Dave Jones
kernel.org bugzilla #6206 Based on patch from Serge Belyshev <belyshev@depni.sinp.msu.ru> Signed-off-by: Dave Jones <davej@redhat.com>
2006-05-21[AGPGART] Enable SIS AGP driver on x86-64 for EM64T systemsAndi Kleen
Enable SIS AGP driver on x86-64 for EM64T systems Untested so far Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Dave Jones <davej@redhat.com>
2006-05-19Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] s3c2410_wdt.c stop watchdog after boot [WATCHDOG] i8xx_tco.c - remove support for ICH6 + ICH7 [WATCHDOG] Documentation/watchdog/watchdog-api.txt - fix watchdog daemon [WATCHDOG] sc1200wdt.c printk fix
2006-05-15[WATCHDOG] s3c2410_wdt.c stop watchdog after bootBen Dooks
If the s3c2410 watchdog timer is not enabled by the driver at startup, ensure that it is stopped in-case the boot process has enabled it. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-05-15[WATCHDOG] i8xx_tco.c - remove support for ICH6 + ICH7Wim Van Sebroeck
Temporary remove support for ICH6 + ICH7. In these newer TCO's the watchdog timer has changed: the TCO_TMR register is not at the TCOBASE+0x1 offset, but changed it's place to TCOBASE+0x12 and became 10 bit long [0:9]. (Kernel BUG 6031). ICH6 + ICH7 support will be added in a new driver. Code is under test. Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-05-15[WATCHDOG] sc1200wdt.c printk fixDave Jones
Fix printk output. sc1200wdt: build 20020303<3>sc1200wdt: io parameter must be specified Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-05-15[PATCH] tpm_register_hardware gcc 4.1 warning fixDaniel Walker
drivers/char/tpm/tpm.c: In function 'tpm_register_hardware': drivers/char/tpm/tpm.c:1157: warning: assignment from incompatible pointer type Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] Final rio polishAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] tpm: fix constantKylene Jo Hall
Fix the constant used for the base address when it cannot be determined from ACPI. It was off by one order of magnitude. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] tpm: update module dependenciesKylene Jo Hall
The TIS driver is dependent upon information from the ACPI table for device discovery thus it compiles but does no actual work without this dependency. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-10[Cardman 40x0] Fix udev device creationHarald Welte
This patch corrects the order of the calls to register_chrdev() and pcmcia_register_driver(). Now udev correctly creates userspace device files /dev/cmmN and /dev/cmxN respectively. Based on an earlier patch by Jan Niehusmann <jan@gondor.com>. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] genrtc: fix read on 64-bit platformsAtsushi Nemoto
Fix genrtc's read() routine for 64-bit platforms. Current gen_rtc_read() stores 64bit integer and returns 8 even if an user tried to read a 32bit integer. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
2006-04-28[PATCH] fix array overrun in drivers/char/mwave/mwavedd.cEric Sesterhenn
this fixes coverity id #489. Since the last element in the array is always ARRAY_SIZE-1 we have to check for ipcnum >= ARRAY_SIZE() Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] tipar oops fixDaniel Drake
If compiled into the kernel, parport_register_driver() is called before the parport driver has been initalised. This means that it is expected that tp_count is 0 after the parport_register_driver() call() - tipar's attach function will not be called until later during bootup. Signed-off-by: Daniel Drake <dsd@gentoo.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] splice: add ->splice_write support for /dev/nullJens Axboe
Useful for testing. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-26Input: allow using several chords for brailleSamuel Thibault
For coping with bad keyboards, permit to type a braille pattern by pressing several chords. By default, only one chord is needed. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-23Merge branch 'drm-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: possible cleanups drm: fixup r300 scratch on BE machines
2006-04-23drm: possible cleanupsDave Airlie
This patch contains the following possible cleanups: - make the following needlessly global function static: - drm_bufs.c: drm_addbufs_fb() - remove the following unused EXPORT_SYMBOL's: - drm_agpsupport.c: drm_agp_bind_memory - drm_bufs.c: drm_rmmap_locked - drm_bufs.c: drm_rmmap - drm_stub.c: drm_get_dev Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-23drm: fixup r300 scratch on BE machinesDave Airlie
This fixes the r300 scratch stuff to work on PPC, from Ben Herrenschmidt on IRC. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-22[PATCH] tpm: add HID module parameterKylene Jo Hall
I recently found that not all BIOS manufacturers are using the specified generic PNP id in their TPM ACPI table entry. I have added the vendor specific IDs that I know about and added a module parameter that a user can specify another HID to the probe list if their device isn't being found by the default list. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
