path: root/drivers/char
2010-03-17hpet: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-13Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, k8 nb: Fix boot crash: enable k8_northbridges unconditionally on AMD systems x86, UV: Fix target_cpus() in x2apic_uv_x.c x86: Reduce per cpu warning boot up messages x86: Reduce per cpu MCA boot up messages x86_64, cpa: Don't work hard in preserving kernel 2M mappings when using 4K already
2010-03-13x86, k8 nb: Fix boot crash: enable k8_northbridges unconditionally on AMD ↵Borislav Petkov
systems de957628ce7c84764ff41331111036b3ae5bad0f changed setting of the x86_init.iommu.iommu_init function ptr only when GART IOMMU is found. One side effect of it is that num_k8_northbridges is not initialized anymore if not explicitly called. This resulted in uninitialized pointers in <arch/x86/kernel/cpu/intel_cacheinfo.c:amd_calc_l3_indices()>, for example, which uses the num_k8_northbridges thing through node_to_k8_nb_misc(). Fix that through an initcall that runs right after the PCI subsystem and does all the scanning. Then, remove initialization in gart_iommu_init() which is a rootfs_initcall and we're running before that. What is more, since num_k8_northbridges is being used in other places beside GART IOMMU, include it whenever we add AMD CPU support. The previous dependency chain in kconfig contained K8_NB depends on AGP_AMD64|GART_IOMMU which was clearly incorrect. The more natural way in terms of hardware dependency should be AGP_AMD64|GART_IOMMU depends on K8_NB depends on CPU_SUP_AMD && PCI. Make it so Number One! Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20100312144303.GA29262@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Joerg Roedel <joerg.roedel@amd.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12drivers/char/mmtimer.c: eliminate useless codeJulia Lawall
The variable x is initialized twice to the same (side effect-free) expression. Drop one initialization. A simplified version of the semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @forall@ idexpression *x; identifier f!=ERR_PTR; @@ x = f(...) ... when != x ( x = f(...,<+...x...+>,...) | * x = f(...) ) // </smpl> Stefan observed: The next x = rb_entry(mn->next, struct mmtimer, list); is preceded by a test whether mn->next is NULL. Unless that test is redundant too, your patch fixes a potential NULL pointer dereference, introduced by commit cbacdd95 "SGI Altix mmtimer: allow larger number of timers per node" in 2.6.26. Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ldisc n_tty: add new method n_tty_inherit_ops()Rodolfo Giometti
This new method can be used to init a new struct tty_ldisc_ops as the default tty_ldisc_N_TTY struct. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ipmi: fix slave_addrs setting to actually workBela Lubkin
Actually use the slave_addrs module parameter if it is specified, and make things consistent about passing zero in for the slave address for the default. Signed-off-by: Bela Lubkin <blubkin@vmware.com> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ipmi: add parameter to limit CPU usage in kipmidMartin Wilck
In some cases kipmid can use a lot of CPU. This adds a way to tune the CPU used by kipmid to help in those cases. By setting kipmid_max_busy_us to a value between 100 and 500, it is possible to bring down kipmid CPU load to practically 0 without loosing too much ipmi throughput performance. Not setting the value, or setting the value to zero, operation is unaffected. Signed-off-by: Martin Wilck <martin.wilck@ts.fujitsu.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12copy_signal() cleanup: clean tty_audit_fork()Veaceslav Falico
Remove unneeded initialization in tty_audit_fork(). It is called only via copy_signal() and is useless after the kmem_cache_zalloc() was used. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/char/mem.c: cleanupsAndrew Morton
- fix switch statement layout - fix whitespace stuff - fix comment layout - remove unneeded inlining - use __weak - remove trailing whitespace - move uncached_access() inside `#ifndef __HAVE_PHYS_MEM_ACCESS_PROT' - it is otherwise unused. Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12/dev/mem: dont allow seek to last pageWu Fengguang
So as to return a uniform error -EOVERFLOW instead of a random one: # kmem-seek 0xfffffffffffffff0 seek /dev/kmem: Device or resource busy # kmem-seek 0xfffffffffffffff1 seek /dev/kmem: Block device required Suggested by OGAWA Hirofumi. Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-08[S390] hvc_iucv: allocate memory buffers for IUCV in zone DMAHendrik Brueckner
The device driver must allocate memory for IUCV buffers with GFP_DMA, because IUCV cannot address memory above 2GB (31bit addresses only). Because the IUCV ignores the higher bits of the address, sending and receiving IUCV data with this driver might cause memory corruptions. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/amit/virtio-consoleLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/amit/virtio-console: virtio: console: Use better variable names for fill_queue operation virtio: console: Fix type of 'len' as unsigned int
2010-03-04Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (151 commits) vga_switcheroo: disable default y by new rules. drm/nouveau: fix *staging* driver build with switcheroo off. drm/radeon: fix typo in Makefile vga_switcheroo: fix build on platforms with no ACPI drm/radeon: Fix printf type warning in 64bit system. drm/radeon/kms: bump the KMS version number for square tiling support. vga_switcheroo: initial implementation (v15) drm/radeon/kms: do not disable audio engine twice Revert "drm/radeon/kms: disable HDMI audio for now on rv710/rv730" drm/radeon/kms: do not preset audio stuff and start timer when not using audio drm/radeon: r100/r200 ums: block ability for userspace app to trash 0 page and beyond drm/ttm: fix function prototype to match implementation drm/radeon: use ALIGN instead of open coding it drm/radeon/kms: initialize set_surface_reg reg for rs600 asic drm/i915: Use a dmi quirk to skip a broken SDVO TV output. drm/i915: enable/disable LVDS port at DPMS time drm/i915: check for multiple write domains in pin_and_relocate drm/i915: clean-up i915_gem_flush_gpu_write_domain drm/i915: reuse i915_gpu_idle helper drm/i915: ensure lru ordering of fence_list ... Fixed trivial conflicts in drivers/gpu/vga/Kconfig
2010-03-04virtio: console: Use better variable names for fill_queue operationAmit Shah
We want to keep track of the number of buffers added to a vq. Use nr_added_bufs instead of 'ret'. Also, the users of fill_queue() overloaded a local 'err' variable to check the numbers of buffers allocated. Use nr_added_bufs instead of err. Signed-off-by: Amit Shah <amit.shah@redhat.com> Reported-by: Juan Quintela <quintela@redhat.com>
2010-03-04virtio: console: Fix type of 'len' as unsigned intAmit Shah
We declare 'len' as int type but it should be 'unsigned int', as get_buf() wants it to be. Signed-off-by: Amit Shah <amit.shah@redhat.com> Reported-by: Juan Quintela <quintela@redhat.com>
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (220 commits) USB: backlight, appledisplay: fix incomplete registration failure handling USB: pl2303: remove unnecessary reset of usb_device in urbs USB: ftdi_sio: remove obsolete check in unthrottle USB: ftdi_sio: remove unused tx_bytes counter USB: qcaux: driver for auxiliary serial ports on Qualcomm devices USB: pl2303: initial TIOCGSERIAL support USB: option: add Longcheer/Longsung vendor ID USB: fix I2C API usage in ohci-pnx4008. USB: usbmon: mask seconds properly in text API USB: sisusbvga: no unnecessary GFP_ATOMIC USB: storage: onetouch: unnecessary GFP_ATOMIC USB: serial: ftdi: add CONTEC vendor and product id USB: remove references to port->port.count from the serial drivers USB: tty: Prune uses of tty_request_room in the USB layer USB: tty: Add a function to insert a string of characters with the same flag USB: don't read past config->interface[] if usb_control_msg() fails in usb_reset_configuration() USB: tty: kill request_room for USB ACM class USB: tty: sort out the request_room handling for whiteheat USB: storage: fix misplaced parenthesis USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., devices and spectrometers ...
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) jsm: fixing error if the driver fails to load jsm: removing the uart structure and filename on error tty: Add a new VT mode which is like VT_PROCESS but doesn't require a VT_RELDISP ioctl call tty: Keep the default buffering to sub-page units tty: Fix up char drivers request_room usage tty: Fix the ldisc hangup race serial: timberdale: Remove dependancies nozomi: Tidy up the PCI table nozomi: Fix mutex handling nozomi: Add tty_port usage sdio_uart: Use kfifo instead of the messy circ stuff serial: bcm63xx_uart: allow more than one uart to be registered. serial: bcm63xx_uart: don't use kfree() on non kmalloced area. serial: bfin_5xx: pull in linux/io.h for ioremap prototypes serial: bfin_5xx: kgdboc should accept gdb break only when it is active serial: bfin_5xx: need to disable DMA TX interrupt too serial: bfin_5xx: remove useless gpio handling with hard flow control Char: synclink, remove unnecessary checks tty: declare MODULE_FIRMWARE in various drivers ip2: Add module parameter. ...
2010-03-02USB: tty: Add a function to insert a string of characters with the same flagAlan Cox
The USB drivers often want to insert a series of bytes all with the same flag set - provide a helper for this case. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: Add a new VT mode which is like VT_PROCESS but doesn't require a ↵Ari Entlich
VT_RELDISP ioctl call This new VT mode (VT_PROCESS_AUTO) does everything that VT_PROCESS does except that it doesn't wait for a VT_RELDISP ioctl before switching away from a VT with that mode. If the X server eventually uses this new mode, debugging and crash recovery should become easier. This is because even when currently in the VT of a frozen X server it would still be possible to switch out by doing SysRq-r and then CTRL-<number of a text vt>, sshing in and doing chvt <number of a text vt>, or any other method of VT switching. The general concensus on #xorg-devel seems to be that it should be safe to use this with X now that we have KMS. This also moves the VT_ACKACQ define to a more appropriate place, for clarity's sake. Signed-off-by: Ari Entlich <atrigent@ccs.neu.edu> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: Keep the default buffering to sub-page unitsAlan Cox
We allocate during interrupts so while our buffering is normally diced up small anyway on some hardware at speed we can pressure the VM excessively for page pairs. We don't really need big buffers to be linear so don't try so hard. In order to make this work well we will tidy up excess callers to request_room, which cannot itself enforce this break up. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: Fix up char drivers request_room usageAlan Cox
We can't change them all but quite a few misuse it. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: Fix the ldisc hangup raceAlan Cox
This was noticed by Matthias Urlichs and he proposed a fix. This patch does the fixing a different way to avoid introducing several new race conditions into the code. The problem case is TTY_DRIVER_RESET_TERMIOS = 0. In that case while we abort the ldisc change, the hangup processing has not cleaned up and restarted the ldisc either. We can't restart the ldisc stuff in the set_ldisc as we don't know what the hangup did and may touch stuff we shouldn't as we are no longer supposed to influence the tty at that point in case it has been re-opened before we get rescheduled. Instead do it the simple way. Always re-init the ldisc on the hangup, but use TTY_DRIVER_RESET_TERMIOS to indicate that we should force N_TTY. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02nozomi: Tidy up the PCI tableAlan Cox
2010-03-02nozomi: Fix mutex handlingAlan Cox
The original author didn't realise the kernel lock was a drop while sleep lock so did clever (and wrong) things to work around the non need to avoid deadlocks. Remove the cleverness and the comment (as we don't hold the BKL now anyway in those paths) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02nozomi: Add tty_port usageAlan Cox
The Nozomi tty handling is very broken on the open/close side (See http://bugzilla.kernel.org/show_bug.cgi?id=13024 for one example). In particular it marks the tty as closed on the first close() not on the last. Most of the logic is pretty solid except for the open/close path so switch to the tty_port helpers and let them do all the heavy lifting. This is also fixes all the POSIX behaviour violations in the open/close paths. Begin by adding the tty port usage Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02Char: synclink, remove unnecessary checksJiri Slaby
Stanse found a potential null dereference in mgsl_put_char and mgsl_write. There is a check for tty being NULL, but it is dereferenced earlier. Actually, tty cannot be NULL in .write and .put_char, so remove the tests. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: declare MODULE_FIRMWARE in various driversBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02ip2: Add module parameter.Rakib Mullick
Stephen Rothwell found the following warning (x86_64 allmodconfig): drivers/char/ip2/ip2main.c:511: warning: 'ip2_setup' defined but not used This patch adds module parameter to fix the above warning. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02ip2: remove #ifdef MODULE from ip2main.cRakib Mullick
On the kernel command line we can pass "module parameters". So #ifdef MODULE is obsolute now. Remove it completely. When CONFIG_PCI=n and building ip2main.c then we are hit by the following warning. So move *pdev into #ifdef CONFIG_PCI. drivers/char/ip2/ip2main.c: In function `ip2_loadmain': drivers/char/ip2/ip2main.c:542: warning: unused variable `pdev' Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Acked-by: Michael H. Warfield <mhw@WittsEnd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: moxa: remove #ifdef MODULE completely.Rakib Mullick
We can pass "module parameters" on the kernel command line even when !MODULE. So, #ifdef MODULE becomes obsolete. Also move the declaration moxa_board_conf at the start of the function, since we were hit by the following warning. drivers/char/moxa.c: In function `moxa_init': drivers/char/moxa.c:1040: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Rakib Mullick<rakib.mullick@gmail.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02hvc_console: fix test on unsigned in hvc_console_print()Roel Kluin
vtermnos[] is unsigned, so this test was wrong. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02serial: isicom.c: use pr_fmt and pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Convert printks to pr_<level> Convert some embedded function names to %s...__func__ Remove a period after exclamation points. Remove #define pr_dbg which could be used by future kernel.h includes Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: char: mxser, remove unnecessary tty testJiri Slaby
Stanse found unnecessary test in mxser_startup. tty is dereferenced earlier, the test is superfluous. Remove it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02serial: cyclades: allow overriding ISA defaults also when the driver is built-inBartlomiej Zolnierkiewicz
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02serial: Char: cyclades, fix compiler warningJiri Slaby
With gcc 4.0.2: drivers/char/cyclades.c: In function 'cyy_interrupt': drivers/char/cyclades.c:581: warning: 'info' may be used uninitialized in this function introduced by : commit 3aeea5b92210083c7cffd4f08a0bb141d3f2d574 : Author: Jiri Slaby <jirislaby@gmail.com> : AuthorDate: Sat Sep 19 13:13:16 2009 -0700 : Commit: Live-CD User <linux@linux.site> : CommitDate: Sat Sep 19 13:13:16 2009 -0700 : : cyclades: introduce cyy_readb/writeb In fact the true branch which uses uninitialized 'info' can never happen because chip is always less than ->nchips and channel is always less than 4 which we alloc. So behave similar to rx handling and remove the test completely. I wonder why gcc 4.4.1 doesn't spit a word. Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Jiri Slaby <jslaby@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02serial: synclink_gt: dropped transmit data bugfixPaul Fulghum
Fix transmit bug that could drop send data if write() called close to serial transmitter going idle after sending previous data. Bug is caused by incorrect use of device information member tx_count. Driver originally processed one data block (write call) at a time, waiting for transmit idle before sending more. tx_count recorded how much data was loaded in DMA buffers on write(), and was cleared on send completion. tx_count use was overloaded to record accumulated data from put_char() callback when transmitter was idle. A bug was introduced when transmit code was reworked to allow multiple blocks of data in the tx DMA buffers which keeps transmitter from going idle between blocks. tx_count was set to size of last block loaded, cleared when tx went idle, and monitored to know when to restart transmitter without proper synchronization. tx_count could be cleared when unsent data remained in DMA buffers and transmitter required restarting, effectively dropping unsent data. Solution: 1. tx_count now used only to track accumulated data from put_char 2. DMA buffer state tracked by direct inspection of descriptors with spinlock synchronization 3. consolidate these tasks in tx_load() : a. check for available buffer space b. load buffers c. restart DMA and or serial transmitter as needed These steps were previously duplicated in multiple places, sometimes incompletely. 4. fix use of tx_count as active transmit indicator, instead using tx_active which is meant for that purpose Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (214 commits) omap2: Initialize Menelaus and MMC for N8X0 AM3517 EVM: correct typo - tca6416 mispelt as tca6516 AM3517 EVM: Enable I2C support AM35x: Enable OMAP_MUX in defconfig AM35x: Add missing GPIO mux config for EHCI port Zoom3: Defconfig update omap: i2c: Fix muxing for command line enabled bus OMAP4: clock: Remove clock hacks from timer-gp.c OMAP4: clock: Add dummy clock nodes for interface clocks OMAP4: clock: Rename leaf clock nodes to end with a _ick or _fck OMAP2+ clock: revise omap2_clk_{disable,enable}() OMAP2/3 clock: combine OMAP2 & 3 boot-time MPU rate change code OMAP clockdomain: if no autodeps exist, don't try to add or remove them OMAP hwmod: add hwmod class support OMAP hwmod: convert header files with static allocations into C files OMAP hwmod: convert hwmod to use hardware clock names rather than clkdev dev+con OMAP clock: add omap_clk_get_by_name() for use by OMAP hwmod core code OMAP3: clock: add capability to change rate of dpll4_m5_ck_3630 OMAP4 clock: drop the ALWAYS_ENABLED clock flag OMAP clock: drop RATE_FIXED clock flag ...
2010-03-01Merge with mainline to remove plat-omap/Kconfig conflictTony Lindgren
Conflicts: arch/arm/plat-omap/Kconfig
2010-03-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits) Input: atkbd - release previously reserved keycodes 248 - 254 Input: add KEY_WPS_BUTTON definition Input: ads7846 - add regulator support Input: winbond-cir - fix suspend/resume Input: gamecon - use pr_err() and friends Input: gamecon - constify some of the setup structures Input: gamecon - simplify pad type handling Input: gamecon - simplify coordinate calculation for PSX Input: gamecon - fix some formatting issues Input: gamecon - add rumble support for N64 pads Input: wacom - add device type to device name string Input: s3c24xx_ts - report touch only when stylus is down Input: s3c24xx_ts - re-enable IRQ on resume Input: wacom - constify product features data Input: wacom - use per-device instance of wacom_features Input: sh_keysc - enable building on SH-Mobile ARM Input: wacom - get features from driver info Input: rotary-encoder - set gpio direction for each requested gpio Input: sh_keysc - update the driver with mode 6 Input: sh_keysc - switch to using bitmaps ...
2010-03-01Merge branches 'futexes-for-linus', 'irq-core-for-linus' and ↵Linus Torvalds
'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Protect pid lookup in compat code with RCU * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix documentation of default chip disable() * 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: nvram: Drop the BKL from nvram_open()
2010-02-28Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, cacheinfo: Enable L3 CID only on AMD x86, cacheinfo: Remove NUMA dependency, fix for AMD Fam10h rev D1 x86, cpu: Print AMD virtualization features in /proc/cpuinfo x86, cacheinfo: Calculate L3 indices x86, cacheinfo: Add cache index disable sysfs attrs only to L3 caches x86, cacheinfo: Fix disabling of L3 cache indices intel-agp: Switch to wbinvd_on_all_cpus x86, lib: Add wbinvd smp helpers
2010-02-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (24 commits) m68k: Define sigcontext ABI of ColdFire m68knommu: NPTL support for uClinux m68k: Add NPTL support m68k: Eliminate unused variable in page_to_phys() m68k: Switch to generic siginfo layout macfb: fix 24-bit visual and stuff macfb: cleanup fbdev: add some missing mac modes mac68k: start CUDA early valkyriefb: various fixes fbdev: mac_var_to_mode() fix mac68k: move macsonic and macmace platform devices mac68k: move mac_esp platform device mac68k: replace mac68k SCC code with platform device pmac-zilog: add platform driver pmac-zilog: cleanup mac68k: rework SWIM platform device mac68k: cleanup ataflop: Killl warning about unused variable flags m68k: Use DIV_ROUND_CLOSEST ...
2010-02-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: validate late-added resources pcmcia: allow for extension of resource interval pcmcia: remove useless msleep in ds.c pcmcia: use read_cis_mem return value pcmcia: handle error in serial_cs config calls pcmcia: add locking to pcmcia_{read,write}_cis_mem pcmcia: avoid prod_id memleak pcmcia: avoid sysfs-related lockup for cardbus pcmcia: use state machine for extended requery pcmcia: delay re-scanning and re-querying of PCMCIA bus pcmcia: use pccardd to handle eject, insert, suspend and resume requests pcmcia: use ops_mutex for rsrc_{mgr,nonstatic} locking pcmcia: use mutex for dynid lock pcmcia: assert locking to struct pcmcia_device pcmcia: add locking documentation pcmcia: simplify locking pcmcia: add locking to struct pcmcia_socket->pcmcia_state() pcmcia: protect s->device_count pcmcia: properly lock skt->irq, skt->irq_mask pcmcia: lock ops->set_socket ...
2010-02-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (88 commits) powerpc: Fix lwsync feature fixup vs. modules on 64-bit powerpc: Convert pmc_owner_lock to raw_spinlock powerpc: Convert die.lock to raw_spinlock powerpc: Convert tlbivax_lock to raw_spinlock powerpc: Convert mpic locks to raw_spinlock powerpc: Convert pmac_pic_lock to raw_spinlock powerpc: Convert big_irq_lock to raw_spinlock powerpc: Convert feature_lock to raw_spinlock powerpc: Convert i8259_lock to raw_spinlock powerpc: Convert beat_htab_lock to raw_spinlock powerpc: Convert confirm_error_lock to raw_spinlock powerpc: Convert ipic_lock to raw_spinlock powerpc: Convert native_tlbie_lock to raw_spinlock powerpc: Convert beatic_irq_mask_lock to raw_spinlock powerpc: Convert nv_lock to raw_spinlock powerpc: Convert context_lock to raw_spinlock powerpc/85xx: Add NOR, LEDs and PIB support for MPC8568E-MDS boards powerpc/86xx: Enable VME driver on the GE SBC610 powerpc/86xx: Enable VME driver on the GE PPC9A powerpc/86xx: Add MSI section to GE PPC9A DTS ...
2010-02-27m68k: vme_scc - __init annotationsPeter Huewe
Trivial patch which adds the __init macro to the module_init function and all of its helper functions of drivers/char/vme_scc.c Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) crypto: aes_generic - Fix checkpatch errors crypto: fcrypt - Fix checkpatch errors crypto: ecb - Fix checkpatch errors crypto: des_generic - Fix checkpatch errors crypto: deflate - Fix checkpatch errors crypto: crypto_null - Fix checkpatch errors crypto: cipher - Fix checkpatch errors crypto: crc32 - Fix checkpatch errors crypto: compress - Fix checkpatch errors crypto: cast6 - Fix checkpatch errors crypto: cast5 - Fix checkpatch errors crypto: camellia - Fix checkpatch errors crypto: authenc - Fix checkpatch errors crypto: api - Fix checkpatch errors crypto: anubis - Fix checkpatch errors crypto: algapi - Fix checkpatch errors crypto: blowfish - Fix checkpatch errors crypto: aead - Fix checkpatch errors crypto: ablkcipher - Fix checkpatch errors crypto: pcrypt - call the complete function on error ...
2010-02-26drm/i915: Add dependency on the intel agp moduleZhenyu Wang
See http://bugzilla.kernel.org/show_bug.cgi?id=15021 Make sure that the appropriate AGP module is loaded and probed before trying to set up the DRM. The DRM already depends on the AGP core, but in this case we know the specific AGP driver we need too, and can help users avoid the trap of loading the AGP driver after the DRM driver. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-26agp/intel: Add a new Sandybridge HB/IG PCI ID combo.Eric Anholt
