path: root/drivers/char
2008-10-16Merge branch 'agp-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/nvidia: Support agp user-memory on nvidia agp. agp/amd-k7: Suspend support for AMD K7 GART driver agp/intel: Reduce extraneous PCI posting reads during init agp: Fix stolen memory counting on G4X.
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits) UIO: Fix mapping of logical and virtual memory UIO: add automata sercos3 pci card support UIO: Change driver name of uio_pdrv UIO: Add alignment warnings for uio-mem Driver core: add bus_sort_breadthfirst() function NET: convert the phy_device file to use bus_find_device_by_name kobject: Cleanup kobject_rename and !CONFIG_SYSFS kobject: Fix kobject_rename and !CONFIG_SYSFS sysfs: Make dir and name args to sysfs_notify() const platform: add new device registration helper sysfs: use ilookup5() instead of ilookup5_nowait() PNP: create device attributes via default device attributes Driver core: make bus_find_device_by_name() more robust usb: turn dev_warn+WARN_ON combos into dev_WARN debug: use dev_WARN() rather than WARN_ON() in device_pm_add() debug: Introduce a dev_WARN() function sysfs: fix deadlock device model: Do a quickcheck for driver binding before doing an expensive check Driver core: Fix cleanup in device_create_vargs(). Driver core: Clarify device cleanup. ...
2008-10-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: wm97xx - update email address for Liam Girdwood Input: i8042 - add Thinkpad R31 to nomux list Input: move map_to_7segment.h to include/linux Input: ads7846 - fix cache line sharing issue Input: cm109 - add missing newlines to messages Input: document i8042.debug in kernel-parameters.txt Input: keyboard - fix potential out of bound access to key_map Input: psmouse - add OLPC touchpad driver Input: psmouse - tweak PSMOUSE_DEFINE_ATTR to support raw set callbacks Input: psmouse - add psmouse_queue_work() for ps/2 extension to make use of Input: psmouse - export psmouse_set_state for ps/2 extensions to use Input: ads7846 - introduce .gpio_pendown to get pendown state Input: ALPS - add signature for DualPoint found in Dell Latitude E6500 Input: serio_raw - allow attaching to translated (SERIO_I8042XL) ports Input: cm109 - don't use obsolete logging macros Input: atkbd - expand Latitude's force release quirk to other Dells Input: bf54x-keys - add power management support Input: atmel_tsadcc - improve accuracy Input: convert drivers to use strict_strtoul() Input: appletouch - handle geyser 3/4 status bits ...
2008-10-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (51 commits) [ARM] 5308/1: Fix Viper ISA IRQ handling [ARM] 5307/1: pxa: fix CM-X2XX PCMCIA build error [ARM] 5306/1: pxa: fix build error on CM-X270 [ARM] 5302/1: ARM: OMAP: Revert omap3 WDT changes to avoid merge conflict [ARM] 5305/1: ARM: OMAP: Fix compile of McBSP by removing unnecessary check [ARM] 5301/1: ARM: OMAP: Add missing irq defines ARM: OMAP3: Add default kernel config for OMAP LDP ARM: OMAP3: Add basic board support for OMAP LDP ARM: OMAP3: Defconfig for the Gumstix Overo board (rev 3) ARM: OMAP3: Add support for the Gumstix Overo board (rev 3) ARM: OMAP3: Add Beagle defconfig ARM: OMAP3: Add minimal Beagle board support ARM: OMAP3: Add minimal omap3430 support ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ code ARM: OMAP: Fixes to omap_mcbsp_request function ARM: OMAP: Add support for OMAP2430 in McBSP ARM: OMAP: Add support for McBSP devices 3 - 5 on 34xx ARM: OMAP: Allocate McBSP devices dynamically Fix sections for omap-mcbsp platform driver [ARM] S3C24XX: Additional include moves ...
2008-10-16drivers/char/tpm/tpm.c: fix error-path memory leakAndrew Morton
tpm_register_hardware() leaks devname on an error path. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11425 Reported-by: Daniel Marjamki <danielm77@spray.se> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: work around bug in Broadcom BCM0102 chipsetValdis Kletnieks
Patch tpm-correct-tpm-timeouts-to-jiffies-conversion reveals a bug in the Broadcom BCM0102 TPM chipset used in the Dell Latitude D820 - although most of the timeouts are returned in usecs as per the spec, one is apparently returned in msecs, which results in a too-small value leading to a timeout when the code treats it as usecs. To prevent a regression, we check for the known too-short value and adjust it to a value that makes things work. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: correct tpm timeouts to jiffies conversionMarcin Obara
This patch fixes timeouts conversion to jiffies, by replacing msecs_to_jiffies() calls with usecs_to_jiffies(). According to TCG TPM Specification Version 1.2 Revision 103 (pages 166, 167) TPM timeouts and durations are returned in microseconds (usec) not in miliseconds (msec). This fixes a long hang while loading TPM driver, if TPM chip starts in "Idle" state instead of "Ready" state. Without this patch - 'modprobe' may hang for 30 seconds or more. Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16proc: move sysrq-trigger out of fs/proc/Alexey Dobriyan
Move it into sysrq.c, along with the rest of the sysrq implementation. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16char: moxa.c sparse annotationHarvey Harrison
The only use is to pass this to le16_to_cpu, declare as such drivers/char/moxa.c:548:11: warning: cast to restricted __le16. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16applicom.c: fix apparently-broken code in do_ac_read()Andrew Morton
The code scriblles over a local pointer whereas it appears to be trying to write to the memory at which that pointer points. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11397 Nobody we know can test this change. Reported-by: Zvonimir Rakamaric <zrakamar@cs.ubc.ca> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Char: ds1286, eliminate busy waitingJiri Slaby
ds1286_get_time(); is not called from atomic context, sleep for 20 ms is better choice than a (home-made) busy waiting for such a situation. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16legacy rtc: remove needless/confusing HPET_RTC_IRQ optionDavid Brownell
HPET_RTC_IRQ is no longer needed; HPET_EMULATE_RTC suffices and is more correct. (http://bugzilla.kernel.org/show_bug.cgi?id=11111) Note that when using the legacy RTC driver, platforms don't really do a dynamic switch between HPET and non-HPET modes based on whether HPET hardware actually exists ... only rtc-cmos (using the new RTC framework) currently switches that way. So this reflects bitrot in that legacy code, for x86/ia64: kernels with HPET support configured (e.g. for a clocksource) can't get IRQs from the legacy RTC driver unless they really have HPET hardware. (The obvious workaround is to not use the legacy RTC driver on those platforms when you configure HPET ... unless you know the target really has a HPET.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysrq: add enable_mask in sysrq_moom_opNaohiro Ooiwa
It is written in the Documentation/sysrq.txt that oom-killer is enabled when we set "64" in /proc/sys/kernel/sysrq: <Documentation/sysrq.txt> Here is the list of possible values in /proc/sys/kernel/sysrq: 64 - enable signalling of processes (term, kill, oom-kill) ^^^^^^^^ but enable_mask is not set in sysrq_moom_op. Signed-off-by: Naohiro Ooiwa <nooiwa@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16agp/nvidia: Support agp user-memory on nvidia agp.Thomas Hellstrom
This adds user memory support required for TTM to the nvidia AGP driver. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-16agp/amd-k7: Suspend support for AMD K7 GART driverStuart Bennett
Reinitialize bridge registers after suspend, but avoid repeating the ioremap Tested and works on AMD761 Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-16agp/intel: Reduce extraneous PCI posting reads during initKeith Packard
Instead of doing a posting read after each GTT entry update, do a single one at the end of the writes. This should reduce boot time a tiny amount by avoiding a lot of extra uncached reads. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-16agp: Fix stolen memory counting on G4X.Eric Anholt
On the GM45, the amount of stolen memory mapped to the GTT was underestimated, even though we had 508KB more available since the GTT doesn't take from stolen memory. On the non-GM45 G4X, we overestimated how much stolen was mapped to the GTT by 4KB, resulting in GPU page faults when that page was accessed. This update requires a corresponding update to xf86-video-intel to work correctly. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-15Merge branch 'next' into for-linusDmitry Torokhov
2008-10-15Merge branch 'fixes' into for-linusRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-15tty: make sure that proc_clear_tty stores the cpu flagsArjan van de Ven
proc_clear_tty() gets called with interrupts off (while holding the task list lock) from sys_setid. This means that it needs the _irqsave version of the locking primitives. Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-15Merge commit 'origin'Benjamin Herrenschmidt
Manual fixup of conflicts on: arch/powerpc/include/asm/dcr-regs.h drivers/net/ibm_newemac/core.h
2008-10-15hvc_console: Fix free_irq in spinlocked sectionChristian Borntraeger
commit 611e097d7707741a336a0677d9d69bec40f29f3d Author: Christian Borntraeger <borntraeger@de.ibm.com> hvc_console: rework setup to replace irq functions with callbacks introduced a spinlock recursion problem. The notifier_del is called with a lock held, and in turns calls free_irq which then complains when manipulating procfs. This fixes it by moving the call to the notifier to outside of the locked section. Signed-off-by: Christian Borntraeger<borntraeger@de.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-14Merge branch 's3c-move' into develRussell King
2008-10-14Revert "vt: fix background color on line feed"Linus Torvalds
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the subsequent commits that fixed it up: - afa9b649 "fbcon: prevent cursor disappearance after switching to 512 character font" - d850a2fa "vt/fbcon: fix background color on line feed" - 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font switch" by request of Alan Cox. Quoth Alan: "Unfortunately it's wrong and its been causing breakages because various apps like ncurses expect our previous (and correct) behaviour." Alexander sent out a similar patch. Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Tested-by: Jan Engelhardt <jengelh@medozas.de> Cc: Alexander V. Lukyanov <lav@netis.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: ioctl-internal definitions pcmcia: cistpl header cleanup pcmcia: remove unused argument to pcmcia_parse_tuple() pcmcia: card services header cleanup pcmcia: device_id header cleanup pcmcia: encapsulate ioaddr_t pcmcia: cleanup device driver header file pcmcia: cleanup socket services header file pcmcia: merge ds_internal.h into cs_internal.h pcmcia: cleanup cs_internal.h pcmcia: cs_internal.h is internal pcmcia: use dev_printk for cs_error() pcmcia: remove CS_ error codes alltogether pcmcia: deprecate CS_BAD_TUPLE pcmcia: deprecate CS_BAD_ARGS pcmcia: deprecate CS_BAD_BASE, CS_BAD_IRQ, CS_BAD_OFFSET and CS_BAD_SIZE pcmcia: deprecate CS_BAD_ATTRIBUTE, CS_BAD_TYPE and CS_BAD_PAGE pcmcia: deprecate CS_NO_MORE_ITEMS pcmcia: deprecate CS_IN_USE pcmcia: deprecate CS_CONFIGURATION_LOCKED ... Fix trivial conflict in drivers/pcmcia/ds.c manually
2008-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (24 commits) integrity: special fs magic As pointed out by Jonathan Corbet, the timer must be deleted before ERROR: code indent should use tabs where possible The tpm_dev_release function is only called for platform devices, not pnp Protect tpm_chip_list when transversing it. Renames num_open to is_open, as only one process can open the file at a time. Remove the BKL calls from the TPM driver, which were added in the overall netlabel: Add configuration support for local labeling cipso: Add support for native local labeling and fixup mapping names netlabel: Changes to the NetLabel security attributes to allow LSMs to pass full contexts selinux: Cache NetLabel secattrs in the socket's security struct selinux: Set socket NetLabel based on connection endpoint netlabel: Add functionality to set the security attributes of a packet netlabel: Add network address selectors to the NetLabel/LSM domain mapping netlabel: Add a generic way to create ordered linked lists of network addrs netlabel: Replace protocol/NetLabel linking with refrerence counts smack: Fix missing calls to netlbl_skbuff_err() selinux: Fix missing calls to netlbl_skbuff_err() selinux: Fix a problem in security_netlbl_sid_to_secattr() selinux: Better local/forward check in selinux_ip_postroute() ...
2008-10-13Merge phase #5 (misc) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip Merges oprofile, timers/hpet, x86/traps, x86/time, and x86/core misc items. * 'x86-core-v4-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (132 commits) x86: change early_ioremap to use slots instead of nesting x86: adjust dependencies for CONFIG_X86_CMOV dumpstack: x86: various small unification steps, fix x86: remove additional_cpus x86: remove additional_cpus configurability x86: improve UP kernel when CPU-hotplug and SMP is enabled dumpstack: x86: various small unification steps dumpstack: i386: make kstack= an early boot-param and add oops=panic dumpstack: x86: use log_lvl and unify trace formatting dumptrace: x86: consistently include loglevel, print stack switch dumpstack: x86: add "end" parameter to valid_stack_ptr and print_context_stack dumpstack: x86: make printk_address equal dumpstack: x86: move die_nmi to dumpstack_32.c traps: x86: finalize unification of traps.c traps: x86: make traps_32.c and traps_64.c equal traps: x86: various noop-changes preparing for unification of traps_xx.c traps: x86_64: use task_pid_nr(tsk) instead of tsk->pid in do_general_protection traps: i386: expand clear_mem_error and remove from mach_traps.h traps: x86_64: make io_check_error equal to the one on i386 traps: i386: use preempt_conditional_sti/cli in do_int3 ...
2008-10-13tty: rename the remaining oddly named n_tty functionsAlan Cox
Original idea for this from a patch by Rodolfo Giometti which merges various bits of PPS support Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: tty_io.c shadows sparse fixJason Wessel
drivers/char/tty_io.c:1413:17: warning: symbol 'buf' shadows an earlier one drivers/char/tty_io.c:1379:20: originally declared here Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13applicom: Fix an unchecked user ioctl range and an error returnAlan Cox
Closes bug #11408 by checking the card index range for command 0 Fixes the ioctl to return ENOTTY which is correct for unknown ioctls Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Minor tidyups and document fixes for n_ttyAlan Cox
Remove/fix some bogus NULL checks, comment some locking etc Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove lots of NULL checksAlan Cox
Many tty drivers contain 'can't happen' checks against NULL pointers passed in by the tty layer. These have never been possible to occur. Even more importantly if they ever do occur we want to know as it would be a serious bug. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: some ICANON magic is in the wrong placesAlan Cox
Move the set up on ldisc change into the ldisc Move the INQ/OUTQ cases into the driver not in shared ioctl code where it gives bogus answers for other ldisc values Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: simplify ktermios allocationAlan Cox
Copy the simplification from the pty unix98 special case to the generic one. This allows us to kill off driver->termios_locked entirely which is nice. We have to whack bits of the cris driver as it meddles in places it shouldn't providing its own arrays that were never used anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: simplify unix98 allocationAlan Cox
We need both termios and termios_locked so allocate them as one Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: Fix allocation failure double freeAlan Cox
The updating and moving around of the pty code added a bug where both the helper and caller free the main tty struct (the pty driver must free the o_tty pair itself however). Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: Coding style and polishAlan Cox
We've done the heavy lifting now its time to mop up a bit Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Move tty lookup/reopen to callerSukadev Bhattiprolu
Move tty_driver_lookup_tty() and tty_reopen() from tty_init_dev() into tty_open() (one of the two callers of tty_init_dev()). These calls are not really required in ptmx_open(), the other caller, since ptmx_open() would be setting up a new tty. Changelog[v2]: - remove the lookup and reopen calls from ptmx_open - merge with recent changes to ttydev tree Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: extract the pty init time special casesAlan Cox
The majority of the remaining init_dev code is pty special cases. We refactor this code into the driver->install method. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Finish fixing up the init_dev interface to use ERR_PTRAlan Cox
Original suggestion and proposal from Sukadev Bhattiprolu. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: More driver operationsAlan Cox
We have the lookup operation abstracted which is nice for pty cleanup but we really want to abstract the add/remove entries as well so that we can pull the pty code out of the tty core and create a clear defined interface for the tty driver table. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: kref the tty driver objectAlan Cox
2008-10-13tty: Clean up the tty_init_dev changes furtherAlan Cox
Fix up the naming, style and extract some bits of code into the driver specific code Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Move parts of tty_init_dev into new functionsSukadev Bhattiprolu
Move the 'find-tty' and 'fast-track-open' parts of init_dev() to separate functions. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove more special casing and out of place codeAlan Cox
Carry on pushing code out of tty_io when it belongs to other drivers. I'm not 100% happy with some of this and it will be worth revisiting some of the exports later when the restructuring work is done. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: shutdown methodAlan Cox
Right now there are various drivers that try to use tty->count to know when they get the final close. Aristeau Rozanski showed while debugging the vt sysfs race that this isn't entirely safe. Instead of driver side tricks to work around this introduce a shutdown which is called when the tty is being destructed. This also means that the shutdown method is tied into the refcounting. Use this to rework the console close/sysfs logic. Remove lots of special case code from the tty core code. The pty code can now have a shutdown() method that replaces the special case hackery in the tree free up paths. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
